06-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Switch Series Command References-R63xx-6W10206-IP Multicast Command Reference
11-IPv6 multicast routing and forwarding commands
display ipv6 mrib interface
Use display ipv6 mrib interface to display information about interfaces maintained by the IPv6 MRIB.
display ipv6 mrib interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the IPv6 MRIB.
# Display information about interfaces maintained by the IPv6 MRIB.
<Sysname> display ipv6 mrib interface
 Interface: Vlan-interface1
     Index: 0x00004444
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : FE80:7:11::1/10
             Remote address: ::
             Reference     : 1
             State         : NORMAL
Interface name.
Index
Index number of the interface.
Current state
Current status of the interface: up or down.
MTU
MTU value.
Interface type:
·     BROADCAST—Broadcast link interface.
·     LOOP—Loopback interface.
·     REGISTER—Register interface.
·     MTUNNEL—Multicast tunnel interface.
This field is empty if the interface is Null 0.
Protocol
Protocol running on the interface: PIM-DM, PIM-SM, MLD, or PROXY.
PIM protocol state
Whether IPv6 PIM is enabled: Enabled or Disabled.
Address list
Interface address list.
Local address
Local IP address.
Remote address
Remote end IP address. This field is displayed only when the interface is vlink type.
Reference
Number of times that the address has been used.
Status of the interface address: NORMAL or DEL.
display ipv6 multicast boundary
Use display ipv6 multicast boundary to display IPv6 multicast boundary information.
display ipv6 multicast boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
group: Displays the IPv6 multicast boundary information for the specified groups.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast boundary information for all IPv6 multicast groups.
prefix-length: Specifies an address prefix length in the range of 8 to 128. The default is 128.
scope: Displays the IPv6 multicast group boundary information in the admin-scoped zone.
scope-id: Specifies an admin-scope zone by its ID in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address. If you do not specify an admin-scoped zone, this command displays IPv6 multicast boundary information for all IPv6 admin-scoped zones.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6 multicast boundary information for all interfaces.
# Display IPv6 multicast boundary information of all IPv6 multicast groups for all interfaces.
<Sysname> display ipv6 multicast boundary group
 Boundary                                                 Interface
 FF1E::/64                                                Vlan1
# Display IPv6 multicast boundary information in all IPv6 admin-scope zones for all interfaces.
<Sysname> display ipv6 multicast boundary scope
 Boundary            Interface
        3            Vlan-interface1
Boundary
IPv6 multicast group or IPv6 admin-scoped zone associated with the IPv6 multicast boundary.
Boundary interface associated with the IPv6 multicast boundary.
display ipv6 multicast fast-forwarding cache
Use display ipv6 multicast fast-forwarding cache to display IPv6 multicast fast forwarding entries.
display ipv6 multicast fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
ipv6-source-address: Specifies an IPv6 multicast source address.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 multicast fast forwarding entries for the master device.
# Display IPv6 multicast fast forwarding entries.
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status     : Enabled
Source port: 2001                   Destination port: 2002
Protocol   : 2                      Flag            : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled               Flag: 0x14
Total number of (S, G) entries, and the total number of matching (S, G) entries.
(S, G) entry.
Protocol
Protocol number.
Flag
Flag for the (S, G) entry or the outgoing interface of the entry.
This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2. The value 0x14 means that the outgoing interface has flags 0x10 and 0x4.
The following flags are available for an entry:
·     0x1—The entry is created because of packets passed through between cards.
·     0x2—The entry is added by IPv6 multicast forwarding.
The following flags are available for an outgoing interface:
·     0x1—The interface is added to the entry because of packets passed through between cards.
·     0x2—The interface is added to an existing entry.
·     0x4—The MAC address of the interface is needed for fast forwarding.
·     0x8—The interface is an outgoing interface associated with the incoming VLAN or super VLAN interface.
·     0x10—The interface is associated with the entry.
·     0x20—The interface is to be deleted.
Status
Status of the (S, G) entry or the outgoing interface:
·     Enabled—Available.
·     Disabled—Unavailable.
Incoming interface
Incoming interface of the (S, G) entry.
Outgoing interface list of the (S, G) entry.
reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast forwarding event
Use display ipv6 multicast forwarding event to display statistics of IPv6 multicast forwarding events.
display ipv6 multicast forwarding event [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics of IPv6 multicast forwarding events for the master device.
# Display statistics of IPv6 multicast forwarding events.
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Number of times that entry-active events have been sent.
Number of times that entry-inactive events have been sent.
Number of times that NoCache events have been sent.
Number of times that NoCache events have been dropped.
Number of times that WrongIF events have been sent.
Number of times that WrongIF events have been dropped.
Number of times that SPT-switch events have been sent.
NoCache rate limit
Rate limit for sending NoCache events, in pps.
WrongIF rate limit
Rate limit for sending WrongIF events, in packets per 10 seconds.
Number of times that the registration suppression has timed out in total.
reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
Use display ipv6 multicast forwarding-table to display IPv6 multicast forwarding entries.
display ipv6 multicast forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] *
prefix-length: Specifies an address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 forwarding entries that contain the specified incoming interface.
outgoing-interface: Specifies the IPv6 forwarding entries that contain the specified outgoing interface.
exclude: Specifies the IPv6 forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the IPv6 forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the IPv6 forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 multicast forwarding entries for the master device.
statistics: Displays statistics for the IPv6 multicast forwarding table.
# Display IPv6 multicast forwarding entries.
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
          Incoming sub-VLAN: VLAN 11
          Outgoing sub-VLAN: VLAN 12
                             VLAN 13
     List of 1 outgoing interface:
       1: Vlan-interface20
          Sub-VLAN: VLAN 21
                    VLAN 22
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 5 Command output
00001
Sequence number of the (S, G) entry.
(1::1, ff0e::1)
(S, G) entry.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0.
·     0x0—The entry is in correct state.
·     0x1—The entry is in inactive state.
·     0x2—The entry is null.
·     0x4—The entry fails to update.
·     0x8—The outgoing interface information fails to update for the entry.
·     0x20—A register outgoing interface is available.
·     0x40—The entry is to be deleted.
·     0x80—The entry is in registration suppression state.
·     0x100—The entry is being deleted.
·     0x200—The entry is in GR state.
·     0x400—The entry has the VLAN interface of the super VLAN.
·     0x800—The entry has the associated ND entry for the IPv6 multicast source address.
·     0x4000000—The entry is created by the MLD proxy.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will time out.
Incoming interface
Incoming sub-VLAN
Incoming sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Outgoing sub-VLAN
Outgoing sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Sub-VLAN
Outgoing sub-VLAN of the super VLAN when the outgoing interface of the (S, G) entry is the VLAN interface of this super VLAN.
Matched 19648 packets (20512512 bytes), Wrong If 0 packet
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors.
The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot.
Forwarded 19648 packets (20512512 bytes)
Number of packets (bytes) that have been forwarded.
reset ipv6 multicast forwarding-table
display ipv6 multicast routing-table
Use display ipv6 multicast routing-table to display IPv6 multicast routing entries.
display ipv6 multicast routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
prefix-length: Specifies an address prefix length. The default is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Displays the IPv6 routing entries that contain the specified incoming interface.
outgoing-interface: Displays the IPv6 routing entries that contain the specified outgoing interface.
exclude: Displays the IPv6 routing entries that do not contain the specified interface in the outgoing interface list.
include: Displays the IPv6 routing entries that contain the specified interface in the outgoing interface list.
match: Displays the IPv6 routing entries that contain only the specified interface in the outgoing interface list.
IPv6 multicast routing entries are the basis of IPv6 multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display IPv6 multicast routing entries.
<Sysname> display ipv6 multicast routing-table
 Total 1 entries
 00001. (2001::2, FFE3::101)
       Uptime: 00:00:14
       Upstream Interface: Vlan-interface1
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
Table 6 Command output
Total 1 entries
Total number of (S, G) entries.
00001
(S, G) entry.
Uptime
Upstream Interface
Upstream interface at which the (S, G) packets should arrive.
List of downstream interfaces that forward (S, G) packets.
reset ipv6 multicast routing-table
display ipv6 multicast rpf-info
Use display ipv6 multicast rpf-info to display RPF information for an IPv6 multicast source.
display ipv6 multicast rpf-info ipv6-source-address [ ipv6-group-address ]
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
# Display RPF information for IPv6 multicast source 2001::101 on the public network.
<Sysname> display ipv6 multicast rpf-info 2001::101
 RPF information about source 2001::101:
     RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:101:1
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     Load splitting rule: disable
     Source AS: 0
     C-multicast route target: 0x0000000000000000
Table 7 Command output
RPF information of the IPv6 multicast source 2001::101.
RPF interface
Type and number of the RPF interface.
RPF neighbor
IPv6 address (link-local address) of the RPF neighbor.
Referenced route and its prefix length.
Type of the referenced route:
·     igp—IPv6 IGP unicast route.
·     egp—IPv6 EGP unicast route.
·     unicast (direct) —IPv6 directly connected unicast route.
·     unicast—Other IPv6 unicast route, such as IPv6 unicast static route.
·     mbgp—IPv6 MBGP route.
RPF route selection rule:
·     Route preference.
·     Longest prefix match.
Load splitting rule
Whether load splitting is enabled.
Source AS
AS number of the source-side PE.
Route target attribute value of the C-multicast route.
ipv6 mtrace-service port
Use ipv6 mtrace-service port to specify the UDP port number used by IPv6 mtrace.
Use undo ipv6 mtrace-service port to restore the default.
ipv6 mtrace-service port number
IPv6 mtrace uses UDP port number 10240.
number: Specifies a UDP port number to be used by IPv6 mtrace, in the range of 1024 to 49151.
For successful IPv6 mtrace, do not specify a UDP port number used by other modules.
You must specify the same UDP port number on all devices on the traced path. Additionally, the specified UDP port number must be the same as that specified in the mtrace v2 command.
# Specify 12345 as the UDP port number used by IPv6 mtrace.
<Sysname> system-interview
[sysname] ipv6 mtrace-service port 12345
mtrace v2 ipv6
Use ipv6 multicast boundary to configure an IPv6 multicast forwarding boundary.
Use undo ipv6 multicast boundary to delete an IPv6 multicast forwarding boundary.
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length| all | scope { scope-id | admin-local | global | organization-local | site-local } }
An interface is not an IPv6 multicast forwarding boundary.
Interface view
prefix-length: Specifies the address prefix length in the range of 8 to 128.
all: Specifies all IPv6 multicast boundaries configured on the interface.
scope-id: Specifies the ID of an admin-scoped zone, in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address.
admin-local: Specifies the scoped zone as admin-local, which has a scope ID of 4.
global: Specifies the scoped zone as global, which has a scope ID of 14.
organization-local: Specifies the scoped zone as organization-local, which has a scope ID of 8.
site-local: Specifies the scoped zone as site-local, which has a scope ID of 5.
A multicast forwarding boundary sets the boundary condition for the IPv6 multicast groups in the specified address range. If the destination address of an IPv6 multicast packet matches the set boundary condition, the packet is not forwarded.
An interface can act as a forwarding boundary for multiple IPv6 multicast groups in different address ranges. You can implement this by using this command on the interface for each multicast address range. These multicast groups must be in the same scope. The latest configuration of a scope overwrites the previous one.
You do not need to enable IPv6 multicast routing before you execute this command.
Assume that Set A and Set B are both IPv6 multicast forwarding boundary sets with different address ranges, and that B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the range of FF03::/16.
[Sysname-Vlan-interface100] ipv6 multicast boundary ff03:: 16
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the admin-local scope.
[Sysname-Vlan-interface100] ipv6 multicast boundary scope 4
ipv6 multicast forwarding supervlan community
Use ipv6 multicast forwarding supervlan community to enable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN.
Use undo ipv6 multicast forwarding supervlan community to disable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN.
IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN is disabled.
VLAN interface view
For this command to take effect, you must clear all IPv6 multicast forwarding entries with the super VLAN interface as the incoming interface after executing this command. To clear IPv6 multicast forwarding entries, use the reset ipv6 multicast forwarding-table command.
# Enable IPv6 multicast forwarding between sub-VLANs that are associated with the super VLAN 2.
[Sysname-Vlan-interface2] ipv6 multicast forwarding supervlan community
Use ipv6 multicast routing to enable IPv6 multicast routing and enter IPv6 MRIB view.
Use undo ipv6 multicast routing to disable IPv6 multicast routing.
IPv6 multicast routing is disabled.
Other Layer 3 IPv6 multicast commands take effect only when IPv6 multicast routing is enabled.
The device does not forward any IPv6 multicast packets before IPv6 multicast routing is enabled.
# Enable IPv6 multicast routing, and enter IPv6 MRIB view.
[Sysname] ipv6 multicast routing
[Sysname-mrib6]
load-splitting (IPv6 MRIB view)
Use load-splitting to enable IPv6 multicast load splitting.
Use multicast load-splitting to restore the default.
undo load-splitting
IPv6 multicast load splitting is disabled.
IPv6 MRIB view
source: Enables IPv6 multicast load splitting based on IPv6 multicast source.
source-group: Enables IPv6 multicast load splitting based on IPv6 multicast source and group.
# Enable IPv6 multicast load splitting based on IPv6 multicast source.
[Sysname-mrib6] load-splitting source
longest-match (IPv6 MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route selection.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest route preference is used as the RPF route.
IPv6 MRIB view
This command enables the device to use the matching route with the longest prefix as the RPF route.
# Specify the longest prefix match principle for RPF route selection.
[Sysname-mrib6] longest-match
mtrace v2 ipv6
Use mtrace v2 ipv6 to trace an IPv6 multicast path through mtrace2.
mtrace v2 ipv6 { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ]
source-address: Specifies an IPv6 multicast source by its IPv6 address.
group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers from 0 to F.
destination address: Specifies the destination address of IPv6 mtrace. The default destination address is FF02::2.
port number: Specifies a UDP port number for IPv6 mtrace, in the range of 1024 to 49151. The default value is 10240.
wait-time time: Specifies the length of time that the client waits for a Reply message. The value range for the time argument is 1 to 65535 seconds and the default value is 10 seconds. If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop IPv6 mtrace.
max-hop count: Specifies the maximum number of the hops to be traced. The value range for the count argument is 1 to 255 and the default value is 255. If the maximum number of hops is reached on a device, the device directly sends a Reply message to the client and the mtrace is terminated.
verbose: Displays detailed information about IPv6 mtrace. If you do not specify this keyword, the command displays brief information about IPv6 mtrace.
To perform a non-group-specific mtrace, specify an IPv6 multicast source and a destination. The mtrace starts from the destination and ends at the device directly connected to the source.
To perform a non-source-specific mtrace, specify an IPv6 multicast group and a destination. The mtrace starts from the destination and ends at the RP associated with the group.
To perform a source-and-group-specific mtrace, specify both an IPv6 multicast source and an IPv6 multicast group. If you also specify a destination, the mtrace starts from the destination and ends at the device directly connected to the source. If you do not specify a destination, the mtrace starts from the upstream device of the client and ends at the device directly connected to the source.
An IPv6 mtrace process stops if the maximum number of the hops to be traced is reached.
If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If the client receives a Reply message within the waiting time, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace2 to trace the path along which IPv6 multicast data of group FF1E::1 travels from source 10::7 to destination 50::5 and display brief mtrace information.
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5
 Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, press
CTRL_C to break.
 Querying full reverse path...
  Hop  Local address                       Protocol       Time    Fwd code
    0  50::1                               PIM-SM(OSPF)   50 s    NO_ERROR
   -1  40::1                               PIM-SM(OSPF)   40 s    NO_ERROR
   -2  30::1                               PIM-SM(OSPF)   60 s    NO_ERROR
   -3  20::1                               PIM-SM(OSPF)   55 s    NO_ERROR
   -4  10::1                               PIM-SM(OSPF)   30 s    NO_ERROR
Table 8 Command output
Hop
Number of the hop. 0 represents the last hop, -1 represents the hop before the last hop, and so on.
Local address
IPv6 address of this hop on the traced path.
Protocol
Multicast routing protocol used between this device and the previous-hop device:
·     PIM-SM.
·     PIM-DM.
Unicast routing protocol used between this device and the previous-hop device:
·     LOCAL—Direct route.
·     STATIC ROUTE—Static route.
·     RIP.
·     ISIS.
·     OSPF.
·     BGP.
Time
Length of time used to transmit an mtrace message between this device and the previous-hop device, in seconds.
Fwd code
Forwarding code or error code:
·     NO_ERROR—No error.
·     WRONG_IF—The interface on which the mtrace message arrives is not in the outgoing interface list of the multicast data.
·     PRUNE_SENT—This device has sent a prune message to the upstream device.
·     PRUNE_RCVD—This device has received a prune message from the downstream device.
·     SCOPED—A multicast border is configured on the incoming interface or outgoing interface of the multicast data.
·     NO_ROUTE—This device does not have any route for the source or the RP.
·     WRONG_LAST_HOP—This device is not the expected last-hop device.
·     REACHED_RP—This device is the RP for the (*, G) multicast data.
·     RPF_IF—The mtrace message arrived on the RPF interface for the multicast data.
·     NO_MULTICAST—The mtrace message arrived on an interface that is not enabled with IP multicast.
·     NO_SPACE—No space is available for inserting a response data block in the packet.
# Use mtrace2 to trace the path along which IPv6 multicast data of group FF1E::1 travels from source 10::7 to destination 50::5 and display detailed mtrace information.
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5 verbose
 Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, use query
ID 12345, client port 50001, press CTRL_C to break.
    0: Incoming interface ID: 1501
       Outgoing interface ID: 1502
       Local address: 50::1
       Remote address: FE80::A27B:99FF:FECB:207
       Input multicast packets: 111
       Output multicast packets: 111
       Forwarded packets for the (S, G) pair: 22
       Multicast protocol in use: PIM-SM
       Unicast protocol in use: OSPF
       Forwarding code: NO_ERROR
       Time used (s): 50
   -1: Incoming interface ID: 1601
       Outgoing interface ID: 1602
       Local address: 40::1
       Remote address: FE80::A27B:99FF:FECB:206
       Time used (s): 50
Table 9 Command output
n
Index of the incoming interface of the IPv6 multicast data.
Index of the outgoing interface of the IPv6 multicast data.
Local address
Remote address
IPv6 address of the upstream device.
Statistics of packets received on the incoming interface of the IPv6 multicast data.
Statistics of packets forwarded through the outgoing interface of the IPv6 multicast data.
Statistics of forwarded (S, G) packets.
Multicast routing protocol running on the incoming interface of the multicast data.
Unicast routing protocol running on the incoming interface of the multicast data.
Forwarding code
Time used (s)
Length of time for transmitting the mtrace message from the previous-hop device to this device.
Use reset ipv6 multicast fast-forwarding cache to clear IPv6 multicast fast forwarding entries.
reset ipv6 multicast fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears IPv6 multicast fast forwarding entries for the master device.
all: Specifies all IPv6 multicast fast forwarding entries.
# Clear all IPv6 multicast fast forwarding entries.
<Sysname> reset ipv6 multicast fast-forwarding cache all
# Clear the IPv6 multicast fast forwarding entry for IPv6 multicast source and group (FE1F:20::2, FF0E::1).
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
Use reset ipv6 multicast forwarding event to clear statistics for IPv6 multicast forwarding events.
# Clear statistics for the IPv6 multicast forwarding events.
<Sysname> reset ipv6 multicast forwarding event
Use reset ipv6 multicast forwarding-table to clear IPv6 multicast forwarding entries.
reset ipv6 multicast forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
prefix-length: Specifies the address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 multicast forwarding entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast forwarding entries.
When you clear an IPv6 multicast forwarding entry, the associated IPv6 multicast routing entry is also cleared.
# Clear IPv6 multicast forwarding entries for IPv6 multicast group FF0E::1.
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
Use reset ipv6 multicast routing-table to clear IPv6 multicast routing entries.
reset ipv6 multicast routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
incoming-interface: Specifies the IPv6 multicast routing entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast routing entries.
When you clear an IPv6 multicast routing entry, the associated IPv6 multicast forwarding entry is also cleared.
# Clear IPv6 multicast routing entries for IPv6 multicast group FF03::101.
<Sysname> reset ipv6 multicast routing-table ff03::101
