HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[830][2600][3600] Routers Configuration Guides(V7)-R0821-6W50101-Fundamentals Configuration Guide
04-FTP and TFTP configuration
04-FTP and TFTP configuration 180.91 KB
Configuring FTP·· 1
About FTP· 1
FTP file transfer modes· 1
FTP operation modes· 1
FIPS compliance· 1
Using the device as an FTP server 1
FTP server configuration tasks at a glance· 1
Enabling the FTP server 2
Configuring client authentication and authorization· 2
Configuring FTP server access control 2
Setting connection management parameters· 3
Specifying an SSL server policy for SFTP connections· 3
Setting the DSCP value for outgoing FTP packets· 4
Manually releasing FTP connections· 4
Display and maintenance commands for the FTP server 4
Example: Using the device as an FTP server (in standalone mode) 4
Example: Using the device as an FTP server (in IRF mode) 6
Using the device as an FTP client 7
FTP client configuration tasks at a glance· 7
Establishing an FTP connection· 7
Displaying command help information· 9
Displaying directories and files on the FTP server 9
Managing directories on the FTP server 9
Managing directories on the FTP client 9
Working with files on the FTP server 10
Changing to another user account 10
Maintaining and troubleshooting the FTP connection· 11
Terminating the FTP connection· 11
Display and maintenance commands for the FTP client 12
Example: Using the device as an FTP client (in standalone mode) 12
Example: Using the device as an FTP client (in IRF mode) 13
Configuring TFTP·· 15
About TFTP· 15
FIPS compliance· 15
Restrictions and guidelines: TFTP configuration· 15
Configuring the device as a TFTP server 15
Configuring and using the IPv4 TFTP client 15
Configuring and using the IPv6 TFTP client 16
Configuring FTP
About FTP
File Transfer Protocol (FTP) is an application layer protocol for transferring files from one host to another over an IP network. It uses TCP port 20 to transfer data and TCP port 21 to transfer control commands.
FTP is based on the client/server model. The device can act as the FTP server or FTP client.
FTP supports the following transfer modes:
·           Binary mode—Used to non-text files, such as .app, .bin, and .btm files.
·           ASCII mode—Used to transfer text files, such as .txt, .bat, and .cfg files.
When the device acts as the FTP client, you can set the transfer mode (binary by default). When the device acts as the FTP server, the transfer mode is determined by the FTP client.
FTP operation modes
FTP can operate in either of the following modes:
·           Active mode (PORT)—The FTP server initiates the TCP connection. This mode is not suitable when the FTP client is behind a firewall, for example, when the FTP client resides in a private network.
·           Passive mode (PASV)—The FTP client initiates the TCP connection. This mode is not suitable when the server does not allow the client to use a random unprivileged port greater than 1024.
FTP operation mode varies depending on the FTP client program.
FIPS compliance
FTP is not supported in FIPS mode.
To use the device as an FTP server, you must enable the FTP server and configure authentication and authorization on the device. Other commands are optional.
To use the device as an FTP server, perform the following tasks:
1.      Enabling the FTP server
2.      Configuring client authentication and authorization
3.      (Optional.) Configuring FTP server access control
4.      (Optional.) Setting connection management parameters
5.      (Optional.) Specifying an SSL server policy for SFTP connections
6.      (Optional.) Setting the DSCP value for outgoing FTP packets
7.      (Optional.) Manually releasing FTP connections
1.      Enter system view.
2.      Enable the FTP server.
ftp server enable
By default, the FTP server is disabled.
Perform this task on the FTP server to authenticate FTP clients and set the authorized directories that authenticated clients can access.
The following authentication modes are available:
·           Local authentication—The device looks up the client's username and password in the local user account database. If a match is found, authentication succeeds.
·           Remote authentication—The device sends the client's username and password to a remote authentication server for authentication. The user account is configured on the remote authentication server rather than the device.
The following authorization modes are available:
·           Local authorization—The device assigns authorized directories to FTP clients based on the locally configured authorization attributes.
·           Remote authorization—A remote authorization server assigns authorized directories on the device to FTP clients.
For more information about configuring authentication and authorization, see AAA in Security Configuration Guide.
Use ACLs to prevent unauthorized access. If an applied ACL does not exist or does not have any rules, no user login restriction is applied. If the ACL exists and has rules, only FTP clients permitted by the ACL can access the device.
When no ACL is applied, all FTP clients can access the FTP server. To control FTP access, specify an ACL that exists and has rules so only FTP clients permitted by the ACL can access the FTP server. If you specify an ACL that does not exist or does not have rules, no FTP clients can access the FTP server.
The ACL takes effect only for FTP connections to be established. It does not impact existing FTP connections.
For more information about ACL, see ACL and QoS Configuration Guide.
If you configure FTP server access control multiple times, the most recent configuration takes effect.
2.      (Optional.) Use an ACL to control access to the FTP server.
IPv4:
ftp server acl { advanced-acl-number | basic-acl-number | mac mac-acl-number }
IPv6:
ftp server acl ipv6 { advanced-acl-number | basic-acl-number | mac mac-acl-number }
By default, no ACL is used for access control.
3.      (Optional.) Enable logging for FTP login attempts that are denied by the FTP login control ACL.
ftp server acl-deny-log enable
By default, logging is disabled for FTP login attempts that are denied by the FTP login control ACL.
2.      Set the FTP connection idle-timeout timer.
ftp timeout minutes
By default, the FTP connection idle-timeout timer is 30 minutes.
If no data transfer occurs on an FTP connection before the idle-timeout timer expires, the FTP server closes the FTP connection.
3.      Set the maximum number of concurrent FTP users.
aaa session-limit ftp max-sessions
By default, the maximum number of concurrent FTP users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online FTP users, no additional FTP users can log in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
After you associate an SSL server policy with the device, a client that supports SFTP will establish a secure connection to the device to ensure data security.
2.      Associate an SSL server policy with the FTP server to ensure data security.
ftp server ssl-server-policy policy-name
By default, no SSL server policy is associated with the FTP server.
2.      Set the DSCP value for outgoing FTP packets.
IPv4:
ftp server dscp dscp-value
IPv6:
ftp server ipv6 dscp dscp-value
By default, the DSCP value is 0.
To manually release FTP connections, execute the following commands in user view:
·           Release the FTP connection established by using a specific user account:
free ftp user username
·           Release the FTP connection to a specific IP address:
free ftp user-ip [ ipv6 ] ip-address [ port port ]
Display FTP server configuration and status information.
display ftp-server
Display detailed information about online FTP users.
display ftp-user
·           Configure the device as an FTP server.
·           Create a local user account named abc on the FTP server. Set the password to hello12345.
·           Use the user account to log in to the FTP server from the FTP client.
·           Upload the temp.bin file from the FTP client to the FTP server.
·           Download configuration file startup.cfg from the FTP server to the FTP client for backup.
Figure 1 Network diagram
1.      Configure IP addresses as shown in Figure 1. Make sure the device and PC can reach each other. (Details not shown.)
2.      Configure the device (FTP server):
# Create a local user named abc. Set the password to hello12345.
[Sysname] local-user abc class manage
[Sysname-luser-abc] password simple hello12345
# Assign the network-admin user role to the user. Set the working directory to the root directory of the flash memory.
[Sysname-luser-abc] authorization-attribute user-role network-admin work-directory flash:/
# Assign the service type FTP to the user.
[Sysname-luser-abc] service-type ftp
[Sysname-luser-abc] quit
# Enable the FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Examine the storage space for space insufficiency and delete unused files for more free space.
<Sysname> dir
Directory of flash:
     0      drw-           -  Jun 29 2011 18:30:38     logfile
     1      drw-           -  Jun 21 2011 14:51:38     diagfile
     2      drw-           -  Jun 21 2011 14:51:38     seclog
     3      -rw-        2943  Jul 02 2011 08:03:08     startup.cfg
     4      -rw-       63901  Jul 02 2011 08:03:08     startup.mdb
     5      -rw-         716  Jun 21 2011 14:58:02     hostkey
     6      -rw-         572  Jun 21 2011 14:58:02     serverkey
     7      -rw-     6541264  Aug 04 2011 20:40:49     backup.bin
473664 KB total (467080 KB free)
<Sysname> delete /unreserved flash:/backup.bin
3.      Perform FTP operations from the PC (FTP client):
# Log in to the FTP server at 1.1.1.1 using username abc and password hello12345.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User (1.1.1.1:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Use the ASCII mode to download configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
200 TYPE is now ASCII
ftp> get startup.cfg back-startup.cfg
# Use the binary mode to upload the temp.bin file to the device.
ftp> binary
200 TYPE is now 8-bit binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
·           Configure the IRF fabric as an FTP server.
Download configuration file config.cfg from the FTP server to the FTP client for backup.
Figure 2 Network diagram
1.      Configure IP addresses as shown in Figure 2. Make sure the IRF fabric and the PC can reach each other. (Details not shown.)
2.      Configure the FTP server:
# Examine the storage space on the member devices. If the free space is insufficient, use the delete/unreserved file command to delete unused files. (Details not shown.)
# Create a local user with username abc and password hello12345.
# Assign the network-admin user role to the user. Set the working directory to the root directory of the flash memory on the master. (To set the working directory to the root directory of the flash memory on the subordinate member, you must include the slot number in the directory path.)
[Sysname] quit
3.      Perform FTP operations from the FTP client:
c:\> ftp 1.1.1.1
User(1.1.1.1:(none)):abc
Password:
230 User logged in.
# Use the ASCII mode to download configuration file config.cfg from the FTP server to the PC for backup.
ftp> ascii
ftp> get config.cfg back-config.cfg
# Use the binary mode to upload the temp.bin file from the PC to the root directory of the flash memory on the master.
ftp> binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
1.      Establishing an FTP connection
2.      (Optional.) Displaying command help information
3.      (Optional.) Displaying directories and files on the FTP server
4.      (Optional.) Managing directories on the FTP server
5.      (Optional.) Working with files on the FTP server
6.      (Optional.) Changing to another user account
7.      (Optional.) Maintaining and troubleshooting the FTP connection
8.      (Optional.) Terminating the FTP connection
FTP connection establishment task list
To establish an FTP connection, perform the following tasks:
1.      (Optional.) Specifying a source IP address for outgoing FTP packets
2.      Establishing an FTP connection
3.      Setting the FTP file transfer mode and operation mode
The source IP address specified in the ftp command takes precedence over the one set by the ftp client source command.
The source IP address specified in the ftp ipv6 command takes precedence over the one set by the ftp client ipv6 source command.
2.      Specify a source IP address for outgoing FTP packets.
IPv4:
By default, no source IP address is specified. The device uses the primary IP address of the output interface as the source IP address.
IPv6:
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
By default, no source IPv6 address is specified. The source address is automatically selected as defined in RFC 3484.
·           Log in to the FTP server from user view.
IPv4:
ftp [ ftp-server [ service-port ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] ] *
IPv6:
ftp ipv6 [ ftp-server [ service-port ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { ipv6 source-ipv6-address | interface interface-type interface-number } ] * [ -i interface-type interface-number ] ]
·           Log in to the FTP server from FTP client view.
a.    Enter FTP client view.
ftp [ ipv6 ]
b.    Log in to the FTP server.
open server-address [ service-port ]
1.      Enter FTP client view from user view.
ftp
2.      Set the file transfer mode.
¡  Set the file transfer mode to ASCII.
ascii
¡  Set the file transfer mode to binary.
binary
The default file transfer mode is binary.
3.      Change the FTP operation mode.
passive
The default FTP operation mode is passive.
ftp
2.      Display command help information.
¡  help [ command-name ]
¡  ? [ command-name ]
ftp
2.      Display directories and files on the FTP server.
¡  dir [ remotefile [ localfile ] ]
¡  ls [ remotefile [ localfile ] ]
Use the dir or ls command to display the directories and files on the FTP server.
ftp
2.      Manage directories on the FTP server.
¡  Display the working directory that is being accessed on the FTP server.
pwd
¡  Change the working directory on the FTP server.
cd { directory | .. | / }
¡  Return to the upper level directory on the FTP server.
cdup
¡  Create a directory on the FTP server.
mkdir directory
¡  Delete a directory from the remote FTP server.
rmdir directory
ftp
2.      Display or change the local working directory of the FTP client.
lcd [ directory | / ]
To upload a file, use this command to change to the directory where the file resides. Downloaded files are saved in the working directory.
ftp
2.      Work with files on the FTP server.
¡  Delete a file from the FTP server permanently.
delete remotefile
This command requires that you have the delete right.
¡  Rename a file.
rename [ oldfilename [ newfilename ] ]
¡  Upload a file to the FTP server.
put localfile [ remotefile ]
¡  Download a file from the FTP server.
get remotefile [ localfile ]
¡  Add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
¡  Specify the retransmit marker.
restart marker
Use this command together with the put, get, or append command.
¡  Update a local file.
newer remotefile
¡  Get the missing part of a file.
reget remotefile [ localfile ]
After you log in to the FTP server, you can initiate an FTP authentication to change to a new account. By changing to a new account, you can get a different privilege without re-establishing the FTP connection.
For successful account change, you must enter the new username and password correctly. A wrong username or password can cause the FTP connection to be disconnected.
ftp
2.      Initiate an FTP authentication on the current FTP connection.
user username [ password ]
After you use the device to establish an FTP connection to the FTP server, use the commands in this section to locate and troubleshoot problems about the FTP connection.
ftp
2.      Maintain and troubleshoot the FTP connection.
¡  Display FTP commands supported by the FTP server.
rhelp
¡  Display help information about an FTP command that is supported by the FTP server.
rhelp protocol-command
¡  Display FTP server status.
rstatus
¡  Display detailed information about a directory or file on the FTP server.
rstatus remotefile
¡  Display FTP connection status.
status
¡  Display the system information of the FTP server.
system
¡  Enable or disable FTP operation information display.
verbose
By default, this function is enabled.
¡  Enable FTP client debugging.
debug
By default, FTP client debugging is disabled.
¡  Clear the reply information in the buffer.
reset
ftp
2.      Terminate the connection.
¡  Terminate the connection to the FTP server without exiting FTP client view.
disconnect
close
¡  Terminate the connection to the FTP server and return to user view.
bye
Execute the display command in any view.
Display source IP address information on the FTP client.
display ftp client source
As shown in Figure 3, the PC is acting as an FTP server. A user account with username abc and password hello12345 has been created on the PC.
·           Use the device as an FTP client to log in to the FTP server.
·           Download the temp.bin file from the PC to the device.
·           Upload configuration file startup.cfg from the device to the PC for backup.
Figure 3 Network diagram
# Configure IP addresses as shown in Figure 3. Make sure the device and PC can reach each other. (Details not shown.)
# Examine the storage space of the device. If the free space is insufficient, use the delete/unreserved file command to delete unused files. (Details not shown.)
# Log in to the FTP server at 10.1.1.1 using username abc and password hello12345.
<Sysname> ftp 10.1.1.1
Press CTRL+C to abort.
Connected to 10.1.1.1 (10.1.1.1).
User (10.1.1.1:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the temp.bin file from the PC to the device.
ftp> get temp.bin
local: temp.bin remote: temp.bin
150 Connecting to port 47457
226 File successfully transferred
23951480 bytes received in 95.399 seconds (251.0 kbyte/s)
# Use the ASCII mode to upload configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
ftp> put startup.cfg back-startup.cfg
local: startup.cfg remote: back-startup.cfg
150 Connecting to port 47461
3494 bytes sent in 5.646 seconds (618.00 kbyte/s)
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
As shown in Figure 4, the PC is acting as an FTP server. A user account with username abc and password hello12345 has been created on the PC.
·           Use the IRF fabric as an FTP client to log in to the FTP server.
·           Download the temp.bin file from the FTP server to the FTP client.
Upload configuration file config.cfg from the FTP client to the FTP server for backup.
Figure 4 Network diagram
# Configure IP addresses as shown in Figure 4. Make sure the IRF fabric and PC can reach each other. (Details not shown.)
Password:
ftp>
ftp> binary
# Download the temp.bin file from the PC to the root directory of the flash memory on the master device.
ftp> get temp.bin
# Download the temp.bin file from the PC to the root directory of the flash memory on the subordinate member (with member ID of 2).
ftp> get temp.bin slot2#flash:/temp.bin
# Use the ASCII mode to upload configuration file config.cfg from the IRF fabric to the PC for backup.
ftp> ascii
ftp> put config.cfg back-config.cfg
local: config.cfg remote: back-config.cfg
ftp> bye
221 Logout.
<Sysname>
Configuring TFTP
About TFTP
Trivial File Transfer Protocol (TFTP) is a simplified version of FTP for file transfer over secure reliable networks. TFTP uses UDP port 69 for data transmission. In contrast to TCP-based FTP, TFTP does not require authentication or complex message exchanges, and is easier to deploy. TFTP is suited for reliable network environments.
The device can act as the TFTP server or TFTP client.
FIPS compliance
TFTP is not supported in FIPS mode.
You can upload a file from a TFTP client to the TFTP server or download a file from the TFTP server to a TFTP client. As a best practice, specify a file name that has not been used in the destination directory. If the destination file name has been used in the destination directory, the device deletes the existing file before saving the new file.
2.      Enable the TFTP server.
tftp server enable
By default, the TFTP server is disabled.
The device can act as the TFTP server on both IPv4 and IPv6 networks.
3.      Set the TFTP server working directory.
tftp server work-directory directory
By default, the TFTP server working directory is the root directory of the default file system.
2.      (Optional.) Use an ACL to control the client's access to TFTP servers.
tftp-server acl acl-number
3.      Specify the source IP address for TFTP packets sent by the TFTP client.
4.      Return to user view.
5.      Download or upload a file in an IPv4 network.
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] *
The source IP address specified in this command takes precedence over the source IP address set by using the tftp client source command.
tftp-server ipv6 acl ipv6-acl-number
3.      Specify the source IPv6 address for TFTP packets sent by the TFTP client.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
5.      Download or upload a file in an IPv6 network.
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] *
The source IP address specified in this command takes precedence over the one set by the tftp client ipv6 source command.
