11-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6526XE-HI[EI] Switch Series Command References-R8340Pxx-6W10011-Security Command Reference
14-SSL commands
14-SSL commands 131.18 KB
SSL commands
certificate-chain-sending enable
Use certificate-chain-sending enable to enable the SSL server to send the complete certificate chain to the client during SSL negotiation.
Use undo certificate-chain-sending enable to restore the default.
During SSL negotiation, the SSL server sends the server certificate rather than the complete certificate chain to the client.
SSL server policy view
This feature causes additional overheads in the SSL negotiation process. Enable it only when the SSL client does not have the complete certificate chain to verify the server certificate.
# Enable the SSL server to send the complete certificate chain to the client during SSL negotiation.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] certificate-chain-sending enable
display ssl server-policy
ciphersuite
Use ciphersuite to specify the cipher suites supported by an SSL server policy.
Use undo ciphersuite to restore the default.
In non-FIPS mode:
ciphersuite { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha } *
undo ciphersuite
In FIPS mode:
ciphersuite { ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 } *
undo ciphersuite
An SSL server policy supports all cipher suites.
dhe_rsa_aes_128_cbc_sha: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
dhe_rsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
dhe_rsa_aes_256_cbc_sha: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA.
dhe_rsa_aes_256_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA256.
ecdhe_ecdsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
ecdhe_ecdsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
ecdhe_ecdsa_aes_256_cbc_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA384.
ecdhe_ecdsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
ecdhe_rsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
ecdhe_rsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
ecdhe_rsa_aes_256_cbc_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA384.
ecdhe_rsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
exp_rsa_des_cbc_sha: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm DES_CBC, and MAC algorithm SHA.
exp_rsa_rc2_md5: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm RC2, and MAC algorithm MD5.
exp_rsa_rc4_md5: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm RC4, and MAC algorithm MD5.
rsa_3des_ede_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 3DES_EDE_CBC, and MAC algorithm SHA.
rsa_aes_128_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
rsa_aes_128_cbc_ sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
rsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
rsa_aes_256_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA.
rsa_aes_256_cbc_ sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA256.
rsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
rsa_des_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm DES_CBC, and MAC algorithm SHA.
rsa_rc4_128_md5: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm MD5.
rsa_rc4_128_sha: Specifies key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm SHA.
SSL employs the following algorithms:
·     Data encryption algorithms—Encrypt data to ensure privacy. Commonly used data encryption algorithms are symmetric key algorithms. When a symmetric key algorithm is used, the SSL server and the SSL client must use the same key.
·     Message Authentication Code (MAC) algorithms—Calculate the MAC value for data to ensure integrity. Commonly used MAC algorithms include MD5 and SHA. When a MAC algorithm is used, the SSL server and the SSL client must use the same key.
·     Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and the MAC algorithm. Commonly used key exchange algorithms are usually asymmetric key algorithms, such as RSA.
After the SSL server receives a cipher suite from a client, the server matches the received cipher suite against the cipher suits it supports. If a match is found, the cipher suite negotiation succeeds. Otherwise, the negotiation fails.
# Configure SSL server policy policy1 to support the following cipher suites:
·     Key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
·     Key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
[Sysname-ssl-server-policy-policy1] ciphersuite dhe_rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha
prefer-cipher
client-verify
Use client-verify to enable mandatory or optional SSL client authentication.
Use undo client-verify to restore the default.
undo client-verify
SSL client authentication is disabled. The SSL server does not authenticate SSL clients based on digital certificates.
enable: Enables mandatory SSL client authentication.
optional: Enables optional SSL client authentication.
SSL uses digital certificates to authenticate communicating parties. For more information about digital certificates, see Security Configuration Guide.
Mandatory SSL client authentication—The SSL server requires an SSL client to submit its digital certificate for identity authentication. The SSL client can access the SSL server only after it passes identity authentication.
Optional SSL client authentication—The SSL server does not require an SSL client to submit its digital certificate for identity authentication.
·     If an SSL client submits its certificate to the SSL server, the server authenticates the client identity. The client must pass authentication to access the server.
·     If an SSL client does not submit its certificate to the SSL server, the server does not authenticate the client identity. The client can access the SSL server without authentication.
If SSL client authentication is disabled, the SSL server does not authenticate SSL clients regardless of whether the clients submit digital certificates or not. SSL clients can access the SSL server without authentication.
When authenticating a client by using the digital certificate, the SSL server performs the following operations:
·     Verifies the certificate chain presented by the client.
·     Checks that the certificates in the certificate chain (except the root CA certificate) are not revoked.
# Enable mandatory SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify enable
# Enable optional SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify optional
# Disable SSL client authentication.
[Sysname-ssl-server-policy-policy1] undo client-verify
display ssl client-policy
Use display ssl client-policy to display SSL client policy information.
display ssl client-policy [ policy-name ]
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all SSL client policies.
# Display information about the SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL client policy: policy1
     SSL version: SSL 3.0
     PKI domain: client-domain
     Preferred ciphersuite:
         RSA_AES_128_CBC_SHA
     Server-verify: enabled
Server-verify
Indicates whether the client is enabled to use digital certificates to authenticate servers.
PKI domain
PKI domain used by the SSL client policy.
Use display ssl server-policy to display SSL server policy information.
display ssl server-policy [ policy-name ]
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all SSL server policies.
# Display information about the SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL server policy: policy1
     PKI domain: server-domain
     Ciphersuites:
         DHE_RSA_AES_128_CBC_SHA
         RSA_AES_128_CBC_SHA
     Session cache size: 600
     Caching timeout: 3600 seconds
     Client-verify: Enabled
     Certificate chain sending: Enabled
Caching timeout
Session cache timeout time in seconds.
PKI domain
PKI domain used by the SSL server policy.
Client-verify
SSL client authentication mode, including:
·     Disabled—SSL client authentication is disabled.
·     Enabled—SSL client authentication is mandatory.
·     Optional—SSL client authentication is optional.
Whether the SSL server is enabled to send the complete certificate chain to the client during SSL negotiation.
pki-domain (SSL client policy view)
Use pki-domain to specify a PKI domain for an SSL client policy.
Use undo pki-domain to restore the default.
pki-domain domain-name
undo pki-domain
No PKI domain is specified for an SSL client policy.
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters.
If you specify a PKI domain for an SSL client policy, the SSL client that uses the SSL client policy will obtain its digital certificate through the specified PKI domain.
# Specify PKI domain client-domain for SSL client policy policy1.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
pki domain
pki-domain (SSL server policy view)
Use pki-domain to specify a PKI domain for an SSL server policy.
undo pki-domain
No PKI domain is specified for an SSL server policy.
If you specify a PKI domain for an SSL server policy, the SSL server that uses the SSL server policy will obtain its digital certificate through the specified PKI domain.
# Specify PKI domain server-domain for SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
pki domain
prefer-cipher
Use prefer-cipher to specify a preferred cipher suite for an SSL client policy.
Use undo prefer-cipher to restore the default.
In non-FIPS mode:
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
In FIPS mode:
prefer-cipher { ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 }
undo prefer-cipher
In non-FPIS mode:
An SSL client policy supports the rsa_rc4_128_md5 cipher suite.
In FIPS mode:
An SSL client policy supports the rsa_aes_128_cbc_sha cipher suite.
rsa_rc4_128_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm SHA.
·     Data encryption algorithms—Encrypt data to ensure privacy. Commonly used data encryption algorithms are usually symmetric key algorithms. When using a symmetric key algorithm, the SSL server and the SSL client must use the same key.
·     Message Authentication Code (MAC) algorithms—Calculate the MAC value for data to ensure integrity. Commonly used MAC algorithms include MD5 and SHA. When using a MAC algorithm, the SSL server and the SSL client must use the same key.
·     Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and MAC algorithm. Commonly used key exchange algorithms are asymmetric key algorithms, such as RSA.
The SSL client sends the preferred cipher suite to the SSL server. The server compares the received cipher suite with the cipher suits it supports. If a match is found, the cipher suite negotiation succeeds. If no match is found, the negotiation fails.
# Configure SSL client policy policy1 to support the key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
ciphersuite
server-verify enable
Use server-verify enable to enable the SSL client to use digital certificates to authenticate the SSL server.
Use undo server-verify enable to disable SSL server authentication. The SSL client does not authenticate the SSL server.
The SSL client uses digital certificates to authenticate the SSL server.
If you execute the server-verify enable command, the SSL server must send its digital certificate to the SSL client for authentication. The client can access the SSL server only after the server passes the authentication.
# Enable the SSL client to use digital certificates to authenticate the SSL server.
[Sysname-ssl-client-policy-policy1] server-verify enable
session
Use session to set the maximum number of sessions that the SSL server can cache and the timeout time for cached sessions.
Use undo session to restore the default.
undo session { cachesize | timeout } *
The SSL server can cache a maximum of 500 sessions, and the timeout time for cached sessions is 3600 seconds.
cachesize size: Sets the maximum number of cached sessions, in the range of 100 to 20480.
timeout time: Sets the session cache timeout in the range of 1 to 4294967295 seconds.
The SSL server caches SSL sessions to reuse negotiated session parameters to simplify SSL handshake. Use this command to limit the maximum number and timeout time for cached sessions. When the number of cached sessions reaches the maximum, SSL does not cache new sessions. When the timeout timer for a cached session expires, SSL deletes the session.
# Set the maximum number of cached sessions to 600, and the timeout time for cached sessions to 1800 seconds.
[Sysname-ssl-server-policy-policy1] session cachesize 600 timeout 1800
ssl client-policy
Use ssl client-policy to create an SSL client policy and enter its view, or enter the view of an existing SSL client policy.
Use undo ssl client-policy to delete an SSL client policy.
ssl client-policy policy-name
undo ssl client-policy policy-name
No SSL client policies exist.
This command creates an SSL client policy for which you can configure SSL parameters that the client uses to establish a connection to the server. The parameters include a PKI domain and a preferred cipher suite. An SSL client policy takes effect only after it is associated with an application such as DDNS.
# Create an SSL client policy named policy1 and enter its view.
ssl renegotiation disable
Use ssl renegotiation disable to disable SSL session renegotiation.
Use undo ssl renegotiation disable to restore the default.
SSL session renegotiation is enabled.
The SSL session renegotiation feature enables the SSL client and server to reuse a previously negotiated SSL session for an abbreviated handshake.
Disabling session renegotiation causes more computational overhead to the system but it can avoid potential risks. Disable SSL session renegotiation only when explicitly required.
#Disable SSL session renegotiation.
[Sysname] ssl renegotiation disable
ssl server-policy
Use ssl server-policy to create an SSL server policy and enter its view, or enter the view of an existing SSL server policy.
Use undo ssl server-policy to delete an SSL server policy.
ssl server-policy policy-name
undo ssl server-policy policy-name
No SSL server policies exist.
policy-name: Specifies a name for the SSL server policy, a case-insensitive string of 1 to 31 characters.
This command creates an SSL server policy for which you can configure SSL parameters such as a PKI domain and supported cipher suits. An SSL server policy takes effect only after it is associated with an application such as HTTPS.
# Create an SSL server policy named policy1 and enter its view.
ssl version disable
Use ssl version disable to disable the SSL server from using specific SSL protocol versions for session negotiation.
Use undo ssl version disable restore the default.
In non-FIPS mode:
ssl version { ssl3.0 | tls1.0 | tls1.1 } * disable
undo ssl version { ssl3.0 | tls1.0 | tls1.1 } * disable
In FIPS mode:
ssl version { tls1.0 | tls1.1 } * disable
undo ssl version { tls1.0 | tls1.1 } * disable
In non-FIPS mode:
An SSL server can use versions SSL 3.0, TLS 1.0, TLS 1.1, and TLS 1.2 for session negotiation.
In FIPS mode:
An SSL server can use versions TLS 1.0, TLS 1.1, and TLS 1.2 for session negotiation.
ssl3.0: Specifies SSL 3.0.
tls1.0: Specifies TLS 1.0.
tls1.1: Specifies TLS 1.1.
To enhance system security, you can disable the SSL server from using specific SSL protocol versions (SSL 3.0, TLS 1.0, and TLS 1.1) for session negotiation.
Disabling an SSL protocol version does not affect the availability of earlier SSL protocol versions. For example, if you execute the ssl version tls1.1 disable command, TLS 1.1 is disabled but TLS 1.0 is still available for the SSL server.
# Disable SSL 3.0 for the SSL server.
[Sysname] ssl version ssl3.0 disable
version
Use version to specify an SSL protocol version for an SSL client policy.
Use undo version to restore the default.
In non-FIPS mode:
undo version
In FIPS mode:
version { tls1.0 | tls1.1 | tls1.2 }
undo version
An SSL client policy uses SSL protocol version TLS 1.0.
tls1.2: Specifies TLS 1.2.
To ensure security, do not specify SSL 3.0 for an SSL client policy.
# Set the SSL protocol version to TLS 1.0 for SSL client policy policy1.
[Sysname-ssl-client-policy-policy1] version tls1.0
