01-Text | 850.73 KB |
LED descriptions for single-LED APs
LED descriptions for single-LED APs (1)
WA6300/WA6500B/WA6600 AP series
WA7200/WA7300/WA7500/WA7600 AP series
LED descriptions for single-LED APs (2)
LED descriptions for multi-LED APs
LED descriptions for multi-LED APs (1)
LED descriptions for multi-LED APs (2)
LED descriptions for multi-LED APs (3)
LED description for the reset button
About LEDs
The LED status includes the color and flashing frequency of the LEDs, which indicates the AP operating status.
APs can be classified into single-LED APs and multi-LED APs based on the LED quantity.
Figure 1 Single-LED AP (WA6520 as an example)
Figure 2 Multi-LED AP (WA6520H as an example)
Wi-Fi 6 AP LEDs
AP series |
Models |
Wi-Fi 6 |
WA6300 AP series |
· WA6320-HI, WA6320-SI, WA6320-SI-H20, WA6320S-E, WA6320S-C, WA6320X-G, WA6322-G, WA6322H-G, WA6322H-HI, WA6338-HI · WAP922 · WTU630-IOT |
See "WA6300/WA6500B/WA6600 AP series" in "LED descriptions for single-LED APs (1)." |
· WA6320, WA6320-C, WA6320-D, WA6322, WA6322H, WA6322H-LI, WA6330, WA6330-LI, WA6338, WA6338-LI · WAP922E, WAP922H, WAP923 · WTU630, WTU632H-IOT |
See "WA6300/WA6600 AP series" in "LED descriptions for single-LED APs (2)." |
WA6320H-H20, WA6320H-HI, WA6320H-HI-EG |
See "WA6300/WA6500A AP series" in "LED descriptions for multi-LED APs (1)." |
· WA6320H, WA6320H-LI, WA6320H-XEPON · WTU630H |
See "WA6300 AP series" in "LED descriptions for multi-LED APs (2)." |
WA6500 AP series |
WA6500A: · WA6020, WA6022H, WA6120, WA6120X, WA6126 · WA6520, WA6520-C, WA6520-E, WA6520-EG, WA6520-EI, WA6520H-HI, WA6520-HI, WA6520-LI, WA6520S-C, WA6520S-D, WA6520S-E, WA6520-SI, WA6520X-E, WA6520XS-LI, WA6521, WA6522, WA6522-C, WA6522H-D, WA6522H-HI, WA6522H-LI, WA6526, WA6526E, WA6530, WA6530-E, WA6530i, WA6530-LI, WA6530M · WAP912X, WAP952, WAP952E, WAP952H, WAP953 |
See "WA6500A AP series" in "LED descriptions for single-LED APs (1)." |
WA6500B: WA6528i, WA6528X-E |
WA6500A: · WA6120H · WA6520H, WA6520H-E, WA6520H-EGPON, WA6520H-LI, WA6520H-SI, WA6526H |
WA6500B: WA6510E-T |
See "WA6500 AP series" in "LED descriptions for multi-LED APs (3)." |
WA6600 AP series |
WA6636, WA6638i |
· WA6620, WA6620X, WA6620X-EG, WA6620XE-LI, WA6620X-LI, WA6620XM, WA6622, WA6622-EG, WA6624X, WA6628, WA6628X, WA6628XM, WA6630X, WA6638 · WAP922X |
WA6628E-T |
See "WA6600 AP series" in "LED descriptions for multi-LED APs (3)." |
Wi-Fi 7 AP LEDs
Table 2 Wi-Fi 7 AP models
Series |
Model |
Wi-Fi 7 |
WA7200 AP series |
· WA7130, WA7220, WA7220CE, WA7220-HI, WA7220-LI, WA7220H, WA7220H-EI, WA7220X, WA7226-C, WA7230, WA7230-LI, WA7232 · WTU720 |
See "WA7200/WA7300/WA7500/WA7600 AP series" in "LED descriptions for single-LED APs (1)." |
WA7300 AP series |
WA7320, WA7320i, WA7320XE, WA7322H-HI, WA7330i, WA7330X, WA7338-HI |
WA7500 AP series |
WA7538, WA7539 |
WA7600 AP series |
WA7620CE, WA7630X, WA7636, WA7638 |
WA7610E-T |
See "WA7200/WA7300/WA7500/WA7600 AP series" in "LED descriptions for multi-LED APs (1)." |
The description for the status LED on an AP varies by AP operating mode. For information about the operating modes supported by an AP, see the release notes.
LED descriptions before modification
This section is applicable to the following APs:
· WA6300 AP series and WA6600 AP series in versions earlier than 2484.
· WA6500B AP series in versions earlier than 2484, which includes the WA6528i and WA6528X-E APs.
Table 3 LED description (fit mode)
LED color |
Status |
N/A |
Off |
No power is present or the LED has been turned off from the CLI. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing (twice per second) |
The Ethernet ports are down and no mesh links are established. |
Green |
Steady on |
The AP has started up and registered with an AC, but is in standby state (does not have any associated clients). |
Flashing (once every two seconds) |
The AP has started up, but has not registered to any AC. |
The AP is upgrading the image. |
Blue |
Flashing (once per second) |
The radios have associated clients. |
Table 4 LED description (cloud mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients. |
The AP has connected to Cloudnet, and the radios have associated clients. |
Blue |
Steady on |
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients. |
The AP has not connected to Cloudnet, but the radios have associated clients. |
Table 5 LED description (anchor AC mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP has started up and is in standby state, but does not have any associated clients. |
Blue |
LED descriptions after modification
· WA6300 AP series and WA6600 AP series in 2484 and later versions.
· WA6500B AP series in 2484 and later versions, which includes the WA6528i and WA6528X-E APs.
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state and does not have any associated clients. |
The AP has started up in fit mode, but has not registered to any AC. |
Blue |
WA6500A AP series
This section is applicable to the WA6500A AP series in versions earlier than 2616.
Table 7 LED description (fit mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
Table 8 LED description (cloud mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
Steady on |
This section is applicable to the WA6500A AP series in 2616 and later versions.
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
· WA7200 AP series and WA7600 AP series in versions earlier than 2614P02.
· WA7300 AP series and WA7500 AP series in versions earlier than 2615.
Table 10 LED description (fit mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
The radios have associated clients and the number of associated clients is less than the threshold. |
Alternating between green and blue |
The number of associated clients has exceeded the threshold. |
Table 11 LED description (cloud mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
Steady on |
The AP has not connected to Cloudnet, but the radios have associated clients. The number of associated clients is less than the threshold. |
Table 12 LED description (anchor AC mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
· WA7200 AP series and WA7600 AP series in 2614P02 and later versions.
· WA7300 AP series and WA7500 AP series in 2615 and later versions.
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state and does not have any associated online clients. |
Blue |
This section is applicable to the WA6300 AP series and WA6600 AP series in versions earlier than 2484.
Table 14 LED description (fit mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Only the 2.4G radio has associated clients. |
Blue |
Only the 5G radio has associated clients. |
Both the 2.4G and 5G radios have associated clients. |
Table 15 LED description (cloud mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
Steady on |
Table 16 LED description (anchor AC mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
This section is applicable to the WA6300 AP series and WA6600 AP series in 2484 and later versions.
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Blue |
The descriptions for the status LEDs on an AP vary by AP operating mode. For information about the operating modes supported by an AP, see the release notes.
· WA6300 AP series in versions earlier than 2484.
· WA6500A AP series in versions earlier than 2616.
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
· The system software is starting. · An initialization exception has occurred. |
Green |
The AP is operating in cloud mode and has connected to Cloudnet. |
Steady on |
The AP is in standby state. (The fit AP has registered with an AC.) |
Alternating between yellow and green |
The AP is operating in cloud mode and has not connected to Cloudnet. |
Radio status LED |
N/A |
Off |
The radios are disabled or the LED has been turned off from the CLI. |
Yellow |
A radio has been enabled but does not have associated clients. |
Green |
A radio has associated clients. |
LED for a copper or fiber Ethernet port (such as a 1000M, 2.5G, 5G, or 10G port) |
N/A |
Off |
No link is present on the port. |
Yellow |
Steady on |
Negotiation has succeeded on the port, and the port is operating at a reduced speed. |
The port is operating correctly at a reduced speed. |
Green |
Steady on |
Negotiation has succeeded on the port, and the port is operating at the maximum speed. |
The port is operating correctly at the maximum speed. |
PON |
Green |
Steady on |
Normal PON link. |
The ONU is registering. |
Off |
The ONU is not registered. |
· WA6300 AP series in 2484 and later versions.
· WA6500A AP series in 2616 and later versions.
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Radio status LED |
N/A |
Off |
Yellow |
Green |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
PON |
Green |
Steady on |
Normal PON link. |
Off |
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Radio status LED |
N/A |
Off |
Yellow |
Green |
A radio has associated clients and the number of associated clients is less than the threshold. |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Radio status LED |
N/A |
Off |
Yellow |
Green |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
WA6300 AP series
This section is applicable to the WA6300 AP series in versions earlier than 2484.
LED |
Color |
Status |
Power status LED |
Yellow |
Steady on |
No radio cards have been detected. |
The Ethernet ports are down and no mesh links are present. |
Green |
Steady on |
N/A |
Off |
Radio status LED |
Yellow |
Green |
N/A |
Off |
The radios do not have any associated clients, or the LED has been turned off from the CLI. |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
PON |
Green |
Steady on |
Normal PON link. |
Off |
This section is applicable to the WA6300 AP series in 2484 and later versions.
LED |
Color |
Status |
Power status LED |
Yellow |
Steady on |
Green |
Steady on |
N/A |
Off |
Radio status LED |
N/A |
Off |
Yellow |
The radios do not have any associated clients. |
Green |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
PON |
Green |
Steady on |
Normal PON link. |
Off |
WA6500 AP series
This section is applicable to the WA6500B AP series in versions earlier than 2484, which includes the WA6510E-T AP.
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
2.4G radio status LED |
Green |
The 2.4G radio has associated clients. |
N/A |
Off |
The radio is disabled, or the LED has been turned off from the CLI. |
5G radio status LED |
Green |
The 5G radio has associated clients. |
N/A |
Off |
GE |
Yellow |
Steady on |
The port has negotiated to operate at 100/10 Mbps. |
Flashing |
The port is operating correctly at 100/10 Mbps. |
Green |
Steady on |
The port has negotiated to operate at 1000 Mbps. |
Flashing |
The port is operating correctly at 1000 Mbps. |
N/A |
Off |
5GE |
Yellow |
Steady on |
The port has negotiated to operate at 2500/1000/100/10 Mbps. |
Flashing |
The port is operating correctly at 2500/1000/100/10 Mbps. |
Green |
Steady on |
The port has negotiated to operate at 5000 Mbps. |
Flashing |
The port is operating correctly at 5000 Mbps. |
N/A |
Off |
10GE/SFP+ |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
The port has negotiated to operate at 10 Gbps. |
Flashing |
The port is operating correctly at 10 Gbps. |
N/A |
Off |
This section is applicable to the WA6500B AP series in 2484 and later versions, which includes the WA6510E-T AP.
LED |
Color |
Status |
Power status LED |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
Green |
N/A |
Off |
Green |
N/A |
Off |
GE |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
5GE |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
10GE/SFP+ |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
WA6600 AP series
This section is applicable to the WA6600 AP series in versions earlier than 2484, which includes the WA6628E-T AP.
LED |
Color |
Status |
POWER |
Yellow |
Steady on |
Green |
Steady on |
N/A |
Off |
RADIO1 |
Green |
Radio1 has associated clients. |
N/A |
Off |
Radio1 is disabled, or the LED has been turned off from the CLI. |
RADIO2 |
Green |
Radio2 has associated clients. |
Yellow |
In tri-radio mode, radio3 has associated clients. |
In tri-radio mode, both radio2 and radio3 have associated clients. |
N/A |
Off |
GE1/GE2 |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
10GE/SFP+ |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
This section is applicable to the WA6600 AP series in 2484 and later versions, which includes the WA6628E-T AP.
LEDs |
Color |
Status |
POWER |
Yellow |
Steady on |
Green |
Steady on |
N/A |
Off |
RADIO1 |
Green |
N/A |
Off |
Radio is disabled, or the LED has been turned off from the CLI. |
RADIO2 |
Green |
Yellow |
N/A |
Off |
GE1/GE2 |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
10GE/SFP+ |
Yellow |
Steady on |
Flashing |
Green |
Steady on |
Flashing |
N/A |
Off |
Table 28 LED description for the reset button
Reset button |
Press and hold duration (seconds) |
LED color |
LED status |
RESET |
0 to 5 |
Green |
Steady on |
Reset the AP. |
5 to 20 |
Green |
Restore to the factory defaults. |
20 to 30 |
Yellow |
The AP is operating in fit mode. |
The AP is operating in anchor AC mode. |
Flashing (four times per second) |
The AP is operating in cloud mode. |
> 30 |
Yellow |
Green |
The AP is switching from fit mode to cloud mode. Note: After you release the button, if the AP has switched from fit mode to cloud mode, it will restart for the new mode to take effect. |
