12-WLAN Advanced Features Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1210P01)-6W10112-WLAN Advanced Features Command Reference
09-WLAN forwarding commands
09-WLAN forwarding commands 48.08 KB
display wlan forward statistics
Use display wlan forward statistics to display WLAN forwarding statistics.
# Display WLAN forwarding statistics.
<Sysname> display wlan forward statistics
Discarded frames:
  Forwarding type error           : 5
  Packet validity check fail      : 7
  Service module discard          : 0
  Packets only for listening      : 0
  BSS/station info get fail       : 13
  Radio info get fail             : 0
  Tunnel info get fail            : 3
  Memory/MBUF fail                : 3
  Roaming discard                 : 0
  Adjacency list get fail         : 0
  CAPWAP validity check fail      : 0
  Format conversion fail          : 0
  Inside packet decode fail       : 0
  Encrypt/decrypt fail            : 0
  Radio fragment/reassemble fail  : 6
  CAPWAP fragment/reassemble fail : 5
  Priority process fail           : 0
  QoS/IP forward fail             : 0
  MAC forward fail                : 0
  Radio forward fail              : 0
Number of packets discarded because of an incorrect forwarding mode.
Number of packets discarded because of validity check failure.
Number of packets discarded by the service module.
Number of packets only for packet listening.
Number of packets from which the system fails to get BSS or client information.
Radio info get fail
Number of packets from which the system fails to get radio information.
Number of packets from which the system fails to get tunnel information.
Memory/MBUF fail
Number of packets discarded because of memory or MBUF operation failure.
Roaming discard
Number of packets discarded because of roaming.
Number of packets from which the system fails to get the adjacency list.
Number of packets discarded because of CAPWAP validity check failure.
Number of packets discarded because of format conversion failure.
Number of packets discarded because of decoding failure.
Number of packets discarded because of encryption or decryption failure.
Number of packets discarded because of radio fragmentation or reassembling failure.
Number of packets discarded because of tunnel fragmentation or reassembling failure.
Number of packets discarded because of priority processing failure.
QoS/IP forward fail
Number of packets discarded because of QoS or IP forwarding failure.
MAC forward fail
Number of packets discarded because of MAC forwarding failure.
Radio forward fail
Number of packets discarded because of radio forwarding failure.
reset wlan forward statistics
Use reset wlan forward statistics to clear WLAN forwarding statistics.
# Clear WLAN forwarding statistics.
<Sysname> reset wlan forward statistics
