06-Layer 2—WAN Access
HomeSupportDiagnose & MaintainAlarms ReferencesH3C MSR Router Series Alarm Reference-R6749-6W10006-Layer 2—WAN Access
01-HH3C-3GMODEM-MIB
01-HH3C-3GMODEM-MIB 95.86 KB
HH3C-3GMODEM-MIB
About this MIB
Use this MIB to retrieve basic information, collect diagnostic information, and configure network connection settings for the 3G modem.
MIB file name
hh3c-3gmodem.mib
Notifications
hh3cWirelessCardInserted
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.98.3.0.1
A 3G modem inserted.
Recovery
Warning
N/A
ON
Notification triggers
This notification is generated when a 3G modem is inserted into the device.
System impact
The wireless network service is available.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.98.2.2 (hh3cDeviceOUI)
Organizational Unique Identifier (OUI) of the device.
N/A
SnmpAdminString
OCTET STRING (0..64)
1.3.6.1.4.1.25506.2.98.2.1 (hh3cDevSerialNumber)
Serial number of the device.
N/A
SnmpAdminString
OCTET STRING (0..32)
1.3.6.1.4.1.25506.2.98.1.1.1.1.5 (hh3cWirelessCardSerialNumber)
Vendor-specific serial number of the 3G modem.
N/A
SnmpAdminString
1.3.6.1.4.1.25506.2.98.1.2.1.1.3 (hh3cUIMImsi)
IMSI of the UIM card.
N/A
SnmpAdminString
Recommended action
No action is required.
hh3cWirelessCardPulledOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.98.3.0.2
A 3G modem pulled out.
Error
Minor
1.3.6.1.4.1.25506.2.98.3.0.1 (A 3G modem inserted.)
ON
This notification is generated when a 3G modem is pulled out from the device.
System impact
The wireless network service is not available.
Status control
Objects
OID (object name)
Index nodes
Value range
OUI of the device.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
To resolve the issue:
1.     Verify that the 3G modem is removed on purpose manually.
2.     If the 3G modem is not removed on purpose manually, verify that it is installed correctly and functions correctly.
3.     If the issue persists, contact H3C Support.
hh3cAccessMediaChanged
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.98.3.0.5
Access media changed
Informational
Warning
N/A
ON
This notification is generated when the access media is changed.
System impact
The wireless network service might be affected.
Status control
Objects
OID (object name)
Index nodes
Value range
OUI of the device.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
1.3.6.1.4.1.25506.2.98.2.3 (hh3cAccessMedia)
Current access media.
N/A
INTEGER
unknown(1), air(2), cable(3)
Recommended action
hh3c3GRssiStrongSignalTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.98.3.0.6
Current RSSI exceeded the medium signal threshold.
Informational
Warning
N/A
ON
This notification is generated when the current RSSI exceeds the medium signal threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.98.1.1.1.1.1 (hh3cWirelessCardIndex)
Index of the 3G modem.
N/A
Integer32
Integer32 (1..2147483647)
OUI of the device.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
1.3.6.1.4.1.25506.2.98.2.4 (hh3c3GCurrentService)
Current network service type.
N/A
INTEGER
unknown(1), oneXRtt(2), evDo(3), gsm(4), lte(5)
1.3.6.1.4.1.25506.2.98.2.5 (hh3c3GCurrentRssiBind)
Current RSSI.
N/A
Integer32
Integer32 (-2147483648 | -150..0)
1.3.6.1.4.1.25506.2.98.2.6 (hh3c3GImsiBind)
IMSI of the SIM/UIM card.
N/A
SnmpAdminString
Recommended action
hh3c3GRssiMediumSignalTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.98.3.0.7
Current RSSI fell or rose to a value between the medium and weak signal thresholds.
Informational
Warning
N/A
ON
This notification is generated when the current RSSI falls or rises to a value between the medium and weak signal thresholds.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
OUI of the device.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
INTEGER
Current RSSI.
N/A
Integer32
N/A
SnmpAdminString
Recommended action
hh3c3GRssiWeakSignalTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.98.3.0.8
Current RSSI fell below the weak signal threshold
Informational
Warning
N/A
ON
This notification is generated when the current RSSI falls below the weak signal threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
OUI of the device.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
INTEGER
Current RSSI.
N/A
Integer32
N/A
SnmpAdminString
Recommended action
To resolve the issue, check the antenna and remove obstacles that block signals to ensure that the RSSI is in the normal range.
