01-Fundamentals Command Reference
HomeSupportSwitchesS6812 & S6813 SeriesReference GuidesCommand ReferencesH3C S6812 & S6813 Switch Series Command Reference-R6628Pxx-6W10201-Fundamentals Command Reference
13-License management commands
13-License management commands 114.55 KB
display license
Use display license to display detailed license information.
display license [ activation-file ] [ slot slot-number ]
activation-file: Displays license information about activation files.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices.
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
Slot 1:
flash:/license/210235A1XE01234567892017050317574882633.ak
Feature: APMGR
Product Description: Enhanced Access Controller License,128 APs,for Verticals,fo
r V7
Registered at: 2013-01-01 09:26:52
License Type: Trial (days restricted)
Trial Time Left (days): 30
Current State: In use
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use. If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210235A045B05B0004350
Device ID: flash:/license/210235A045B05B0004350.did
display license feature
Use display license feature to display brief license information for features.
# Display brief feature license information.
<Sysname> display license feature
Slot 1:
Slot 1:
Total: 64  Usage: 0
Feature                         Licensed        State
APMGR                           N               -
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Trial—Trial license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install file-name slot slot-number
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked. A licensed feature can run on the IRF member device where its activation file is installed even after the member device is moved from one IRF fabric to another IRF fabric.
# Install activation file 20130811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20130811.ak slot 1
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
license activation-file uninstall file-name slot slot-number
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 1
Uninstall file: flash:/license/20130811.uak
display license
license compress
Use license compress to compress the license storage.
license compress slot slot-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# Compress the license storage on the specified slot.
[Sysname] license compress slot 1
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
License client commands
display license client
Use display license client to display the license client configuration and the obtained license information on the license client.
# Display the license client configuration and the obtained license information on the license client.
<Sysname> display license client
Username: user
Ciphertext password: ******
License server's IPv6 address: 2008::1, port: 2000
License server's IPv4 address: 1.1.1.1, port: 1000, vpn-instance: test
License client: Enabled, Registering, Miss sync count 0
Cache Size:
  License name: APMGR, cache size: 64
License Count: 1
License Name: APMGR
Licensed Count:32
License Description: H3C WLAN AP Management, 32 licenses
Get Time: 2018-11-22 16:55:01
Figure 1 Command output
Username
Username for accessing the license server.
This field displays Not configured if no username is specified.
Ciphertext password
Password in encrypted form for accessing the license server.
This field displays Not configured if no password is specified.
License server's IPv4 address: 192.168.3.124, port: 5555
IPv4 address and port number of the license server.
License server's IPv6 address: 2001::1, port: 6000
IPv6 address and port number of the license server.
License server's IPv4/IPv6 address: Not configured, port: Not configured
IP address and port number of the license server.
This field displays Not configured if no IP address or port number of the license server is specified.
License client
Status of the license client:
·     Enabled.
·     Disabled.
·     Registering.
·     Registered.
Miss sync count
Number of packets for synchronization that are dropped by the license client.
Cache Size:
Name and size of the license cached on the license client.
License Count
Number of licenses cached on the license client.
ID
Identification of the license allocated by the license server. The license server assigns an ID for each license request.
Licensed Count
Maximum number of licensed nodes in the license. For example, this field displays 32 for the license H3C WLAN AP Management, 32 licenses. The value 32 indicates that the license allows a maximum of 32 concurrent online APs.
For a feature license, this field always displays 1.
License description
Description of the license.
Current State
Current status of the license:
·     In use—The license is in use.
·     Unusable—The license is not in use.
·     Expired (will be reclaimed in n days)—The license is expired and will be reclaimed in n days.
Get Time
Time when the license was obtained from the license server.
display license client statistics
Use display license client statistics to display license statistics on the license client.
# Display license statistics on the license client.
<Sysname> display license client statistics
Name    Type       Total
APMGR   UINT32     64
Name
License name.
License data type:
·     UINT32—Quantity type.
·     BOOL—Boolean type. It defines whether the license client can use the feature.
·     STRING—String type. It defines whether the license client can use the feature with specific settings.
Total
For a quantity type, this field displays total number of licenses.
For a Boolean or string type, this field displays total number of licensed users.
license client config cache
Use license client config cache to configure license cache on the license client.
Use undo license client config cache to disable license cache.
license client config cache license-name license-name size cache-size
undo license client config cache license-name license-name
License cache is not configured. No license can be cached on the license client.
license-name: Specifies a license by its license name. Only string APMGR is supported. Make sure the string is in upper case and not abbreviated.
cache-size: Specifies the maximum number of licenses that can be cached.
# Configure the license client to accommodate a maximum of 64 APMGR licenses.
[Sysname] license client config cache license-name APMGR size 64
license client enable
Use license client enable to enable the license client.
Use undo license client enable to disable the license client.
License client is disabled, and it cannot get licenses from the license server.
Specify the IP address, username, and password of the license server before enabling license client. Otherwise, the configuration fails.
After you enable the license client, the device automatically initiates a connection to the license server. The license server verifies the device identity through the username and password. If they are consistent with those specified on the license server, the device passes authentication. Then the device can apply for licenses from the license server and use the licensed features.
# Enable the license client.
[Sysname] license client enable
license client username
license server
Use license client username to specify the username and password on the license client for accessing the license server.
Use undo license client username to delete the username and password settings.
license client username username password { cipher | simple } password
No username or password is specified on the license client.
username: Specify the username, a case-sensitive string of 1 to 31 characters.
cipher: Specify a password in encrypted form.
password: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 33 to 73 characters.
You can specify only one username and one password on the license client for accessing the license server.
If you execute the command multiple times before enabling the license client, the most recent configuration takes effect.
After the license client is enabled, you cannot modify the username or password. To modify the settings, disable the license client first.
# Specify test and 123456 as the username and password on the license client.
[Sysname] license client username test password simple 123456
license server
Use license server to specify the IP address and port number of the license server.
Use undo license server to delete the license server settings on the license client.
license server { ipv4 ipv4-address | ipv6 ipv6-address } port port-number [ vpn-instance vpn-instance-name ]
undo license server { ipv4 ipv4-address | ipv6 ipv6-address } port port-number [ vpn-instance vpn-instance-name ]
No IP address or port number of the license server is specified.
ipv4 ipv4-address: Specifies the IPv4 address of the license server.
ipv6 ipv6-address: Specifies the IPv6 address of the license server.
port-number: Specifies the port number of the license server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies a VPN instance to which the license server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the license server is on the public network, do not specify this option.
You can specify a maximum of four license servers on the license client. Each license server is uniquely identified by the combination of an IPv4 address and a port number.
When the upper limit is reached, you cannot specify new license servers unless you delete existing license server settings.
As a best practice, make sure only one license server is reachable. If multiple license servers are reachable, the license client selects the first license server with which the client establishes a connection.
After the license client is enabled, you cannot modify the license server settings on the client. To modify the settings, disable the license client first.
# Specify 192.168.100.1 and 5555 as the IPv4 address and port number of the license server, respectively.
[Sysname] license server ipv4 192.168.100.1 port 5555
# Specify 3001::1 and 5555 as the IPv6 address and port number of the license server, respectively.
[Sysname] license server ipv6 3001::1 port 5555
