H3C UniServer BX1020EF Switch Module User Guide-6W100
HomeSupportServersBlade ServerH3C UniServer B16000BX1020EFInstall & UpgradeInstallation GuidesH3C UniServer BX1020EF Switch Module User Guide-6W100
01-Text
01-Text 1.46 MB
Safety· 1
Safety information· 1
General operating safety· 1
Electrical safety· 1
Safety precautions· 1
ESD prevention· 1
Preventing electrostatic discharge· 1
Grounding methods to prevent electrostatic discharge· 2
Overview of BX1020EF converged network switch module· 0
Product overview· 0
Reliability· 0
Device redundancy· 0
Link redundancy· 1
Specifications· 1
Port 2
Port numbering rules· 2
External ports· 2
Internal ports· 4
LEDs and buttons· 4
Logical structure· 7
Installation guidelines· 7
Internal networking· 0
Internal connections between blade server Mezz NICs and ICM modules· 0
Internal connections between blade server Mezz NIC ports and ICM modules· 1
Hardware compatibility· 0
Compatibility between switch modules and Mezz NICs· 0
Compatibility between switch modules and transceiver modules/cables· 0
Replacing the switch module· 0
Scenario· 0
Tool preparations· 0
Preparations· 1
Replacement procedure· 1
Powering on and powering off 0
Powering on the switch module· 0
Supported power-on methods· 0
Operation methods· 0
Powering off the switch module· 3
Supported power-off methods· 3
Operation methods· 3
Configuring the switch module· 0
Logging in to the switch module· 0
Obtaining the related data· 0
Login methods· 0
Logging in through the SYS serial port (console port) 0
Logging in through redirection over the SOL serial port 1
Configuring the management IP address of the switch module· 1
Obtaining and planning related data· 1
Configuration methods· 2
Configuring the management IP address from the Web interface of the OM module· 2
Configuring the management IP address from the CLI of the OM module· 4
Configuring the management IP address from the CLI of the switch module· 4
Converged port type switching· 4
Switching from an Ethernet port to an FC port 4
Switching from an FC port to an Ethernet port 5
Splitting and combining FC converged ports· 5
Configuring services of the switch module· 6
Saving the configuration in profile· 6
Common operations· 8
Logging in to the Web interface of the OM module· 8
Logging in to the CLI of the OM module· 9
Firmware upgrade· 0
Safety
Safety information
To avoid personal injury or device damage, read the following safety information carefully before you operate the device. Safety precautions in actual operation include but are not limited to safety information mentioned in this document.
·     Only H3C authorized or professional engineers are allowed to operate the device.
·     Keep the device clean and dust-free. Do not place it in a humid place or allow liquids to enter it.
·     Before powering on the device, make sure the blade enclosure is securely grounded.
·     To maintain sufficient heat dissipation, use blanks on idle slots.
Electrical safety
·     Carefully check any potential hazards in the work area, for example, whether the ground is wet and whether the blade enclosure is grounded or reliably grounded.
·     Do not work alone when performing live-line maintenance.
·     Do not touch the power supply directly or indirectly through conductive objects to prevent electric shock.
Safety precautions
·     When maintaining the device, place the device on a clean, stable table or floor.
·     To avoid personal injury from hot surfaces or internal components, make sure the device and its internal components have cooled off before maintenance.
·     When using tools to maintain the device, follow the correct operation methods to avoid damage to the personnel or device.
·     When connecting, testing or replacing optical fibers, do not look directly into the optical fiber outlet to prevent the laser beam from hurting your eyes.
·     Gently and slowly transport or place the device with force evenly distributed.
ESD prevention
Electrostatic charges that build up on people and conductors damage or shorten the lifespan of the main board and electrostatic-sensitive components.
To prevent electrostatic damage, follow these guidelines:
·     Transport or store the device in an ESD package.
·     Place the device on a grounded table before taking it out of the ESD package.
·     Avoid touching pins or circuitry of the device without taking any ESD prevention measures.
When removing or installing the device, you can use one or multiple of the following grounding methods to prevent electrostatic discharge:
·     Wear an ESD wrist strap and make sure it is reliably grounded. Make sure that the ESD wrist strap makes good skin contact and can be flexibly stretched out and drawn back.
·     In the work areas, wear ESD clothing and shoes.
·     Use conductive field service tools.
·     Use a portable field service kit with a folding ESD tool mat.
IMPORTANT
IMPORTANT:
·     Hardware images shown in this manual are for illustration only. The actual product may vary.
·     The software UI may be updated from time to time. Please refer to the actual product UI.
·     ICM modules supported by the blade enclosure are classified into switch modules and straight-through modules (also known as cascading modules in some manuals). BX1020EF is a type of switch module. Both ICM and switch modules mentioned in this document refer to BX1020EF.
Product overview
As a converged network switching control unit inside the blade enclosure, the H3C UniServer BX1020EF switch module provides data switching functions for blade servers installed in the blade enclosure and centrally provides external data ports, to achieve the communication between blade servers and external networks. External ports include Ethernet ports and FC ports.
Figure 1 shows the appearance of BX1020EF.
Figure 1 Appearance
Reliability
Device redundancy
The blade enclosure can accommodate up to six switch modules. For specific positions, see Figure 2. Among them, switch modules in slot 1 and slot 4, switch modules in slot 2 and slot 5, and switch modules in slot 3 and slot 6 are mutually interconnected through their internal interfaces. Each of the three pairs can function as a switching plane. You can configure these pairs of switch modules in active/standby mode according to service requirements.
Figure 2 Slots for installing the switch modules
机箱_17
(1) ICM1 slot
(2) ICM2 slot
(3) ICM3 slot
(4) ICM4 slot
(5) ICM5 slot
(6) ICM6 slot
Link redundancy
The switch modules internally connect to blade servers through the mid-plane, and provide uplink interfaces for the blade servers through the external interfaces of the switch modules. The switch modules can connect to a blade server through two internal interfaces, which function in active/standby mode to ensure the reliability of internal links.
Specifications
Table 1 describes the specifications of the switch module.
Table 1 Specifications
Category
Item
Physical specifications
Dimensions (H × W × D)
27 × 491.6 × 296.5 mm (1.06 × 19.35 × 11.67 in)
Maximum weight
3.60 kg (7.94 lb)
Power consumption
Maximum power consumption
122 W
Environment specifications
Temperature
·     Operating temperature: 5°C to 45°C (41°F to 113°F)
·     Storage temperature: –40°C to 70°C (–40°F to +158°F)
Humidity
·     Operating humidity: 8% to 90% (non-condensing)
·     Storage humidity: 5% to 95% (non-condensing)
Altitude
·     Operating altitude: –60 to +5000 m (–196.85 to +16404.20 ft)
The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
·     Storage altitude: –60 to +5000 m (–196.85 to +16404.20 ft)
Port
This section describes numbering rules, positions, quantity, and other information about the ports of the switch module.
Ports of the switch module are numbered in three dimensions: A, B, and C.
·     A: Indicates the number of the IRF member device. Since the switch module does not have any IRF by default, the default value of A is 1. Note that devices with the same member device number cannot form an IRF. When creating an IRF, you can run the irf member renumber command to modify the IRF member device number.
·     B: Indicates an internal or external port. 0 indicates an internal port, and 1 indicates an external port.
·     C: Indicates the sequence number of the port.
External ports
Figure 3 shows the external ports provided by the switch module. Table 2 describes specific functions of the external ports.
Figure 3 External ports
(1) AMC serial port
(2) SYS serial port (Console port)
(3) Converged port
(4) 25GE optical interface
(5) 100GE optical interface
Table 2 Description of external ports
No.
Port Name
Port Type
Port Quantity
1
AMC serial port
RJ-45
1
Serial port used to enter the AMC CLI of the switch module. The baud rate is 115200 bit/s. It is only used by technical support engineers to upgrade the AMC firmware.
2
RJ-45
1
Serial port used for local management, debugging, and maintenance of the switch module. The baud rate is 9600 bit/s. You can log in to the CLI of the switch module through the SYS serial port.
3
Converged port
SFP28
8
·     Eight ports are divided into two groups. Ports 1-4 are in a group, and ports 5-8 are in another group.
·     Each port can be switched over between Ethernet port and FC port. By default, the port works as an Ethernet port. The default rate of the Ethernet port is 25 Gbps, and that of the FC port is 16 Gbps.
·     Port switching is conducted in the unit of groups. You can uniformly switch a group of ports from Ethernet ports to FC ports or from FC ports to Ethernet ports from the ICM CLI. For specific switching methods, see "Converged port type switching."
·     After ports are switched to FC ports, splitting and combination are supported. For specific methods, see "Splitting and combining FC converged ports."
4
25GE fiber port
SFP28
8
Support for FCoE
5
100GE fiber port
QSFP28
4
Support for FCoE
For details about the transceiver modules and cables supported by the switch module, see their specifications in "Compatibility between switch modules and transceiver modules/cables."
Internal ports
Table 3 shows the internal port provided by the switch module.
Table 3 Description of the internal port
Port Name
Port Type
Port Quantity
25GE port
N/A
38
·     A total of 32 ports are provided to connect to blade servers. The port number ranges from WGE1/0/1 to WGE1/0/32.
·     A total of four ports are provided to connect to switch modules in pairs (the switch modules in slot 1 and slot 4 are a pair, the switch modules in slot 2 and slot 5 are a pair, and the switch modules in slot 3 and slot 6 are a pair). The port number ranges from WGE1/0/33 to WGE1/0/36. The four internal ports have been interconnected (one to one) via the mid-plane and are recommended as the physical ports for IRF configuration.
·     A total of two ports are provided to connect to AE modules, where only switch modules in slot 1 and slot 4, with the port number ranging from WGE1/0/37 to  WGE1/0/38, are connected to the AE modules.
LEDs and buttons
Figure 4 shows positions and appearance of LEDs and buttons on the switch module. Table 4 describes LED colors and the corresponding meanings.
Figure 4 LEDs and buttons
(1) Reset button
(2) UID LED
(3) RUN LED
(4) Health LED
(5) Port LED
The appearance of all port LEDs of the switch module is identical. The figure takes one port LED for illustration.
Table 4 LED and button description
No.
Name
Color
Status
1
Reset button (RESET)
N/A
It is used to reset and restart the switch module. When the system is executing commands, it is prohibited to press the Reset button to restart the switch module, because it may cause data loss.
2
UID LED
Blue
·     Steady blue: The UID LED is activated (through the OM module).
·     Flashing blue (1 Hz): The switch module is under remote management through SOL or the firmware version of the switch module (including the ICM module software version and AMC firmware version) is being updated through the OM module.
·     Off: The UID LED is not activated.
3
RUN LED (RUN)
Green
·     Steady green/off: The system is faulty.
·     Flashing green (4 Hz): The system is loading data.
·     Flashing green (1 Hz): The system is running correctly.
4
Health LED (Health)
Red/Green
·     Steady green: The switch module is running correctly.
·     Flashing red (1 Hz): The switch module generates an alarm.
·     Off: The switch module is not powered on or in position.
5
Port LED
Yellow/Green
·     Converged port (support switching between Ethernet ports and FC ports)
¡     Steady green: The port link is connected but is not receiving or sending data. When the port functions as an Ethernet port, the port rate is 25 Gbps; when the port functions as an FC port, the port rate is 16 Gbps.
¡     Flashing green: The port link is connected and is receiving or sending data. When the port functions as an Ethernet port, the port rate is 25 Gbps; when the port functions as an FC port, the port rate is 16 Gbps.
¡     Steady yellow: The port link is connected but is not receiving or sending data. When the port functions as an Ethernet port, the port rate is 10 Gbps or 1 Gbps; when the port functions as an FC port, the port rate is 8 Gbps or 4 Gbps.
¡     Flashing yellow: The port link is connected and is receiving or sending data. When the port functions as an Ethernet port, the port rate is 10 Gbps or 1 Gbps; when the port functions as an FC port, the port rate is 8 Gbps or 4 Gbps.
¡     Off: The port link is not connected.
·     25GE fiber port
¡     Steady green: The port link is connected, the port rate is 25 Gbps, but the link is not receiving or sending data.
¡     Flashing green: The port link is connected, the port rate is 25 Gbps, and the link is receiving or sending data.
¡     Steady yellow: The port link is connected, the port rate is 10 Gbps or 1 Gbps, but the link is not receiving or sending data.
¡     Flashing yellow: The port link is connected, the port rate is 10 Gbps or 1 Gbps, and the link is receiving or sending data.
·     100GE fiber port
¡     Steady green: The port link is connected, the port rate is 100 Gbps, but the link is not receiving or sending data.
¡     Flashing green: The port link is connected, the port rate is 100 Gbps, and the link is receiving or sending data.
¡     Steady yellow: The port link is connected, the port rate is 40 Gbps, but the link is not receiving or sending data.
¡     Flashing yellow: The port link is connected, the port rate is 40 Gbps, and the link is receiving or sending data.
Logical structure
Figure 5 shows the three major units in the logical structure of the switch module.
·     CPU unit: As the control and management core of the switch module, the CPU unit is mainly responsible for device management, system configuration, and special packet processing.
·     AMC unit: As the auxiliary management unit of the switch module, the AMC unit mainly supports functions such as ICM module data collection and reporting, ICM module power-on/off control, and system monitoring.
·     Switch unit: As the data processing core of the switch module, the switch unit mainly supports functions such as internal and external data forwarding and unrecognizable packet reporting.
Figure 5 Logical structure
·     Up to six switch modules can be installed in the blade enclosure.
·     The installation positions of the switch modules and Mezz NICs must satisfy internal connection relationships. For details, see Figure 7 and Figure 8.
·     Six switch module slots can be divided into three pairs, corresponding to three switching planes. Where, slots 1 and 4, slots 2 and 5, and slots 3 and 6 function as the active and standby slots of three switching planes.
·     The switch module is hot swappable.
Figure 6 Switch module installation guidelines
机箱_17
(1) ICM1 slot
(2) ICM2 slot
(3) ICM3 slot
(4) ICM4 slot
(5) ICM5 slot
(6) ICM6 slot
Internal networking
The installation positions of the ICM modules and Mezz NICs must satisfy internal connection relationships. For details, see Table 5.
Table 5 Connections between switch modules and blade server Mezz NICs
Model of Blade server
Maximum Number of Supported Mezz NICs
Internal Connection Diagram
H3C UniServer B5700 G3
3
Figure 7
The connection diagram is a logical diagram used to identify the mapping between Mezz NIC slots and switch module slots. For the specific positions of the Mezz NIC slots and switch module slots, refer to the module silkscreens.
H3C UniServer B7800 G3
6
Figure 8
H3C UniServer B5800 G3
3
Figure 7
Figure 7 shows the first method of connections between switch modules and blade server Mezz NICs, where:
·     The onboard NIC is connected to the active and standby OM modules.
·     Mezz NIC 1 is connected to switch modules in slot 1 and slot 4.
·     Mezz NIC 2 is connected to switch modules in slot 2 and slot 5.
·     Mezz NIC 3 is connected to switch modules in slot 3 and slot 6.
Figure 7 Connections between switch modules and blade server Mezz NICs (1)
Figure 8 shows the second method of connections between switch modules and blade server Mezz NICs, where:
·     Mezz NIC 1 and Mezz NIC 4 are connected to switch modules in slot 1 and slot 4.
·     Mezz NIC 2 and Mezz NIC 5 are connected to switch modules in slot 2 and slot 5.
·     Mezz NIC 3 and Mezz NIC 6 are connected to switch modules in slot 3 and slot 6.
Figure 8 Connections between switch modules and blade server Mezz NICs (2)
When configuring the Mezz NICs of blade servers, you need to be clear about the connections between the Mezz NIC ports and ICM modules. For details, use the networking query tool for query.
This section describes the compatibility between switch modules and Mezz NICs and the compatibility between switch modules and transceiver modules/cables.
Table 6 describes the compatibility between the BX1020EF converged network switch module and the blade server Mezz NIC.
Table 6 Mezz NIC compatible with the switch module
Mezz NIC Model
Port Quantity
NIC-ETH522i-Mb-2*10G
2
2-Port 10GB Converged Network Mezz NIC
NIC-ETH521i-Mb-4*10G
4
4-Port 10GB Converged Network Mezz NIC
NIC-ETH682i-Mb-2*25G
2
2-Port 25GB Converged Network Mezz NIC
Table 7 describes the compatibility between the BX1020EF converged network switch module and the transceiver modules/cables.
Table 7 Optical modules/cables compatible with the switch module
Model
Center Wavelength
Transmission Distance
SFP-XG-SX-MM850-A1
SFP+
850 nm
300 m (984.25 ft)
10GB transceiver module
SFP-XG-SX-MM850-A
SFP+
850 nm
300 m (984.25 ft)
SFP-XG-SX-MM850-E1
SFP+
850 nm
300 m (984.25 ft)
SFP-XG-SX-MM850-E
SFP+
850 nm
300 m (984.25 ft)
SFP-XG-LX-SM1310-CM
SFP+
1310 nm
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
SFP+
1310 nm
10 km (6.21 miles)
QSFP-40G-SR4-MM850-CM
QSFP+
850 nm
100 m (328.08 ft)
40G transceiver module
QSFP-40G-SR4-MM850
QSFP+
850 nm
100 m (328.08 ft)
QSFP-40G-CSR4-MM850-CM
QSFP+
850 nm
300 m (984.25 ft)
QSFP-40G-CSR4-MM850
QSFP+
850 nm
300 m (984.25 ft)
SFP-FC-8G-SW-MM850-CM
SFP
850 nm
150 m (492.13 ft) (8G)
380 m (1246.72 ft) (4G)
500 m (1640.42 ft) (2G)
8G/4G/2G FC transceiver module
SFP-FC-8G-SW-MM850
SFP
850 nm
SFP-FC-16G-SW-MM850-CM
SFP
850 nm
100 m (328.08 ft) (16G)
16G/8G/4G FC transceiver module
SFP-FC-16G-SW-MM850
SFP
850 nm
SFP-FC-16G-LW-SM1310-CM
SFP
1310 nm
10 km (6.21 miles)
SFP
1310 nm
10 km (6.21 miles)
SFP-XG-CAB-3M-CM
SFP+
3 m (9.84 ft)
SFP+ cable
LSWM3STK
SFP+
3 m (9.84 ft)
SFP+ cable
SFP-XG-CAB-5M-CM
SFP+
5 m (16.40 ft)
SFP+ cable
LSTM1STK
SFP+
5 m (16.40 ft)
SFP+ cable
QSFP-40G-3M-CM
QSFP+
3 m (9.84 ft)
QSFP+ cable
QSFP-40G-5M-CM
QSFP+
5 m (16.40 ft)
QSFP+ cable
QSFP-40G-D-AOC-7M-CM
QSFP+
7 m (22.97 ft)
QSFP+ active cable
QSFP-40G-D-AOC-7M
QSFP+
7 m (22.97 ft)
QSFP+ active cable
QSFP-40G-D-AOC-10M-CM
QSFP+
10 m (32.81 ft)
QSFP+ active cable
QSFP-40G-D-AOC-10M
QSFP+
10 m (32.81 ft)
QSFP+ active cable
QSFP-40G-D-AOC-20M-CM
QSFP+
20 m (65.62 ft)
QSFP+ active cable
QSFP-40G-D-AOC-20M
QSFP+
20 m (65.62 ft)
QSFP+ active cable
SFP-25G-SR-MM850-1
SFP28
850 nm
100 m (328.08 ft)
SFP28 transceiver module
SFP-25G-SR-MM850-1-X
SFP28
850 nm
100 m (328.08 ft)
QSFP-100G-SR4-MM850-CM
QSFP28
850 nm
100 m (328.08 ft)
QSFP28 transceiver module
QSFP-100G-SR4-MM850
QSFP28
850 nm
100 m (328.08 ft)
SFP-25G-D-CAB-3M
SFP28
3 m (9.84 ft)
SFP28 cable
SFP-25G-D-CAB-3M-CM
SFP28
3 m (9.84 ft)
SFP28 cable
QSFP-100G-D-CAB-3M
QSFP28
3 m (9.84 ft)
QSFP28 cable
QSFP-100G-D-CAB-3M-CM
QSFP28
3 m (9.84 ft)
QSFP28 cable
SFP-FC-32G-SW-MM850-CM
SFP+
850
Up to 190 m (623.36 ft)
SFP+ transceiver module
SFP-FC-32G-SW-MM850
SFP+
850
QSFP-40G-SR4-MM850-CM, QSFP-40G-SR4-MM850, QSFP-40G-CSR4-MM850-CM, and QSFP-40G-SR4-MM850 modules support splitting one port into four ports, which can be used to connect one 40G QSFP+ port with four 10G SFP+ ports when a 100GE port is split into four 10GE ports. The specifications (including the center wavelength and fiber type) of the interconnected QSFP+ modules and SFP+ modules must be identical.
·     As a best practice, use H3C SFP/SFP+ modules on the switch module.
·     For specifications of transceiver modules or cables, see H3C Transceiver Modules User Guide.
·     The types of H3C SFP/SFP+ modules may change over time. If you need accurate information about module types, consult H3C marketing or technical support personnel.
·     When installing transceiver modules and cables, wear ESD wrist straps. For installation methods and precautions, see H3C Transceiver Modules and Network Cable Installation Guide.
Scenario
·     The switch module is faulty.
·     The switch module needs to be replaced by a switch module or straight-through module in another model.
Tool preparations
The following tools or devices may be required when you install, use, and maintain the equipment.
Table 8 Required tools
Name
Diagonal pliers
Used to clip insulating sleeves and binding straps
Multimeter
Used to measure resistance and voltage and check the circuitry
ESD wrist strap
Used for installing, removing, or maintaining the equipment
ESD gloves
ESD clothing
Ladder
Used for high-position operations
Interface cable (such as an Ethernet cable or optical fiber)
Used to connect the equipment with the external network
Login device (such as a PC)
Used to log in to the equipment
Preparations
·     Take ESD preventive measures: Wear the ESD clothing. Properly wear and ground the ESD wrist strap. Remove conductive objects (such as jewelry or watch).
·     Back up data of the switch module.
·     Before replacing a component, check the slots and connectors, and make sure the pins are not damaged (for example, check whether pins are deformed or whether foreign objects are on the connectors).
·     Understand the guidelines for installing the switch module, as described in "Installation guidelines."
For details about the procedure, see Component Installation and Replacement Video.
1.     Remove the switch module. Press the unlock button on the switch module to fully open the ejector lever, and slowly pull the switch module out of the blade enclosure horizontally.
2.     Put the switch module into the ESD package.
3.     Install the switch module. Take out the switch module to be installed from the ESD package.
4.     Press the unlock button to automatically open the ejector lever.
5.     Slowly insert the switch module into the blade enclosure horizontally with UP facing upwards, and then lock the ejector lever.
This section describes how to power on/off the switch module.
This section describes how to power on the switch module.
Table 9 describes power-on methods supported by the switch module.
Table 9 Power-on methods supported by the switch module
Power-on Method
Application Scenario
Method 1: The switch module is powered on by the blade enclosure.
·     The switch module is installed before the blade enclosure is powered on.
·     The switch module is installed after the blade enclosure is powered on.
Method 2: The switch module is powered on from the OM Web interface.
The blade enclosure is powered on. The switch module is installed but is not energized. The Health LED of the switch module is off.
Method 3: The switch module is powered on from the OM CLI.
Operation methods
After the switch module is successfully powered on, the Health LED is steady green. For specific positions of LEDs, see "LEDs and buttons."
·     If the switch module is pre-installed, it is automatically powered on when the blade enclosure is powered on. You do not need to perform any operation.
·     If the switch module is installed after the blade enclosure is powered on, it is automatically powered on. You do not need to perform any operation.
You can power on the switch module by leveraging the ICM module management function on the OM Web interface. The specific procedure is as follows:
Before powering on the switch module from the OM Web interface, obtain the data listed in Table 10.
Table 10 Data to be obtained before you power on the switch module from the OM Web interface
Data
Management IP address of the OM module
·     Management IP address (default): 192.168.100.100
·     Subnet mask (default): 255.255.255.0
User name and password used to log in to the OM module
·     User name (default): admin
·     Password (default): Password@_
Slot for installing the switch module
·     Slot number: 1
·     The data marked "default" refer to factory default settings.
·     The data in the table is for illustration only. The actual data during operations shall prevail.
As shown in Figure 9, open the browser on the PC and enter the URL (in the format of https://OM_ip_address) used to log in to the OM Web interface. Enter the admin user name and password. Click Login.
Figure 9 Logging in to the Web interface of the OM module
As shown in Figure 10, perform the following steps to power on the switch module:
1.     Click Switch Module.
2.     Select a target switch module.
3.     Click Power State, and click Power On.
4.     Click OK. As shown in the red frame in Figure 11, make sure the switch module is powered on.
Figure 10 Powering on the switch module
Figure 11 Ensuring that the switch module is powered on
Set the SSH login parameters and log in to the OM CLI using the remote access software. Table 11 lists the login parameters.
Table 11 Parameters used to log in to the OM CLI via SSH
Login Parameter
Data
Protocol
SSH
Port number
22
·     The SSH access mode is enabled for the OM module by default.
After login, the OM CLI displays the login page, as shown below.
* Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.*
<OM>
Run io 1 CPU on to power on the switch module in slot 1.
<OM> io 1 CPU on
Run display io list to check whether the switch module in slot 1 is powered on.
<OM>display io list
 Slot : 1
      Running status   : Normal
      UID LED          : Off
      PSU              : On
      Management URL   : http://192.168.200.1/web/index.html
      Product name     : BX1020EF
      CPU usage        : 15%
This section describes how to power off the switch module.
Table 12 describes power-off methods supported by the switch module.
Table 12 Power-off methods supported by the switch module
Power-off Mode
Method 1: The switch module is powered off together with the blade enclosure.
Method 2: The switch module is powered off from the OM Web interface.
The blade enclosure and switch module are powered on, and the switch module works properly.
Method 3: The switch module is powered off from the OM CLI.
Operation methods
After the switch module is successfully powered off, the Health LED is off. For specific positions of LEDs, see "LEDs and buttons."
When the blade enclosure is powered off, the switch module is automatically powered off with the blade enclosure without any manual intervention.
Before powering off the switch module from the OM Web interface, obtain the data listed in Table 13.
Table 13 Data to be obtained before you power off the switch module from the OM Web interface
Data
Slot number: 1
As shown in Figure 12, open the browser on the PC and enter the URL (in the format of https://OM_ip_address) used to log in to the OM Web interface. Enter the admin user name and password. Click Login.
Figure 12 Logging in to the Web interface of the OM module
As shown in Figure 13, perform the following steps to power off the switch module:
3.     Click Power State, and click Power Off.
4.     Click OK. As shown in the red frame in Figure 14, make sure the switch module is powered off.
Figure 13 Powering off the switch module
Figure 14 Verifying that the switch module is powered off
Table 14 Parameters used to log in to the OM CLI via SSH
Login Parameter
Data
Protocol
SSH
Port number
22
<OM>
Run io 1 CPU off to power off the switch module in slot 1.
<OM> io 1 CPU off
Run display io list to check whether the switch module in slot 1 is powered off.
<OM>display io list
 Slot : 1
      UID LED          : Off
      PSU              : Off
      Management URL   :
      CPU usage        : 0%
The data in operations of this section is used for illustration only. The actual operation data on site shall prevail.
Before logging in to the switch module, obtain the related data, as described in Table 15.
Table 15 Data to be obtained before you log in to the switch module
Required Data
Example
·     Slot number: 1
Login methods
You can log in to the switch module in the following methods:
·     Log in to the switch module through the SYS serial port (Console port) of the switch module. For details, see "Logging in through the SYS serial port (console port)."
·     On the OM CLI, log in to the switch module through redirection over the SOL serial port. For details, see "Logging in through redirection over the SOL serial port."
·     The switch module has been powered on. For details, see "Powering on the switch module."
·     The PC has been connected to the SYS serial port (Console port) of the switch module. For details about the position of the SYS serial port (Console port), see "External ports."
Set the login parameters and log in to the CLI of the switch module through the Console port using the remote login software. Table 16 lists the login parameters.
Table 16 Parameters used to log in to the CLI of the switch module through the Console port
Login Parameter
Data
Serial Line to connect to
COMn, where n indicates the serial port number. The value is an integer. The specific value is subject to the actual settings.
Speed (baud)
9600 (default)
Data bits
8 (default)
Stop bits
1 (default)
Parity
None (default)
Flow control
None (default)
The data marked "default" refer to factory default settings. The actual data during operations shall prevail.
After login, the CLI of the switch module displays the login page, as shown below.
* Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.  *
<Sysname>
·     You have logged in to the CLI of the OM module. For details, see "Logging in to the CLI of the OM module."
From the OM CLI, run the sol connect command to log in to the CLI of the switch module in slot 1.
<OM>sol connect io 1
Begin to edit commands.
<Sysname>%Jul 29 13:42:35:975 2013 H3C SHELL/5/SHELL_LOGIN: Console logged in from c
on1.
<Sysname>
After logging in to the CLI of the switch module through the SOL serial port in redirection mode, enter "~" and "." (the entered "~" is not displayed on the CLI) in any view. Press Enter to log out and go back to the OM CLI.
Before configuring the management IP address of the switch module, obtain and plan the related data, as described in Table 17.
Table 17 Data to be obtained before you configure the switch module
Data
Example
Required Data
Username and password used to log in to the OM module
·     Username (default): admin
·     Slot number: 1
Planned Data
Data planned for the switch module
·     IP address: 192.168.200.1
·     Subnet mask: 255.255.255.0
·     Gateway: 192.168.200.254
You can configure the management IP address of the switch module in the following methods:
·     Configure the management IP address of the switch module from the Web interface of the OM module. For details, see "Configuring the management IP address from the Web interface of the OM module."
·     Configure the management IP address of the switch module from the CLI of the OM module. For details, see "Configuring the management IP address from the CLI of the OM module."
·     Configure the management IP address of the switch module from the CLI of the switch module. For details, see "Configuring the management IP address from the CLI of the switch module."
Before configuring the management IP address of the switch module through the OM module, make sure the following work is completed:
·     For details about how to log in to the Web interface of the OM module, see "Logging in to the Web interface of the OM module."
1.     Click Chassis-Enclosure and choose Enclosure > Network > IPv4 Setting.
Figure 15 Configure the management IP address (1)
2.     Toggle on the Enable in Position button to enable the function of configuring the management IPv4 address of the ICM module, and configure the management IP address of the ICM module, as shown in Figure 16. Click Apply.
Figure 16 Configure the management IP address (2)
3.     In the window that appears, click OK to complete the IP address configuration, as shown in Figure 17. Note that in the window that appears, you can toggle on Save Configuration File and select the slot that accommodates the switch module, so that the system saves the current configuration information of the switch module in the selected slot.
Figure 17 Configure the management IP address (3)
Before configuring the management IP address of the switch module through the CLI of the OM module, make sure the following work is completed:
From the OM CLI, run the auto-ipv4 command to configure the management IP address of the switch module in slot 1. When configuring the management IP address of the switch module, you can determine whether to save the configuration in the profile. The configuration methods include:
·     Configure the management IP address and save the configuration in the profile:
<OM>auto-ipv4 address 192.168.200.1 mask 255.255.255.0 gateway 192.168.200.254 io 1 save enable
·     Configure the management IP address but do not save the configuration in the profile:
<OM>auto-ipv4 address 192.168.200.1 mask 255.255.255.0 gateway 192.168.200.254 io 1 save disable
Before configuring the management IP address of the switch module from the CLI of the switch module, make sure the following work is completed:
·     You have logged in to the switch module. For details, see "Logging in to the switch module."
For specific operation procedures, see H3C UniServer BX1020EF Switch Module Configuration Guides and H3C UniServer BX1020EF Switch Module Command References.
·     The device puts eight converged ports into two groups, the first four ports in one group and the last four ports in the other group. For specific positions of the converged ports, see "External ports." You can run the port-type fc command in the view of any Ethernet port in a group to switch the group of Ethernet ports to FC ports.
# Switch Ethernet ports Twenty-FiveGigE1/1/1, Twenty-FiveGigE1/1/2, Twenty-FiveGigE1/1/3, and Twenty-FiveGigE1/1/4 to FC ports.
[Sysname] interface twenty-fivegige 1/1/1
[Sysname-Twenty-FiveGigE1/1/1] port-type fc
The interfaces Twenty-FiveGigE1/1/1, Twenty-FiveGigE1/1/2, Twenty-FiveGigE1/1/3, and Twenty-FiveGigE1/1/4 will be deleted. Continue? [Y/N]:y
[Sysname-Fc1/1/1]
The device puts eight converged ports into two groups, the first four ports in one group and the last four ports in the other group. For specific positions of the converged ports, see "External ports." You can run the port-type ethernet command in the view of any FC port in a group to switch the group of FC ports to Ethernet ports.
When switching an FC port to an Ethernet port, make sure the FC port is a 16G FC port.
# Switch FC ports Fc1/1/1, Fc1/1/2, Fc1/1/3, and Fc1/1/4 to Ethernet ports.
[Sysname] interface fc 1/1/1
[Sysname-Fc1/1/1] port-type ethernet
The interfaces 16G Fc1/1/1, 16G Fc1/1/2, 16G Fc1/1/3, and 16G Fc1/1/4 will be deleted. Continue? [Y/N]:y
[Sysname-Twenty-FiveGigE 1/1/1]
A group of FC converged ports can be used as four 16G FC ports for independent use. The four ports can also be combined into two 32G FC ports. Note that after the first four ports are combined into a group, they form two 32G FC ports: FC1/1/3 and FC1/1/4; after the last four ports are combined into a group, they form two 32G FC ports: FC1/1/5 and FC1/1/6.
·     You can run the using thirty-twogigfc command in the view of any FC port of a group to combine the four 16G FC ports of the group into two 32G FC ports.
·     You can run the using sixteengigfc command in the view of any FC port of a group to split the two 32G FC ports of the group into four 16G FC ports.
·     You have switched converged ports to the FC type. For details, see "Switching from an Ethernet port to an FC port."
Combining four 16G FC ports into two 32G FC ports
# Combine four 16G FC ports, namely FC1/1/1, FC1/1/2, FC1/1/3, and FC1/1/4, into two 32G FC ports.
<System> system-view
[System] interface fc 1/1/4
[System-Fc1/1/4] using thirty-twogigfc
The interfaces 16G FC1/1/1, 16G Fc1/1/2, 16G Fc1/1/3, and 16G Fc1/1/4 will be deleted. Continue? [Y/N]:y
[System]
Splitting two 32G FC ports into four 16G FC ports
# Split two 32G FC ports, namely FC1/1/3 and FC1/1/4, into four 16G FC ports.
[System] interface fc 1/1/3
[System-Fc1/1/3] using sixteengigfc
The interface 32G FC1/1/3, and 32G Fc1/1/4 will be deleted. Continue? [Y/N]:y
[System]
·     You have planned functions required by services of the switch module according to actual requirements.
1.     In user view on the CLI of the switch module, run the dir command to view the current file system of the switch module. Check the boot file name, profile name, and available space of the flash memory, and make sure the flash memory has sufficient space to save a new boot file.
<Sysname> dir
Directory of flash:
   0 drw-           - Apr 17 2020 17:43:29   diagfile
   1 drw-           - Apr 08 2020 14:49:27   flyfishlog
   2 -rw-         412 Apr 29 2020 10:50:54   ifindex.dat
   3 drw-           - Apr 17 2020 17:43:29   logfile
   4 drw-           - Apr 08 2020 14:51:51   pki
   5 drw-           - Apr 08 2020 14:49:17   seclog
   6 -rw-        2649 Apr 29 2020 10:50:54   startup.cfg
   7 -rw-      669171 Apr 29 2020 10:50:55   startup.mdb
   8 -rw-     5705728 Apr 28 2020 14:35:55   uis-cmw710-boot-1.01.10.bin
   9 -rw-   108381184 Apr 28 2020 14:36:52   uis-cmw710-system-1.01.10.bin
  10 -rw-        7168 Apr 29 2020 14:06:09   uis.db
  11 -rw-        7168 Apr 29 2020 14:06:09   uis_bak.db
  12 drw-           - Apr 22 2020 11:19:19   versionInfo
1048576 KB total (792076 KB free)
<Sysname>
2.     In any view on the CLI of the switch module, run the save command to save the current configuration information of the switch module:
<Sysname> save
<Sysname>
3.     In user view on the CLI of the switch module, run the tftp put command to back up the system file and boot file on the TFTP file server:
<Sysname>tftp 192.168.1.1 put flash:/uis-cmw710-system-1.01.10.bin
Press CTRL+C to abort.
%   Total    % Received %  Xferd  Average  Speed    Time    Time     Time  Current
                                 Dload   Upload   Total    Spent    Left    Speed
84  103M    0     0  84  87.0M    0     851k    0:02:04   0:01:44  0:00:20   837k
<Sysname>tftp 192.168.1.1 put flash:/uis-cmw710-boot-1.00.10.bin
100  5572k   0     0  100  5572k      0   832k   0:00:06    0:00:06   --:--:--    828k
<Sysname>
4.     In user view on the CLI of the switch module, run the tftp put command to back up profile startup.cfg on the TFTP file server:
<Sysname>tftp 192.168.1.1 put startup.cfg
100  6549    0     0  100  6549      0   270k --:--:-- --:--:-- --:--:--  319k
<Sysname>
Common operations
·     The blade enclosure has been energized.
·     You have obtained the login data of the OM module.
As shown in Figure 18, connect the Ethernet interface of the PC to the MGMT interfaces of the active and standby OM modules through the LAN. Ensure that the IP addresses of the PC and OM module are accessible at Layer 3.
Figure 18 Setting up the hardware environment
As shown in Figure 19, open the browser on the PC and enter the URL (in the format of https://OM_ip_address) used to log in to the OM Web interface. Enter the admin username and password. Click Login.
Figure 19 Logging in to the Web interface of the OM module
As shown in Figure 20, connect the Ethernet interface of the PC to the MGMT interfaces of the active and standby OM modules through the LAN. Ensure that the IP addresses of the PC and OM module are accessible at Layer 3.
Figure 20 Setting up the hardware environment
Set the login parameters and log in to the OM CLI using the remote access software. Table 18 lists the login parameters.
Table 18 Parameters used to log in to the OM CLI via SSH
Login Parameter
Data
Protocol
SSH
Port number
·     22
<OM>
