- 07-Wireless authentication
- 01-Local Portal Authentication Configuration Examples
- 02-HTTPS-Based Local Portal Authentication Configuration Examples
- 03-Remote Portal Authentication Configuration Examples
- 04-Local Portal Authentication through LDAP Server Configuration Examples
- 05-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 06-Local Portal MAC-Trigger Authentication Configuration Examples
- 07-Portal MAC-Trigger Authentication Configuration Examples
- 08-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 09-Local Portal Authentication (IPv6) Configuration Examples
- 10-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 11-Remote Portal Authentication (IPv6) Configuration Examples
- 12-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 13-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 14-Portal Fail-Permit Configuration Examples
- 15-Local MAC Authentication Configuration Examples
- 16-Remote MAC Authentication Configuration Examples
- 17-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 18-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 19-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 20-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 21-Local MAC-And-802.1X Authentication Configuration Examples
- 22-Local 802.1X Authentication Configuration Examples
- 23-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 24-Remote 802.1X Authentication Configuration Examples
- 25-Remote 802.1X Authentication (IPv6) Configuration Examples
- 26-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 27-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 28-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 29-EAD Authentication Configuration Examples
- 30-EAD Authentication (IPv6) Configuration Examples
19-MAC Authentication with Guest VLAN Assignment Configuration Examples | 379.82 KB |
H3C Access Controllers |
MAC Authentication with Guest VLAN Assignment |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring a guest VLAN for wireless clients that fail MAC authentication.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, MAC authentication, WLAN authentication, and WLAN access.
Example: Configuring MAC authentication with guest VLAN assignment
As shown in Figure 1, the AC acts as a DHCP server to provide IP addresses for the AP and the client. The AC centrally forwards the client traffic.
To control the client's access to network resources, complete the following tasks:
· Configure VLAN 200 as the access VLAN of the client.
· Configure the AC to use the RADIUS server to perform MAC authentication for the client.
· Configure VLAN 300 as the guest VLAN on the service template that the client uses to access the network.
The device reauthenticates a client every 30 seconds in the guest VLAN.
When you configure MAC authentication for wireless clients, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Remove the ports that connect the AC to the AP from VLAN 1 in case there are too many packets in VLAN 1.
· Some endpoints by default use random MAC addresses. To ensure successful MAC authentication for such an endpoint, disable the endpoint from using a random MAC address.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 112.12.1.25 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 112.13.1.25 16
[AC-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300, and assign an IP address to the VLAN interface. The AC will use VLAN 300 as a guest VLAN to accommodate clients that fail MAC authentication.
[AC] vlan 300
[AC-vlan300] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ip address 112.14.1.25 16
[AC-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, remove the port from VLAN 1, assign the port to VLANs 100, 200, and 300.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
2. Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Create a DHCP address pool named vlan100, and specify subnet 112.12.0.0/16 and gateway IP address 112.12.1.25 in the DHCP address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200, and specify subnet 112.13.0.0/16 and gateway IP address 112.13.1.25 in the DHCP address pool. In this example, the address of the DNS server is 112.13.1.25 (the gateway address). You must replace it with the actual address of the DNS server on your network.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
[AC-dhcp-pool-vlan200] dns-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
# Create a DHCP address pool named vlan300, and specify subnet 112.14.0.0/16 and gateway IP address 112.14.1.25 in the DHCP address pool. In this example, the address of the DNS server is 112.14.1.25 (the gateway address). You must replace it with the actual address of the DNS server on your network.
[AC] dhcp server ip-pool vlan300
[AC-dhcp-pool-vlan300] network 112.14.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan300] gateway-list 112.14.1.25
[AC-dhcp-pool-vlan300] dns-list 112.14.1.25
[AC-dhcp-pool-vlan300] quit
3. Configure RADIUS-based MAC authentication:
# Create a RADIUS scheme named office and enter its view.
[AC] radius scheme office
# Specify the IP addresses of the primary authentication and accounting RADIUS servers.
[AC-radius-office] primary authentication 112.12.1.50
[AC-radius-office] primary accounting 112.12.1.50
# Specify the shared keys for RADIUS authentication and accounting.
[AC-radius-office] key authentication simple 123456789
[AC-radius-office] key accounting simple 123456789
# Exclude the ISP domain names from the usernames sent to the RADIUS servers.
[AC-radius-office] user-name-format without-domain
# Specify IP address 112.12.1.25 as the source IP address for outgoing RADIUS packets.
[AC-radius-office] nas-ip 112.12.1.25
[AC-radius-office] quit
# Create an ISP domain named office1 and enter its view.
[AC] domain office1
# Apply RADIUS scheme office to ISP domain office1 for LAN user authentication, authorization, and accounting.
[AC-isp-office1] authentication lan-access radius-scheme office
[AC-isp-office1] authorization lan-access radius-scheme office
[AC-isp-office1] accounting lan-access radius-scheme office
# Configure the idle cut feature for clients in ISP domain office1.
[AC-isp-office1] authorization-attribute idle-cut 15 1024
[AC-isp-office1] quit
# Configure the AC to use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation without hyphens and with letters in lower case. (The configuration in this step is the default configuration. This step is optional.)
[AC] mac-authentication user-name-format mac-address without-hyphen lowercase
4. Configure a wireless service:
# Create a service template named 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID of service template 1 as service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1] vlan 200
# Set the PSK AKM mode and configure simple character string of 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite for frame encryption and enable the RSN IE in beacon and probe responses.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Enable the AC to forward client data traffic. If the AC forwards client data traffic by default, skip this step.
[AC-wlan-st-1] client forwarding-location ac
# Set the authentication mode to MAC authentication.
[AC-wlan-st-1] client-security authentication-mode mac
# Specify the MAC authentication domain as ISP domain office1.
[AC-wlan-st-1] mac-authentication domain office1
5. Configure a guest VLAN:
# Specify VLAN 300 as the guest VLAN for clients that fail MAC authentication on service template 1.
[AC-wlan-st-1] client-security authentication fail-vlan 300
# Enable the service template.
[AC-wlan-st-1] quit
6. Configure AP settings:
IMPORTANT: In a large-scale network, configure AP groups as a best practice. |
# Create a manual AP named officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1 and create an AP grouping rule by AP names to add AP officeap to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 300. The switch will use this VLAN to forward packets in the guest VLAN.
[Switch] vlan 300
[Switch-vlan300] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port, remove the port from VLAN 1, assign the trunk port to VLAN 100.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port. Assign the access port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
Configuring the RADIUS server
In this example, the RADIUS server runs IMC PLAT 7.1(E0303P10) and IMC UAM 7.1(E0303P10).
1. Add an access device:
a. Log in to IMC and click the User tab.
b. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c. Click Add.
The Add Access Device page opens.
d. In the Device List area, click Add Manually to add the device at 112.12.1.25 as an access device.
This IP address is the source IP address specified on the AC for outgoing RADIUS packets.
e. In the Access Configuration area, configure the following parameters, as shown in Figure 2:
- Enter 123456789 in the Shared Key and Confirm Shared Key fields.
The key is consistent with the shared key configured on the AC.
- Use the default values for other parameters.
f. Click OK.
Figure 2 Adding an access device
2. Add an access policy:
a. Click the User tab.
b. From the navigation tree, select User Access Policy > Access Policy.
c. Click Add.
d. On the Add Access Policy page, configure the following parameters, as shown in Figure 3:
- Enter office in the Access Policy Name field.
Figure 3 Adding an access policy
3. Add an access service:
b. From the navigation tree, select User Access Policy > Access Service.
c. Click Add.
d. On the Add Access Service page, configure the following parameters, as shown in Figure 4:
- Enter office_mac in the Service Name field.
- Select office from the Default Access Policy list.
e. Click OK.
Figure 4 Adding an access service
4. Add an access user:
b. From the navigation tree, select Access User > Access User.
The access user list opens.
c. Click Add.
The Add Access User page opens.
d. In the Access Information area, add a user, as shown in Figure 5:
- Click Add User.
- On the dialog box that opens, enter adm_office_mac in the User Name and Identity Number fields.
- Click Check Availability to verify the validity of the username and identity number.
- Click OK.
e. In the Access Information area, configure the following parameters, as shown in Figure 6:
- Enter admin in the Account Name field.
- Enter 123456 in the Password and Confirm Password fields.
NOTE: For the client to fail MAC authentication, configure a different username and password on the RADIUS server than on the AC. |
f. In the Access Service area, select office_mac from the list.
g. Click OK.
Figure 6 Adding an access user account
The client requests to access the network.
# On the AC, verify that the wireless client fails MAC authentication and is assigned to VLAN 300.
[AC] display wlan client
Total number of clients: 1
MAC address User name AP name R IP address VLAN
3ca9-f414-4c20 3ca9f4144c20 officeap 2 112.14.0.2 300
# Verify that the wireless client in the guest VLAN can access network resources only in VLAN 300 before passing MAC authentication. (Details not shown.)
# Modify the username and password on the RADIUS server to the MAC address of the client. The MAC address is in hexadecimal notation without hyphens, and letters are in lower case. (Details not shown.)
# Display MAC authentication information after the wireless client in the guest VLAN passes MAC authentication.
[AC] display mac-authentication
MAC authentication : Enabled
Authentication method : PAP
DR member configuration conflict : Unknown
User name format : MAC address in lowercase(xxxxxxxxxxxx)
Username : 3ca9f4144c20
Password : $c$3$KWMkvq/FnQ2opPqBnpSTs3NPhVKrSOvqFPLAECSiDQ==
Offline detect period : 180 s
Quiet period : 180 s
Server timeout : 100 s
Reauth period : 3600 s
User aging period for critical VLAN : 1000 s
User aging period for guest VLAN : 1000 s
Authentication domain : Not configured, use default domain
Online MAC-auth wired users : 0
Online MAC-auth wireless users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
AP name: officeap Radio ID: 2 SSID: service
BSSID : 741f-4ad4-8d50
Authentication domain : office1
Max online users : 4096
Authentication attempts : successful 0, failed 42
Configuration files
· AC:
dhcp enable
vlan 1
vlan 100
vlan 200
vlan 300
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$9tIUHSkAUVqCH9/EPrL26ldkcEQnngexUEFj
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
ip address 112.13.1.25 255.255.0.0
interface Vlan-interface300
ip address 112.14.1.25 255.255.0.0
key authentication cipher $c$3$IrnigzRDMkG7Jk1FNf2+tm04+zvnCwiaJzI9TA==
key accounting cipher $c$3$ehledYNyJ+vTlcYcyUEisTa+ZXvWqU1O2QlSYg==
nas-ip 112.12.1.25
domain office1
ap officeap
ap-model WA6320
radio 1
radio 2
radio enable
service-template 1
· Switch:
vlan 1
vlan 100
vlan 200
vlan 300
poe enable
Related documentation
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· AP and WT Management Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
