17-NAT and IPv6 Transition Technologies Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)- R9141-6W10017-NAT and IPv6 Transition Technologies Command Reference
02-AFT commands
02-AFT commands 201.00 KB
AFT commands
address
Use address to add an address range to an AFT address group.
Use undo address to remove an address range from an AFT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
AFT address group view
start-address end-address: Specifies the start and end IP addresses for an address range. The end address cannot be lower than the start address. If they are the same, the address range has only one IP address. Each address range can contain a maximum of 256 addresses.
An AFT address group is a set of address ranges. Dynamic AFT translates an IPv6 address to an IPv4 address in one of the address ranges.
You can repeat this command to add multiple address ranges to an AFT address group. Make sure the address ranges do not overlap in the AFT address group.  The device supports a maximum of 4096 address ranges in total for all AFT address groups.
# Add two address ranges to AFT address group 2.
[Sysname] aft address-group 2
[Sysname-aft-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-aft-address-group-2] address 10.1.1.20 10.1.1.30
aft address-group
aft address-group
Use aft address-group to create an AFT address group and enter its view, or enter the view of an existing AFT address group.
Use undo aft address-group to delete an AFT address group.
aft address-group group-id
undo aft address-group group-id
No AFT address groups exist.
group-id: Assigns an ID to the address group. The value range for this argument is 0 to 65535.
An AFT address group is a set of address ranges. Use the address command to add an address range.
The AFT address group is used in dynamic AFT. Dynamic AFT translates the source address of an IPv6 packet to an IPv4 address in the address group.
# Create AFT address group 1 and enter its view.
[Sysname] aft address-group 1
[Sysname-aft-address-group-1]
address
aft v6tov4 source
display aft address-group
display aft configuration
aft alg
Use aft alg to enable AFT ALG for the specified or all supported protocols.
Use undo aft alg to disable AFT ALG for the specified or all supported protocols.
aft alg { all | dns | ftp | http | icmp-error }
undo aft alg { all | dns | ftp | http | icmp-error }
AFT ALG is enabled for DNS, FTP, ICMP error messages, and HTTP.
all: Enables AFT ALG for all supported protocols.
dns: Enables AFT ALG for DNS.
ftp: Enables AFT ALG for FTP.
http: Enables AFT ALG for HTTP.
icmp-error: Enables AFT ALG for ICMP error packets.
AFT ALG translates address or port information in the application layer payload.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires AFT ALG to translate the address and port information.
You can execute this command multiple times to enable AFT ALG for different protocols.
# Enable AFT ALG for FTP.
[Sysname] aft alg ftp
aft enable
Use aft enable to enable AFT on an interface.
Use undo aft enable to disable AFT on an interface.
aft enable
undo aft enable
AFT is disabled on an interface.
Interface view
You must enable AFT on interfaces connected to the IPv4 network and interfaces connected to the IPv6 network.
# Enable AFT on Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] aft enable
aft log enable
Use aft log enable to enable AFT logging.
Use undo aft log enable to disable AFT logging.
aft log enable
undo aft log enable
AFT logging is disabled.
For security auditing, you can enable AFT logging to record AFT session information. An AFT session is a session whose source and destination IP addresses are translated by AFT.
AFT can log the following events:
·     An AFT port block is assigned.
To log AFT port block assignments, you must also execute the aft log port-block-assign command.
·     An AFT port block is withdrawn.
To log AFT port block withdrawals, you must also execute the aft log port-block-withdraw command.
·     An AFT port allocation fails.
To log AFT port allocation failures, you must also execute the aft log port-alloc-fail command.
·     An AFT session is established.
To log AFT session establishment events, you must also execute the aft log flow-begin command.
·     An AFT session is removed.
To log AFT session removal events, you must also execute the aft log flow-end command.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see System Management Configuration Guide.
# Enable AFT logging.
[Sysname] aft log enable
aft log flow-begin
aft log flow-end
aft log flow-begin
Use aft log flow-begin to enable AFT session establishment logging.
Use undo aft log flow-begin to disable AFT session establishment logging.
aft log flow-begin
AFT session establishment logging is disabled.
This feature enables the AFT module to generate a log entry for every AFT session establishment event.
AFT session establishment logging takes effect only after you enable AFT logging.
# Enable AFT session establishment logging.
[Sysname] aft log flow-begin
aft log enable
aft log flow-end
aft log flow-end
Use aft log flow-end to enable AFT session removal logging.
Use undo aft log flow-end to disable AFT session removal logging.
aft log flow-end
AFT session removal logging is disabled.
This feature enables the AFT module to generate a log entry for every AFT session removal event.
AFT session removal logging takes effect only after you enable AFT logging.
# Enable AFT session removal logging.
[Sysname] aft log flow-end
aft log enable
aft log flow-begin
aft port-block flow-trigger enable
Use aft port-block flow-trigger enable to enable flow-triggered port block assignment.
Use undo aft port-block flow-trigger enable to disable flow-triggered port block assignment.
Flow-triggered port block assignment is disabled.
For port block-based dynamic AFT, this feature allocates address and port block resources to IPv6 hosts. When an IPv6 host initiates a connection, the device allocates an IPv4 address and a port block for address translation. AFT translates the IPv6 address to the IPv4 address, and source ports to ports in the port block for subsequent connections from the IPv6 host until the ports in the port block are exhausted.
You cannot modify the enabling status of flow-triggered port block assignment if a user is online or AFT translation entries exist.
# Enable flow-triggered port block assignment.
[Sysname] aft port-block flow-trigger enable
aft prefix-general
Use aft prefix-general to configure a general prefix.
Use undo aft prefix-general to delete a general prefix.
aft prefix-general prefix-general prefix-length
undo aft prefix-general prefix-general prefix-length
No general prefixes exist.
prefix-general: Specifies the general prefix.
prefix-length: Specifies the prefix length. The value for this argument can be 32, 40, 48, 56, 64, or 96.
A general prefix is an IPv6 address prefix of 32, 40, 48, 56, 64, or 96 bits. A general prefix can be used for source and destination address translation between IPv4 and IPv6.
When a general prefix is used alone, it provides IPv6-to-IPv4 source and destination address translation. If a source or destination IPv6 address matches the general prefix, AFT translates it to the embedded IPv4 address.
When a general prefix is used in the aft v4tov6 source or aft v4tov6 destination command, it provides IPv4-to-IPv6 source or destination address translation. If a source or destination IPv4 address matches the ACL, AFT constructs the IPv6 address by using the general prefix and the IPv4 address.
A general prefix cannot be on the same subnet as any interface on the device.
A general prefix must be different from a NAT64 prefix or an IVI prefix.
# Specify 2000:db8e:: as a general prefix and set its prefix length to 32.
[Sysname] aft prefix-general 2000:db8e:: 32
aft v4tov6 source
aft prefix-ivi
Use aft prefix-ivi to configure an IVI prefix.
Use undo aft prefix-ivi to delete an IVI prefix.
aft prefix-ivi prefix-ivi
undo aft prefix-ivi prefix-ivi
No IVI prefixes exist.
prefix-ivi: Specifies an IVI prefix.
An IVI prefix is an IPv6 address prefix whose length is fixed at 32 bits. An IVI prefix can be used for IPv6-to-IPv4 source address translation and IPv4-to-IPv6 destination address translation.
When an IVI prefix is used alone, it provides IPv6-to-IPv4 source address translation. If a source IPv6 address matches the IVI prefix, AFT translates it to the embedded IPv4 address.
When an IVI prefix is used in the aft v4tov6 destination command, it provides IPv4-to-IPv6 destination address translation. If a destination IPv4 address matches the ACL, AFT constructs the IPv6 address by using the IVI prefix and the IPv4 address.
An IVI prefix must be different from a NAT64 prefix or a general prefix.
# Specify 3000:db8e:: as an IVI prefix.
[Sysname] aft prefix-ivi 3000:db8e::
aft prefix-nat64
Use aft prefix-nat64 to configure a NAT64 prefix.
Use undo aft prefix-nat64 to delete a NAT64 prefix.
aft prefix-nat64 prefix-nat64 prefix-length
undo aft prefix-nat64 prefix-nat64 prefix-length
No NAT64 prefixes exist.
prefix-nat64: Specifies a NAT64 prefix.
prefix-length: Specifies the NAT64 prefix length. The value for this argument can be 32, 40, 48, 56, 64, or 96.
A NAT64 prefix is an IPv6 address prefix of 32, 40, 48, 56, 64, or 96 bits. A NAT64 prefix can be used for IPv4-to-IPv6 source address translation and IPv6-to-IPv4 destination address translation.
When a NAT64 prefix is used alone, it provides IPv6-to-IPv4 destination address translation. If a destination IPv6 address matches the NAT64 prefix, AFT translates it to the embedded IPv4 address.
When a NAT64 prefix is used alone or in the aft v4tov6 source command, it also provides IPv4-to-IPv6 source address translation. AFT constructs the IPv6 address by using the NAT64 prefix and the source IPv4 address. If the NAT64 prefix is used in the aft v4tov6 source command, AFT only translates packets permitted by the ACL.
When you configure a 96-bit NAT64 prefix, make sure bits 64 through 71 are all 0.
A NAT64 prefix cannot be on the same subnet as any of the interfaces on the device.
A NAT64 prefix must be different from an IVI prefix or a general prefix.
# Specify 2000:db8e:: as a NAT64 prefix and set its prefix length to 32.
[Sysname] aft prefix-nat64 2000:db8e:: 32
aft v4tov6 source
aft turn-off tos
Use aft turn-off tos to set the ToS field to 0 for IPv4 packets translated from IPv6 packets.
Use undo aft turn-off tos to restore the default.
aft turn-off tos
The ToS field value of translated IPv4 packets is the same as the Traffic Class field value of original IPv6 packets.
# Set the ToS field to 0 for IPv4 packets translated from IPv6 packets.
[Sysname] aft turn-off tos
aft turn-off traffic-class
Use aft turn-off traffic-class to set the Traffic Class field to 0 for IPv6 packets translated from IPv4 packets.
Use undo aft turn-off traffic-class to restore the default.
The Traffic Class field value of translated IPv6 packets is the same as the ToS field value of original IPv4 packets.
# Set the Traffic Class field to 0 for IPv6 packets translated from IPv4 packets.
[Sysname] aft turn-off traffic-class
Use aft v4tov6 destination to configure an IPv4-to-IPv6 destination address translation policy.
Use undo aft v4tov6 destination to delete an IPv4-to-IPv6 destination address translation policy.
aft v4tov6 destination acl { name ipv4-acl-name prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-ivi prefix-ivi [ vpn-instance ipv6-vpn-instance-name ] } }
undo aft v4tov6 destination acl { name ipv4-acl-name | number ipv4-acl-number }
No IPv4-to-IPv6 destination address translation policies exist.
acl: Identifies IPv4 packets for address translation. AFT translates destination addresses for IPv4 packets permitted by the ACL.
name ipv4-acl-name: Specifies an IPv4 ACL by its name. The ipv4-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
number ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
prefix-general prefix-general prefix-length: Specifies a general prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the general prefix to translate destination addresses for packets permitted by the ACL.
prefix-ivi prefix-ivi: Specifies an IVI prefix. AFT uses the IVI prefix to translate destination addresses for packets permitted by the ACL.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance to which translated IPv6 addresses belong. The ipv6-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv6 addresses belong to the public network, do not specify this option.
You must specify different ACLs for different IPv4-to-IPv6 destination address translation policies.
You can specify a nonexistent IVI prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
# Configure the device to use IVI prefix 3000:db8e:: to translate IPv4 destination addresses to IPv6 for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 destination acl number 2000 prefix-ivi 3000:db8e::
# Configure the device to use general prefix 2000:db8e::/32 to translate IPv4 destination addresses to IPv6 for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 destination acl number 2000 prefix-general 2000:db8e:: 32
aft prefix-general
aft prefix-ivi
aft v4tov6 source
Use aft v4tov6 source to configure an IPv4-to-IPv6 source address translation policy.
Use undo aft v4tov6 source to delete an IPv4-to-IPv6 source address translation policy.
Static IPv4-to-IPv6 source address mapping:
aft v4tov6 source ipv4-address [ vpn-instance ipv4-vpn-instance-name ] ipv6-address [ vpn-instance ipv6-vpn-instance-name ]
undo aft v4tov6 source ipv4-address [ vpn-instance ipv4-vpn-instance-name ]
IPv4-to-IPv6 source address translation policy using a NAT64 prefix or general prefix:
aft v4tov6 source acl { name ipv4-acl-name prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] | number ipv4-acl-number { prefix-general prefix-general prefix-length | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] } }
undo aft v4tov6 source acl { name ipv4-acl-name | number ipv4-acl-number }
No IPv4-to-IPv6 source address translation policies exist.
ipv4-address: Specifies an IPv4 address.
vpn-instance ipv4-vpn-instance-name: Specifies an IPv4 MPLS L3VPN instance to which the IPv4 address belongs. The ipv4-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv4 address belongs to the public network, do not specify this option.
ipv6-address: Specifies an IPv6 address. The IPv6 address cannot be on the same subnet as any interface on the device.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance to which the IPv6 address belongs. The ipv6-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the IPv6 address belongs to the public network, do not specify this option.
acl: Identifies IPv4 packets for address translation. AFT translates source addresses for packets permitted by the ACL.
prefix-general prefix-general prefix-length: Specifies a general prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the general prefix to translate source IPv4 address for packets permitted by the ACL.
prefix-nat64 prefix-nat64 prefix-length: Specifies a NAT64 prefix and its prefix length. The value for the prefix-length argument can be 32, 40, 48, 56, 64, or 96. AFT uses the NAT64 prefix to translate source IPv4 address for packets permitted by the ACL.
The IPv4 and IPv6 addresses in different static mappings must be both unique.
You must specify different ACLs for IPv4-to-IPv6 source address translation policies that use NAT64 prefixes or general prefixes.
You can specify a nonexistent NAT64 prefix or general prefix in a policy, but the policy takes effect only after you configure the prefix.
# Map IPv4 source address 2.2.2.123 to IPv6 source address 3001::5.
[Sysname] aft v4tov6 source 2.2.2.123 3001::5
# Configure the device to use NAT64 prefix 2000::/32 to translate IPv4 source addresses to IPv6 addresses for IPv4 packets permitted by ACL 2000.
[Sysname] aft prefix-nat64 2000:: 32
[Sysname] aft v4tov6 source acl number 2000 prefix-nat64 2000:: 32
# Configure the device to use general prefix 3000::/32 to translate IPv4 source addresses to IPv6 for IPv4 packets permitted by ACL 2000.
[Sysname] aft v4tov6 source acl number 2000 prefix-general 3000:: 32
aft prefix-general
aft prefix-nat64
aft v6server
Use aft v6server to configure an AFT mapping for an IPv6 internal server.
Use undo aft v6server to delete an AFT mapping for an IPv6 internal server.
aft v6server protocol protocol-type ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ] ipv6-destination-address ipv6-port-number [ vpn-instance ipv6-vpn-instance-name ]
undo aft v6server protocol protocol-type ipv4-destination-address ipv4-port-number [ vpn-instance ipv4-vpn-instance-name ]
The IPv6 internal server does not have an AFT mapping.
protocol protocol-type: Specifies a transport layer protocol by its type. The protocol-type argument can be tcp or udp.
ipv4-destination-address: Specifies an IPv4 address.
ipv4-port-number: Specifies an IPv4 port number in the range of 1 to 65535.
ipv6-destination-address: Specifies an IPv6 address.
ipv6-port-number: Specifies an IPv6 port number in the range of 1 to 65535.
The AFT mappings for different IPv6 internal servers cannot be the same.
# Map IPv6 address 3001::5 and port number 1720 of an IPv6 internal server to IPv4 address 2.2.2.123 and port number 1720 for TCP packets.
[Sysname] aft v6server protocol tcp 2.2.2.123 1720 3001::5 1720
aft v6tov4 source
Use aft v6tov4 source to configure an IPv6-to-IPv4 source address translation policy.
Use undo aft v6tov4 source to delete an IPv6-to-IPv4 source address translation policy.
Static IPv6-to-IPv4 source address mapping:
aft v6tov4 source ipv6-address [ vpn-instance ipv6-vpn-instance-name ] ipv4-address [ vpn-instance ipv4-vpn-instance-name ]
undo aft v6tov4 source ipv6-address [ vpn-instance ipv6-vpn-instance-name ]
Dynamic IPv6-to-IPv4 source address translation policy:
aft v6tov4 source { acl ipv6 { name ipv6-acl-name | number ipv6-acl-number } | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] } { address-group group-id [ no-pat | port-block-size blocksize ] | interface interface-type interface-number } [ vpn-instance ipv4-vpn-instance-name ]
undo aft v6tov4 source { acl ipv6 { name ipv6-acl-name | number ipv6-acl-number } | prefix-nat64 prefix-nat64 prefix-length [ vpn-instance ipv6-vpn-instance-name ] }
No IPv6-to-IPv4 source address translation policies exist.
acl ipv6: Identifies IPv6 packets for address translation. AFT translates source addresses for IPv6 packets permitted by the ACL.
name ipv6-acl-name: Specifies an IPv6 ACL by its name. The ipv6-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
number ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
prefix-nat64 prefix-nat64 prefix-length: Specifies a NAT64 prefix and its prefix length. The prefix-length argument represents a prefix length, which can be 32, 40, 48, 56, 64, or 96. AFT translates source IPv6 addresses for packets whose destination IPv6 addresses match the NAT64 prefix.
address-group group-id: Specifies an AFT address group by its ID in the range of 0 to 65535.
no-pat: Specifies the NO-PAT mode. If you do not specify the keyword, AFT uses the PAT mode.
port-block-size blocksize: Specifies the port block size in the range of 100 to 64512. If you do not specify the option, the port range will not be divided.
interface interface-type interface-number: Specifies an interface by its type and number. AFT translates source IPv6 addresses to the primary IPv4 address of the specified interface.
If you set a port block size, the port range (1024 to 65535) will be divided into port blocks by the port block size. For example, if you set the port block size to 1000, the port range is divided into port blocks 1024 to 2023, 2024 to 3023, and so on. The port blocks are used for PAT.
The IPv4 or IPv6 addresses in different static mappings cannot be the same.
When you specify AFT address groups, ACLs, and NAT64 prefixes, follow these guidelines:
·     If you specify an ACL and an AFT address group in a translation policy, do not repeat this command to change the AFT address group. To change the AFT address group, delete the translation policy and reconfigure it with the ACL and new AFT address group.
·     If you specify a NAT64 prefix and an AFT address group in a translation policy, do not repeat this command to change the AFT address group. To change the AFT address group, delete the translation policy and reconfigure it with the NAT64 prefix and new AFT address group.
You can specify a nonexistent NAT64 prefix in a policy, but the policy takes effect only after you configure the prefix.
·     You can specify the same AFT address group in translation policies that use different ACLs or NAT64 prefixes.
# Map source IPv6 address 3001::5 to source IPv4 address 2.2.2.123.
[Sysname] aft v6tov4 source 3001::5 2.2.2.123
# Configure the device to use AFT address group 0 to translate IPv6 source addresses to IPv4 address for IPv6 packets permitted by ACL 2000.
[Sysname] aft v6tov4 source acl ipv6 number 2000 address-group 0 port-block-size 100
display aft port-block
Use display aft address-group to display AFT address group information.
display aft address-group [ group-id ]
View
group-id: Specifies an AFT address group ID in the range of 0 to 65535. If you do not specify this argument, the command displays information about all AFT address groups.
# Display information about all AFT address groups.
<Sysname> display aft address-group
There are 3 AFT address groups.
Group ID           Start address         End address
1                  202.110.10.10         202.110.10.15
2                  202.110.10.20         202.110.10.25
                   202.110.10.30         202.110.10.35
6                  ---                   ---
# Display information about AFT address group 1.
<Sysname> display aft address-group 1
There are n AFT address groups
Total number of existing AFT address groups.
Group ID
Address group ID.
Start address
Start IP address of an address range. If you do not specify the start address, this field displays three hyphens (---).
End address
End IP address of an address range. If you do not specify the end address, this field displays three hyphens (---).
display aft address-mapping
Use display aft address-mapping to display AFT mappings.
display aft address-mapping [ slot slot-number ]
View
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays AFT mappings for all cards.
# Display AFT mappings.
<Sysname> display aft address-mapping
Slot 1:
IPv6: Source IP/port: 2000:0:FF01:101:100::8/1024
      Destination IP/port: 5000::1717:1714/1025
      Protocol: TCP(6)
IPv4: Source IP/port: 1.1.1.1/1031
      Destination IP/port: 23.23.23.20/1025
      Protocol: TCP(6)
Total address mapping found: 1
IPv4
IPv4 address information.
IPv6
IPv6 address information.
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs. ‌
·     VLAN ID—VLAN to which the session belongs for Layer 2 forwarding.
·     Inline ID—INLINE to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or Inline ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, ICMPv6, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Use display aft configuration to display AFT configuration.
# Display AFT configuration.
<Sysname> display aft configuration
aft address-group 1
 address 202.110.10.10 202.110.10.15
 address 101.1.1.100 101.1.1.200
aft prefix-ivi 3000:DB8E::
aft prefix-general 2000:DB8E:: 32
aft v4tov6 destination acl number 2000 prefix-ivi 3000:DB8E::
aft turn-off tos
aft log enable
aft log flow-begin
aft log flow-end
interface Ten-GigabitEthernet0/0/6
  aft enable
AFT ALG:
  DNS        : Enabled
  FTP        : Enabled
  HTTP       : Enabled
  ICMP-ERROR : Enabled
aft address-group XX
AFT address group ID.
address
Address range of AFT address group.
aft prefix-nat64 X:X::X:X
NAT64 prefix.
aft prefix-ivi X:X::X:X
IVI prefix.
aft prefix-general X:X::X:X
General prefix.
Information about the IPv6-to-IPv4 source address translation policy:
·     number—Number of the IPv6 ACL.
·     name—Name of the IPv6 ACL.
·     address-group—ID of the AFT address group.
·     port-block-size—Port block size.
Information about the IPv4-to-IPv6 source address translation policy:
·     number—Number of the IPv4 ACL.
·     name—Name of the IPv4 ACL.
·     prefix-nat64—NAT64 prefix and its prefix length.
·     prefix-ivi—IVI prefix.
An AFT mapping is configured for an IPv6 internal server.
aft turn-off tos
The ToS field is set to 0 for IPv4 packets translated from IPv6 packets
The Traffic Class field is set to 0 for IPv6 packets translated from IPv4 packets.
aft log enable
AFT logging is enabled.
aft log flow-begin
AFT session establishment logging is enabled.
aft log flow-end
AFT session removal logging is enabled.
AFT port block assignment logging is enabled.
AFT port block withdrawal logging is enabled.
AFT port allocation failure logging is enabled.
aft v6tov4 source XX::XX
Source IPv6 address for address translation.
Interface on which AFT is enabled.
aft enable
AFT is enabled.
AFT ALG
AFT ALG status: Enabled or Disabled.
display aft no-pat
Use display aft no-pat to display AFT NO-PAT entries.
display aft no-pat [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays AFT NO-PAT entries for all cards.
An AFT NO-PAT entry records a mapping between an IPv4 address and an IPv6 address without ports.
# Display AFT NO-PAT entries.
<Sysname> display aft no-pat
Slot 1:
IPv6 address: 3006::0002
IPv4 address: 200.100.1.100
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
IPv6 address: 4016::1102
IPv4 address: 202.120.12.110
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Total entries found: 2
IPv6 address
Original IPv6 address.
IPv4 address
Translated IPv4 address.
IPv4 VPN
VPN instance to which the translated IPv4 address belongs. If the IPv4 address does not belong to a VPN instance, this field is not displayed.
IPv6 VPN
VPN instance to which the original IPv6 address belongs. If the IPv6 address does not belong to a VPN instance, this field is not displayed.
Total entries found
Total number of AFT NO-PAT entries.
Use display aft port-block to display AFT port block mappings.
display aft port-block [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays AFT port block mappings for all cards.
# Display AFT port block mappings.
<Sysname> display aft port-block
Slot 1:
Port block  : [1024 – 1123]
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Port block  : [1024 – 1200]
IPv4 VPN    : vpn2
IPv6 VPN    : vpn1
Table 5 Command output
IPv6 address
IPv4 address
Port block
Port range for the translated IPv4 address.
IPv4 VPN
IPv6 VPN
Total entries found
Total number of AFT port block mapping entries.
display aft session
Use display aft session to display AFT sessions.
display aft session ipv4 [ { source-ip source-ip-address | destination-ip destination-ip-address } * [ vpn-instance ipv4-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
display aft session ipv6 [ { source-ip source-ipv6-address | destination-ip destination-ipv6-address } * [ vpn-instance ipv6-vpn-instance-name ] ] [ slot slot-number ] [ verbose ]
ipv4: Displays IPv4 AFT sessions.
source-ip source-ip-address: Specifies the source IPv4 address of the packets that initiate AFT sessions.
destination-ip destination-ip-address: Specifies the destination IPv4 address of the packets that initiate AFT sessions.
vpn-instance ipv4-vpn-instance-name: Specifies an IPv4 MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays AFT sessions for the public network.
ipv6: Displays IPv6 AFT sessions.
source-ip source-ipv6-address: Specifies the source IPv6 address of the packets that initiate AFT sessions.
destination-ip destination-ipv6-address: Specifies the destination IPv6 address of the packets that initiate AFT sessions.
vpn-instance ipv6-vpn-instance-name: Specifies an IPv6 MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays AFT sessions for the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays AFT sessions for all cards.
verbose: Display detailed information about AFT sessions. If you do not specify this keyword, this command displays brief information about AFT sessions.
If you do not specify any parameters, this command displays all AFT sessions.
# Display detailed information about AFT sessions for the specified slot.
<Sysname> display aft session ipv4 slot 1 verbose
Slot 1:
Initiator:
  Source IP/port: 192.168.1.18/1877
  Destination IP/port: 102.128.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/6
Responder:
  Source IP/port: 102.128.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/7
State: TCP_SYN_SENT
Application: SSH
Start time: 2020-02-13 19:12:36    TTL: 28s
Initiator->Responder:            1 packets         48 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
Table 6 Command output
Initiator
Session information about the initiator.
Source IP/port
Destination IP/port
DS-Lite tunnel peer
Address of the B4 end on the DS-Lite tunnel. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
If no VPN instance, VLAN ID, or inline ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Inbound interface
Input interface.
Responder
Session information about the responder.
APP
Application layer protocol, such as FTP and DNS.
This field displays unknown for the protocol types that are identified by non-well-known ports and are not user-defined.
AFT session state.
Start time
Time when the session starts.
TTL
Remaining lifetime of the session, in seconds.
Number of packets and bytes from the initiator to the responder.
Number of packets and bytes from the responder to the initiator.
Total number of AFT sessions.
reset aft session
display aft statistics
Use display aft statistics to display AFT statistics.
display aft statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays AFT statistics for all cards.
If you do not specify any parameters, this command displays all AFT statistics.
# Display AFT statistics for the specified slot.
<Sysname> display aft statistics slot 1
Slot 1:
Total NO-PAT entries found: 0
Total port-block entries found: 0
Total IPv4 sessions: 0
Total IPv6 sessions: 0
Table 7 Command output
Total number of AFT port block mappings.
Total IPv4 sessions
Total number of IPv4 sessions created by AFT.
Total IPv6 sessions
Total number of IPv6 sessions created by AFT.
reset aft session
Use reset aft session to delete AFT sessions.
reset aft session [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command deletes AFT sessions for all cards.
After you delete AFT sessions, the corresponding AFT NO-PAT entries and port block mappings are also deleted.
# Delete AFT sessions for the specified slot.
<Sysname> reset aft session slot 1
display aft session
