07-Inter-VLAN Communication on Downlink Switches Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C MSR Routers Commonly Used Feature Configuration Examples(Web)-R9141-6W10007-Inter-VLAN Communication on Downlink Switches Configuration Examples
00-Preface
00-Preface 109.73 KB
Preface
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the SR6600 router series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
