07-Layer 2 - WAN Access
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10007-Layer 2 - WAN Access
06-PPP-LCP-MIB
06-PPP-LCP-MIB 99.27 KB
PPP-LCP-MIB
About this MIB
Use this MIB to configure and get PPP LCP negotiation information, and configure and get LQR packet information.
MIB file name
rfc1471-ppp-lcp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).ppp(23)
Tabular objects
pppLinkStatusTable
About this table
This table gets the PPP LCP negotiation information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
pppLinkStatusPhysicalIndex (1.3.6.1.2.1.10.23.1.1.1.1.1)
read-only
Integer32
Integer32 (0..2147483647)
Interface index.
As per the MIB.
pppLinkStatusBadAddresses (1.3.6.1.2.1.10.23.1.1.1.1.2)
read-only
Counter
Standard MIB values.
Number of packets with wrong addresses.
As per the MIB.
pppLinkStatusBadControls (1.3.6.1.2.1.10.23.1.1.1.1.3)
read-only
Counter
Number of packets with wrong control fields.
As per the MIB.
pppLinkStatusPacketTooLongs (1.3.6.1.2.1.10.23.1.1.1.1.4)
read-only
Counter
Number of too long packets.
As per the MIB.
pppLinkStatusLocalMRU (1.3.6.1.2.1.10.23.1.1.1.1.6)
read-only
Integer32
Integer32 (1..2147483648)
Local MRU.
If the connection is disconnected, the value is 255.
pppLinkStatusRemoteMRU (1.3.6.1.2.1.10.23.1.1.1.1.7)
read-only
Integer32
Remote MRU.
If the connection is disconnected, the value is 255. If no MRU is negotiated, the value is 1500.
pppLinkStatusLocalToPeerACCMap (1.3.6.1.2.1.10.23.1.1.1.1.8)
read-only
OCTET STRING
OCTET STRING (4)
Local ACCM value.
If the connection is disconnected, the value is 0xffffffff.
pppLinkStatusPeerToLocalACCMap (1.3.6.1.2.1.10.23.1.1.1.1.9)
read-only
OCTET STRING
OCTET STRING (4)
Remote ACCM value.
If the connection is disconnected or the ACCM does not needs to be negotiated, the value is 0xffffffff.
pppLinkStatusLocalToRemoteProtoComp (1.3.6.1.2.1.10.23.1.1.1.1.10)
read-only
INTEGER
enabled(1)
disabled(2)
Local PFC status.
As per the MIB.
pppLinkStatusRemoteToLocalProtoComp (1.3.6.1.2.1.10.23.1.1.1.1.11)
read-only
INTEGER
enabled(1)
disabled(2)
Remote PFC status.
As per the MIB.
pppLinkStatusLocalToRemoteACCompression (1.3.6.1.2.1.10.23.1.1.1.1.12)
read-only
INTEGER
enabled(1)
disabled(2)
Local ACFC status.
As per the MIB.
pppLinkStatusRemoteToLocalACCompression (1.3.6.1.2.1.10.23.1.1.1.1.13)
read-only
INTEGER
enabled(1)
disabled(2)
Remote ACFC status.
As per the MIB.
pppLinkStatusTransmitFcsSize (1.3.6.1.2.1.10.23.1.1.1.1.14)
read-only
Integer32
Integer32 (0..128)
Local FCS size.
If the connection is disconnected or the packets do not need to be processed in software, the value is 0.
pppLinkStatusReceiveFcsSize (1.3.6.1.2.1.10.23.1.1.1.1.15)
read-only
Integer32
Integer32 (0..128)
Remote FCS size.
pppLinkConfigTable
About this table
This table configures PPP LCP negotiation.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pppLinkConfigInitialMRU (1.3.6.1.2.1.10.23.1.1.2.1.1)
read-write
Integer32
Initial MRU value.
Supports only the read operation.
pppLinkConfigReceiveACCMap (1.3.6.1.2.1.10.23.1.1.2.1.2)
read-write
OCTET STRING
OCTET STRING (4)
Receive ACCM.
Supports only the read operation. The default value is 0xffffffff.
pppLinkConfigTransmitACCMap (1.3.6.1.2.1.10.23.1.1.2.1.3)
read-write
OCTET STRING
OCTET STRING (4)
Transmit ACCM.
pppLinkConfigMagicNumber (1.3.6.1.2.1.10.23.1.1.2.1.4)
read-write
INTEGER
false (1)
 true (2)
Magic-Number check enable status.
pppLinkConfigFcsSize (1.3.6.1.2.1.10.23.1.1.2.1.5)
read-write
Integer32
Integer32 (0..128)
FCS size.
Supports only the read operation. The default value is 0.
pppLqrTable
About this table
This table gets information about PPP LQR packets.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pppLqrQuality (1.3.6.1.2.1.10.23.1.2.1.1.1)
read-only
INTEGER
good(1)
bad(2)
not-determined(3)
Link quality.
As per the MIB.
pppLqrlnGoodOctets (1.3.6.1.2.1.10.23.1.2.1.1.2)
read-only
Counter
Number of packets sent by PPP to the upper layer.
As per the MIB.
pppLqrLocalPeriod (1.3.6.1.2.1.10.23.1.2.1.1.3)
read-only
Integer32
Interval for the local interface to send LQR packets on the local end.
As per the MIB.
pppLqrRemotePeriod (1.3.6.1.2.1.10.23.1.2.1.1.4)
read-only
Integer32
Interval for the remote interface to send LQR packets on the local end.
As per the MIB.
pppLqrOutQRs (1.3.6.1.2.1.10.23.1.2.1.1.5)
read-only
Counter
Number of incoming LQR packets.
As per the MIB.
pppLqrlnLQRs
(1.3.6.1.2.1.10.23.1.2.1.1.6)
read-only
Counter
Number of outgoing LQR packets.
As per the MIB.
pppLqrConfigTable
About this table
This table configures the PPP LQR parameters.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pppLqrConfigPeriod (1.3.6.1.2.1.10.23.1.2.2.1.1)
read-write
Integer32
Interval for sending LQR packets.
The maximum value is 3276700, and the minimum value 0 cannot set through MIB. If you set this parameter to 0 through the CLI, MIB will reads the value as 2147483647.
pppLqrConfigStatus (1.3.6.1.2.1.10.23.1.2.2.1.2)
read-write
INTEGER
disabled (1)
enabled (2)
PPP LQM enable status.
pppLqrExtnsTable
About this table
This table gets extended information about PPP LQR packets.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pppLqrExtnsLastReceivedLqrPacket (1.3.6.1.2.1.10.23.1.2.3.1.1)
read-only
OCTET STRING
OCTET STRING (68)
LQR packet last received.
As per the MIB.
