12-ACL and QoS
HomeSupportDiagnose & MaintainAlarms ReferencesH3C MSR Router Series Alarm Reference-R6749-6W10012-ACL and QoS
Table of Contents
Related Documents
01-HH3C-ACL-MIB
01-HH3C-ACL-MIB 58.17 KB
HH3C-ACL-MIB
About this MIB
This MIB provides some basic table for managing ACLs on a switch.
MIB file name
hh3c-acl.mib
Notifications
This section describes the HH3C-ACL-MIB notifications.
hh3cAclRuleMatchCount
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.8.5.0.2
Notification for the ACL rule matches.
Informational
Warning
OFF
Notification triggers
When a trap interval is set through the table hh3cAclIntervalTable, notifications will be generated at intervals. The notification information includes the number of rule matches in the interval.
System impact
None.
Status control
ON
·     CLI: Use the acl trap interval interval command.
·     MIB: Set hh3cAclIntervalType to trap(2), set the hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
·     MIB: Use the table hh3cAclIntervalTable to perform a destroy operation.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.8.3.6.1.1 (hh3cPfilter2ApplyObjType)
Object to which the ACL is applied.
hh3cPfilter2ApplyObjIndex
hh3cPfilter2ApplyDirection
hh3cPfilter2ApplyAclType
hh3cPfilter2ApplyAclIndex
hh3cPfilter2AclRuleIndex
INTEGER
·     interface(1)
·     vlan(2)
·     global(3)
1.3.6.1.4.1.25506.2.8.3.6.1.2 (hh3cPfilter2ApplyObjIndex)
Object index.
Integer32
0 to 2147483647
1.3.6.1.4.1.25506.2.8.3.6.1.3 (hh3cPfilter2ApplyDirection)
Direction of the packet filter.
INTEGER
·     inbound(1)
·     outbound(2)
1.3.6.1.4.1.25506.2.8.3.6.1.4 (hh3cPfilter2ApplyAclType)
Type of the ACL.
INTEGER
·     ipv4(1)
·     ipv6(2)
·     default(3)
·     mac(4)
·     user(5)
1.3.6.1.4.1.25506.2.8.3.6.1.5 (hh3cPfilter2ApplyAclIndex)
ACL index.
OCTET STRING
SIZE (1 to 63)
1.3.6.1.4.1.25506.2.8.3.8.1.1 (hh3cPfilter2AclRuleIndex)
ACL rule index
Integer32
0 to 65534.
1.3.6.1.4.1.25506.2.8.3.8.1.4 (hh3cPfilter2AclRuleMatchPackets)
ACL rule match count.
N/A
Counter64
0 to 18446744073709551615.
Recommended action
No action is required.
