05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS6812 & S6813 SeriesConfigure & DeployConfiguration GuidesH3C S6812 & S6813 Switch Series Configuration Guide-R6628Pxx-6W10205-Layer 3—IP Routing Configuration Guide
07-Policy-based routing configuration
07-Policy-based routing configuration 309.65 KB
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop and output interface.
Packet forwarding process
When the device receives a packet, the device searches the PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops or output interfaces specified on the node to forward the packet.
b.     Searches the routing table for a route to forward the packet if one of the following conditions exists:
-     No next hops or output interfaces are specified on the node.
-     Forwarding failed based on the next hops or output interfaces.
·     The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
PBR types
PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses but only one if-match clause for each type.
To match a node, a packet must match all types of the if-match clauses for the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node contains apply clauses, PBR executes the apply clauses on the node.
¡     If PBR-based forwarding succeeds, PBR does not compare the packet with the next node.
¡     If PBR-based forwarding fails, PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No.
PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop or output interface.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: PBR configuration
If a packet destined for the local device matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
PBR tasks at a glance
To configure PBR, perform the following tasks:
1.     Configuring a policy
a.     Creating a node
b.     Setting match criteria for a node
c.     Configuring actions for a node
2.     Specifying a policy for PBR
¡     Specifying a policy for local PBR
¡     Specifying a policy for interface PBR
¡     Specifying a policy for global PBR
3.     (Optional.) Enabling PBR to ignore IPv4 packets destined to the local interface
Creating a node
2.     Create a node for a policy, and enter its view.
3.     (Optional.) Configure a description for the policy node.
By default, no description is configured for a policy node.
2.     Enter policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, PBR ignores the action (permit or deny) and time range settings in the ACL.
¡     Set a service chain match criterion.
if-match service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain match criterion is set.
You can use the apply next-hop clause set next hops for matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in PBR
Clause
Meaning
Remarks
apply loadshare next-hop
Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available options in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops are set in the policy.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
If both clauses are configured, only the apply next-hop clause is executed.
apply service-chain
Sets service chain information.
For this clause to take effect, you must also use the apply next-hop clause to specify a reachable next hop.
apply mirror-to-destination
Sets a mirroring action that mirrors packets to the specified destination IP address
This clause enables the device to mirror packets to a specific destination device through a tunnel (for example, a GRE tunnel) for packet analysis and monitoring. The device will encapsulate the specified parameters in the outer header of the mirrored packets.
This clause is always executed for matching packets.
apply fail-action-drop next-hop
Sets the action that drops matching packets when all next hops become invalid.
If no next hops are specified on the policy node, this clause drops all packets that match the policy node.
This clause is typically used in scenarios that require strict routing paths.
If you specify a next hop, PBR periodically performs FIB table lookup to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to direct packet forwarding
3.     Configure actions.
¡     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-6>
By default, no next hops are specified.
On a node, you can specify a maximum of eight next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Enable load sharing among multiple next hops.
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface null 0
By default, no output interfaces are specified.
¡     Set service chain information.
apply service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain information is set.
¡     Set a mirroring action that mirrors packets to the specified destination IP address.
apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ip-address [ source-ip source-ip-address ] [ dscp dscp-value ]
By default, the mirroring action is not set.
¡     Set the action that drops matching packets when all next hops specified on the policy node are invalid.
By default, the drop action is not configured. The matching packets are forwarded based on the typical packet forwarding process as described in "Packet forwarding process."
This command does not apply to software-forwarded packets.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
In a VXLAN IP gateway or EVPN gateway deployment, when you apply a policy to an interface on a border gateway, follow these restrictions and guidelines:
·     If the interface is a Layer 3 Ethernet interface, the policy is also applied to its subinterfaces. For more information about VXLAN IP gateway deployment, see VXLAN Configuration Guide.
·     If the interface is a Layer 3 aggregate interface, the policy is also applied to its subinterfaces. For more information about EVPN gateway deployment, see EVPN Configuration Guide.
2.     Enter interface view.
3.     Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no interface policy is applied to an interface.
Perform this task to apply a policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one policy for global PBR and the specified policy must already exist. Before you can apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
2.     Specify a policy for global PBR.
ip global policy-based-route policy-name
By default, no policy is specified for global PBR.
If the device performs forwarding in hardware and a packet destined for it matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. To prevent PBR from mistakenly forwarding the packet to another device, you can perform this task. Upon receiving a packet destined to any IPv4 addresses (main or secondary) of the interface, the device will ignore PBR settings and deliver the packet to the CPU.
3.     Enable PBR to ignore IPv4 packets destined to the local interface.
ip ignore policy-based-route dest-local enable
By default, PBR does not ignore IPv4 packets destined to the local interface.
Display and maintenance commands for PBR
Display PBR policy information.
display ip policy-based-route [ policy policy-name ]
Display global PBR configuration and statistics.
display ip policy-based-route global [ slot slot-number ]
Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
Display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
Display PBR configuration.
display ip policy-based-route setup
Clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
PBR configuration examples
Example: Configuring packet type-based local PBR
As shown in Figure 1, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2 (Switch B).
Figure 1 Network diagram
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-ipv4-adv-3101] rule permit tcp
[SwitchA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
1.     Perform telnet operations to verify that local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
Example: Configuring packet type-based interface PBR
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2 (Switch B).
Figure 2 Network diagram
1.     Configure IP addresses and unicast routing protocol settings to make sure Switch B and Switch C can reach Host A. (Details not shown.)
2.     Configure Switch A:
# Configure interface PBR by applying the policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip policy-based-route aaa
1.     Perform telnet operations to verify that interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
Example: Configuring packet type-based global PBR
As shown in Figure 3, Switch E and Switch F do not have a route to reach each other.
Configure global PBR on Switch D to forward TCP packets to the next hop 1.1.4.2 (Switch E).
Figure 3 Network diagram
1.     Assign IP addresses to the interfaces, as shown in Figure 3. (Details not shown.)
2.     Configure unicast routing protocol settings to make sure Switch A, B and C can communicate with Switch E and Switch F, respectively. (Details not shown.)
3.     Configure Switch D:
# Configure ACL 3101 to match TCP packets sourced from networks 1.1.1.0/24, 1.1.2.0/24, and 1.1.3.0/24.
<SwitchD> system-view
[SwitchD] acl advanced 3101
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.1.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.2.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.3.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] quit
# Configure node 5 in PBR policy aaa to forward TCP packets that match ACL 3101 to next hop 1.1.4.2.
[SwitchD] policy-based-route aaa permit node 5
[SwitchD-pbr-aaa-5] if-match acl 3101
[SwitchD-pbr-aaa-5] apply next-hop 1.1.4.2
[SwitchD-pbr-aaa-5] quit
# Specify PBR policy aaa as the global PBR policy.
[SwitchD] ip global policy-based-route aaa
1.     Perform telnet operations to verify that global PBR on Switch D operates as configured to forward the matching TCP packets to the next hop 1.1.4.2 (Switch E), as follows:
# Verify that you can telnet to Switch E from Switch A, Switch B, and Switch C successfully. (Details not shown.)
# Verify that you cannot telnet to Switch F from Switch A, Switch B, or Switch C. (Details not shown.)
2.     Verify that Switch D forwards packets other than TCP packets as long as a route is available. For example, verify that you can ping Switch F from Switch A, Switch B, and Switch C. (Details not shown.)
Example: Configuring EVPN-based service chain PBR
As shown in Figure 4, Switch A, Switch B, and Switch C are distributed EVPN gateway devices. Switch D acts as a route reflector to reflect BGP routes for the other switches.
Configure PBR to direct packets sent by Server 1 to Service node 1. After being processed, the packets are forwarded to Server 2.
Figure 4 Network diagram
1.     Configure IP addresses and subnet masks for interfaces, as shown in Figure 4. (Details not shown.)
# Enable L2VPN.
[SwitchA] l2vpn enable
# Disable remote-MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create an EVPN instance in VSI instance view, and configure the system to automatically generate an RT and RD.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Configure BGP to advertise EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 4.4.4.4 as-number 200
[SwitchA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# Create VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 0001-0001-0001
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 3, associate the interface with VPN instance vpna, and set the L3 VXLAN ID to 1000.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] quit
# Associate VSI instance vpna with VSI-interface 1.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Configure VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 11.1.1.1 255.255.255.0
[SwitchA-Vlan-interface11] ospf 1 area 0.0.0.0
# Associate Ethernet service instance 1000 with VSI instance vpna.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
# Create ACL 3000 to permit packets with source IP address 10.1.1.10 and destination IP address 10.1.1.20.
[SwitchA] acl advanced 3000
[SwitchA-acl-ipv4-adv-3000] rule 0 permit ip source 10.1.1.10 0 destination 10.1.1.20
# Create node 0 that uses ACL 3000 to filter packets. Apply next hop 10.1.1.11 and service chain path ID 1 to packets with source IP address 10.1.1.10 and destination IP address 10.1.1.20.
[SwitchA] policy-based-route aa permit node 0
[SwitchA-pbr-aa-0] if-match acl 3000
[SwitchA-pbr-aa-0] apply service-chain path-id 1
[SwitchA-pbr-aa-0] apply next-hop vpn-instance vpna 10.1.1.11
# Apply policy aa to VSI-interface 1.
[SwitchA-Vsi-interface1] ip policy-based-route aa
3.     Configure Switch B:
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
# Configure VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 0001-0001-0001
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
# Configure VSI-interface 3.
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] quit
# Configure Ten-GigabitEthernet 1/0/1 as an AC interface.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchB-Ten-GigabitEthernet1/0/1] quit
# Create node 0 and apply next hop 10.1.1.11 to packets with service chain path ID 1.
[SwitchB] policy-based-route aa permit node 0
[SwitchB-pbr-aa-0] if-match service-chain path-id 1
[SwitchB-pbr-aa-0] apply next-hop vpn-instance vpna 10.1.1.11
[SwitchB-pbr-aa-0] quit
# Apply policy aa to VSI-interface 3.
[SwitchB-Vsi-interface3] ip policy-based-route aa
4.     Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
# Create VSI-interface 1, assign an IP address to it, and specify the interface as a distributed gateway in VXLAN 10.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpna
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] mac-address 0001-0001-0001
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] quit
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Bind VSI instance vpna to Ten-GigabitEthernet 1/0/1.
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] port link-mode bridge
[SwitchC-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchC-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 2
[SwitchC-Ten-GigabitEthernet1/0/1] xconnect vsi vpna
[SwitchC-Ten-GigabitEthernet1/0/1] quit
5.     Configure Switch D:
# Configure Switch D to establish BGP connections with the other switches.
[SwitchD] bgp 200
[SwitchD-bgp-default] group evpn
[SwitchD-bgp-default] peer 1.1.1.1 group evpn
[SwitchD-bgp-default] peer 2.2.2.2 group evpn
[SwitchD-bgp-default] peer 3.3.3.3 group evpn
[SwitchD-bgp-default] peer evpn as-number 200
[SwitchD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise EVPN routes, and disable route target filtering for BGP EVPN routes.
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer evpn enable
[SwitchD-bgp-default-evpn] undo policy vpn-target
# Configure Switch D as a route reflector.
[SwitchD-bgp-default-evpn] peer evpn reflect-client
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
[SwitchD] interface vlan-interface 11
[SwitchD-Vlan-interface11] ip address 11.1.1.4 255.255.255.0
[SwitchD-Vlan-interface11] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface11] quit
# Configure VLAN-interface 12.
[SwitchD] interface vlan-interface 12
[SwitchD-Vlan-interface12] ip address 12.1.1.4 255.255.255.0
[SwitchD-Vlan-interface12] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface12] quit
# Configure VLAN-interface 13.
[SwitchD] interface Vlan-interface 13
[SwitchD-Vlan-interface13] ip address 13.1.1.4 255.255.255.0
[SwitchD-Vlan-interface13] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface13] quit
# Capture packets sent from Server 1 to Server 2 in Ethernet service instance 1000. (Details not shown.)
The packets are processed by Service node 1 before they are delivered to Server 2.
