- H3C S12500R Ethernet Switch Router Series Config Examples-6W101
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
- 64-Configuration Example of Using Ethernet OAM to Monitor ERPS Ring Link Performance
- 65-GRE Tunneling Between DHCP Relay and DHCP Server Configuration Examples
- 66-Loop Detection Configuration Examples
- 67-MPLS L3VPN+VRRP Configuration Examples
- 68-MSTP and VRRP Load Balancing Configuration Examples
- 69-Routing Policy for VPN Access Control Configuration Examples
- 70-Switch and Firewall Connection Configuration Examples for External Network Access
- 71-Switch and Router Connection Configuration Examples for External Network Access
- 72-VRRP Network Multicast Data Transmission Configuration Examples
69-Routing Policy for VPN Access Control Configuration Examples | 205.59 KB |
H3C S12500R Switch Router Series |
Example: Using routing policies to control access among VPN users
Introduction
The following information provides a configuration example that uses routing policies to control access among VPN users.
This document is not restricted to specific software or hardware versions.
The configuration examples were created and verified in a lab environment, and all the devices were started with the factory default configuration. When you are working on a live network, make sure you understand the potential impact of every command on your network. If you have configured the devices before performing this configuration task, make sure that the existing configuration does not conflict with the configuration in the following example.
The following information is provided based on the assumption that you have basic knowledge of routing policy.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Some physical interfaces in this example must operate in bridge (Layer 2) mode. By default, the physical interfaces on the device operate in routed (Layer 3) mode. To change the link mode of a physical interface, use the port link-mode command.
Hardware |
Software version |
S12500R switch series |
Release 5210 and later |
All sites within an enterprise network can access each other, belonging to the same VPN. To prevent a less secure site from accessing an important server deployed on a certain network, use routing policies to filter routes. In this way, you can limit the site’s access to the important server without affecting other inter-site VPN accesses.
As shown in Figure 1:
· CE 1, CE 2, and CE 3 belong to VPN 1.
· Two user networks 100.1.1.0/24 and 100.2.1.0/24 are connected to CE 1. An important server exists in network 100.2.1.0/24.
· Site 2 is connected to CE 2 and is less secure. It is not allowed to access network 100.2.1.0/24.
· The PEs use OSPF to communicate with each other, and use MP-IBGP to exchange VPNv4 routes.
· A PE and a CE use EBGP to exchange private network routes.
Device |
IP address |
PE 1 |
Loop0 |
1.1.1.1/32 |
Vlan-int10 |
10.1.1.1/24 |
Vlan-int11 |
11.1.1.1/24 |
Vlan-int13 |
13.1.1.1/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
Vlan-int20 |
20.1.1.2/24 |
Vlan-int11 |
11.1.1.2/24 |
Vlan-int12 |
12.1.1.2/24 |
PE 3 |
Loop0 |
3.3.3.3/32 |
Vlan-int30 |
30.1.1.3/24 |
Vlan-int12 |
12.1.1.3/24 |
Vlan-int13 |
13.1.1.3/24 |
CE 1 |
Loop1 |
100.1.1.0/24 |
Loop2 |
100.2.1.0/24 |
Vlan-int10 |
10.1.1.10/24 |
CE 2 |
Loop1 |
200.1.1.0/24 |
Vlan-int20 |
20.1.1.20/24 |
CE 3 |
Loop1 |
103.1.1.0/24 |
Vlan-int30 |
30.1.1.30/24 |
Analysis
To control access among VPN users through routing policies in an MPLS L3VPN network, perform the following tasks:
· Configure EBGP between each PE and CE, so they can exchange private network routes. Redistribute direct routes into BGP on each CE.
· Configure OSPF on PE interfaces connected to the backbone network so that traffic can be routed to the public network.
· Establish MP-IBGP peer relationships between PEs, so they can exchange BGP VPNv4 routes.
· Perform the following operations to configure PE 2 to deny routes destined for network 100.2.1.0/24, thus disabling site 2 from accessing network 100.2.1.0/24:
¡ Configure a routing policy on PE 1. The routing policy adds RT attribute 2:2 to routes destined for network 100.2.1.0/24 when PE 1 advertises VPNv4 routes to PE 2.
¡ Configure a routing policy on PE 2 to deny routes carrying RT attribute 2:2.
Data plan
Item |
Value |
AS number for CE 1 |
65410 |
AS number for CE 2 |
65420 |
AS number for CE 3 |
65430 |
AS numbers for PE 1, PE 2, and PE 3 |
100 |
Procedures
Configuring PE 1
Assigning interfaces to VLANs
[Sysname] sysname PE1
[PE1] vlan 10
[PE1-vlan10] quit
[PE1] vlan 11
[PE1-vlan11] quit
[PE1] vlan 13
[PE1-vlan13] quit
[PE1] interface hundredgige 1/0/1
[PE1-HundredGigE1/0/1] port access vlan 10
[PE1-HundredGigE1/0/1] quit
[PE1] interface hundredgige 1/0/2
[PE1-HundredGigE1/0/2] port access vlan 11
[PE1-HundredGigE1/0/2] quit
[PE1] interface hundredgige 1/0/3
[PE1-HundredGigE1/0/3] port access vlan 13
[PE1-HundredGigE1/0/3] quit
Configuring IP addresses and unicast routing
# Configure IP addresses for the loopback interface and VLAN interfaces.
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.1 255.255.255.255
[PE1-LoopBack0] quit
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip address 11.1.1.1 24
[PE1-Vlan-interface11] quit
[PE1] interface vlan-interface 13
[PE1-Vlan-interface13] ip address 13.1.1.1 24
[PE1-Vlan-interface13] quit
# Configure OSPF to achieve inter-network communication at the network layer.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[PE1-ospf-1] quit
Configuring an MPLS LSR ID and enabling MPLS and MPLS LDP
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface11] mpls enable
[PE1-Vlan-interface11] mpls ldp enable
[PE1-Vlan-interface13] mpls enable
[PE1-Vlan-interface13] mpls ldp enable
Establishing MP-IBGP peer relationships between PEs for exchanging VPNv4 routes
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default] peer 3.3.3.3 as-number 100
[PE1-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-vpnv4] peer 3.3.3.3 enable
[PE1-bgp-default-vpnv4] quit
Configuring VPN instances
# Create VPN instance vpn1, and set its RD, import RT, and export RT.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 1:1
[PE1-vpn-instance-vpn1] vpn-target 1:1 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
[PE1-vpn-instance-vpn1] quit
# Bind VLAN-interface 10 to VPN instance vpn1, and configure an IP address for the interface.
[PE1] interface vlan-interface 10
[PE1-Vlan-interface10] ip binding vpn-instance vpn1
[PE1-Vlan-interface10] ip address 10.1.1.1 24
[PE1-Vlan-interface10] quit
Establishing an EBGP peer relationship between PE 1 and CE 1 for exchanging private network routes
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.10 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.10 enable
[PE1-bgp-default-vpn1] quit
Configuring a routing policy that adds RT attribute 2:2 to routes advertised to peer 2.2.2.2
# Create IP prefix list network1 to match network 100.2.1.0/24.
[PE1] ip prefix-list network1 index 10 permit 100.2.1.0 24
[PE1] ip prefix-list network1 index 20 deny 0.0.0.0 0
# Create routing policy addrt to add RT attribute 2:2 to routes destined for network 100.2.1.0/24.
[PE1] route-policy addrt permit node 10
[PE1-route-policy-addrt-10] if-match ip address prefix-list network1
[PE1-route-policy-addrt-10] apply extcommunity rt 2:2 additive
[PE1-route-policy-addrt-10] quit
[PE1] route-policy addrt permit node 20
[PE1-route-policy-addrt-20] quit
# In the BGP VPNv4 address family, apply routing policy addrt to routes advertised to peer 2.2.2.2.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2.2.2.2 route-policy addrt export
[PE1-bgp-default] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] vlan 11
[PE2-vlan11] quit
[PE2] vlan 12
[PE2-vlan12] quit
[PE2] vlan 20
[PE2-vlan20] quit
[PE2] interface hundredgige 1/0/1
[PE2-HundredGigE1/0/1] port access vlan 11
[PE2-HundredGigE1/0/1] quit
[PE2] interface hundredgige 1/0/2
[PE2-HundredGigE1/0/2] port access vlan 12
[PE2-HundredGigE1/0/2] quit
[PE2] interface hundredgige 1/0/3
[PE2-HundredGigE1/0/3] port access vlan 20
[PE2-HundredGigE1/0/3] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.2 255.255.255.255
[PE2-LoopBack0] quit
[PE2] interface vlan-interface 11
[PE2-Vlan-interface11] ip address 11.1.1.2 24
[PE2-Vlan-interface11] quit
[PE2-Vlan-interface12] ip address 12.1.1.2 24
[PE2-Vlan-interface12] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1] quit
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface11] mpls enable
[PE2-Vlan-interface11] mpls ldp enable
[PE2-Vlan-interface12] mpls enable
[PE2-Vlan-interface12] mpls ldp enable
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.3 as-number 100
[PE2-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] peer 3.3.3.3 enable
[PE2-bgp-default-vpnv4] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 1:1
[PE2-vpn-instance-vpn1] vpn-target 1:1 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
[PE2-vpn-instance-vpn1] quit
# Bind VLAN-interface 20 to VPN instance vpn1, and configure an IP address for the interface.
[PE2] interface vlan-interface 20
[PE2-Vlan-interface20] ip binding vpn-instance vpn1
[PE2-Vlan-interface20] ip address 20.1.1.2 24
[PE2-Vlan-interface20] quit
Establishing an EBGP peer relationship between PE 2 and CE 2 for exchanging private network routes
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 20.1.1.20 as-number 65420
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.20 enable
[PE2-bgp-default-vpn1] quit
Configuring a routing policy that denies routes with RT attribute 2:2
# Create extended community attribute list 1 to match RT attribute 2:2.
[PE2] ip extcommunity-list 1 index 1 permit rt 2:2
# Create routing policy checkrt that denies routes carrying RT attribute 2:2.
[PE2] route-policy checkrt deny node 10
[PE2-route-policy-checkrt-10] if-match extcommunity 1
[PE2-route-policy-checkrt-10] quit
[PE2] route-policy checkrt permit node 20
[PE2-route-policy-checkrt-20] quit
# In the BGP VPNv4 address family, apply routing policy checkrt to routes received from peer 1.1.1.1.
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1.1.1.1 route-policy checkrt import
[PE2-bgp-default] quit
Configuring PE 3
[Sysname] sysname PE3
[PE3] vlan 12
[PE3-vlan12] quit
[PE3] vlan 13
[PE3-vlan13] quit
[PE3] vlan 30
[PE3-vlan30] quit
[PE3] interface hundredgige 1/0/1
[PE3-HundredGigE1/0/1] port access vlan 13
[PE3-HundredGigE1/0/1] quit
[PE3] interface hundredgige 1/0/2
[PE3-HundredGigE1/0/2] port access vlan 12
[PE3-HundredGigE1/0/2] quit
[PE3] interface hundredgige 1/0/3
[PE3-HundredGigE1/0/3] port access vlan 30
[PE3-HundredGigE1/0/3] quit
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 3.3.3.3 255.255.255.255
[PE3-LoopBack0] quit
[PE3] interface vlan-interface 12
[PE3-Vlan-interface12] ip address 12.1.1.3 24
[PE3-Vlan-interface12] quit
[PE3] interface vlan-interface 13
[PE3-Vlan-interface13] ip address 13.1.1.3 24
[PE3-Vlan-interface13] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE3-ospf-1] quit
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Vlan-interface12] mpls enable
[PE3-Vlan-interface12] mpls ldp enable
[PE3-Vlan-interface13] mpls enable
[PE3-Vlan-interface13] mpls ldp enable
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.1 as-number 100
[PE3-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.2 as-number 100
[PE3-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE3-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE3-bgp-default-vpnv4] quit
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 1:1
[PE3-vpn-instance-vpn1] vpn-target 1:1 import-extcommunity
[PE3-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
[PE3-vpn-instance-vpn1] quit
# Bind VLAN-interface 30 to VPN instance vpn1, and configure an IP address for the interface.
[PE3] interface vlan-interface 30
[PE3-Vlan-interface30] ip binding vpn-instance vpn1
[PE3-Vlan-interface30] ip address 30.1.1.3 24
[PE3-Vlan-interface30] quit
Establishing an EBGP peer relationship between PE 3 and CE 3 for exchanging private network routes
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 30.1.1.30 as-number 65430
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 30.1.1.30 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
Configuring CE 1
[Sysname] sysname CE1
[CE1] vlan 10
[CE1-vlan10] quit
[CE1] interface hundredgige 1/0/1
[CE1-HundredGigE1/0/1] port access vlan 10
[CE1-HundredGigE1/0/1] quit
# Configure IP addresses for the loopback interfaces and VLAN interface.
[CE1] interface vlan-interface 10
[CE1-Vlan-interface100] ip address 10.1.1.10 24
[CE1-Vlan-interface100] quit
[CE1] interface loopback 1
[CE1-LoopBack1] ip address 100.1.1.1 24
[CE1-LoopBack1] quit
[CE1] interface loopback 2
[CE1-LoopBack1] ip address 100.2.1.1 24
Establishing an EBGP peer relationship between CE 1 and PE 1 for redistributing direct routes into BGP
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
Configuring CE 2
[Sysname] sysname CE2
[CE2] vlan 20
[CE2-vlan20] quit
[CE2] interface hundredgige 1/0/1
[CE2-HundredGigE1/0/1] port access vlan 20
[CE2-HundredGigE1/0/1] quit
# Configure IP addresses for the loopback interface and VLAN interface.
[CE2] interface vlan-interface 20
[CE2-Vlan-interface20] ip address 20.1.1.20 24
[CE2-Vlan-interface20] quit
[CE2] interface loopback 1
[CE2-LoopBack1] ip address 200.1.1.1 24
[CE2-LoopBack1] quit
Establishing an EBGP peer relationship between CE 2 and PE 2 for redistributing direct routes into BGP
[CE2] bgp 65420
[CE2-bgp-default] peer 20.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
Configuring CE 3
[Sysname] sysname CE3
[CE3] vlan 30
[CE3-vlan30] quit
[CE3] interface hundredgige 1/0/1
[CE3-HundredGigE1/0/1] port access vlan 30
[CE3-HundredGigE1/0/1] quit
[CE3] interface vlan-interface 30
[CE3-Vlan-interface30] ip address 30.1.1.30 24
[CE3-Vlan-interface30] quit
[CE3] interface loopback 1
[CE3-LoopBack1] ip address 103.1.1.1 24
[CE3-LoopBack1] quit
Establishing an EBGP peer relationship between CE 3 and PE 3 for redistributing direct routes into BGP
[CE3] bgp 65430
[CE3-bgp-default] peer 30.1.1.3 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 30.1.1.3 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
# On PE 1, display routes destined for network 100.2.1.0/24.
[PE1] display bgp routing-table vpnv4 100.2.1.0 24 advertise-info
BGP local router ID: 1.1.1.1
Local AS number: 100
Route distinguisher: 1:1
Total number of routes: 1
Paths: 1 best
BGP routing table information of 100.2.1.0/24(TxPathID:0):
Advertised to VPN peers (2 in total):
2.2.2.2
3.3.3.3
Inlabel : 600127
The output shows that a route destined for network 100.2.1.0/24 has been advertised to PE 2 and PE 3.
# On PE 2, display BGP VPNv4 routes.
[PE2] display bgp routing-table vpnv4
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
Total number of routes from all PEs: 4
Route distinguisher: 1:1(vpn1)
Total number of routes: 6
* >i 10.1.1.0/24 1.1.1.1 0 100 0 65410?
* >e 20.1.1.0/24 20.1.1.20 0 0 65420?
* >i 30.1.1.0/24 3.3.3.3 0 100 0 65430?
* >i 100.1.1.0/24 1.1.1.1 0 100 0 65410?
* >i 103.1.1.0/24 3.3.3.3 0 100 0 65430?
* >e 200.1.1.0 20.1.1.20 0 0 65420?
The output shows that PE 2 does not have a route to network 100.2.1.0/24.
# On PE 3, display BGP VPNv4 routes.
[PE3] display bgp routing-table vpnv4
a - additional-path
Total number of routes from all PEs: 5
Total number of routes: 7
* >i 20.1.1.0/24 2.2.2.2 0 100 0 65420?
* >e 30.1.1.0/24 30.1.1.30 0 0 65430?
* >i 100.2.1.0/24 1.1.1.1 0 100 0 65410?
* >e 103.1.1.0/24 30.1.1.30 0 0 65430?
* >i 200.1.1.0 2.2.2.2 0 100 0 65420?
The output shows that PE 3 has a route to network 100.2.1.0/24.
# On CE 2, use the ping command to ping 100.1.1.1, 100.2.1.1, and 103.1.1.1.
[CE2] ping 100.1.1.1
Ping 100.1.1.1 (100.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 100.1.1.1: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 100.1.1.1: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 100.1.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.000/1.000/0.000 ms
[CE2] ping 100.2.1.1
Ping 100.2.1.1 (100.2.1.1): 56 data bytes, press CTRL+C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 100.2.1.1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[CE2] ping 103.1.1.1
Ping 103.1.1.1 (103.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 103.1.1.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 103.1.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 103.1.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 103.1.1.1: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 103.1.1.1: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 103.1.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
The output shows that CE 2 can access networks 100.1.1.0/2 and 和103.1.1.0/24, but cannot access network 100.2.1.0/24.
# On CE 3, use the ping command to ping 100.1.1.1, 100.2.1.1, and 200.1.1.1.
[CE3] ping 100.1.1.1
56 bytes from 100.1.1.1: icmp_seq=4 ttl=253 time=2.000 ms
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
[CE3] ping 100.2.1.1
56 bytes from 100.2.1.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 100.2.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 100.2.1.1: icmp_seq=2 ttl=253 time=2.000 ms
56 bytes from 100.2.1.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 100.2.1.1: icmp_seq=4 ttl=253 time=2.000 ms
round-trip min/avg/max/std-dev = 1.000/1.800/2.000/0.400 ms
[CE3] ping 200.1.1.1
Ping 200.1.1.1 (200.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 200.1.1.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 200.1.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 200.1.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 200.1.1.1: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 200.1.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 200.1.1.1 ---
The output shows that CE 3 can access all of these networks.
In conclusion, site 2 connected to CE 2 is disabled from accessing network 100.2.1.0/24, because PE 2 uses a routing policy to deny routes destined for network 100.2.1.0/24. Other sites in VPN 1 still can access each other.
Configuration files
PE 1
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.1
vlan 10 to 11
vlan 13
mpls ldp
interface LoopBack0
interface Vlan-interface10
interface Vlan-interface11
ip address 11.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface13
ip address 13.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 10
combo enable fiber
interface HundredGigE1/0/2
port access vlan 11
combo enable fiber
interface HundredGigE1/0/3
port access vlan 13
combo enable fiber
bgp 100
peer 2.2.2.2 connect-interface LoopBack0
peer 3.3.3.3 connect-interface LoopBack0
peer 2.2.2.2 enable
peer 3.3.3.3 enable
return
PE 2
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.2
vlan 11 to 12
vlan 20
mpls ldp
interface LoopBack0
ip address 11.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface12
ip address 12.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface20
ip address 20.1.1.2 255.255.255.0
port access vlan 11
combo enable fiber
port access vlan 12
combo enable fiber
port access vlan 20
combo enable fiber
bgp 100
peer 1.1.1.1 connect-interface LoopBack0
peer 1.1.1.1 enable
peer 3.3.3.3 enable
return
PE 3
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.3
vlan 12 to 13
vlan 30
mpls ldp
interface LoopBack0
ip address 12.1.1.3 255.255.255.0
mpls enable
mpls ldp enable
ip address 13.1.1.3 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface30
ip address 30.1.1.3 255.255.255.0
port access vlan 13
combo enable fiber
port access vlan 12
combo enable fiber
port access vlan 30
combo enable fiber
bgp 100
peer 1.1.1.1 enable
peer 2.2.2.2 enable
return
CE 1
sysname CE1
vlan 10
interface LoopBack1
ip address 100.1.1.1 255.255.255.0
interface LoopBack2
ip address 100.2.1.1 255.255.255.0
ip address 10.1.1.10 255.255.255.0
port access vlan 10
combo enable fiber
bgp 65410
import-route direct
return
CE 2
sysname CE2
vlan 20
interface LoopBack1
ip address 200.1.1.1 255.255.255.0
ip address 20.1.1.20 255.255.255.0
port access vlan 20
combo enable fiber
bgp 65420
import-route direct
return
CE 3
sysname CE3
vlan 30
interface LoopBack1
ip address 103.1.1.1 255.255.255.0
ip address 30.1.1.30 255.255.255.0
port access vlan 30
combo enable fiber
bgp 65430
import-route direct
Return
Related documentation
· Layer 3—IP Routing Configuration Guide in H3C S12500R Switch Router Series Configuration Guides-R52xx
· Layer 3—IP Routing Command Reference in H3C S12500R Switch Router Series Command References-R52xx
· Layer 3—IP Routing Configuration Guide in H3C S12500R-48Y8C&S12500R-48C6D Switch Router Configuration Guides-R52xx
· Layer 3—IP Routing Command Reference in H3C S12500R-48Y8C&S12500R-48C6D Switch Router Command References-R52xx
