- 20-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-SNMP commands
- 05-RMON commands
- 06-NETCONF commands
- 07-Process monitoring and maintenance commands
- 08-Mirroring commands
- 09-Email Notification Service Commands
- 10-UCC commands
- 11-SQA commands
- 12-Packet capture commands
00-Preface | 110.00 KB |
Preface
This command reference describes the configuration commands for the network management and monitoring features, including Ping and tracert, system debugging, NQA, SNMP, RMON, NETCONF, UCC, SQA, Packet capture, Email Notification Service, process monitoring and maintenance,and mirroring.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
