12-User Access and Authentication
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R838x-6W10012-User Access and Authentication
07-HH3C-USER-MIB
07-HH3C-USER-MIB 53.67 KB
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Notifications
hh3cUserBlacklistLock
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.12.3.1.0.1
A user was locked to the password control blacklist.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when the number of login failures of a user reaches the upper limit. The user is added to the password control blacklist.
System impact
The system may be under login attacks.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-lock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-lock command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.12.1.1.1.1 (hh3cUserName)
Username.
hh3cUserIndex
DisplayString
OCTET STRING (1..255)
1.3.6.1.4.1.25506.2.12.3.1.1.1 (hh3cUserIPAddressType)
Address type of the user.
hh3cUserIndex
INTEGER
unknown(0),, ipv4(1), , ipv6(2)
1.3.6.1.4.1.25506.2.12.3.1.1.2 (hh3cUserIPAddress)
IP address of the user.
hh3cUserIndex
InetAddress
OCTET STRING(0..255)
Recommended action
Use the display password-control blacklist command to view users in the password control blacklist and analyze whether login user attacks exist. If login user attacks exist, contact the administrator.
hh3cUserBlacklistUnlock
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.12.3.1.0.2
A user was unlocked from the password control blacklist.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a user blacklisted due to login failures is removed from the blacklist because the administrator executed the reset password-control blacklist command or the user lockout timer expires.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-unlock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-unlock command.
Object
OID (object name)
Index
Value range
Username.
hh3cUserIndex
DisplayString
OCTET STRING (1.. 255)
User address type.
hh3cUserIndex
INTEGER
User IP address.
hh3cUserIndex
InetAddress
OCTET STRING (0..255)
Recommended action
No action is required.
hh3cUserGroupThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.12.4.0.1
Maximum number of user groups already reached.
Error
Major
1.3.6.1.4.1.25506.2.12.4.0.2 (hh3cUserGroupThresholdResume)
OFF
This notification is generated when the number of user groups configured on the device reaches the upper limit.
System impact
New user groups cannot be created.
Status control
ON
CLI: Use the snmp-agent trap enable user-group max-count-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable user-group max-count-threshold command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.12.4.1.1 (hh3cUserGroupUsedNum)
Current number of user groups.
N/A
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.12.4.1.2 (hh3cUserGroupNumThreshold)
Maximum number of user groups.
N/A
Integer32
Recommended action
1.Use the display user-group command in any view to view local user group information and analyze whether unused user groups exist.
  - If unused user groups exist, proceed to step 2.
  - If no unused user group exists, proceed to step 3.
2.Use the undo user-group command in system view to deleted unused user groups.
3.Collect alarm, log, and configuration information, and contact Technical Support.
Basic information
OID
Event
Severity
Default status
Number of user groups dropped to 90% of the maximum number.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the number of user groups configured on the device drops below 90% of the maximum value.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
N/A
Integer32
Recommended action
