04-Interface
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10004-Interface
02-HH3C-LswINF-MIB
02-HH3C-LswINF-MIB 106.93 KB
HH3C-LswINF-MIB
About this MIB
Use this MIB to manage interfaces.
An isolation group either can have only one uplink port or does not have any uplink port. You can create an isolation group, specify an uplink port for the group, add member ports to the group, and then remove the uplink port.
Speed autonegotiation allows an interface to operate at the possible fastest speed. You can set the speed modes that an interface can automatically negotiated with the peer interface to meet various speed requirements.
MIB file name
hh3c-splat-inf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35) .hh3cLswL2InfMib(5)
Scalar objects
hh3cSlotPortMax
Object (OID)
Access
Value range
Implementation
hh3cSlotPortMax (1.3.6.1.4.1.25506.8.35.5.1.1)
read-only
INTEGER
1..65535
Maximum number of ports on a slot.
As per the MIB.
hh3cSwitchPortMax
Object (OID)
Access
Value range
Implementation
hh3cSwitchPortMax (1.3.6.1.4.1.25506.8.35.5.1.2)
read-only
INTEGER
1..65535
Maximum number of ports on the switch.
As per the MIB.
hh3cIsolateGroupMax
Object (OID)
Access
Value range
Implementation
hh3cIsolateGroupMax (1.3.6.1.4.1.25506.8.35.5.1.5)
read-only
Integer32
Integer32(1..2147483647)
Maximum number of isolation groups supported by the switch.
As per the MIB.
hh3cMaxMacLearnRange
Object (OID)
Access
Value range
Implementation
hh3cMaxMacLearnRange (1.3.6.1.4.1.25506.8.35.5.1.12)
read-only
Integer32
Maximum number of MAC addresses supported by an interface.
Implementation varies by product.
Tabular objects
hh3cifXXTable
About this table
This table contains extended information for an interface.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifUnBoundPort.
Object (OID)
Access
Value range
Implementation
hh3cifUnBoundPort (1.3.6.1.4.1.25506.8.35.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
Whether an interface is a member port of an aggregate interface.
Not supported
hh3cifISPhyPort (1.3.6.1.4.1.25506.8.35.1.1.1.2)
read-only
TruthValue
true(1),
false(2)
Whether the interface is a physical interface.
Not supported
hh3cifAggregatePort (1.3.6.1.4.1.25506.8.35.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the interface is an aggregate interface.
Not supported
hh3cifMirrorPort (1.3.6.1.4.1.25506.8.35.1.1.1.4)
read-write
TruthValue
true(1),
false(2)
Whether the interface is a mirroring interface.
Not supported.
When read, this object returns false.
hh3cifVLANType (1.3.6.1.4.1.25506.8.35.1.1.1.5)
read-write
INTEGER
vLANTrunk(1),
access(2),
hybrid(3),
fabric(4)
VLAN type of the interface.
Value fabric(4) is not supported.
hh3cifMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.6)
read-write
INTEGER
INTEGER (0..100)
Multicast suppression threshold.
hh3cifFlowControl (1.3.6.1.4.1.25506.8.35.1.1.1.7)
read-write
TruthValue
true(1),
false(2)
Flow control status on the interface.
As per the MIB.
hh3cifSrcMacControl (1.3.6.1.4.1.25506.8.35.1.1.1.8)
read-only
TruthValue
true(1),
false(2)
Whether to filter packets by source MAC address.
Not supported
hh3cifClearStat (1.3.6.1.4.1.25506.8.35.1.1.1.9)
read-write
INTEGER
clear(1)
Clear packet statistics on the interface.
Supports only the read operation.
hh3cifXXBasePortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.10)
read-only
INTEGER
INTEGER
Index of the interface.
As per the MIB.
hh3cifXXDevPortIndex (1.3.6.1.4.1.25506.8.35.1.1.1.11)
read-only
INTEGER
INTEGER
As per the MIB.
hh3cifPpsMcastControl (1.3.6.1.4.1.25506.8.35.1.1.1.12)
read-write
Integer32
Integer32 (-2147483648..2147483647)
Multicast suppression threshold in pps.
As per the MIB.
hh3cifPpsBcastDisValControl (1.3.6.1.4.1.25506.8.35.1.1.1.13)
read-write
INTEGER
enable(1),
disable(2)
Enabling status of broadcast suppression in pps mode.
Not supported
hh3cifUniSuppressionStep (1.3.6.1.4.1.25506.8.35.1.1.1.14)
read-only
Integer32
Step of unicast suppression in percentage.
Not supported
hh3cifPpsUniSuppressionMax (1.3.6.1.4.1.25506.8.35.1.1.1.15)
read-only
Integer32
Maximum number of the unicast suppression threshold in pps.
Not supported
hh3cifMulSuppressionStep
(1.3.6.1.4.1.25506.8.35.1.1.1.16)
read-only
Integer32
Step of multicast suppression in percentage.
Not supported
hh3cifPpsMulSuppressionMax
(1.3.6.1.4.1.25506.8.35.1.1.1.17)
read-only
Integer32
Maximum number of multicast suppression threshold in pps
Not supported
(1.3.6.1.4.1.25506.8.35.1.1.1.18)
read-write
Integer32
Unicast suppression threshold in percentage.
(1.3.6.1.4.1.25506.8.35.1.1.1.19)
read-write
Integer32
Unicast suppression threshold in pps.
As per the MIB.
(1.3.6.1.4.1.25506.8.35.1.1.1.20)
read-write
Integer32
Multicast suppression threshold in percentage.
(1.3.6.1.4.1.25506.8.35.1.1.1.21)
read-write
Integer32
As per the MIB.
hh3cifComboActivePort (1.3.6.1.4.1.25506.8.35.1.1.1.22)
read-write
INTEGER
fiber(1),
copper(2)
na(3)
Active port of a combo interface.
Not supported
hh3cifBMbpsMulSuppressionMax
(1.3.6.1.4.1.25506.8.35.1.1.1.23)
read-only
Integer32
Maximum value of the multicast suppression threshold in Mbps.
Not supported
(1.3.6.1.4.1.25506.8.35.1.1.1.24)
read-only
Integer32
Multicast suppression threshold in Mbps.
Not supported
hh3cifBKbpsMulSuppressionMax
(1.3.6.1.4.1.25506.8.35.1.1.1.25)
read-only
Integer32
Maximum value of the multicast suppression threshold in kbps.
Not supported
hh3cifBKbpsMulSuppressionStep
(1.3.6.1.4.1.25506.8.35.1.1.1.26)
read-only
Integer32
Step of multicast suppression in kbps.
Not supported
(1.3.6.1.4.1.25506.8.35.1.1.1.27)
read-only
Integer32
Multicast suppression in kbps.
Not supported
hh3cifUnknownPacketDropMul
(1.3.6.1.4.1.25506.8.35.1.1.1.28)
read-write
INTEGER
disable(name)
Enabling status of dropping unknown multicast packets.
Not supported
hh3cifUnknownPacketDropUni
(1.3.6.1.4.1.25506.8.35.1.1.1.29)
read-write
INTEGER
disable(name)
Enabling status of dropping unknown unicast packets.
Not supported
hh3cifBMbpsUniSuppressionMax
(1.3.6.1.4.1.25506.8.35.1.1.1.30)
read-only
Integer32
Maximum value of the unicast suppression threshold in Mbps.
Not supported
(1.3.6.1.4.1.25506.8.35.1.1.1.31)
read-write
Integer32
Unicast suppression threshold in Mbps.
Not supported
hh3cifBKbpsUniSuppressionMax
(1.3.6.1.4.1.25506.8.35.1.1.1.32)
read-only
Integer32
Maximum value of the unicast suppression threshold in kbps.
Not supported
hh3cifBKbpsUniSuppressionStep
(1.3.6.1.4.1.25506.8.35.1.1.1.33)
read-only
Integer32
Step of unicast suppression in kbps.
Not supported
(1.3.6.1.4.1.25506.8.35.1.1.1.34)
read-write
Integer32
Unicast suppression threshold in kbps.
Not supported
hh3cifOutPayloadOctets (1.3.6.1.4.1.25506.8.35.1.1.1.35)
read-only
CounterBasedGauge64
Counter64 (0..18446744073709551615)
Number of octets transmitted by the interface.
Not supported
hh3cifInPayloadOctets (1.3.6.1.4.1.25506.8.35.1.1.1.36)
read-only
CounterBasedGauge64
Number of octets received on the interface.
Not supported
hh3cifInErrorPktsRate (1.3.6.1.4.1.25506.8.35.1.1.1.37)
read-only
CounterBasedGauge64
Number of error packets on the interface.
Not supported
hh3cifInPkts (1.3.6.1.4.1.25506.8.35.1.1.1.38)
read-only
CounterBasedGauge64
Number of correct packets on the interface.
Not supported
hh3cifInNormalPkts (1.3.6.1.4.1.25506.8.35.1.1.1.39)
read-only
CounterBasedGauge64
Number of correct packets received on the interface.
Not supported
hh3cifOutPkts (1.3.6.1.4.1.25506.8.35.1.1.1.40)
read-only
CounterBasedGauge64
Number of correct packets transmitted by the interface.
Not supported
hh3cifMulSuppressionFlag
(1.3.6.1.4.1.25506.8.35.1.1.1.41)
read-write
INTEGER
all(1),
unknown(2)
Flag of multicast suppression.
As per the MIB.
hh3cifHybridPortTable
About this table
This table contains hybrid interface information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifHybridPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cifHybridPortIndex (1.3.6.1.4.1.25506.8.35.1.3.1.1)
read-only
INTEGER
INTEGER
Index of a hybrid interface.
As per the MIB.
hh3cifHybridTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.2)
read-write
OCTET STRING
OCTET STRING (0..256)
Per-bit representation of tagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN.
As per the MIB.
hh3cifHybridTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.3)
read-write
OCTET STRING
Per-bit representation of tagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a tagged VLAN.
As per the MIB.
hh3cifHybridUnTaggedVlanListLow (1.3.6.1.4.1.25506.8.35.1.3.1.4)
read-write
OCTET STRING
Per-bit representation of untagged VLANs (in the range of VLAN 1 to VLAN 2048). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN.
As per the MIB.
hh3cifHybridUnTaggedVlanListHigh (1.3.6.1.4.1.25506.8.35.1.3.1.5)
read-write
OCTET STRING
Per-bit representation of untagged VLANs (in the range of VLAN 2049 to VLAN 4094). Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is an untagged VLAN.
As per the MIB.
hh3cifComboPortTable
About this table
This table contains combo interface information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifComboPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cifComboPortIndex (1.3.6.1.4.1.25506.8.35.1.4.1.1)
read-only
Integer32
Index of a combo interface.
As per the MIB.
hh3cifComboPortCurActive (1.3.6.1.4.1.25506.8.35.1.4.1.2)
read-write
INTEGER
fiber(1)
copper(2)
na(3)
auto(4)
Type of the activated combo port.
As per the MIB.
hh3cifPktBufTable
About this table
This table contains packet buffer information for an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifPktBufFree.
Object (OID)
Access
Value range
Implementation
hh3cifPktBufFree (1.3.6.1.4.1.25506.8.35.1.5.1.1)
read-only
Integer32
Size of the available packet buffer for an interface.
As per the MIB.
hh3cifPktBufInit (1.3.6.1.4.1.25506.8.35.1.5.1.2)
read-only
Integer32
Number of packet buffers allocated to the interface when the interface was created.
As per the MIB.
hh3cifPktBufMin (1.3.6.1.4.1.25506.8.35.1.5.1.3)
read-only
Integer32
Minimum number of packet buffers allocated to the interface.
As per the MIB.
hh3cifPktBufMiss (1.3.6.1.4.1.25506.8.35.1.5.1.4)
read-only
Counter64
Number of times that the interface failed to obtain a packet buffer before dropping the packet.
As per the MIB.
hh3cifPktBufInDrop (1.3.6.1.4.1.25506.8.35.1.5.1.5)
read-only
Counter64
Number of incoming packets dropped by the interface because of insufficient data buffer.
As per the MIB.
hh3cifPktBufEgDrop (1.3.6.1.4.1.25506.8.35.1.5.1.6)
read-only
Counter64
Number of outgoing packets dropped by the interface because of insufficient data buffer.
As per the MIB.
hh3cifQueuePktBufTable
About this table
This table contains packet buffer queue information for an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifQueueId.
Object (OID)
Access
Value range
Implementation
hh3cifQueueId
(1.3.6.1.4.1.25506.8.35.1.6.1.1)
read-only
Integer32
Integer32(1..8)
ID of a packet buffer queue.
As per the MIB.
hh3cifQueuePktBufTotal
(1.3.6.1.4.1.25506.8.35.1.6.1.2)
read-only
Unsigned32
Unsigned32
Number of packet buffers for the queue.
As per the MIB.
hh3cifQueueBufUsed
(1.3.6.1.4.1.25506.8.35.1.6.1.3)
read-only
Unsigned32
Unsigned32
Number of packet buffers used by the queue.
As per the MIB.
hh3cifQueueBufThreCount
(1.3.6.1.4.1.25506.8.35.1.6.1.4)
read-only
Counter32
Counter32
Number of times that a queue of the interface has exceeded the threshold.
As per the MIB.
hh3cifQueueBufUsageIn5Seconds
(1.3.6.1.4.1.25506.8.35.1.6.1.5)
read-only
Integer32
Integer32(0..100)
Buffer usage in the most recent 5 seconds for the queue.
As per the MIB.
hh3cifQueueBufUsageIn1Minute
(1.3.6.1.4.1.25506.8.35.1.6.1.6)
read-only
Integer32
Integer32(0..100)
Buffer usage in the most recent 1 minute for the queue.
As per the MIB.
hh3cifQueueBufUsageIn5Minutes
(1.3.6.1.4.1.25506.8.35.1.6.1.7)
read-only
Integer32
Integer32(0..100)
Buffer usage in the most recent 5 minutes for the queue.
As per the MIB.
hh3cifVLANTrunkStatusTable
About this table
This table contains GVRP attributes for a trunk port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifVLANTrunkIndex.
Object (OID)
Access
Value range
Implementation
hh3cifVLANTrunkIndex (1.3.6.1.4.1.25506.8.35.5.1.3.1.1)
read-only
INTEGER
INTEGER
Index of a trunk port.
As per the MIB.
hh3cifVLANTrunkPassListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.4)
read-only
OCTET STRING
Per-bit representation of permitted VLANs (in the range of VLAN 1 to VLAN 2048) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN.
As per the MIB.
hh3cifVLANTrunkPassListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.5)
read-only
OCTET STRING
Per-bit representation of permitted VLANs (in the range of VLAN 2049 to VLAN 4094) on the port. Each bit in an octet represents a VLAN. If a bit is set to 1, the VLAN represented by this bit is a trunked VLAN.
As per the MIB.
hh3cifVLANTrunkAllowListLow (1.3.6.1.4.1.25506.8.35.5.1.3.1.6)
read-write
OCTET STRING
You must specify this object and hh3cifVLANTrunkAllowListHigh in pairs in an SNMP request.
hh3cifVLANTrunkAllowListHigh (1.3.6.1.4.1.25506.8.35.5.1.3.1.7)
read-write
OCTET STRING
You must specify this object and hh3cifVLANTrunkAllowListLow in pairs in an SNMP request.
hh3cethernetTable of hh3cLswL2InfMibObject
About this table
This table contains Layer 2 interface settings.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifEthernetDuplex.
Object (OID)
Access
Value range
Implementation
hh3cifEthernetDuplex (1.3.6.1.4.1.25506.8.35.5.1.4.1.3)
read-write
INTEGER
full(1),
half(2),
auto(3)
Duplex mode of an interface.
Values half and auto are supported only when the interface operates at a speed higher than 1000 Mbps or is connected to a fiber connector.
Layer 3 interfaces do not support write operation.
hh3cifEthernetMTU (1.3.6.1.4.1.25506.8.35.5.1.4.1.4)
read-write
INTEGER
1..65535
MTU of the interface.
Only interfaces that operate in Layer 2 mode or allow jumbo frames to pass through support write operation.
When write, value 1 indicates to set the maximum value in the value range. Value 2 indicates to set the minimum value in the value range.
hh3cifEthernetSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.5)
read-write
INTEGER
auto(0),
s10M(10),
s100M(100),
s1000M(1000),
s2500M(2500),
s5000M(5000),
s10000M(10000),
s24000M(24000),
s40000M(40000),
s20000M(20000),
s25000M(25000),
s50000M(50000),
s100000M(100000)
Speed of the interface.
Ethernet interfaces do not support values s1000 and higher.
GE interfaces do not support values s10000 and higher.
hh3cifEthernetMdi (1.3.6.1.4.1.25506.8.35.5.1.4.1.7)
read-write
INTEGER
mdi-ii(1),
mdi-x(2),
mdi-auto(3)
MDI type of the interface.
GE, XGE, 20GE, 25GE, 40GE, 50GE, and 100GE interfaces that connect to fiber connectors do not support write operation.
hh3cMaxMacLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.8)
read-write
INTEGER
-1..2147483647
Maximum number of MAC addresses that the interface can learn.
The value of this object must be smaller than the maximum number of MAC addresses supported on the interface.
hh3cifMacAddressLearn (1.3.6.1.4.1.25506.8.35.5.1.4.1.9)
read-only
INTEGER
enabled(1),
disabled(2)
Enabling status of MAC address learning on the interface.
As per the MIB.
hh3cifEthernetTest (1.3.6.1.4.1.25506.8.35.5.1.4.1.10)
read-write
INTEGER
test(1)
Test the interface.
Not supported
hh3cifMacAddrLearnMode (1.3.6.1.4.1.25506.8.35.5.1.4.1.11)
read-only
INTEGER
iVL(1),
sVL(2)
MAC address learning mode of the interface.
Not supported
hh3cifEthernetFlowInterval (1.3.6.1.4.1.25506.8.35.5.1.4.1.12)
read-write
INTEGER
5..300
Flow interval of the interface.
read-write
INTEGER
5..300
hh3cifEthernetIsolate (1.3.6.1.4.1.25506.8.35.5.1.4.1.13)
read-write
OCTETSTRING
OCTETSTRING
Isolation groups.
Not supported
hh3cifVlanVPNStatus (1.3.6.1.4.1.25506.8.35.5.1.4.1.14)
read-write
INTEGER
enabled(1),
disabled(2)
Enabling status of the VLAN-VPN feature.
Not supported
hh3cifVlanVPNUplinkStatus(1.3.6.1.4.1.25506.8.35.5.1.4.1.15)
read-write
INTEGER
enabled(1),
disabled(2)
Uplink status of the VLAN VPN for the interface.
Not supported
hh3cifVlanVPNTPID(1.3.6.1.4.1.25506.8.35.5.1.4.1.16)
read-write
Integer32
Integer32(1..65535)
VLAN VPN TPID of the interface.
Not supported
hh3cifIsolateGroupID (1.3.6.1.4.1.25506.8.35.5.1.4.1.17)
read-write
Integer32
ID of the isolation group to which the interface belongs.
Value 0 indicates that the interface does not belong to any isolation group.
hh3cifisUplinkPort (1.3.6.1.4.1.25506.8.35.5.1.4.1.18)
read-only
INTEGER
yes(1),
no(2)
Uplink status of the interface.
Not supported
hh3cifEthernetAutoSpeedMask (1.3.6.1.4.1.25506.8.35.5.1.4.1.19)
read-only
SpeedModeFlagBITS
BITS{
s10M(0),
s100M(1),
s1000M(2),
s10000M(3),
s24000M(4),
s40000M(5),
s100000M(6),
s2500M(7),
s5000M(8),
s20000M(9),
s25000M(10),
s50000M(11)
Speed modes that can be negotiated
As per the MIB.
hh3cifEthernetAutoSpeed (1.3.6.1.4.1.25506.8.35.5.1.4.1.20)
read-write
SpeedModeFlagBITS
BITS{
s10M(0),
s100M(1),
s1000M(2),
s10000M(3),
s24000M(4),
s40000M(5),
s100000M(6),
s2500M(7),
s5000M(8),
s20000M(9),
s25000M(10),
s50000M(11)
Speed modes that  are negotiable on this port
As per the MIB.
hh3cPortIsolateGroupTable
About this table
This table contains isolation group settings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Supported
Supported
Columns
The table index is hh3cPortIsolateGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cPortIsolateGroupIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.1)
not-accessible
Integer32
Index of an isolation group.
As per the MIB.
hh3cPortIsolateUplinkIfIndex (1.3.6.1.4.1.25506.8.35.5.1.11.1.2)
read-create
Integer32
Integer32
Index of the uplink interface.
Not supported
hh3cPortIsolateGroupRowStatus (1.3.6.1.4.1.25506.8.35.5.1.11.1.3)
read-create
INTEGER
INTEGER
Row status.
Supports only the following values:  createAndGo, destroy, and active.
Isolation group is available only when the row is in active status.
You can set this object only when the device supports multiple isolation groups.
hh3cPortIsolateGroupDescription (1.3.6.1.4.1.25506.8.35.5.1.11.1.4)
read-create
DisplayString
OCTETSTRING(0..80)
Description of the isolation group.
Not supported
hh3cifPortProtocolStatTable
About this table
This table contains IPv4 and IPv6 packet statistics for an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cifIPv4InOctets.
Object (OID)
Access
Value range
Implementation
hh3cifIPv4InOctets
(1.3.6.1.4.1.25506.8.35.5.1.13.1.1)
read-only
Counter64
Number of octets in IPv4 packets received on an interface.
As per the MIB.
hh3cifIPv4InUcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.2)
read-only
Counter64
Number of IPv4 unicast packets received on the interface.
As per the MIB.
hh3cifIPv4InMultiPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.3)
read-only
Counter64
Number of IPv4 multicast packets received on the interface.
As per the MIB.
hh3cifIPv4InBroadcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.4)
read-only
Counter64
Number of IPv4 broadcast packets received on the interface.
As per the MIB.
hh3cifIPv4InDiscards
(1.3.6.1.4.1.25506.8.35.5.1.13.1.5)
read-only
Counter64
Number of incoming IPv4 packets dropped by the interface.
As per the MIB.
hh3cifIPv4InErrors
(1.3.6.1.4.1.25506.8.35.5.1.13.1.6)
read-only
Counter64
Number of incoming IPv4 error packets on the interface.
As per the MIB.
hh3cifIPv4OutOctets
(1.3.6.1.4.1.25506.8.35.5.1.13.1.7)
read-only
Counter64
Number of IPv4 packets transmitted by the interface.
As per the MIB.
hh3cifIPv4OutUcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.8)
read-only
Counter64
Number of IPv4 unicast packets transmitted by the interface.
As per the MIB.
hh3cifIPv4OutMultiPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.9)
read-only
Counter64
Number of IPv4 multicast packets transmitted by the interface.
As per the MIB.
hh3cifIPv4OutBroadcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.10)
read-only
Counter64
Number of IPv4 broadcast packets transmitted by the interface.
As per the MIB.
hh3cifIPv4OutDiscards
(1.3.6.1.4.1.25506.8.35.5.1.13.1.11)
read-only
Counter64
Number of outgoing IPv4 packets transmitted by the interface.
As per the MIB.
hh3cifIPv4OutErrors
(1.3.6.1.4.1.25506.8.35.5.1.13.1.12)
read-only
Counter64
Number of outgoing IPv4 error packets transmitted by the interface.
As per the MIB.
hh3cifIPv6InOctets
(1.3.6.1.4.1.25506.8.35.5.1.13.1.13)
read-only
Counter64
Number of octets in IPv6 packets received on an interface.
As per the MIB.
hh3cifIPv6InUcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.14)
read-only
Counter64
Number of IPv6 unicast packets received on the interface.
As per the MIB.
hh3cifIPv6InMultiPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.15)
read-only
Counter64
Number of IPv6 multicast packets received on the interface.
As per the MIB.
hh3cifIPv6InAnycastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.16)
read-only
Counter64
Number of IPv6 broadcast packets received on the interface.
As per the MIB.
hh3cifIPv6InDiscards
(1.3.6.1.4.1.25506.8.35.5.1.13.1.17)
read-only
Counter64
Number of incoming packets dropped by the interface.
As per the MIB.
hh3cifIPv6InErrors
(1.3.6.1.4.1.25506.8.35.5.1.13.1.18)
read-only
Counter64
Number of incoming error packets received on the interface.
As per the MIB.
hh3cifIPv6OutOctets
(1.3.6.1.4.1.25506.8.35.5.1.13.1.19)
read-only
Counter64
Number of octets in IPv6 packets transmitted by the interface.
As per the MIB.
hh3cifIPv6OutUcastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.20)
read-only
Counter64
Number of IPv6 unicast packets transmitted by the interface.
As per the MIB.
hh3cifIPv6OutMultiPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.21)
read-only
Counter64
Number of IPv6 multicast packets transmitted by the interface.
As per the MIB.
hh3cifIPv6OutAnycastPkts
(1.3.6.1.4.1.25506.8.35.5.1.13.1.22)
read-only
Counter64
Number of IPv6 broadcast packets transmitted by the interface.
As per the MIB.
hh3cifIPv6OutDiscards
(1.3.6.1.4.1.25506.8.35.5.1.13.1.23)
read-only
Counter64
Number of outgoing packets dropped by the interface.
As per the MIB.
hh3cifIPv6OutErrors
(1.3.6.1.4.1.25506.8.35.5.1.13.1.24)
read-only
Counter64
Number of outgoing error packets received on the interface.
As per the MIB.
