06-SNMPv2-MIB | 83.68 KB |
SNMPv2-MIB
About this MIB
Use this MIB to configure SNMPv2 basic settings and obtain SNMP packet statistics.
MIB file name
rfc3418-snmpv2.mib
Notifications
coldStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.6.3.1.1.5.1 |
SNMP agent cold start |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a variable of an alarm entry falls to or below its falling threshold and the triggered event is to send SNMP notifications.
System impact
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.1
Informational
Warning
N/A
ON
This notification is generated when an SNMP agent is reinitializing itself with the configuration probably changed.
【System impact】
Status control
ON
CLI: snmp-agent trap enable standard coldstart
OFF
CLI: undo snmp-agent trap enable standard coldstart
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
No action is required.
warmStart
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.6.3.1.1.5.2 |
SNMP agent warm start |
Informational |
Warning |
N/A (N/A) |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.2
Informational
Warning
N/A
ON
This notification is generated when an SNMPv2 agent is reinitializing itself with the configuration unaltered.
【System impact】
Status control
ON
CLI: snmp-agent trap enable standard warmstart
OFF
CLI: undo snmp-agent trap enable standard warmstart
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
authenticationFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.6.3.1.1.5.5 |
SNMP authentication failure |
Informational |
Warning |
N/A (N/A) |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.5
Informational
Warning
N/A
ON
This notification is generated when an SNMPV2 agent receives a protocol message that is not properly authenticated. While all implementations of the SNMPv2 must be capable of generating this trap, the snmpEnableAuthenTraps object indicates whether this trap will be generated.
【System impact】
Status control
ON
CLI: snmp-agent trap enable standard authentication
OFF
CLI: undo snmp-agent trap enable standard authentication
Object
OID (object name) |
Index |
Type |
Value range |
无 (无) |
无 |
无 |
无 |
无 |
Recommended action
1.Verify that the agent and network management system are configured with the same SNMP settings.
2.Identify whether a network attack has occurred.
3.If the issue persists, contact H3C Support.
