- 11-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PTP commands
- 05-PoE commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-NETCONF commands
- 10-SmartMC commands
- 11-EPA commands
- 12-CWMP commands
- 12-EAA commands
- 13-Process monitoring and maintenance commands
- 14-Mirroring commands
- 15-sFlow commands
- 16-Information center commands
- 17-Packet capture commands
- 18-EPS agent commands
- 19-Cloud connection commands
- 20-VCF fabric commands
18-EPS agent commands | 49.04 KB |
EPS agent commands
display eps agent discovery
Use display eps agent discovery to display scanned endpoint information.
# Display scanned endpoint information.
<Sysname> display eps agent discovery
IP-Address MAC-Address OS-Type OS-ver Vendor Product
100.100.100.100 cc:ef:48:9b:5f:c1 IOS 12.X Cisco C3560E
IP-Address |
Endpoint IP address. |
MAC-Address |
Endpoint MAC address. |
OS-Type |
Endpoint operating system type. |
OS-ver |
Endpoint operating system version. |
Vendor |
Endpoint vendor. |
Product |
Endpoint model. |
eps agent enable
Use eps agent enable to enable EPS agent.
Use undo eps agent enable to disable EPS agent.
eps agent enable
EPS agent is disabled.
After you enable EPS agent on a scanner, the scanner scans and manages endpoints in its associated areas by following the instruction of the EPS server.
# Enable EPS agent.
[Sysname] eps agent enable
eps server
Use eps server to configure EPS server parameters.
Use undo eps server to restore the default.
eps server ip-address port port-number [ key { cipher | simple } key-value ] [ log-level level-value ] [ use-server-setting ]
undo eps server
EPS server parameters are not configured.
ip-address: Specifies the IP address of the EPS server.
port port-number: Specifies the port number of the EPS server, in the range of 1 to 65535.
key: Sets the key for communication between the scanner and the EPS server.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
key-value: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 24 characters. Its encrypted form is a case-sensitive string of 1 to 65 characters.
log-level level-value: Specifies the level of logs sent to the EPS server, in the range of 0 to 5. A higher value represents more detailed log information.
use-server-setting: Specifies that the scanner uses the configured global parameter settings of the EPS server. If you do not specify this keyword, the scanner uses the default global parameter settings of the EPS server.
A scanner enabled with EPS agent automatically generates EPS logs to record the running conditions of the EPS agent. EPS logs are not sent to the information center of the scanner. To enable the scanner to send EPS logs to the EPS server for monitoring, specify the log-level level-value option.
# Specify 192.168.7.27 as the IP address of the EPS server, and 4500 as the port number of the EPS server.
[Sysname] eps server ip-address 192.168.7.27 port 4500
