- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-SAVI commands
- 22-SAVA commands
- 23-MFF commands
- 24-Crypto engine commands
- 25-FIPS commands
- 26-802.1X client commands
- 27-IP-SGT mapping commands
- 28-Microsegmentation commands
18-ARP attack protection commands | 243.37 KB |
Unresolvable IP attack protection commands
arp resolving-route probe-count
arp resolving-route probe-interval
display arp source-suppression
display arp source-suppression cache
ARP packet rate limit commands
ARP packet source MAC consistency check commands
ARP active acknowledgement commands
arp detection port-match-ignore
display arp detection statistics attack-source
display arp detection statistics packet-drop
reset arp detection statistics attack-source
reset arp detection statistics packet-drop
ARP scanning and fixed ARP commands
ARP keepalive entry scanning commands
display arp scan keepalive entry
display arp scan keepalive statistics
reset arp scan keepalive statistics
ARP gateway protection commands
ARP packet sender IP address checking commands
arp resolving-route enable
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable ARP blackhole routing.
ARP blackhole routing is enabled.
Configure this command on the gateways.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
Use arp resolving-route probe-count to set the number of ARP blackhole route probes for each unresolved IP address.
Use undo arp resolving-route probe-count to restore the default.
arp resolving-route probe-count count
The device performs three ARP blackhole route probes for each unresolved IP address.
count: Sets the number of probes, in the range of 1 to 25.
# Configure the device to perform five ARP blackhole route probes for each unresolved IP address.
[Sysname] arp resolving-route probe-count 5
Use arp resolving-route probe-interval to set the interval at which the device probes ARP blackhole routes.
Use undo arp resolving-route probe-interval to restore the default.
arp resolving-route probe-interval interval
The device probes ARP blackhole routes every 1 second.
interval: Specifies the probe interval in the range of 1 to 5 seconds.
# Configure the device to probe ARP blackhole routes every 3 seconds.
[Sysname] arp resolving-route probe-interval 3
arp source-suppression enable
Use arp source-suppression enable to enable the ARP source suppression feature.
Use undo arp source-suppression enable to disable the ARP source suppression feature.
The ARP source suppression feature is disabled.
Configure this feature on the gateways.
# Enable the ARP source suppression feature.
[Sysname] arp source-suppression enable
arp source-suppression limit
Use arp source-suppression limit to set the maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
Use undo arp source-suppression limit to restore the default.
The device can process a maximum of 10 unresolvable packets per source IP address within 5 seconds.
limit-value: Specifies the limit in the range of 2 to 1024.
If unresolvable packets received from an IP address within 5 seconds exceed the limit, the device stops processing the packets from that IP address until the 5 seconds elapse.
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Sysname] arp source-suppression limit 100
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
ARP source suppression is enabled
Current suppression limit: 100
Current suppression limit |
Maximum number of unresolvable packets that can be processed per source IP address within 5 seconds. |
Use display arp source-suppression cache to display ARP source suppression entries.
display arp source-suppression cache [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its ID.
# Display ARP source suppression entries.
<Sysname> display arp source-suppression cache
Interface IP address Attack Time Block Time Try times
XGE1/0/1 100.1.1.10 2021-11-09 11:05:20 2021-11-09 11:05:48 10
XGE1/0/2 100.1.4.10 2021-11-09 11:28:02 2021-11-09 11:28:37 5
Name of the interface. |
IP address |
IP address in the ARP source suppression entry. |
Attack Time |
Time when the entry was created. |
Block Time |
Time when the number of ARP source suppression entries reached the threshold. |
Try times |
Times of resolving unknown IP addresses. |
arp rate-limit
Use arp rate-limit to enable the ARP packet rate limit feature on an interface.
Use undo arp rate-limit to disable the ARP packet rate limit feature on an interface.
arp rate-limit [ pps ]
undo arp rate-limit
The ARP packet rate limit feature is enabled on an interface.
pps: Specifies the upper limit for ARP packet rate in pps. The value range for this argument is 5 to 1000.
If you do not specify a value for the pps argument in the arp rate-limit command, the default rate limit value applies. Packets that exceed the rate limit are discarded.
If you set both ARP packet rate limit on an interface and source MAC-based ARP packet rate limit, the rate limit that takes effect varies by device model.
The ARP packet rate limit configured in Ethernet interface view or aggregate interface view takes effect only on the current interface. The limit on an aggregation member port takes effect only when the member port leaves the aggregation group.
# Enable the ARP packet rate limit feature on Ten-GigabitEthernet 1/0/1, and set the maximum ARP packet rate to 50 pps.
[Sysname-Ten-GigabitEthernet1/0/1] arp rate-limit 50
arp rate-limit source-mac
arp rate-limit log enable
Use arp rate-limit log enable to enable logging for ARP packet rate limit.
Use undo arp rate-limit log enable to disable logging for ARP packet rate limit.
Logging for ARP packet rate limit is disabled.
When logging for ARP packet rate limit is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a log message to the information center. You can configure the information center module to set the log output rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
# Enable logging for ARP packet rate limit.
[Sysname] arp rate-limit log enable
arp rate-limit log interval
Use arp rate-limit log interval to set the notification and log message sending interval for ARP packet rate limit.
Use undo arp rate-limit log interval to restore the default.
arp rate-limit log interval interval
The device sends notifications or log messages every 60 seconds when the rate of ARP packets received on an interface exceeds the limit.
interval: Specifies an interval in the range of 1 to 86400 seconds.
To change the default interval and activate it, you must enable ARP packet rate limit and enable sending notifications or log messages for ARP packet rate limit.
# Set the device to send notifications and log messages every 120 seconds when the rate of ARP packets received on an interface exceeds the limit.
[Sysname] arp rate-limit log interval 120
arp rate-limit
snmp-agent trap enable arp
SNMP notifications for ARP
Use snmp-agent trap enable arp to enable SNMP notifications for ARP.
Use undo snmp-agent trap enable arp to disable SNMP notifications for ARP.
snmp-agent trap enable arp [ rate-limit ]
undo snmp-agent trap enable arp [ rate-limit ]
SNMP notifications for ARP is disabled.
rate-limit: Specifies the ARP packet rate limit feature. If you do not specify this keyword, this command enables all types of SNMP notifications for ARP.
If you specify the rate-limit keyword, the device sends the peak rate as a notification to the SNMP module when the ARP packet rate on an interface exceeds the specified rate limit.
For ARP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for ARP packet rate limit.
[Sysname] snmp-agent trap enable arp rate-limit
arp valid-check enable
Use arp valid-check enable to enable ARP packet source MAC address consistency check.
Use undo arp valid-check enable to disable ARP packet source MAC address consistency check.
ARP packet source MAC address consistency check is disabled.
Configure this feature on gateways. The gateways can filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp valid-check enable
arp active-ack enable
Use arp active-ack enable to enable the ARP active acknowledgement feature.
Use undo arp active-ack enable to disable the ARP active acknowledgement feature.
arp active-ack [ strict ] enable
undo arp active-ack [ strict ] enable
The ARP active acknowledgement feature is disabled.
strict: Enables strict mode for ARP active acknowledgement.
Configure this feature on gateways to prevent user spoofing.
# Enable the ARP active acknowledgement feature.
[Sysname] arp active-ack enable
Authorized ARP commands
arp authorized enable
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to disable authorized ARP on an interface.
Authorized ARP is disabled on the interface.
VSI interface view
VLAN interface view
# Enable authorized ARP on VLAN-interface 200.
[Sysname] interface vlan-interface 200
[Sysname-Vlan-interface200] arp authorized enable
ARP attack detection commands
arp detection enable
Use arp detection enable to enable ARP attack detection.
Use undo arp detection enable to disable ARP attack detection.
ARP attack detection is disabled.
VLAN view
VSI view
A Layer 2 Ethernet interface is enabled with ARP attack detection after you enable ARP attack detection on the interface or in the VLAN to which the interface belongs.
A Layer 2 Ethernet interface is disabled with ARP attack detection only after you disable ARP attack detection both on the interface and in the VLAN to which the interface belongs.
If a Layer 2 Ethernet interface is both enabled with ARP attack detection and configured as an ARP trusted port, the system does not perform ARP attack detection on packets received on the interface.
# Enable ARP attack detection on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] arp detection enable
# Enable ARP attack detection for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
# Enable ARP attack detection for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp detection enable
arp detection rule
arp detection log enable
Use arp detection log enable to enable ARP attack detection logging.
Use undo arp detection log enable to disable ARP attack detection logging.
arp detection log enable [ interval interval | number number | threshold threshold-value ] *
ARP attack detection logging is disabled.
interval interval: Specifies the interval for sending ARP attack detection logs to the information center, in seconds. The value for this argument can be 0 or a value in the range of 10 to 3600. The default value is 60. If you set the interval to 0 seconds, the device sends ARP detection logs to the information center immediately.
number number: Specifies the maximum number of ARP attack detection logs for each log output. The value range for the number argument is 1 to 128, and the default value is 128.
threshold threshold-value: Specifies the per-destination address threshold for ARP attack detection logging. When the number of ARP packets destined for a destination address reaches or exceeds the threshold, the device generates an ARP attack detection log. The value range for the threshold-value argument is 1 to 128, and the default is 1.
This feature enables the device to generate ARP detection logs and send them to the information center. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
Excessive number of logs not only affects the device performance, but also makes it difficult for you to locate logs for specific events. To resolve the issue, you can adjust the maximum number of ARP attack detection logs for each log output. The logs that exceed the number limit will not be output and displayed. In addition, you can also adjust the per-destination address threshold for logging. The device generates a log only when the number of packets destined for a destination address reaches or exceeds the threshold.
An IRF member device can send a maximum of 128 ARP attack detection logs each time.
# Enable ARP attack detection logging.
[Sysname] arp detection log enable
Use arp detection port-match-ignore to ignore ingress ports of ARP packets during user validity check.
Use undo arp detection port-match-ignore to remove the configuration.
Ingress ports of ARP packets are checked for user invalidity.
This command configures ARP attack detection to ignore the ingress port information of ARP packets when the packets are compared with the entries used for user validity check.
# Ignore ingress ports of ARP packets during user validity check.
[Sysname] arp detection port-match-ignore
arp detection rule
Use arp detection rule to configure a user validity check rule.
Use undo arp detection rule to delete a user validity check rule.
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id | vsi vsi-name ]
undo arp detection rule [ rule-id ]
No user validity check rule is configured.
rule-id: Assigns an ID to the user validity check rule. The ID value range is 0 to 511. A smaller value represents a higher priority.
deny: Denies matching ARP packets.
permit: Permits matching ARP packets.
ip { ip-address [ mask ] | any }: Specifies the sender IP address as the match criterion.
· ip-address: Specifies an IP address in dotted decimal notation.
· mask: Specifies the address mask in dotted decimal notation. If you do not specify the mask, the ip-address argument specifies a host IP address.
· any: Matches any IP address.
mac { mac-address [ mask ] | any }: Specifies the sender MAC address as the match criterion.
· mac-address: Specifies a MAC address in the H-H-H format.
· mask: Specifies the MAC address mask in the H-H-H format. If you do not specify the mask, the argument specifies the host MAC address.
· any: Matches any MAC address.
vlan vlan-id: Specifies the ID of a VLAN in the specified rule. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, the packets' VLAN information is not checked.
vsi vsi-name: Specifies the name of a VSI in the specified rule, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, the packets' VSI information is not checked.
A user validity check rule takes effect only when ARP attack detection is enabled.
If you do not specify a rule ID, the undo arp detection rule command deletes all user validity check rules.
For the VSI information in the user validity check rule to take effect, enable L2VPN by using the l2vpn enabl command.
# Configure a user validity check rule and enable ARP detection for VLAN 2.
[Sysname] arp detection rule 0 permit ip 10.1.1.1 255.255.0.0 mac 0001-0203-0405 ffff-ffff-0000
[Sysname] vlan 2
# Configure a user validity check rule and enable ARP detection for VSI vpna.
[Sysname] arp detection rule 1 permit ip 10.1.1.2 255.255.0.0 mac 0001-0203-0406 ffff-ffff-0000 vsi vpna
[Sysname] vsi vpna
[Sysname-vsi-vpna] arp detection enable
arp detection trust
Use arp detection trust to configure an interface as an ARP trusted interface or configure an AC as an ARP trusted AC.
Use undo arp detection trust to restore the default.
arp detection trust
An interface is an ARP untrusted interface. An AC is an ARP untrusted AC.
Ethernet service instance view
# Configure Ten-GigabitEthernet 1/0/1 as an ARP trusted interface.
[Sysname-Ten-GigabitEthernet1/0/1] arp detection trust
# Configure Ethernet service instance 1 on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 as an ARP trusted AC.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] arp detection trust
arp detection validate
Use arp detection validate to enable ARP packet validity check.
Use undo arp detection validate to disable ARP packet validity check.
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP packet validity check is disabled.
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
src-mac: Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
You can specify more than one object to be checked in one command line.
If no keyword is specified, the undo arp detection validate command disables ARP packet validity check for all objects.
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac ip src-mac
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
ARP restricted forwarding is disabled.
VLAN view
# Enable ARP restricted forwarding in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp restricted-forwarding enable
Use display arp detection to display the VLANs, VSIs, and interfaces that are enabled with ARP attack detection.
# Display the VLANs, VSIs, and interfaces that are enabled with ARP attack detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1-2, 4-5
ARP detection is enabled in the following VSIs:
vpna
vsi-0000-0000-0031
vpnb
vpnc-vsi-0000-0000-00aa
ARP detection is enabled on the following interfaces:
Bridge-Aggregation1
ARP detection is enabled in the following VLANs |
VLANs that are enabled with ARP attack detection. This field displays ARP detection is not enabled in any VLANs if no VLANs are enabled with ARP attack detection. |
ARP detection is enabled in the following VSIs |
VSIs that are enabled with ARP attack detection. This field displays ARP detection is not enabled in any VSIs if no VSIs are enabled with ARP attack detection. |
ARP detection is enabled on the following interfaces |
Interfaces enabled with ARP attack detection. This field displays ARP detection is not enabled in any interfaces if no interfaces are enabled with ARP attack detection. |
Use display arp detection statistics attack-source to display statistics for ARP attack sources.
display arp detection statistics attack-source slot slot-number
slot slot-number: Specifies an IRF member device by its ID. If you do not specify a member device, this command displays ARP attack source statistics for the master device.
This command displays a maximum of 1023 statistic entries for ARP attack sources and 1 identification entry.
When the maximum number is reached for the first time, the device overwrites the oldest statistics entry with the newest statistic entry and generates an identification entry. The parameters in the identification entry are as follows:
· The Interface, VLAN, MAC address, and IP address fields are empty.
· The Number field displays the value of the Number filed in the old entry that has been overwritten.
· The Time field displays the time when the new entry was generated.
Subsequently, each time a new statistic entry is generated, the device updates the identification entry as follows:
· Adds the Number field value of the new entry to the current value of the Number field.
· Replaces the Time field value with the time when this identification entry was updated.
# Display statistics for ARP attack sources on slot 1.
<Sysname> display arp detection statistics attack-source slot 1
Interface VLAN MAC address IP address Number Time
XGE1/0/1 1 0005-0001-0001 10.1.1.14 24 17:09:56
03-27-2017
Receiving interface of ARP attack packets. |
VLAN |
VLAN to which ARP attack packets belong. |
MAC address |
Sender MAC address in ARP attack packets. |
IP address |
Sender IP address in ARP attack packets. |
Number |
Number of ARP attack packets dropped by ARP attack detection. |
Time |
The most recent time when ARP attack detection dropped an ARP attack packet. |
Use display arp detection statistics packet-drop to display statistics for packets dropped by ARP attack detection.
display arp detection statistics packet-drop [ interface interface-type interface-number [ service-instance instance-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays dropped packet statistics for all interfaces and all Ethernet service instances on the interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID. If you do not specify an Ethernet service instance, this command displays dropped packet statistics for all Ethernet service instances on the specified interface.
This command displays numbers of packets discarded by user validity check and ARP packet validity check on interfaces or Ethernet service instances on the interfaces.
# Display statistics for packets dropped by ARP attack detection.
<Sysname> display arp detection statistics packet-drop
State: U-Untrusted T-Trusted
ARP packets dropped by ARP inspect checking:
Interface/AC(State) IP Src-MAC Dst-MAC Inspect
XGE1/0/1(U) 40 0 0 78
XGE1/0/2(U) 0 0 0 0
XGE1/0/3(T) 0 0 0 0
XGE1/0/4(U) 0 0 30 0
XGE1/0/5-srv1(U) 0 10 20 0
XGE1/0/5-srv2(T) 10 0 20 22
Table 5 Command output
State |
State of an interface: · U—ARP untrusted interface or AC. · T—ARP trusted interface or AC. |
Interface/AC(State) |
Inbound interface or AC of ARP packets. State specifies the port or AC state, trusted or untrusted. |
IP |
Number of ARP packets discarded due to invalid sender and target IP addresses. |
Src-MAC |
Number of ARP packets discarded due to invalid source MAC address. |
Dst-MAC |
Number of ARP packets discarded due to invalid destination MAC address. |
Inspect |
Number of ARP packets that failed to pass user validity check. |
Use reset arp detection statistics attack-source to clear statistics for ARP attack sources.
reset arp detection statistics attack-source [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its ID. If you do not specify a member device, this command clears ARP attack source statistics for the master device.
# Clear statistics for ARP attack sources.
<Sysname> reset arp detection statistics attack-source
Use reset arp detection statistics packet-drop to clear statistics for packets dropped by ARP attack detection.
reset arp detection statistics packet-drop [ interface interface-type interface-number [ service-instance service-instance-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears dropped packet statistics for all interfaces and all Ethernet service instances on the interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID. If you do not specify an Ethernet service instance, this command clears dropped packet statistics for all Ethernet service instances on the specified interface.
# Clear statistics for packets dropped by ARP attack detection.
<Sysname> reset arp detection statistics packet-drop
arp fixup
Use arp fixup to convert existing dynamic ARP entries to static ARP entries.
Use undo arp fixup to convert valid static ARP entries to dynamic ARP entries and delete invalid static ARP entries.
arp fixup
undo arp fixup
The ARP conversion is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
The static ARP entries converted from dynamic ARP entries have the same attributes as the manually configured static ARP entries. Due to the device's limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
The static ARP entries after conversion can include the following entries:
· Existing dynamic and static ARP entries before conversion.
· New dynamic ARP entries learned during the conversion.
Dynamic ARP entries that are aged out during the conversion are not converted to static ARP entries.
To delete a static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Convert existing dynamic ARP entries to static ARP entries.
[Sysname] arp fixup
arp scan
Use arp scan to trigger an ARP scanning in an address range.
arp scan [ start-ip-address to end-ip-address ] [ send-rate { ppm ppm | pps } ]
VSI interface view
VLAN interface view
start-ip-address: Specifies the start IP address of the scanning range.
end-ip-address: Specifies the end IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
send-rate: Specifies the rate at which the device sends ARP requests for ARP scanning.
ppm ppm: Specifies the ARP packet sending rate, in packets per minute (ppm). The value range for the ppm argument is 10 to 600, and the value must be a multiple of 10.
ppm pps: Specifies the ARP packet sending rate, in packets per second (pps). The value range for the pps argument is 10 to 1000, and the value must be a multiple of 10.
CAUTION: ARP scanning will take some time and occupy a lot of system and network resources. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated. |
ARP scanning automatically creates ARP entries for devices in the specified address range. IP addresses already in existing ARP entries are not scanned.
If the interface's primary and secondary IP addresses are in the address range, the sender IP address in the ARP request is the address on the smallest network segment.
If no address range is specified, the device learns ARP entries for devices on the subnet where the primary IP address of the interface resides. The sender IP address in the ARP requests is the primary IP address of the interface.
The start and end IP addresses must be on the same subnet as the primary IP address or secondary IP addresses of the interface.
You can set the ARP packet sending rate if the scanning range has a large number of IP addresses. This setting can avoid high CPU usage and heavy network load caused by a burst of ARP traffic.
When you set the sending rate to a large value, the device might use a rate lower than the specified rate to ensure the device performance.
If you do not set the ARP packet sending rate, the device sends ARP requests to all IP addresses in the specified scanning range simultaneously.
# Configure the device to scan the neighbors on the network where the primary IP address of VLAN-interface 2 resides.
[Sysname-Vlan-interface2] arp scan
# Configure the device to scan neighbors in an address range.
[Sysname-Vlan-interface2] arp scan 1.1.1.1 to 1.1.1.20
# Configure the device to scan neighbors in an address range on VLAN-interface 2 and set the ARP packet sending rate to 10 pps.
[Sysname-Vlan-interface2] arp scan 1.1.1.1 to 1.1.1.20 send-rate 10
arp scan auto enable
Use arp scan auto enable to enable automatic ARP scanning on an interface.
Use undo arp scan auto enable to disable automatic ARP scanning on an interface.
arp scan auto enable [ start-ip-address to end-ip-address ]
Automatic ARP scanning is disabled on an interface.
VSI interface view
VLAN interface view
Automatic ARP scanning enables an interface to update its ARP entries in time. It automatically sends ARP requests to the IP addresses in the specified address range to create ARP entries for them. IP addresses that already have ARP entries are not scanned any more.
If no address range is specified, the device learns ARP entries for devices on the subnet where the primary IP address of the interface resides. The sender IP address for the ARP requests is the primary IP address of the interface.
You can set the ARP request sending rate by using the arp scan auto send-rate command.
If you trigger ARP scanning and enable automatic ARP scanning on an interface, both of them take effect. As a best practice, enable automatic ARP scanning only on networks where user come online and go offline frequently.
# Configure the device to automatically scan the neighbors on the network where the primary IP address of VLAN-interface 2 resides.
[Sysname-Vlan-interface2] arp scan auto enable
Use arp scan auto send-rate to set the ARP packet sending rate for automatic ARP scanning.
Use undo arp scan auto send-rate to restore the default.
arp scan auto send-rate { ppm ppm | pps pps }
The device sends ARP packets at the rate of 48 pps during automatic ARP scanning.
# Set the ARP packet sending rate to 10 pps during automatic ARP scanning.
[Sysname] arp scan auto send-rate pps 10
arp scan keepalive aging-time
Use arp scan keepalive aging-time to set the aging time for ARP keepalive entries.
Use undo arp scan keepalive aging-time to restore the default.
arp scan keepalive aging-time time
The aging time for ARP keepalive entries is 60 minutes.
time: Specifies the aging time for ARP keepalive entries in minutes. The value range for this argument is 1 to 1440.
With ARP keepalive entry scanning enabled, the device generates a keepalive entry in online state for a user that comes online. If the user goes offline, the device will perform the following tasks:
· Set the state of the keepalive entry for that user to offline state.
· Delete the keepalive entry if its state does not restore to online after the aging time elapses.
A short aging time causes the keepalive entries to have not enough time to restore online state. A long aging time leads to entry redundancy.
# Set the aging time for ARP keepalive entries to 10 minutes.
[Sysname] arp scan keepalive aging-time 10
arp scan keepalive enable
Use arp scan keepalive enable to enable ARP keepalive entry scanning.
Use undo arp scan keepalive enable to disable ARP keepalive entry scanning.
ARP keepalive entry scanning is disabled on an interface.
VSI interface view
VLAN interface view
In a large-scale network, it takes a long time for ARP scanning to identify the hosts that go offline abnormally if you specify a large scanning range. After you enable ARP keepalive entry scanning, the system can quickly locate those hosts and monitor the host status within the aging time.
When users come online, the system generates dynamic APR entries and IPSG binding entries. Enabled with ARP keepalive entry scanning, the system also creates online keepalive entries when users come online. If users go offline, the corresponding APR entries are deleted and the status of the keepalive entries is set to offline. The device sends ARP requests at intervals to the IP addresses in the offline keepalive entries until the keepalive entries become online again.
The interval varies with the number of ARP requests that have been sent to the IP address in an offline keepalive entry:
· If the number is not greater than 50, the device sends an ARP request every 30 seconds.
· If the number is greater than 50 but not greater than 100, the device sends an ARP request every 45 seconds.
· If the number is greater than 100, the device sends an ARP request every 60 seconds.
To view the keepalive entries, use the display arp scan keepalive entry command.
For more information about IP source guard configuration, see Security Configuration Guide.
To set the aging time for ARP keepalive entries, use the arp scan keepalive aging-time command. The offline keepalive entries are deleted when the aging time expires.
# Enable ARP keepalive entry scanning on VLAN-interface 100.
[Sysname-Vlan-interface100] arp scan keepalive enable
arp scan keepalive send-rate
Use arp scan keepalive send-rate to set the ARP request sending rate for keepalive entry scanning.
Use undo arp scan keepalive send-rate to restore the default.
arp scan keepalive send-rate pps
The device sends ARP requests at a rate of 48 pps during keepalive entry scanning.
pps: Specifies the ARP packet sending rate, in packets per second (pps). The value range for this argument is 10 to 1000, and the value must be a multiple of 10.
Enabled with keepalive entry scanning, the interface sends ARP requests to the IP addresses in the offline keepalive entries. To avoid any impact on the device performance, use this command to set the ARP packet sending rate for keepalive entry scanning.
If the status of a keepalive entry is set to offline and does not become online within an interval, the keepalive entry is to be scanned. The interface sends an ARP request per second to the IP address in each keepalive entry to be scanned.
The ARP packet sending rate is the maximum number of scanned keepalive entries per second.
· If the number of keepalive entries to be scanned per second is lower than the sending rate, the device scans all these keepalive entries within a second.
· If the number of keepalive entries to be scanned per second is greater than the sending rate, the device scans the keepalive entries at the sending rate.
# Set the ARP packet sending rate to 10 pps during keepalive entry scanning.
[Sysname] arp scan keepalive send-rate 10
Use display arp scan keepalive entry to display ARP keepalive entries.
display arp scan keepalive entry [ interface interface-type interface-number ] [ count ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP keepalive entries for all interfaces.
count: Displays the total number of ARP keepalive entries.
# Display ARP keepalive entries.
<Sysname> display arp scan keepalive entry
IfIndex: 1281 Slot: 1
IPv4 address: 192.168.56.1 MAC address: 08-00-27-00-50-38
VLANID: 1 SECVLANID: 1
Port index: 1 VRF index: 0
Scan status: 1 Probe Cnt: 10
Scan time: 08:01:01
Table 6 Command output
IfIndex |
Number of the interface. |
IPv4 address |
IPv4 address in the ARP keepalive entry. |
MAC address |
MAC address in the ARP keepalive entry. |
VLANID |
ID of the primary VLAN. |
SECVLANID |
ID of the secondary VLAN. |
Port index |
Number of the port. |
VRF index |
Number of the VRF. |
Scan status |
Status of the ARP keepalive entry: · 0—Offline. · 1—Online. |
Probe Cnt |
Number of scans on the ARP keepalive entry. |
Scan time |
Time when the ARP keepalive entry became offline. |
Use display arp scan keepalive statistics to display statistics about ARP keepalive entry scanning.
display arp scan keepalive statistics [ slot slot-number [ cpu cpu-number ] ] [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics about ARP keepalive entry scanning for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics about ARP keepalive entry scanning on all member devices.
Interfaces enabled with ARP keepalive entry scanning send ARP requests to the IP addresses in offline ARP keepalive entries until the entries restore online state. This command displays the number of the ARP requests sent to the IP addresses in the offline keepalive entries in the last five seconds, one minute, and five minutes.
A great many ARP requests indicate that the number of offline keepalive entries is great or some offline entries remain in offline state for a long time. The reasons and solutions are as follows:
1. Use the display arp scan keepalive entry command to identify the number of offline keepalive entries.
2. If the number of offline keepalive entries is large, check the aging time set for offline keepalive entries. Shorten the aging time if it is too long.
3. If the aging time is proper, the problem might be caused by too many abnormal user offline events. In this case, check the network configuration and condition.
4. If the number of offline keepalive entries is not large, the problem might be because some offline keepalive entries cannot restore online state through ARP requests. In this case, troubleshoot according to the offline entries.
# Display statistics about ARP requests sent to the IP addresses in offline keepalive entries on slot 1.
<Sysname> display arp scan keepalive statistics slot 1
Scanning statistics for slot 1:
Total ARP requests: 1000 packets
Start time for statistics: 12:20:30
Interface 5 secs 1 min 5 mins
Ten-GigabitEthernet1/0/1 123 200 230
Ten-GigabitEthernet1/0/2 0 0 0
Ten-GigabitEthernet1/0/3 0 0 0
Ten-GigabitEthernet1/0/4 0 0 0
Ten-GigabitEthernet1/0/5 0 0 0
Ten-GigabitEthernet1/0/6 0 0 0
Table 7 Command output
Total ARP requests |
Total number of ARP requests sent to the IP addresses in offline keepalive entries. |
Start time for statistics |
Time when the device started counting the number of ARP requests sent to the IP addresses in offline keepalive entries. |
Name of an interface that sends ARP requests to the IP addresses in offline keepalive entries. |
5 secs |
Number of the ARP requests sent in the last five seconds. |
1 min |
Number of the ARP requests sent in the last one minute. |
5 mins |
Number of the ARP requests sent in the last five minutes. |
Use reset arp scan keepalive statistics to clear statistics about ARP keepalive entry scanning.
reset arp scan keepalive statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics about ARP keepalive entry scanning on the master device.
This command clears statistics about the ARP requests sent to the IP addresses in offline keepalive entries.
The ARP request count and the statistics start time displayed by the display arp scan keepalive statistics command are the data collected since the most recent execution of the reset arp scan keepalive statistics command.
# Clear statistics about ARP requests sent to the IP addresses in offline keepalive entries on slot 1.
<Sysname> reset arp scan keepalive statistics slot 1
arp filter source
Use arp filter source to enable ARP gateway protection for a gateway.
Use undo arp filter source to disable ARP gateway protection for a gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for a maximum of eight gateways on an interface or in an Ethernet service instance.
You cannot configure both the arp filter source and arp filter binding commands on the same interface. You can configure both the arp filter binding command on an interface and the arp filter source command in an Ethernet service instance.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] arp filter source 1.1.1.1
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1 in Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
[SysnameTen-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] arp filter source 1.1.1.1
ARP filtering commands
arp filter binding
Use arp filter binding to enable ARP filtering and configure an ARP permitted entry.
Use undo arp filter binding to remove an ARP permitted entry.
undo arp filter binding ip-address
ARP filtering is disabled.
ip-address: Specifies a permitted sender IP address.
mac-address: Specifies a permitted sender MAC address.
If the sender IP and MAC addresses of an ARP packet match an ARP permitted entry, the ARP packet is permitted. If the sender IP and MAC addresses of an ARP packet do not match an ARP permitted entry, the ARP packet is discarded.
You can configure a maximum of eight ARP permitted entries on an interface.
# Enable ARP filtering and configure an ARP permitted entry.
[Sysname-Ten-GigabitEthernet1/0/1] arp filter binding 1.1.1.1 0e10-0213-1023
arp sender-ip-range
Use arp sender-ip-range to specify the sender IP address range for ARP packet checking.
Use undo arp sender-ip-range to restore the default.
arp sender-ip-range start-ip-address end-ip-address
No sender IP address range is specified for ARP packet checking.
VLAN view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address. The end IP address must be higher than or equal to the start IP address.
The gateway discards an ARP packet if its sender IP address is not within the allowed IP address range.
# Specify the sender IP address range 1.1.1.1 to 1.1.1.20 for ARP packet checking in VLAN 2.
[Sysname] vlan 2
[Sysname–vlan2] arp sender-ip-range 1.1.1.1 1.1.1.20
