- 04-DPI Command Reference
- 01-DPI engine commands
- 02-IPS commands
- 03-URL filtering commands
- 04-Data filtering commands
- 05-File filtering commands
- 06-Anti-virus commands
- 07-Data analysis center commands
- 08-WAF commands
- 09-Proxy policy commands
- 10-IP reputation commands
- 11-Domain reputation commands
- 12-APT defense commands
- 13-DLP commands
- 14-Content moderation commands
- 15-Network asset scan commands
| 07-Data analysis center commands | 145.51 KB |
dac email-server client-authentication enable
dac email-server secure-authentication enable
The following compatibility matrix shows the support of hardware platforms for data analysis center:
Hardware platform |
Module type |
Data analysis center compatibility |
M9006 M9010 M9014 |
Blade IV firewall module |
Yes |
Blade V firewall module |
Yes |
NAT module |
No |
M9010-GM |
Encryption module |
Yes |
M9016-V |
Yes |
M9008-S M9012-S |
Yes |
Intrusion prevention service (IPS) module |
Yes |
Video network gateway module |
Yes |
M9008-S-V |
Yes |
M9000-AI-E4 M9000-AI-E8 M9000-AI-E16 |
Yes |
M9000-AK001 |
Yes |
M9000-X06 M9000-X06-B M9000-X06-B-G M9000-X06-G M9000-X10 |
Blade VI firewall module |
Yes |
M9000-AI-X06 M9000-AI-X10 |
Yes |
Use dac email-server client-authentication enable to enable email client authentication.
Use undo dac email-server client-authentication enable to disable email client authentication.
Email client authentication is disabled.
context-admin
Enable email client authentication on the device if the email server (specified by the dac email-server server-address command) requires client identity authentication.
For successful email client authentication, you must configure the correct username and password for connecting to the email server.
# Enable email client authentication.
[Sysname] dac email-server client-authentication enable
dac email-server username
dac email-server password
Use dac email-server password to set the password for connecting to the email server.
Use unto dac email-server password to restore the default.
dac email-server password { cipher | simple } string
undo dac email-server password
The password for connecting to the email server is not specified.
context-admin
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
Both the username and password for connecting to the email server are required if email client authentication is enabled.
If you configure this command multiple times, the most recent configuration takes effect.
# Specify abc123 as the password for connecting to the email server.
[Sysname] dac email-server password simple abc123
Use dac email-server secure-authentication enable to enable secure transmission of authentication credentials.
Use undo dac email-server secure-authentication enable to disable secure transmission of authentication credentials.
Secure transmission of authentication credentials is disabled.
context-admin
This command enables the device to transmit email client authentication credentials to the email server over a secure channel.
This command takes effect only after email client authentication is enabled.
# Enable secure transmission of authentication credentials.
[Sysname] dac email-server secure-authentication enable
dac email-server sender
Use dac email-server sender to specify the email sender address.
Use undo dac email-server sender to restore the default.
dac email-server sender address-string
The email sender address is not specified.
context-admin
address-string: Specifies the email sender address, as case-sensitive string of 3 to 63 characters.
The data analysis center (DAC) uses the specified email sender address send emails.
# Specify mailto:abc@example.com as the email sender address.
[Sysname] dac email-server sender abc@example.com
Use dac email-server server-address to specify the email server address for the DAC.
Use undo dac email-server server-address to restore the default.
dac email-server server-address address-string
No email server is specified for the DAC.
context-admin
address-string: Specifies the IP address or host name of the email server. The host name is a case-sensitive string of 3 to 63 characters.
The DAC can send emails only after the both email server address and email sender address are configured.
If you specify the host name as the email server address for the DAC, make sure the device can obtain the IP address through static or dynamic domain name resolution. In addition, the device must reach the IP address of the email server. For more information about domain name resolution, see DNS configuration in Layer 3—IP Services.
# Specify 101.1.1.255 as email server address for the DAC.
[Sysname] dac email-server server-address 101.1.1.225
Use dac email-server username to set the username for connecting to the email server.
Use undo dac email-server username to restore the default.
dac email-server username username
The username for connecting to the email server is not specified.
context-admin
username: Specifies the username, a case-sensitive string of 1 to 63 characters.
# Specify admin as the username for connecting to the email server.
[Sysname] dac email-server username admin
dac log-collect enable
Use dac log-collect enable to enable the log collection for a service that is registered to the DAC.
Use undo dac log-collect enable to disable the log collection for a service.
dac log-collect service service-type service-name enable
undo dac log-collect service service-type service-name enable
The log collection status for each service varies by service setting when the service module is registered to the DAC.
context-admin
service-type: Specifies the type of a service that is registered to the DAC. The service type name is a case-insensitive string. To view the supported service type, enter a question mark (?) for this argument.
service-name: Specifies the name of a service that is registered to the DAC. The service name is a case-insensitive string. To view the supported service name, enter a question mark (?) for this argument.
This command enables the log collection for a specific service. To collect the log messages for the traffic service, first enable the session statistics collection and then enable the log collection.
Repeat this command to enable log collection for multiple services.
# Enable the log collection for the DPI traffic service.
[Sysname] dac log-collet service dpi traffic enable
display dac log-collect
dac log-display enable
Use dac log-display enable to enable the real-time log display.
Use undo dac log-collect enable to disable the real-time log display.
dac log-display service service-type service-name enable
undo dac log-display service service-type service-name enable
The real-time log display for all services is disabled.
context-admin
service-type: Specifies the type of a service that is registered with the DAC. The service type name is a case-insensitive string. To view the supported service type, enter a question mark (?) for this argument.
service-name: Specifies the name of a service that is registered with the DAC. The service name is a case-insensitive string. To view the supported service name, enter a question mark (?) for this argument.
This command for a service takes effect only after the log collection for the service is enabled by the dac log-collect enable command.
With this feature enabled, you can see the real-time log messages displayed on the Web interface.
Repeat this command to enable real-time log display for multiple services.
DPI do not support this feature in the current software version.
# Enable the real-time display for system logs.
[Sysname] dac log-display service syslog syslog enable
display dac log-display
dac report
Use dac report to configure the subscription parameters for a report type.
Use undo dac report to remove the subscription parameters for a report type.
dac report type { comparison | integrated | intelligent | summary } subscriber mail-address [ language { chinese | english } ]
undo dac report type { comparison | integrated | intelligent | summary } [ subscriber mail-address ]
No report subscription parameters are configured.
context-admin
comparison: Specifies the comparison report.
integrated: Specifies the integrated report.
intelligent: Specifies the intelligent report.
summary: Specifies the summary report.
subscriber mail-address: Specifies the email address of the report subscriber, a case-sensitive string of 3 to 63 characters. If you do not specify a subscriber, the undo command removes all subscribers for the specified report type.
language: Specifies a language for the reports. If you do not specify this keyword, Chinese is used in the reports.
chinese: Uses Chinese in the reports.
english: Uses English in the reports.
You can configure a maximum of 50 subscribers for each report type.
# Specify admin@example.com and English as the subscriber address and language for the summary report, respectively.
[Sysname] dac report type summary subscriber admin@example.com language english
# Remove subscriber address admin@example.com for the summary report.
[Sysname] undo dac report type summary subscriber admin@example.com
display dac report
dac report top
Use dac report top to specify the number of statistics entries in descending order to be analyzed for a report type.
Use undo dac report top to restore the default.
dac report type { comparison | integrated | intelligent | summary } top number
undo dac report type { comparison | integrated | intelligent | summary } top
Top 5 statistics entries are specified to be analyzed for a report type.
context-admin
top number: Specifies the number of statistics entries in descending order. The value range for the number argument is 5, 10, 15, 20, and 25.
This command takes effect only when report subscription settings are configured.
Use this command to specify the range of statistics to be analyzed by a report. For example, if you specify top 20 statistics entries for the summary report, the generated report will contain the analysis results only about these statistics entries from each service.
# Specify top 5 statistics entries for the comparison report.
[Sysname] dac report type comparison top 15
dac report
display dac report
dac storage
Use dac storage to configure the data storage limits for a service.
Use undo dac storage to restore the default.
dac storage service service-type service-name limit { hold-time time-value | usage usage-value | action { delete | log-only } }
undo dac storage service service-type service-name limit { hold-time | usage | action }
The service data can be saved for a maximum of 365 days.
The data of each service can occupy up to 20% of the total storage space.
If the storage time or storage space usage limit is exceeded, the system deletes the expired or the oldest data.
limit: Configures the data storage limits for a service.
hold-time time-value: Specifies the storage time limit in days. The value range is 1 to 65535. The storage time limit should be longer than the number of days that the oldest service data has been stored for.
usage usage-value: Specifies the percentage of the total storage space the service data can occupy. The value range is 1 to 100. The storage usage limit should be higher than the current storage usage of the service.
action: Specifies the action to take when a data storage limit is exceeded.
delete: Deletes data collected on the oldest dates and generates a log message. The data of the current date cannot be deleted.
log-only: Generates a log message only. When a storage limit is exceeded, old data are not deleted and new data cannot be saved.
The DAC periodically checks the data of each service to determine if the storage time or storage space usage limit is exceeded.
· If a storage limit is exceeded and the action is delete, the system deletes the expired or the oldest service data. A log will be generated to report the event.
· If a storage limit is exceeded and the action is log-only, the system generates a log message. New data will not be saved.
If you configure this command to set the storage time limit for a service multiple times, the most recent configuration takes effect. The same is true for setting the storage space limit or storage limit-violated action for a service. You can view the storage space usage of each service on the Web interface.
This command is supported only on the default context. For more information about contexts, see context configuration in Virtual Technologies Configuration Guide.
# Set the storage time limit, storage space limit, and the action to take when the limits are exceeded for the traffic service.
[Sysname] dac storage service dpi traffic limit hold-time 60
[Sysname] dac storage service dpi traffic limit usage 30
[Sysname] dac storage service dpi traffic limit action delete
dac traffic-statistic enable
Use dac traffic-statistic enable to enable real-time traffic statistics collection.
Use undo dac traffic-statistic enable to disable real-time traffic statistics collection.
dac traffic-statistic { application | user } enable [ verbose ]
undo dac traffic-statistic { application | user } enable
The real-time traffic statistics collection is disabled.
context-admin
application: Collects application traffic statistics in real time.
user: Collects user traffic statistics in real time.
verbose: Collects detailed traffic information in real time. If you do not specify this keyword, this command collects brief traffic information in real time.
The detailed information about user traffic that is collected in real time provides used applications on a per-user basis.
The detailed information about application traffic that is collected in real time provides user information on a per-application basis.
Enabling this feature will have an impact on the CPU performance of the device. Make sure you are fully aware of the impact before you enable this feature in high traffic scenarios.
Repeat this command to enable multiple collections of real-time traffic statistics.
# Enable the collection of detailed user traffic statistics in real time.
[Sysname] dac traffic-statistic user enable verbose
display dac traffic-statistic
display dac email-server
Use display dac email-server to display the email server configuration of the DAC.
context-admin
context-operator
# Display the email server configuration of the DAC.
<Sysname> display dac email-server
Mail server address : 2.2.2.2
Mail sender address : qqq@example.com
Authentication : Enable
secure-authentication : Enable
Username : lkx
password : ******
Authentication |
Enabling status of the email client authentication. |
Secure-authentication |
Enabling status of the secure transmission of authentication credentials. |
Username |
Username for connecting to the email server. |
Password |
Password for connecting to the email server. |
Use display dac log-collect to display the log collection configuration for a service.
display dac log-collect { all | service service-type service-name }
context-admin
context-operator
all: Specifies all types of services that are registered with the DAC. The DAC provides functions only for services that have registered with the DAC.
# Display the log collection configuration for all services.
[Sysname] display dac log-collect all
Service type Service Status
Slot 1:
dpi audit Disabled
dpi ffilter Disabled
dpi threat Disabled
dpi traffic Enabled
dpi uflt Disabled
Service |
Service name. |
Status |
Status of the log collection: Disabled or Enabled. |
Use display dac log-display to display the configuration of the real-time log display.
display dac log-display { all | service service-type service-name }
context-admin
context-operator
# Display the configuration of the real-time log display.
[Sysname] display dac log-display syslog syslog
Slot 1:
syslog syslog Disabled
syslog cfglog Disabled
Service |
Service name. |
Status |
display dac report
Use display dac report to display report subscriber information.
display dac report [ comparison | integrated | intelligent | summary ]
context-admin
context-operator
If you do not specify a report type, this command displays subscriber information for all report types.
# Display subscriber information for all report types.
<Sysname> display dac report
Total subscribers:4
Summary subscribers:1
Comparison subscribers:1
Intelligent subscribers:1
Integrated subscribers:1
Report type Language Top Subscriber email
Summary CH 20 124@example.com
Comparison CH 20 111@example.com
Intelligent EN 15 123@example.com
Integrated EN 25 112@example.com
Total subscribers |
Total number of subscribers. |
Summary subscribers |
Number of subscribers for the summary report. |
Comparison subscribers |
Number of subscribers for the comparison report. |
Intelligent subscribers |
Number of subscribers for the intelligent report. |
Integrated subscribers |
Number of subscribers for the integrated report. |
Language |
Language used in the reports: · CH—Chinese. · EN—English. |
Top |
Statistics range of a report. |
Subscriber email |
Email address of a report subscriber. |
display dac storage
Use display dac storage to display the data storage limit configuration for services.
display dac storage [service-type service-name ]
If you do not specify a service, this command displays the data storage limit configuration for all services.
# Displays the data storage limit configuration for all services.
<Sysname> display dac storage
Total services :25
Service type Service name Time limit (days) Usage limit
Action
syslog cfglog 365 20%
delete
sandbox log 365 20%
---- More ----
Table 5 Command output
Total services |
Total number of services. |
Time limit |
Storage time limit in days. |
Usage limit |
Storage space usage limit in percentage. |
Action |
Action to take when the storage time limit or space limit is exceed. · delete—Delete the oldest data, and generates a log message. · log-only—Generate a log message only. |
Use display dac traffic-statistic to display the configuration of the real-time traffic statistics collection.
display dac traffic-statistic [ application | user ]
context-admin
context-operator
application: Specifies the collection of the real-time application traffic statistics.
user: Specifies the collection of the real-time user traffic statistics.
If you do not specify any keyword, this command displays the configuration of the collection for all real-time traffic statistics.
# Displays the configuration of the real-time user traffic statistics collection.
[Sysname] display dac traffic-statistic user
Slot 1:
Type Status
User Enabled (verbose)
Table 6 Command output
Type |
Type of traffic collected in real time: · Application. · User. |
Status |
Status of the real-time traffic statistics collection: · Disabled—This feature is disabled. · Enabled (brief)—This feature is enabled, and the DAC collects brief traffic information. · Enabled (verbose)—This feature is enabled, and the DAC collects detailed traffic information. |
