03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS6812 & S6813 SeriesReference GuidesCommand ReferencesH3C S6812 & S6813 Switch Series Command Reference-R6628Pxx-6W10203-Layer 2—LAN Switching Command Reference
15-L2PT commands
15-L2PT commands 75.59 KB
L2PT commands
display l2protocol statistics
Use display l2protocol statistics to display Layer 2 Protocol Tunneling (L2PT) statistics.
display l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command displays L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
# Display L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
<Sysname> display l2protocol statistics
L2PT statistics information on interface Bridge-Aggregation1:
Protocol  Encapsulated      Decapsulated      Forwarded         Dropped
CDP       0                 0                 0                 0
DLDP      0                 3                 0                 0
EOAM      0                 2                 0                 0
GVRP      8                 4                 9                 2
LACP      0                 0                 0                 0
LLDP      0                 3                 0                 0
MVRP      0                 0                 0                 0
PAGP      0                 1                 0                 0
PVST      0                 0                 0                 0
STP       5                 5                 5                 0
Tunnel    N/A               N/A               100               10
VTP       0                 6                 0                 0
UDLD      0                 0                 0                 0
L2PT statistics information on interface Ten-GigabitEthernet1/0/1:
CDP       0                 0                 0                 0
DLDP      2                 3                 3                 0
EOAM      5                 2                 9                 0
GVRP      8                 4                 9                 2
LACP      0                 0                 0                 0
LLDP      3                 3                 3                 3
MVRP      0                 0                 0                 0
PAGP      5                 1                 7                 3
PVST      0                 0                 0                 0
STP       5                 5                 5                 0
VTP       0                 6                 0                 0
UDLD      0                 0                 0                 0
Encapsulated
Number of encapsulated packets.
The number increases by 1 when the interface receives and encapsulates a protocol packet from a customer network.
For protocol Tunnel, which represents tunneled packets, this field displays N/A.
Decapsulated
Number of decapsulated packets.
The number increases by 1 when the interface receives and decapsulates a tunneled packet from the service provider network.
Forwarded
Number of forwarded packets.
The number increases by 1 when the interface receives a protocol packet and forwards it.
The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and forwards it. If no interface of the PE is connected to customer networks, the number does not increase.
Dropped
Number of dropped packets.
The number increases by 1 when the interface receives a protocol packet and drops it. Protocol packets dropped by hardware are not counted.
The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and drops it.
l2protocol tunnel dot1q
Use l2protocol tunnel dot1q to enable L2PT for a protocol.
Use undo l2protocol tunnel dot1q to disable L2PT for a protocol.
In Layer 2 Ethernet interface view:
l2protocol { all | cdp | cfd | dldp | dtp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
undo l2protocol { all | cdp | cfd | dldp | dtp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
In Layer 2 aggregate interface view:
l2protocol { all | cdp | cfd | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
undo l2protocol { all | cdp | cfd | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
L2PT is disabled for all protocols.
all: Specifies all protocols.
cdp: Specifies CDP.
cfd: Specifies CFD.
dldp: Specifies DLDP.
dtp: Specifies DTP.
eoam: Specifies EOAM.
gvrp: Specifies GVRP.
lacp: Specifies LACP.
lldp: Specifies LLDP. L2PT for LLDP supports LLDP packets from only nearest bridge agents.
mvrp: Specifies MVRP.
pagp: Specifies PAgP.
pvst: Specifies PVST.
stp: Specifies STP.
udld: Specifies UDLD.
vtp: Specifies VTP.
Before you enable L2PT for a protocol on a port, perform the following tasks:
·     Enable the protocol on the CE, and disable the protocol on the port.
·     Enable L2PT only on customer-facing PE ports. If you enable L2PT on ports connected to the service provider network, L2PT determines that the ports are connected to a customer network.
·     Disable the protocol (for example, STP) on the PE ports connecting to an aggregate interface on a CE when the following conditions exist:
¡     The protocol is running on the aggregate interface on the CE.
¡     The aggregate interface on the CE connects to an L2PT-enabled port on the PE.
You can enable L2PT on member ports of a Layer 2 aggregation group, but the configuration does not take effect.
# Disable STP and enable L2PT for STP on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo stp enable
[Sysname-Ten-GigabitEthernet1/0/1] l2protocol stp tunnel dot1q
# Disable STP and enable L2PT for STP on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo stp enable
[Sysname-Bridge-Aggregation1] l2protocol stp tunnel dot1q
l2protocol tunnel-dmac
Use l2protocol tunnel-dmac to set the destination multicast MAC address for tunneled packets of all protocols.
Use undo l2protocol tunnel-dmac to restore the default.
l2protocol tunnel-dmac mac-address
The tunneled packets of all protocols use 010f-e200-0003 as the destination multicast MAC address.
mac-address: Specifies a destination multicast MAC address. The available addresses are 0100-0ccd-cdd0, 0100-0ccd-cdd1, 0100-0ccd-cdd2, and 010f-e200-0003.
The l2protocol tunnel-dmac command sets the destination multicast MAC address for tunneled packets of all protocols. The l2protocol type tunnel-dmac command sets the destination multicast MAC address for tunneled packets of the specified protocol. If both commands are executed, the l2protocol type tunnel-dmac command takes priority.
# Set the destination multicast MAC address to 0100-0ccd-cdd0 for tunneled packets.
[Sysname] l2protocol tunnel-dmac 0100-0ccd-cdd0
Use l2protocol type tunnel-dmac to set the destination multicast MAC address for tunneled packets of the specified protocol.
Use undo l2protocol type tunnel-dmac to restore the default.
l2protocol type { cdp | cfd | dldp | dtp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel-dmac mac-address
undo l2protocol type { cdp | cfd | dldp | dtp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel-dmac
cdp: Specifies CDP.
cfd: Specifies CFD.
dtp: Specifies DTP.
stp: Specifies STP.
vtp: Specifies VTP.
mac-address: Specifies a destination multicast MAC address for tunneled packets of the specified protocol, in the range of 0100-0000-0000 to 01ff-ffff-ffff.
The l2protocol tunnel-dmac command sets the destination multicast MAC address for tunneled packets of all protocols. This command sets the destination multicast MAC address for tunneled packets of the specified protocol. If both commands are executed, the l2protocol type tunnel-dmac command takes priority.
For tunneled packets to be recognized, set the same destination multicast MAC address for packets of the same protocol on PEs that are connected to the same customer network.
If you execute this command multiple times for a protocol, the most recent configuration takes effect.
# Set the destination multicast MAC address to 0100-0ccd-cddc for tunneled packets of CFD.
[Sysname] l2protocol type cfd tunnel-dmac 0100-0ccd-cddc
reset l2protocol statistics
Use reset l2protocol statistics to clear L2PT statistics.
reset l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command clears L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
# Clear L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
<Sysname> reset l2protocol statistics
