20-OpenFlow Configuration Guide
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C CR16000-M1A Router Configuration Guides-R8630Pxx-6W10220-OpenFlow Configuration Guide
00-Preface
00-Preface 111.19 KB
Preface
This configuration guide describes OpenFlow fundamentals and configuration. OpenFlow separates the data forwarding and routing decision functions. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the routers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Support for slots varies by device model. All slot-related descriptions in this documentation are for illustration only. It is normal that the slots in the examples differ from those on your device. On a device to which this documentation applies, the slot-number argument in a command represents the entire device and is fixed at 0. The command applies to the entire device regardless of whether the slot number is specified.
We appreciate your comments.
