13-OpenFlow Configuration Guide
HomeSupportSwitchesS6530X SeriesConfigure & DeployConfiguration GuidesH3C S6530X Switch Series Configuration Guides-R8307Pxx-6W10013-OpenFlow Configuration Guide
00-Preface
00-Preface 110.03 KB
Preface
This configuration guide describes the OpenFlow fundamentals and configuration procedures. OpenFlow allows a controller to directly access and operate the forwarding plane of the switch, separating the control plane from the data plane. The switch matches and forwards packets according to the flow tables deployed by the controller.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
