| 00-Perface | 30.57 KB |
Preface
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C Intelligent Management Center (IMC).
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
