05-Network Connectivity Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1210P01)-6W10105-Network Connectivity Command Reference
02-Ethernet link aggregation commands
02-Ethernet link aggregation commands 236.63 KB
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the LACP system priority (0x8000 in this sample output) and the LACP system MAC address (0000-FC00-6504 in this sample output).
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode interface [ bridge-aggregation interface-number ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation keyword is available only when Layer 2 aggregate interfaces exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
4 (default)
Link-aggregation load-sharing seed:
0x1 (default)
Link-aggregation load-sharing mode:
Layer 2 traffic: destination-mac address  source-mac address
                 destination-ip address   source-ip address
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
5
0x10
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 1. This example displays a user-configured setting.
Bridge-Aggregation1 load-sharing mode:
Link aggregation load sharing algorithm.
By default, this field displays the default setting. If you have configured the load sharing algorithm, this field displays the configured algorithm.
Link aggregation load sharing hash seed.
By default, this field displays the default setting. If you have configured the load sharing hash seed, this field displays the configured seed.
Link-aggregation load sharing mode of Layer 2 aggregation group 1.
By default, this field displays the global link-aggregation load sharing modes.
If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on source and destination MAC addresses, and source and destination IP addresses.
destination-mac address, source-mac address
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
display link-aggregation load-sharing path
Use display link-aggregation load-sharing path to display forwarding information about the specified traffic flow.
display link-aggregation load-sharing path interface bridge-aggregation interface-number ingress-port interface-type interface-number { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ip-protocol protocol-id | source-mac mac-address | source-port port-id | vlan vlan-id } *
interface-number: Specifies an existing aggregate interface by its number.
ingress-port interface-type interface-number: Specifies an ingress port by its type and number. The ingress port must be a physical port.
destination-ip ip-address: Specifies a destination IPv4 address.
destination-ipv6 ipv6-address: Specifies a destination IPv6 address.
source-ip ip-address: Specifies a source IPv4 address.
source-ipv6 ipv6-address: Specifies a source IPv6 address.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format.
destination-port port-id: Specifies a destination port number in the range of 1 to 65535.
ip-protocol protocol-id: Specifies an IP protocol by its ID in the range of 0 to 255.
source-mac mac-address: Specifies a source MAC address in H-H-H format.
source-port port-id: Specifies a source port number in the range of 1 to 65535.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
A parameter specified in the command might not be used for selecting the egress port. The Load sharing parameters field displays the parameters that are used in egress port selection. For example, you can specify both the destination-mac mac-address and destination-ip ip-address options. If only the destination MAC address is used for selecting the egress port, the Load sharing parameters field does not display the destination-ip parameter.
If a parameter required for selecting the egress port is not specified, the default value of the parameter is used. If the parameter does not have any default values, the parameter is set to 0.
# Display forwarding information about the specified traffic flow to be sent out of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface  bridge-aggregation 1 ingress-port gigabitethernet 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 source-ip 10.100.0.2 destination-ip 10.100.0.1
Load sharing mode: destination-mac, source-mac, source-ip, destination-ip
Unspecified parameters are set to 0.
Load-sharing parameters:
  Ingress port: GigabitEthernet1/0/1
  Destination MAC: 0000-fc00-0001
  Source MAC: 0000-fc00-0002
  Destination IP: 10.100.0.1
  Source IP: 10.100.0.2
Egress port: GigabitEthernet1/0/3
Load sharing mode:
Load sharing mode set for the aggregation group:
·     destination-mac—Traffic is load shared based on destination MAC addresses.
·     source-mac—Traffic is load shared based on source MAC addresses.
·     destination-ip—Traffic is load shared based on destination IP addresses.
·     source-ip—Traffic is load shared based on source IP addresses.
·     destination-port—Traffic is load shared based on destination ports.
·     source-port—Traffic is load shared based on source ports.
Parameters that are used in egress port selection.
Egress port
Egress port of the specified traffic flow. If no egress port is found, this field displays N/A.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
       G -- Defaulted, H -- Expired
GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/2
GigabitEthernet1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Preferred Aggregate Interface
Aggregate interface to which you prefer to assign the member port during automatic assignment.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the LACP system priority and the LACP system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
display link-aggregation summary
Use display link-aggregation summary to display brief information about all aggregation groups.
The Partner ID field in the command output always displays None for a static link aggregation group. This is because the local aggregation system cannot obtain information from the peer system in a static link aggregation.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
BAGG20     D     0x8000,00e0-fcff-ff01   2         0           0           Shar
Table 5 Command output
Aggregate interface type, which can only be BAGG (Layer 2).
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local LACP system priority and the local LACP system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer LACP system priority and the peer LACP system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
display link-aggregation troubleshooting
Use display link-aggregation troubleshooting to display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
route-aggregation: Specifies Layer 3 aggregate interfaces.
If you do not specify an aggregate interface type, the command displays information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregation groups of the specified type.
You can specify the bridge-aggregation or route-aggregation keyword only when aggregate interfaces of the specified type exist on the device.
# Display the aggregation states of aggregation member ports for all aggregation groups and the reason why a port was placed in Unselected state.
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
 Member ports:
  GE1/0/2
   Status: Selected
  GE1/0/3
   Status: Unselected
   Reason: The physical or line protocol state of the port is down
   Advice: Check the connection
Table 6 Command output
Reason
Reason why the port was placed in Unselected state.
Advice
Recommended action.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ bridge-aggregation [ interface-number ] ] [ all-configuration ]
all-configuration: Specifies all member ports in an aggregation group. If you do not specify this keyword, the command displays the member ports on present cards.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
This command does not display the interfaces that are enabled with automatic assignment if they have not joined an aggregation group.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose  bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Role: P -- Primary, S -- Secondary
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  GE1/0/1             S        32768    61       2                      {ACDEF}
  GE1/0/2             S        32768    62       2                      {ACDEF}
  GE1/0/3             S        32768    63       2                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  GE1/0/1(R)          32768    111      2        0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/2             32768    112      2        0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/3             32768    113      2        0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  Port             Status  Priority Oper-Key  Role
  GE1/0/1(R)       S       32768    1         None
  GE1/0/2          S       32768    1         None
  GE1/0/3          S       32768    1         None
Table 7 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type:
·     Auto port—The port is enabled with automatic assignment.
·     Management port—The port is a management port.
·     Reference port—The port is a reference port.
Flags
Role
This field is not supported in the current software version.Role of the port in the aggregation group operating in 1+1 backup mode:
·     Primary.
·     Secondary.
If the aggregation group is not operating in 1+1 backup mode, None is displayed.
Aggregate Interface
Name of the aggregate interface.
Creation Mode
Creation mode of the dynamic aggregate interface:
·     Auto.
·     Manual.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
Management VLANs
Management VLANs. If no management VLANs are specified, this field displays None.
System ID
Local system ID, containing the local LACP system priority and the local LACP system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Index—Port index.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Index and Flag fields are not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port.
·     Priority—Priority of the peer port.
·     Index—Index of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 4.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
[Sysname-Bridge-Aggregation1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames that are within 4000 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value range for this argument is 1700 to 4000.
# Allow jumbo frames on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
lacp default-selected-port disable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp period short
lacp select speed
Use lacp select speed to configure a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection.
Use undo lacp select speed to restore the default.
lacp select speed
Port ID is the prioritized criterion for reference port selection in a dynamic aggregation group.
CAUTION
CAUTION:
Changing reference port selection criteria might cause transient traffic interruption. When you use this command, make sure you understand its impact on your network.
This command enables a dynamic aggregation group to select a high-speed member port as the reference port.
You must execute this command at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
This command takes effect only on dynamic aggregate interfaces. On a static aggregate interface, you can execute this command, but the setting cannot take effect.
# Specify port speed as the prioritized criterion for reference port selection on Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
All S-MLAG devices must use the same LACP system MAC address.
LACPDUs carry the LACP system MAC address configured by using this command. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system MAC address globally and in aggregate interface view. The global LACP system MAC address takes effect on all aggregation groups, and an aggregate-interface-specific LACP system MAC address takes precedence over the global LACP system MAC address.
On an M-LAG system, M-LAG interfaces in the same M-LAG group cannot use the same LACP system MAC address.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the LACP system priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The LACP system priority is 32768.
priority: Specifies the LACP system priority in the range of 0 to 65535. The smaller the value, the higher the LACP system priority.
LACPDUs carry the LACP system priority configured by using this command. To identify the LACP system priority used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system priority globally and in aggregate interface view. The global LACP system priority takes effect on all aggregation groups, and an aggregate-interface-specific LACP system priority takes precedence over the global LACP system priority.
# Set the LACP system priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
link-aggregation global load-sharing algorithm
Use link-aggregation global load-sharing algorithm to configure a link aggregation load sharing algorithm.
Use undo link-aggregation global load-sharing algorithm to restore the default.
link-aggregation global load-sharing algorithm algorithm-number
Algorithm 4 is used in link aggregation load sharing.
algorithm algorithm-number: Specifies an algorithm by its number. The value range for the algorithm-number argument is 1 to 11.
This command does not take effect on per-flow load sharing.
The load sharing algorithm determines the CRC calculation method. In default load sharing mode, if the device fails to load share traffic flows across all Selected ports, repeat the following procedure until the problem is resolved:
1.     Configure the load sharing algorithm.
2.     Use the display counters command to view traffic statistics on Selected ports.
You can use a load sharing algorithm and a hash seed individually or in combination to obtain the optimal load sharing performance.
# Specify algorithm 1 as the link aggregation load sharing algorithm.
[Sysname] link-aggregation global load-sharing algorithm 1
display counters (Interface Command Reference)
link-aggregation global load-sharing mode
link-aggregation global load-sharing seed
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | source-ip | source-mac | source-port }
The device distributes traffic based on the source and destination MAC addresses, and source and destination IP addresses on aggregate links.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
flow-label: Distributes traffic based on flow labels.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
Use link-aggregation global load-sharing seed to configure a link aggregation load sharing hash seed.
Use undo link-aggregation global load-sharing seed to restore the default.
link-aggregation global load-sharing seed seed-number
The link aggregation load sharing hash seed is 0x1.
seed seed-number: Specifies a seed. The value range for the seed-number argument is 0 to FFFF.
The load sharing hash seed is a parameter used in hashing. In default load sharing mode, if the device fails to load share traffic flows across all Selected ports, repeat the following procedure until the problem is resolved:
1.     Configure the load sharing hash seed.
# Specify 1023 (3FF in hexadecimal format) as the link aggregation load sharing hash seed.
[Sysname] link-aggregation global load-sharing seed 3FF
link-aggregation lacp isolate
Use link-aggregation lacp isolate to isolate aggregate interfaces on the device.
Use undo link-aggregation lacp isolate to remove aggregate interface isolation.
link-aggregation lacp isolate [ bagg | ragg ]
undo link-aggregation lacp isolate [ bagg | ragg ]
Aggregate interfaces are not isolated.
bagg: Isolates Layer 2 aggregate interfaces on the device.
ragg: Isolates Layer 3 aggregate interfaces on the device.
Aggregate interface isolation is applicable to the aggregate interfaces that act as M-LAG interfaces when the device acts an M-LAG member device in an M-LAG system. It gracefully changes all M-LAG interfaces on the device to the Unselected state and switch traffic over to their counterpart M-LAG interfaces on the other M-LAG member device.
This feature takes effect only on dynamic aggregate interfaces. It cannot isolate static aggregate interfaces or M-LAG peer-link interfaces.
As a best practice, make sure no M-LAG interfaces are in M-LAG MAD DOWN state before you isolate them. If one of the M-LAG interfaces is in M-LAG MAD DOWN state when you isolate them, that M-LAG interface will persist in that state and cannot forward traffic after the isolation is removed.
If you do not specify any keywords, this command takes effect on all aggregate interfaces on the device.
# Isolate aggregate interfaces.
[Sysname] link-aggregation lacp isolate
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { destination-ip | destination-mac | flow-label | source-ip | source-mac } *
The group-specific load sharing mode is the same as the global load sharing mode.
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
Use link-aggregation mode to set the aggregation mode of an aggregation group.
Use undo link-aggregation mode to restore the default.
link-aggregation mode { dynamic | static }
An aggregation group operates in static aggregation mode.
dynamic: Specifies dynamic mode and enables LACP.
static: Specifies static mode.
When you change the aggregation mode, make sure you understand the impact of the change on services.
Aggregation mode change might cause Selected member ports to become Unselected.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
The maximum number of Selected ports allowed in an aggregation group is 16.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 16.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
On a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
On a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 16.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
link-aggregation selected-port minimum percentage
Use link-aggregation selected-port minimum percentage to set the minimum percentage of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum percentage to restore the default.
link-aggregation selected-port minimum percentage number
The minimum percentage of Selected ports is not set for an aggregation group.
number: Specifies the minimum percentage of Selected ports. The value range for this argument is 1 to 100.
CAUTION
CAUTION:
After you execute this command, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
·     The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
·     The limit set by using the link-aggregation selected-port minimum command.
# Set the minimum percentage of Selected ports to 50% for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum percentage 50
port lacp system-mac
Use port lacp system-mac to set the LACP system MAC address on an aggregate interface.
Use undo port lacp system to restore the default.
port lacp system-mac mac-address
undo port lacp system-mac
Member devices in an S-MLAG system must use the same LACP system MAC address.
On an M-LAG system, M-LAG interfaces in the same M-LAG group must use the same LACP system MAC address.
# Set the LACP system MAC address to 0002-0002-0002 on an aggregate interface.
[Sysname-Bridge-Aggregation1] port lacp system-mac 2-2-2
lacp system-mac
port lacp system-priority
Use port lacp system-priority to set the LACP system priority on an aggregate interface.
Use undo port lacp system-priority to restore the default.
port lacp system-priority priority
Member devices in an S-MLAG system must use the same LACP system priority.
# Set the LACP system priority to 32 on an aggregate interface.
[Sysname-Bridge-Aggregation1] port lacp system-priority 32
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 4.
force: Enables the current interface to synchronize attribute configurations from the aggregate interface. If you do not specify this keyword, the current interface does not synchronize attribute configurations from the aggregate interface when it joins the aggregation group. This keyword is supported only on Layer 2 Ethernet interfaces.
auto: Enables automatic assignment.
A Layer 2 Ethernet interface can be assigned only to a Layer 2 aggregation group.
An interface can belong to only one aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
The force keyword takes effect only when you assign the interface to an aggregation group. It cannot be saved in the running configuration or a configuration file.
When you enable automatic assignment, you can specify a preferred aggregation group, which must be in dynamic mode.
The device assigns the interface to the preferred aggregation group as long as the LACPDUs received on the interface match the peer information of the reference port in the group.
If you do not specify a preferred group or if the preferred group match fails, the device attempts to select a matching group from the existing dynamic aggregation groups. If no match is found, the device creates a dynamic aggregation group based on the LACPDUs and assigns the interface to that aggregation group.
As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
You cannot assign the following interfaces to an aggregation group:
·     Member interfaces of redundant Ethernet interfaces.
·     Member interfaces of redundancy group nodes.
For more information about redundant Ethernet interfaces and redundancy group nodes, see High Availability Configuration Guide.
# Assign Layer 2 Ethernet interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
