- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-NTP commands
- 06-PoE commands
- 07-SNMP commands
- 08-RMON commands
- 09-Event MIB commands
- 10-NETCONF commands
- 11-CWMP commands
- 12-EAA commands
- 13-Process monitoring and maintenance commands
- 14-Sampler commands
- 15-Mirroring commands
- 16-NetStream commands
- 17-IPv6 NetStream commands
- 18-sFlow commands
- 19-Performance management commands
- 20-Flow log commands
- 21-Information center commands
- 22-Packet capture commands
- 23-Cloud connection commands
- 24-GOLD commands
- 25-eMDI commands
- 26-SmartMC commands (self-mesh not supported)
- 27-Fast log output commands
- 28-SQA commands
| 00-Preface | 109.80 KB |
Preface
This command reference describes the commands for configuring basic and extended network management and monitoring features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
