00-Preface | 25.72 KB |
Preface
The U-Center 2.0 user guide allows users to understand and use the function modules of U-Center 2.0, and helps users resolve relevant issues when using the function modules:
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with U-Center 2.0.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
