20-Network Management and Monitoring Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)- R9141-6W10020-Network Management and Monitoring Command Reference
11-NetStream commands
11-NetStream commands 250.00 KB
NetStream commands
display ip netstream cache
Use display ip netstream cache to display NetStream entry information.
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 [ label-position4 label-value4 [ label-position5 label-value5 [ label-position6 label-value6 ] ] ] ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number  | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number ]
verbose: Displays detailed information about NetStream entries. If you do not specify this keyword, this command displays brief information about NetStream entries.
type: Specifies the NetStream entry type. If you do not specify this keyword, this commands displays information about all types of NetStream entries.
ip: Specifies Layer 3 NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 NetStream entries.
l2: Specifies Layer 2 NetStream entries.
mpls: Specifies MPLS NetStream entries.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 6, representing labels from the top label to the bottom label. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified. The value range for the label-value3 argument is 0 to 1048575.
label-position4 label-value4: Specifies a label by its position and value. The value range for the label-position4 argument is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified. The value range for the label-value4 argument is 0 to 1048575.
label-position5 label-value5: Specifies a label by its position and value. The value range for the label-position5 argument is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified. The value range for the label-value5 argument is 0 to 1048575.
label-position6 label-value6: Specifies a label by its position and value. The value range for the label-position6 argument is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified. The value range for the label-value6 argument is 0 to 1048575.
destination destination-ip: Specifies a destination IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
destination-port destination-port: Specifies a destination port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
protocol protocol: Specifies a protocol number in the range of 0 to 255 or a well-known protocol name, such as GRE, OSPF, TCP, or UDP. If you specify this option, this command does not display Layer 2 NetStream entries.
source source-ip: Specifies a source IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
source-port source-port: Specifies a source port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
arrived-time: Specifies the arrival time of flows. If you specify this keyword, make sure the end date and time is not earlier than the start date and time. If you do not specify this keyword, the flow arrival time is not used as a filter criterion.
start-date: Specifies a start date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the start time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
end-date: Specifies an end date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
end-time: Specifies the end time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about NetStream entries for all cards.
The types of NetStream entries for flow packets vary by the export template version and whether the flow packets contain IP headers.
·     If the version 9 or version 10 template is used:
¡     The type of the NetStream entry is ipl2 (Layer 2 and Layer 3) for flow packets containing IP headers.
¡     The type of the Netstream entry is l2 (Layer 2) for flow packets without IP headers.
·     If the version 5 template is used:
¡     The type of the NetStream entry is ip (Layer 3) for flow packets containing IP headers.
¡     The type of the NetStream entry is l2 (Layer 2) for flow packets without IP headers.
# Display detailed information about NetStream entries.
<Sysname> display ip netstream cache verbose
IP NetStream cache information:
  Active flow timeout             : 60 min
  Inactive flow timeout           : 10 sec
  Max number of entries           : 1000
  IP active flow entries          : 1
  MPLS active flow entries        : 2
  L2 active flow entries          : 1
  IPL2 active flow entries        : 1
  IP flow entries counted         : 10
  MPLS flow entries counted       : 20
  L2 flow entries counted         : 10
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 01/01/2019 at 00:01:02
IP packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
 512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86          49        27
TCP-FTP         5900082      86        9        9          11        33
TCP-FTPD        3200453    1006        5      193          45        33
TCP-WWW       546778274   11170      887       12           8        32
TCP-other      49148540    3752       79       47          30        32
UDP-DNS       117240379     570      190        3           7        34
UDP-other      45502422    2272       73       30           8        37
ICMP           14837957     125       24        5          12        34
IP-other          77406       5        0       47          52        27
Type DstIP(Port)         SrcIP(Port)            Pro ToS VNI   If(Direct)  Pkts
     DstMAC(VLAN)        SrcMAC(VLAN)
     TopLblType(IP/Mask) Lbl-Exp-S-List
IP   11.1.1.1(1024)      11.1.1.2(21)           6   128 10    XGE1/0/1(I) 42996
     TCPFlag:      27
     DstMask:      24       SrcMask:      24       NextHop:      0.0.0.0
     DstAS:         0       SrcAS:         0       BGPNextHop:   0.0.0.0
     InVRF:        vpn1
     TTE ID(Local/Remote): 0x00000000/0x00000000
     SamplerMode:   2       SamplerInt:  256
     Active:  120.600       Bytes/Pkt:   152
     First packet arrived: 10/28/2019, 14:10:03
     Last packet arrived:  10/28/2019, 14:21:03
     SrcMac:  0010-9400-0001
     DstMac:  1019-65cd-859c
     SRv6 policy NID:      N/A
L2   0012-3f86-e94c(10)     0012-3f86-e86a(0)                 XGE1/0/1(I) 1253
     SamplerMode:   2       SamplerInt:   64
     Active:    5.510       Bytes/Pkt:   210
     First packet arrived: 10/28/2019, 14:10:00
     SrcMac:  0012-3f86-e94c
     DstMac:  0012-3f86-e86a
MPLS LDP(3.3.3.3/24)        1:18-6-0                          XGE1/0/2(O) 291
                            2:24-6-0
                            3:30-6-0
                            4:32-6-0
                            5:34-6-0
                            6:36-6-1
     SamplerMode:   0       SamplerInt:    0
     Active:  660.084       Bytes/Pkt:   100
     First packet arrived: 10/28/2019, 14:10:01
     SrcMac:  0010-9400-0002
     DstMac:  1019-65cd-858c
     SRv6 policy NID:      2150629378
IP&  192.168.123.1(2048) 192.168.1.1(0)         1    0   N/A   XGE1/0/2(O) 10
L2   0012-3f86-e95d(0)      0012-3f86-e116(1008)
     TCPFlag:      27
     DstMask:      24       SrcMask:      24       NextHop:    192.168.1.2
     OutVRF:        0       TCPFlag:    0
     Active:   12.030       Bytes/Pkt:    86
     First packet arrived: 10/28/2019, 14:10:04
     SrcMac:  0012-3f86-e95d
     DstMac:  0012-3f86-e116
     SRv6 policy NID:      2150629379
IP&  172.16.1.1(68)      172.16.2.1(67)         17  64   N/A   XGE1/0/3(I) 1848
MPLS LDP(4.4.4.4/24)        1:55-6-0
                            2:16-6-1
     TCPFlag:       0
     DstMask:      24       SrcMask:      24       NextHop:    172.16.2.10
     InVRF:         N/A
     Active:  382.542       Bytes/Pkt:  1426
     First packet arrived: 10/28/2019, 14:12:03
     Last packet arrived:  10/28/2019, 14:23:03
     SrcMac:  0010-9400-0003
     DstMac:  1019-65cd-858d
     SRv6 policy NID:      2150629380
Active flow timeout
Aging timer for active flows, in minutes.
Aging timer for inactive flows, in seconds.
Maximum number of flows allowed in the cache.
Number of active IP flows in the cache.
Number of active MPLS flows in the cache.
Number of active Layer 2 flows in the cache.
Number of active Layer 2 and Layer 3 flows in the cache.
Number of IP flows that have been counted.
Number of MPLS flows that have been counted.
Number of Layer 2 flows that have been counted.
Number of Layer 2 and Layer 3 flows that have been counted.
Last time the reset ip netstream statistics command was executed. This field displays Never if you have never executed this command.
Distribution of IP packets by packet size, and the bracketed number is the total number of IP packets.
The value is displayed in the proportion of the number of IP packets of the specified sizes to the total number of IP packets, and the value is displayed with 3 decimal places.
320  352  384  416  448  480 512  544  576
Range of IP packet length (excluding data link layer header) in bytes.
·     For the values in the range of 1 to 576, the range increases in the step of 32. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes.
·     For the values greater than 1024, the range increases in the step of 512. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes.
·     Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry.
Protocol     Total Flows     Packets /sec
Flows/sec   Packets/flow
Active(sec)/flow     Idle(sec)/flow
Statistics of packets by protocol type:
·     Protocol type.
·     Total number of flows.
·     Number of packets per second.
·     Number of flows per second.
·     Number of packets per flow.
·     Active time (in seconds) of each flow.
·     Inactive time (in seconds) of each flow.
Statistics of the active flows in the current cache:
·     Flow type. Flows are classified into the following types:
¡     Layer 3 flows.
¡     Layer 2 flows.
¡     Layer 2 and Layer 3 flows.
¡     MPLS flows without IP options.
¡     MPLS flows with IP options.
·     Destination IP address (destination port).
·     Source IP address (source port).
·     Protocol number.
·     ToS.
·     VXLAN ID. The VNI field displays N/A for non-VXLAN packets and on VXLAN-incapable devices.
·     Interface name (direction).
·     Number of packets.
ICMP packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields:
·     The highest 8 bits represent the type field.
·     The lowest 8 bits represent the code field.
The value for the source port is set to 0 and does not indicate any statistics.
Layer 2 information of the active flows in the current cache:
·     Destination MAC address, followed by the destination VLAN ID in parenthesis.
·     Source MAC address, followed by the source VLAN ID in parenthesis.
Information about the active MPLS flows in the current cache:
·     Type of the labels at the top of the label stack:
¡     IP address associated with the label.
¡     Mask associated with the label.
·     Label list.
Up to six labels can be listed in one label list.
A label includes the following fields:
·     Label—20-bit label value.
·     EXP—3-bit traffic class, used for QoS.
·     S—1-bit bottom of stack flag.
TCPFlag:      TTL
DstMask:      SrcMask:             NextHop:
DstAS:           SrcAS:            BGPNextHop:
OutVRF:       InVRF:
SamplerMode:                     SamplerInt:
Active:       Bytes/Pkt:
SrcMac:
DstMac:
SRv6 policy NID:
Other information about the active flows in the cache:
·     TCPFlag—TCP tag.
·     DstMask—Destination mask.
·     SrcMask—Source mask.
·     NextHop—Routing next hop.
·     DstAS—Destination AS.
·     SrcAS—Source AS.
·     BGPNextHop—BGP next hop.
·     OutVRF—VPN instance to which the outbound packets belong.
·     InVRF—VPN instance to which the inbound packets belong.
·     TTE ID(Local/Remote)—Local/Remote tunnel endpoint ID.
·     SamplerMode—Sampling mode. Supported sampling modes are:
¡     0—No sampling.
¡     1—Fixed sampling.
¡     2—Random sampling.
·     SamplerInt—Sampling interval.
·     Active—Flow's active time.
·     Bytes/Pkt—Number of bytes per packet.
·     First packet arrived—Arrival time of the first packet of the flow.
·     Last packet arrived—Arrival time of the last packet of the flow.
·     SrcMask—Source MAC address.
·     DstMask—Destination MAC address.
·     SRv6 policy NID—NHLFE entry index for the SRv6-TE policy.
display ip netstream cache archive
Use display ip netstream cache archive to display the locally archived NetStream entries.
display ip netstream cache archive [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 [ label-position4 label-value4 [ label-position5 label-value5 [ label-position6 label-value6 ] ] ] ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number ]
verbose: Displays detailed NetStream entry information.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value3 argument is 0 to 1048575.
label-position4 label-value4: Specifies a label by its position and value. The value range for the label-position4 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value4 argument is 0 to 1048575.
label-position5 label-value5: Specifies a label by its position and value. The value range for the label-position5 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value5 argument is 0 to 1048575.
label-position6 label-value6: Specifies a label by its position and value. The value range for the label-position6 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value6 argument is 0 to 1048575.
protocol protocol: Specifies a protocol by its number in the range of 0 to 255 or by its name such as GRE, OSPF, TCP, or UDP. If you specify this option, this command does not display Layer 2 NetStream entries.
arrived-time: Specifies an arrived time range to display NetStream entries. If you specify this keyword, make sure the end date and time is not earlier than the start date and time. If you do not specify this keyword, the arrived time is not used as a criterion for filtering the NetStream entries to be displayed.
start-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
start-time: Specifies the start time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the start time of 0 indicates 00:00:00.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
end-time: Specifies the end time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the end time of 0 indicates 00:00:00.
# Display information about the NetStream entries archived between 14:10:03 and 14:23:03 on July 28, 2017.
<Sysname> display ip netstream cache archive arrived-time 7/28/2017 14:10:03 7/28/2017 14:23:03
Type DstIP(Port)         SrcIP(Port)         Pro ToS VNI  APPID If(Direct)  Pkts
IP   11.1.1.1(1024)      11.1.1.2(21)        6   128 10   0xe   XGE1/0/1(I) 42996
     First packet arrived: 7/28/2017, 14:20:03
     Last packet arrived:  7/28/2017, 14:21:03
MPLS LDP(3.3.3.3/24)        1:18-6-0         6   128 N/A  0xe   XGE1/0/2(O) 291
                            2:24-6-0
                            3:30-6-1
     First packet arrived: 7/28/2017, 14:20:01
See Table 1 for the command output description.
ip netstream cache archive enable
display ip netstream export
Use display ip netstream export to display information about the NetStream data export.
IP NetStream export information varies by aggregation mode. This command displays IP NetStream export information for all the configured aggregation modes.
# Display information about the NetStream data export.
<Sysname> display ip netstream export
IP export information:
  Flow source interface                              : Ten-GigabitEthernet0/0/6
  Flow destination VPN instance                      : VPN1
  Flow destination IP address (UDP)                  : 10.10.0.10 (30000)
  Version  5 exported flow number                    : 16
  Version  5 exported UDP datagram number (failed)   : 16 (0)
  Version  9 exported flow number                    : 20
  Version  9 exported UDP datagram number (failed)   : 2 (0)
  Version 10 exported flow number                    : 0
  Version 10 exported UDP datagram number (failed)   : 0 (0)
  Flow destination IPv6 address (UDP)                : 40::1 (30000)
MPLS export information:
protocol-port aggregation export information:
  Version  8 exported flow number                    : 16
  Version  8 exported UDP datagram number (failed)   : 2 (0)
  Version  9 exported flow number                    : 16
NetStream data export information.
Source interface from which the NetStream data is exported.
VPN to which the destination address of the NetStream data export belongs.
Destination IP address and UDP port number of the NetStream data export.
Destination IPv6 address and UDP port number of the NetStream data export.
Number of flows that are exported in version 5 format.
Number of UDP packets that are sent in version 5 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
Number of flows that are exported in version 9 format.
Number of UDP packets that are sent in version 9 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
Information about MPLS flows exported in version 9 format.
L2 export information
Statistics of the Layer 2 data export.
Statistics of NetStream protocol-port aggregation in version 8 format.
Number of flows that are exported in version 8 format.
Number of UDP packets that are sent in version 8 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
Number of flows that are exported in version 10 format.
Number of UDP packets that are sent in version 10 format. The field in the parentheses indicates the number of UDP packets that failed to be sent.
display ip netstream template
Use display ip netstream template to display NetStream template information.
display ip netstream template [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays NetStream template information for the active MPU.
IP NetStream templates vary by aggregation mode. This command displays IP NetStream template information for all the configured aggregation modes.
# Display NetStream template information.
<Sysname> display ip netstream template
 Flow template refresh frequency            : 20
 Flow template refresh interval             : 30 min
 Active flow templates                      : 2
 Created flow templates                     : 2
Protocol-port outbound template:
 Template ID                : 3258
 Field count                : 15
 Field type                   Field length (bytes)
 Flows                        4
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 PAD                          1
 L4 source port               2
 L4 destination port          2
 Sampling algorithm           1
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Local TTE ID                 4
 Remote TTE ID                4
 Serial number                65535
Protocol-port inbound template:
 Template ID                : 3257
 Field count                : 15
 Flows                        4
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 Protocol                     1
 Direction                    1
 PAD                          1
 PAD                          1
 L4 source port               2
 PAD                          1
 PAD                          1
 PAD                          1
 Sampling interval            4
 Local TTE ID                 4
 Remote TTE ID                4
 Serial number                65535
# Display NetStream template information after the RFC 7011-compliant template format is specified.
L3 outbound template:
 Template ID                : 3282
 Packets                    : 0
 Last template export time  : Never
 Field count                : 26
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Input interface index        4
 Output interface index       4
 Source IPv4 address          4
 Destination IPv4 address     4
 Next hop IPv4 addres         4
 Source AS                    4
 Destination AS               4
 L4 source port               2
 IP protocol version          1
 TCP flags                    1
 Protocol                     1
 Source ToS                   1
 Source address mask          1
 Destination address mask     1
 Direction                    1
 Forwarding status            1
 PAD                          1
 Sampling interval            4
 App ID                       4
L3 inbound template:
 Template ID                : 3281
 Packets                    : 0
 Field count                : 26
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 Source AS                    4
 Destination AS               4
 L4 source port               2
 TCP flags                    1
 Protocol                     1
 Source ToS                   1
 Direction                    1
 Forwarding status            1
 PAD                          1
 Sampling interval            4
 App ID                       4
Refresh frequency at which the templates are sent, in packets.
Refresh interval at which the templates are sent, in minutes.
Number of active NetStream templates.
Number of templates that have been created.
Information of the protocol-port template in the outbound direction.
Information of the protocol-port template in the inbound direction.
Packets
Number of packets sent by using the template.
Time when the template was last exported.
Field count
Total number of fields in a template.
Field type
Type of a field in the template.
Flows
Number of aggregate flows.
Out packets
Number of sent packets.
In packets
Number of received packets.
Out bytes
Size of sent packets, in bytes.
In bytes
Size of received packets, in bytes.
First forwarded
System time when the first packet was forwarded, accurate to milliseconds.
Last forwarded
System time when the last packet was forwarded, accurate to milliseconds.
L4 source port
Source UDP or TCP port.
L4 destination port
Destination UDP or TCP port.
PAD
Padding string.
Sampling interval
Sampling rate.
App ID
Application ID.
APP name
Application name.
Local TTE ID
Local tunnel endpoint ID. This field is supported only by version 9.
Remote TTE ID
Remote tunnel endpoint ID. This field is supported only by version 9.
SRv6 policy color
Color for the SRv6-TE policy. This field is supported only by version 9.
SRv6 policy endpoint
IPv6 address of the destination node for the SRv6-TE policy. This field is supported only by version 9.
SRv6 policy name
Name of the SRv6-TE policy. This field is supported only by version 9.
Serial number
Device serial number. This field is supported only by version 9 and version 10.
enable
Use enable to enable a NetStream aggregation mode.
Use undo enable to disable a NetStream aggregation mode.
enable
undo enable
No NetStream aggregation mode is enabled.
NetStream aggregation mode view
# Enable NetStream destination-prefix aggregation mode.
[Sysname] ip netstream aggregation destination-prefix
[Sysname-ns-aggregation-dstpre] enable
ip netstream
Use ip netstream to enable NetStream on an interface.
Use undo ip netstream to disable NetStream on an interface.
ip netstream { inbound | outbound }
undo ip netstream { inbound | outbound }
NetStream is disabled on an interface.
Interface view
inbound: Enables NetStream for incoming traffic.
outbound: Enables NetStream for outgoing traffic.
# Enable NetStream for incoming traffic on Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ip netstream inbound
Use ip netstream aggregation to specify a NetStream aggregation mode and enter its view.
Use undo ip netstream aggregation to remove the configuration for a NetStream aggregation mode.
ip netstream aggregation { as | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
undo ip netstream aggregation { as | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
No NetStream aggregation mode is specified.
as: Specifies the AS aggregation by source AS number, destination AS number, inbound interface index, and outbound interface index.
destination-prefix: Specifies the destination-prefix aggregation by destination AS number, destination address mask length, destination prefix, and outbound interface index.
prefix: Specifies the source and destination prefix aggregation by the following criteria:
·     Source AS number.
·     Destination AS number.
·     Source address mask length.
·     Destination address mask length.
·     Source prefix.
·     Destination prefix.
·     Inbound interface index.
·     Outbound interface index.
prefix-port: Specifies the prefix-port aggregation by the following criteria:
·     Source prefix.
·     ToS.
·     Protocol number.
·     Source port.
·     Destination port.
protocol-port: Specifies the protocol-port aggregation by protocol number, source port, and destination port.
source-prefix: Specifies the source-prefix aggregation by source AS number, source address mask length, source prefix, and inbound interface index.
tos-as: Specifies the ToS-AS aggregation by ToS, source AS number, destination AS number, inbound interface index, and outbound interface index.
tos-bgp-nexthop: Specifies the ToS-BGP nexthop aggregation by ToS, BGP next hop address, and outbound interface index. ToS-BGP next hop aggregation is supported by a version 9 template.
tos-destination-prefix: Specifies the ToS-destination-prefix aggregation by ToS, destination AS number, destination address mask length, destination prefix, and outbound interface index.
tos-prefix: Specifies the ToS-prefix aggregation by the following criteria:
·     ToS.
·     Source AS number.
·     Source prefix.
tos-protocol-port: Specifies the ToS-protocol-port aggregation by ToS, protocol number, source port, destination port, inbound interface index, and outbound interface index.
tos-source-prefix: Specifies the ToS-source-prefix aggregation by ToS, source AS number, source prefix, source address mask length, and inbound interface index.
In NetStream aggregation mode view, you can perform the following tasks:
·     Enable or disable the specified NetStream aggregation mode.
·     Configure source interface, destination IP address, and destination port for the NetStream data export.
A flow matching multiple aggregation modes is counted as multiple aggregate flows.
# Set the NetStream aggregation mode to AS, and enter NetStream AS aggregation mode view.
[Sysname] ip netstream aggregation as
[Sysname-ns-aggregation-as]
enable
ip netstream export host
ip netstream export source
ip netstream aging
Use ip netstream aging to enable periodical aging and TCP FIN- and RST-triggered aging.
Use undo ip netstream aging to disable periodical aging and TCP FIN- and RST-triggered aging.
ip netstream aging
Periodical aging and TCP FIN- and RST-triggered aging are enabled.
# Disable periodical aging and TCP FIN- and RST-triggered aging.
[Sysname] undo ip netstream aging
Use ip netstream cache archive enable to enable archiving of cached NetStream entries.
Use undo ip netstream cache archive enable to disable archiving of cached NetStream entries.
Archiving of cached NetStream entries is disabled.
This feature enables local archiving of cached NetStream entries when they are exported to NetStream servers.
You can display the locally archived NetStream entries by using the display ip netstream cache archive command.
This feature is applicable when a small number of NetStream entries exist and no log server exists. If the device generates a large number of NetStream entries, do not enable this feature. Otherwise, the device performance will be affected.
# Enable archiving of cached NetStream entries.
[Sysname] ip netstream cache archive enable
Use ip netstream export host to specify a destination host for NetStream data export.
Use undo ip netstream export host to remove the specified destination host or all destination hosts that are configured in the current view.
ip netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
undo ip netstream export host [ ipv4-address | ipv6-address ] [ vpn-instance vpn-instance-name ]
No destination host is specified for NetStream data export.
Ip4-address: Specifies the destination IPv4 address.
ipv6-address: Specifies the destination IPv6 address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
You can specify the same destination IP address and UDP port in different NetStream aggregation mode views. If an aggregation mode is not enabled, the display ip netstream export command cannot display the destination host configuration for the mode.
If no destination host is specified in a NetStream aggregation mode view, the destination host in system view applies. If destination hosts are specified in a NetStream aggregation view and system view, the destination hosts in aggregation view take effect.
You can specify a maximum of four destination hosts in system view or a NetStream aggregation mode view. If you specify a destination host with the same IP address but different UDP ports in the same view, the most recent configuration takes effect. You can specify destination hosts with the same IP address and UDP port but different VPN instances.
NetStream traditional data is exported to all destination hosts in system view. NetStream aggregation data is exported to all destination hosts in the related NetStream aggregation mode view. If you expect only the aggregation data, specify destination hosts only in the NetStream aggregation mode view. Aggregation data export reduces bandwidth usage.
# In system view, specify 172.16.105.48 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Sysname] ip netstream export host 172.16.105.48 5000
ip netstream export rate
Use ip netstream export rate to limit the NetStream data export rate.
Use undo ip netstream export rate to restore the default.
ip netstream export rate rate
The export rate of NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has space for new packets.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ip netstream export rate 10
Use ip netstream export source to specify the source interface for data packets sent to NetStream servers.
Use undo ip netstream export source to restore the default.
ip netstream export source interface interface-type interface-number
The packets take the IP address of the output interface as the source IP address.
interface-type interface-number: Specifies a source interface by its type and number.
The IP address of the specified source interface is used as the source IP address for packets sent to NetStream servers.
You can configure different source interfaces in different NetStream aggregation mode views.
If no source interface is configured in a NetStream aggregation mode view, the source interface in system view applies.
# In system view, specify Ten-GigabitEthernet 0/0/6 as the source interface for NetStream traditional data packets.
[Sysname] ip netstream export source interface ten-gigabitethernet 0/0/6
# In AS aggregation mode view, specify Ten-GigabitEthernet 0/0/7 as the source interface for NetStream aggregation data packets.
[Sysname-ns-aggregation-as] ip netstream export source interface ten-gigabitethernet 0/0/7
ip netstream export template refresh-rate
Use ip netstream export template refresh-rate to set the refresh rate for the NetStream version 9 or version 10 template.
Use undo ip netstream export template refresh-rate to restore the default.
ip netstream export template refresh-rate { packet packets | time minutes }
undo ip netstream export template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 and version 10 are template-based and support user-defined formats. A NetStream device must send the version 9 or version 10 template to NetStream servers regularly, because the servers do not permanently save the templates.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the Netstream version 9 or version 10 template to NetStream servers every 100 packets.
[Sysname] ip netstream export template refresh-rate packet 100
ip netstream export version
Use ip netstream export version 5 to export NetStream data in the version 5 format and choose whether to record AS information.
Use ip netstream export version 9 to export NetStream data in the version 9 format and configure the AS, BGP next hop export, and serial number attributes.
Use ip netstream export version 10 to export NetStream data in the version 10 format and configure the AS, BGP next hop export, and serial number attributes.
Use undo ip netstream export version to restore the default.
ip netstream export version 5 { origin-as | peer-as }
ip netstream export version { 9 | 10 } { origin-as | peer-as } [ bgp-nexthop ]
[ serial-number ]
NetStream traditional data export uses the version 9 format. The peer AS numbers are exported. The BGP next hop and serial number are not recorded.
origin-as: Records the source AS of the source address and the destination AS of the destination address.
peer-as: Records the ASs before and after the AS where the NetStream device resides as the source AS and destination AS, respectively.
bgp-nexthop: Records BGP next hops.
serial-number: Records device serial numbers.
A NetStream entry records the source IP address and destination IP address, and two AS numbers for each IP address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
You can also choose whether to record BGP next hop data and the serial number in the version 9 or version 10 format.
Only one version format can take effect on the device. If you execute the command multiple times, the most recent configuration takes effect.
If the version 5 format is configured, the NetStream aggregation data export uses the version 8 format.
If the version 9 format is configured, the NetStream aggregation data export uses the version 9 format.
If the version 10 format is configured, the NetStream aggregation data export uses the version 10 format.
# Configure the device to export NetStream data in the version 5 format and specify the NetStream data to include the source AS and destination AS.
[Sysname] ip netstream export version 5 origin-as
# Configure the device to export NetStream data in the version 9 format, specify the NetStream data to include the source AS and destination AS, and record the BGP next hop and serial number information.
[Sysname] ip netstream export version 9 origin-as bgp-nexthop serial-number
ip netstream filter
Use ip netstream filter to enable NetStream filtering on an interface.
Use undo ip netstream filter to disable NetStream filtering on an interface.
ip netstream { inbound | outbound } filter acl acl-number
undo ip netstream { inbound | outbound } filter
NetStream filtering is disabled. NetStream collects statistics about all IPv4 packets passing through an interface.
Interface view
inbound: Filters incoming traffic.
outbound: Filters outgoing traffic.
acl acl-number: Specifies an IPv4 ACL by its number. The value range is 2000 to 2999 for basic ACLs and 3000 to 3999 for advanced ACLs.
NetStream filtering uses an ACL to identify intended packets.
·     If you want to collect data for specific flows, use the ACL permit statements to identify the flows. NetStream collects data only for these flows.
·     If you do not want to collect data for specific flows, use the ACL deny statements to identify the flows. NetStream does not collect data for these flows.
When you use an ACL, follow these guidelines:
·     If you use a non-existent ACL or no rule is configured in the ACL, NetStream collects data for all inbound and outbound flows on the interface.
# Use ACL 2003 for outbound NetStream filtering on Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] ip netstream outbound
[Sysname-Ten-GigabitEthernet0/0/6] ip netstream outbound filter acl 2003
ip netstream ipsec raw-packet
Use ip netstream ipsec raw-packet to enable NetStream for incoming IPsec inner packets and disable NetStream for incoming IPsec encrypted packets.
Use undo ip netstream ipsec raw-packet to restore the default.
NetStream is disabled for incoming IPsec inner packets. NetStream is enabled for incoming IPsec encrypted packets.
Interface view
This command takes effect only after you enable NetStream in the inbound direction of the interface.
# Enable NetStream for incoming IPsec inner packets and disable NetStream for incoming IPsec encrypted packets on Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] ip netstream ipsec raw-packet
ip netstream max-entry
Use ip netstream max-entry to set the upper limit for NetStream entries or specify the processing method when the upper limit is reached.
Use undo ip netstream max-entry to restore the default.
ip netstream max-entry { max-entries | aging | disable-caching }
If the number of NetStream entries in the cache reaches the upper limit, the system disables creation of a new entry.
max-entries: Specifies the upper limit for NetStream entries that the cache can accommodate. The value range for this argument is 1000 to 2000000.
aging: Ages out the oldest entries when the upper limit is reached.
disable-caching: Disables creation of a new entry when the upper limit is reached.
The max-entries argument takes effect on each card.
If you execute the ip netstream max-entry max-entries command multiple times, the most recent configuration takes effect.
If you execute the ip netstream max-entry { aging | disable-caching } command multiple times, the most recent configuration takes effect.
# Set the upper limit to 5000 for NetStream entries.
[Sysname] ip netstream max-entry 5000
# Disable creation of a new entry when the upper limit is reached.
[Sysname] ip netstream max-entry disable-caching
# Configure the device to age out the oldest entries when the upper limit is reached.
[Sysname] ip netstream max-entry aging
ip netstream mpls
Use ip netstream mpls to enable MPLS packet statistics collection.
Use undo ip netstream mpls to disable MPLS packet statistics collection.
ip netstream mpls [ label-positions label-position1 [ label-position2 [ label-position3 [ label-position4 [ label-position5 [ label-position6 ] ] ] ] ] ] [ no-ip-fields ]
MPLS packet statistics collection is disabled.
label-positions: Specifies position of the labels to be counted.
label-position1: Specifies the label position in the label stack, in the range of 1 to 6, representing labels from the top label to the bottom label.
label-position2: Specifies the label position in the label stack. The value range is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified.
label-position3: Specifies the label position in the label stack. The value range is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified.
label-position4: Specifies the label position in the label stack. The value range is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified.
label-position5: Specifies the label position in the label stack. The value range is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified.
label-position6: Specifies the label position in the label stack. The value range is 1 to 6, representing labels from the top label to the bottom label. Do not specify the position that has been specified.
no-ip-fields: Specifies not to count IP fields.
This command enables statistics collection of MPLS packets for both IPv4 and IPv6 NetStream.
If you do not specify any keywords or options, the top label and IP fields are counted.
If multiple labels are to be counted, the label positions specified cannot be the same and are in ascending order.
# Enable NetStream for MPLS packets with top label counted but without IP fields.
[Sysname] ip netstream mpls no-ip-fields
ip netstream sampler
Use ip netstream sampler to enable NetStream sampling.
Use undo ip netstream sampler to disable NetStream sampling.
ip netstream { inbound | outbound } sampler sampler-name
undo ip netstream { inbound | outbound } sampler
NetStream sampling is disabled.
Interface view
inbound: Enables NetStream sampling in the inbound direction.
outbound: Enables NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
NetStream sampling allows you to collect basically accurate network statistics and decrease the NetStream traffic volume. The decreased traffic lessens the impact on the device forwarding performance. The higher the sampling rate, the less impact on device performance.
# Use sampler abc for inbound NetStream sampling on Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] ip netstream inbound sampler abc
ip netstream outbound sampler srv6-policy
Use ip netstream outbound sampler srv6-policy to enable NetStream sampling for an SRv6-TE policy.
Use undo ip netstream outbound sampler srv6-policy to disable NetStream sampling for an SRv6-TE policy.
ip netstream outbound sampler sampler-name srv6-policy end-point ipv6 ipv6-address color color-value
undo ip netstream outbound sampler sampler-name srv6-policy end-point ipv6 ipv6-address color color-value
NetStream sampling is disabled for an SRv6-TE policy.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the destination node for an SRv6-TE policy.
color color-value: Specifies the color for an SRv6-TE policy, in the range of 0 to 4294967295.
Execute this command on the ingress node for an SRv6-TE policy to enable NetStream to sample the outgoing traffic forwarded based on that SRv6-TE policy. For more information about SRv6-TE policies, see Segment Routing Configuration Guide.
# Enable NetStream sampling by using sampler abc for the SRv6-TE policy whose destination node is at 1000::1 and color is 10.
[Sysname] ip netstream outbound sampler abc srv6-policy end-point ipv6 1000::1 color 10
ip netstream outbound srv6-policy
Use ip netstream outbound srv6-policy to enable NetStream for an SRv6-TE policy.
Use undo ip netstream outbound srv6-policy to disable NetStream for an SRv6-TE policy.
ip netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
undo ip netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
NetStream is disabled for an SRv6-TE policy.
Execute this command on the ingress node for an SRv6-TE policy to enable NetStream to collect statistics about the outgoing traffic forwarded based on that SRv6-TE policy. For more information about SRv6-TE policies, see Segment Routing Configuration Guide.
# Enable NetStream for the SRv6-TE policy whose destination node is at 1000::1 and color is 10.
[Sysname] ip netstream outbound srv6-policy end-point ipv6 1000::1 color 10
ip netstream template rfc7011
Use ip netstream template rfc7011 to specify the RFC 7011-compliant template format.
Use undo ip netstream template rfc7011 to restore the default.
NetStream uses the H3C-defined template format.
This command enables NetStream to use the template format defined by the RFC 7011 for data export. Make sure the NetStream template format on the device is consistent with that on the server.
This command applies to both IPv4 and IPv6 NetStream templates.
# Specify the RFC 7011-compliant template format.
[Sysname] ip netstream template rfc7011
ip netstream timeout active
Use ip netstream timeout active to set the aging timer for active flows.
Use undo ip netstream timeout active to restore the default.
ip netstream timeout active minutes
The aging timer is 30 minutes for active flows.
minutes: Sets the aging timer for active flows, in the range of 1 to 60 minutes.
A flow is considered active if packets for the NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 60 minutes for active flows.
[Sysname] ip netstream timeout active 60
ip netstream timeout inactive
Use ip netstream timeout inactive to set the aging timer for inactive flows.
Use undo ip netstream timeout inactive to restore the default.
ip netstream timeout inactive seconds
The aging timer is 30 seconds for inactive flows.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 600 seconds.
A flow is considered inactive if no packet for the NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ip netstream timeout inactive 60
ip netstream vxlan udp-port
Use ip netstream vxlan udp-port to enable VXLAN packet statistics collection.
Use undo ip netstream vxlan udp-port to disable VXLAN packet statistics collection.
ip netstream vxlan udp-port port-number
VXLAN packet statistics collection is disabled.
port-number: Specifies the destination UDP port number carried in VXLAN packets. The value range is 1 to 65535.
The value of the port-number argument must be the same as the destination UDP port number carried in the VXLAN packets.
With VXLAN packet statistics collection enabled, NetStream collects statistics about VXLAN packets that carry the specified destination UDP port number. To view the VXLAN packet statistics, see the VNI field in the display ip netstream cache command output.
For more information about for VXLAN packets, see VXLAN Configuration Guide.
# Enable NetStream to collect statistics for VXLAN packets that carry destination UDP port number 2.
[Sysname] ip netstream vxlan udp-port 2
Use reset ip netstream statistics to clear the NetStream cache and export the cached entries to NetStream servers.
It takes the system several minutes to execute the command. During this period, the system does not collect NetStream data.
# Clear the NetStream cache and export the cached data to NetStream servers.
<Sysname> reset ip netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
snmp-agent trap enable ip netstream
Use snmp-agent trap enable ip netstream to enable SNMP notifications for NetStream.
Use undo snmp-agent trap enable ip netstream to disable SNMP notifications for NetStream.
snmp-agent trap enable ip netstream [ entry-limit ]
undo snmp-agent trap enable ip netstream [ entry-limit ]
SNMP notifications are enabled for NetStream.
entry-limit: Generates an alarm when the number of cached NetStream entries exceeds 80% or drops below 70% of the maximum permitted value. If you do not specify this keyword, the system enables or disables all SNMP notifications for NetStream.
To configure the maximum supported number of cached NetStream entries, enter system view and execute the ip netstream max-entry command.
Use this feature to report important events for NetStream through SNMP notifications. The generated alarm information will be sent to the SNMP module on the device and you can configure the SNMP notification sending parameters to determine the export attributes of the alarm information. For more information, see "Configuring SNMP."
# Enable SNMP notifications for NetStream.
[Sysname] snmp-agent trap enable ip netstream
