- 20-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-SNMP commands
- 04-RMON commands
- 05-NETCONF commands
- 06-EAA commands
- 07-Process monitoring and maintenance commands
- 08-Flow log commands
- 09-Fast log output commands
- 10-Packet capture commands
- 11-Mirroring commands
- 12-UCC commands
- 13-SQA commands
- 14-SmartMC commands
00-Preface | 109.68 KB |
Preface
This command reference describes the configuration commands for the network management and monitoring features, including system maintenance and debugging, NQA, SNMP, RMON, NETCONF, EAA, process monitoring, fow log, fast log, packet capture, mirroring, UCC, SQA, and SmartMC.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
