H3C Servers HDM Mobile User Guide-6W100
HomeSupportConfigure & DeployUser ManualsH3C Servers HDM Mobile User Guide-6W100
Table of Contents
Related Documents
01-Text
01-Text 2.42 MB
Introduction· 1
Login· 2
Install HDM Mobile· 2
Install HDM Mobile in Android operating system·· 2
Install HDM Mobile in iOS operating system·· 3
Prepare rack server environment 3
Prepare hardware environment 3
Configure networks· 4
Obtain HDM login information· 4
Prepare blade server or AE module environment 6
Prepare hardware environment 6
Configure networks· 7
Obtain HDM login information· 7
Devices· 10
Add a device· 10
Restrictions and guidelines· 10
Procedure· 10
Parameters· 15
Edit a device· 15
Delete a device· 17
Search for a device· 19
Log in to a device· 21
Switch a device· 23
Configure HDM Mobile· 25
View HDM Mobile information· 25
Set HDM Mobile languages· 28
Dashboard· 30
Basic information· 30
Procedure· 30
Parameters· 32
Alarm information· 32
Parameters· 32
Recent logs· 32
Status Summary· 32
Procedure· 32
Parameters· 34
Information· 36
Event log· 36
Hardware· 39
View processor information· 39
View memory information· 41
View fan information· 43
View power supply information· 45
View network adapter information· 47
View PCIe module information· 49
Sensors· 51
View temperature sensor information· 51
View fan sensor information· 53
View processor sensor information· 55
View power supply information· 57
View memory sensor information· 59
View drive sensor information· 62
View current sensor information· 64
View voltage sensor information· 66
View other sensor information· 68
Configuration· 81
Power control 81
Procedure· 81
Parameters· 83
Power supply configuration· 83
Procedure· 83
Parameters· 85
UID LED control 85
Restrictions and guidelines· 85
Procedure· 85
Parameters· 87
Users· 88
View current account information· 88
View HDM Mobile information· 90
Log out a server 92
Introduction
HDM Mobile is the mobile application for HDM. With the application installed, you can add multiple servers in the system to monitor the overall server states, including basic information, hardware information, and sensor information. You can perform health diagnosis for servers by using event logs, and configure power supplies and UID LEDs based on service requirements.
HDM Mobile pages might vary by server model or HDM version. Figures in this document are for illustration only.
Login
Install HDM Mobile
The HDM Mobile app supports Android and iOS operating systems. To install HDM Mobile, you can scan the QR code for downloading or download the application from the Android or iOS application market directly.
1.     Verify that the Android operating system on your mobile device is version 7.0 or later. If not, upgrade the system first.
2.     Download HDM Mobile in HUAWEI AppGallery or scan the QR code for downloading as needed.
¡     Open the HUAWEI AppGallery, search for HDM Mobile, and download and install HDM Mobile.
¡     Scan the QR code as shown in Figure 1, and download and install HDM Mobile as prompted.
Figure 1 QR code for downloading HDM Mobile
3.     During installation, authorize the permission for HDM Mobile on your device.
The page for the permission authorization varies by operating system.
1.     Verify that the iOS operating system on you device is version 10.0 or later. If not, upgrade the system first.
2.     Download HDM Mobile in App Store or scan the QR code for downloading as needed.
¡     Open App Store, search for HDM Mobile, and download and install HDM Mobile.
¡     Scan the QR code as shown in Figure 3, and download and install HDM Mobile as prompted.
Figure 2 QR code for downloading HDM Mobile
3.     During installation, authorize the permission for HDM Mobile.
Connect the server to a Wi-Fi router (single or multiple server management)
1.     Connect a shared port or the dedicated port of the server to a Wi-Fi router.
¡     HDM shared port—Processes HDM management traffic and data traffic.
¡     HDM dedicated port—Processes HDM management traffic.
Figure 3 Connecting the dedicated port to a Wi-Fi router
Connect the server to a USB Wi-Fi adapter (single server management)
Connect a USB Wi-Fi adapter to the server USB port. This method only applies to servers that support HDM wireless management.
Configure networks
Methods for network configuration vary by hardware environment.
·     If the server is connected to a Wi-Fi router, configure the Wi-Fi router to make sure that the route to the server is reachable, and then connect your mobile device to the corresponding Wi-Fi.
·     If the server is connected to a USB Wi-Fi adapter, access HDM Web interface, configure wireless settings, and then connect your mobile device to the corresponding Wi-Fi. For more information about HDM wireless management, see H3C Servers HDM User Guide.
Before adding servers, you must obtain the HDM management IP address, username, and password for the device.
The HDM default login information is as shown in Table 1.
Table 1 Default login information
Item
Default value
Username
admin
Password
Password@_
HDM shared port IP address
Obtained from the DHCP server
HDM dedicated port IP address
192.168.1.2/24
HDM wireless network IP address
192.168.199.1/24
Use the following methods to obtain login address.
Access HDM Web interface
1.     Log in to HDM from the Web interface. For more information, see H3C Servers HDM User Guide.
2.     Access the Network page, click the Dedicate Port, Shared Port, or Wi-Fi Management tab, and view the corresponding IP address.
Figure 4 Viewing HDM management IP address for the dedicated port
Access the POST screen
You can access the POST screen to obtain the IP address. Options include HDM Shared IPv4, HDM Dedicated IPv4, HDM Shared IPv6, and HDM Dedicated IPv6.
This method is not available for HDM wireless network IP address.
This section takes BIOS 2.00.27 as an example.
Figure 5 POST screen
The login method for blade servers and AE modules are the same. This section takes blade servers as an example.
Connect the management ports (MGMT) of the active and standby OM modules to a Wi-Fi router. For information about positions of the management ports, see the marks on the front panels.
Figure 6 Connecting OM modules to a Wi-Fi router
Configure networks
Configure the Wi-Fi router to make sure the routes to OM modules are reachable, and then connect you mobile device to the corresponding Wi-Fi.
The HDM default login information is as shown in Table 2.
Table 2 Default login information
Item
Default information
Username
admin
Password
Password@_
Use the following methods to obtain the login IP address.
2.     Access the Network page, click the Shared Port tab, and view the HDM management IP address.
Figure 7 Viewing HDM management IP address for a blade server
Access the OM Web interface
1.     Log in to OM from the Web interface. The default OM login information is as shown in Table 3.
Table 3 Default OM information
Item
Default value
OM management IP address
192.168.100.100/24
Username: admin
Password: Password@_
2.     On the OM Web interface, access the Enclosure-Chassis-01 > Blade Servers page, and select the target blade server.
3.     On the HDM Network Info page, view the HDM management IP address.
Figure 8 Viewing HDM management IP address
Devices
Add a device
You can use this feature to add a maximum of 128 servers and manage the servers in batch.
Before adding a device, make sure that your mobile device and the server HDM management port are connected to the same Wi-Fi.
·     The  icon indicates that you can access the server without a password. If the icon does not appear during login, you must enter a password.
·     If HDM Mobile cannot communicate to the server correctly, the server entry in the device list will be non-editable and colored grey.
·     During device adding, if you do not enter the user information as an administrator or operator, the Configuration feature in HDM Mobile will be unavailable.
·     If the username or password for an added server is changed, and the session for adding the server is timed out, the server entry in the device list will be non-editable and colored grey.
1.     Open HDM Mobile and access the Devices page.
Figure 9 Accessing the Devices page
2.     Click the  icon in the upper right corner to access the Add Device page.
Figure 10 Adding a device
3.     Enter the HDM management IP address, port number (default value recommended), username, and password.
4.     Enable Remember password as needed.
5.     Select I have read and agree to the User Agreement.
6.     Click OK.
After the device is added, you can view the server model, HDM management IP address, port number, and health state on the Devices page.
Figure 11 Device list
Address: HDM management IP address for the server, supporting an IP address or a domain name. This field is required.
Port: HDM management port for the server, in the range of 1 to 65535. The default value is 443. This field is required.
Username: Username for the server. As a best practice, enter the username as an administrator or operator. This field is required.
Password: Password for the server. As a best practice, enter the password as an administrator or operator. This field is required.
Edit a device
2.     Press and hold the target sever. In the dialog box that opens, click Edit.
Figure 12 Editing a device
3.     Edit the device information, and click OK.
4.     To refresh the page, click the  icon at the bottom of the page.
Delete a device
2.     Press and hold the target server. In the dialog box that opens, click Delete.
3.     To delete devices in batch, click Manage at the bottom of the page. Select target devices or click Select all, and click Delete.
Figure 13 Deleting devices
Search for a device
2.     In the search box, enter the target HDM management IP address or port number.
Figure 14 Searching for a device
Log in to a device
2.     Click the target device in the device list.
3.     Enter the login password for the server if you do not enable Remember Password.
Figure 15 Accessing a device
Switch a device
Perform the following tasks to switch and manage another device:
2.     Click the current server in the device list.
3.     Click the Me menu.
4.     Click Log out. You will be placed back onto the Devices page.
5.     Click another server you want to manage in the device list.
Figure 16 Exiting the current login account
2.     Click the settings icon in the upper left corner.
Figure 17 Configuring HDM Mobile
3.     Click About HDM Mobile to view the version information and user agreement for HDM Mobile.
Figure 18 HDM Mobile version information and user agreement
3.     Click Language to open the language setting page.
HDM Mobile supports simplified Chinese and English.
4.     Select a language.
5.     Click OK.
Figure 19 Setting languages
Dashboard
You can view device details on the dashboard, including basic information, alarm information, log information, and basic states. Configurations vary by sever model.
Basic information
Perform this task to view basic information for the server, including the device model, host name, HDM firmware version, HDM management IPv4 address, power supply states, and UID LED states.
2.     Click the target server to access the Dashboard page for the server.
3.     View basic information for the server.
Figure 20 Dashboard
·     IPv4 addresses: IPv4 addresses of the network ports for accessing HDM.
·     Server power: Power supply state for the server. Options include On and Off.
·     UID LED: UID LED state for the server. Options include:
¡     On—The UID LED is steady blue. The server is selected.
¡     Flashing—The UID LED is flashing blue. A firmware update is being performed on the server or if the remote console is open.
¡     Off—The UID LED is off. The server is not selected.
Alarm information
3.     View the alarm information for the server as shown in Figure 22.
4.     Click the alarm information to access the Event Log page.
·     Minor: The failure has minor impacts on the system. Prompt action is required to avoid an escalation in severity.
·     Major: The event might cause part of the system to fail and result in service interruption. Immediate action is required.
·     Critical: The event might result in system outage or power failure. Immediate action is required.
Recent logs
3.     View recent logs for the server as shown in Figure 22.
4.     Click View More to access the Event Log page for more log information.
Status Summary
Perform this task to monitor the operation and health states of subsystems for the server.
3.     The Status Summary section displays subsystems and monitors health states for subsystems.
4.     If a subsystem is faulty, you can view the reasons on the corresponding sensor information page or hardware information page.
Figure 21 Status summary
·     The following severity levels indicate the health state for the server:
¡      Normal: All components for the server are working correctly.
¡      Minor,  Major, and  Critical indicate that some of the server components are faulty.
·     The following severity levels indicate health states for subsystem components.
¡      Normal: The component is working correctly.
¡      Minor: The performance for the component has degraded by a minor failure.
¡      Major: The performance for the component has obviously degraded by a major failure.
¡      Critical: The server might be shut down automatically to avoid component damages.
·     Summary of a component health states is shown in Table 4. Subsystem types and states might vary by HDM version. For more information, see the HDM online help.
Table 4 Component health states
Subsystem
Processors
 Normal
The processors are operating correctly.
 Minor
A recoverable processor error has occurred.
 Major
An overtemperature condition has occurred or a processor configuration error is present.
 Critical
One of the following conditions exists:
·     The temperature of the processor has exceeded the critical threshold.
·     An unrecoverable processor error has occurred.
·     The primary processor is absent.
·     The BIOS gets stuck at the POST phase because of a processor error.
Memory
 Normal
The memory is operating correctly.
 Minor
A recoverable memory error has occurred.
 Major
·     All memory modules are absent or isolated.
·     An unrecoverable memory error has occurred.
·     Incorrect DIMM installation or DIMM incompatibility.
 Critical
The BIOS gets stuck at the POST phase because of a memory error.
Fans
 Normal
The fans are operating correctly in redundancy. None of the fans at critical locations have failed.
 Minor
The fan speed has reduced or fan redundancy issue is present because a fan at the critical location has failed.
 Major
Fan redundancy issue is present because fans at two or more critical locations have failed.
Power supplies
 Normal
The power supply is operating correctly.
 Minor
The power supply is not in redundancy.
 Major
A severe power supply error has occurred.
Storage
 Normal
All logical drives, physical drives, and storage controllers are operating correctly.
home-serious-small Major
·     A logical drive error has occurred.
·     A physical drive error has occurred.
·     A storage controller error has occurred.
PCIe modules
 Normal
All PCIe modules are operating correctly.
 Major
A bus uncorrectable error, bus fatal error, or PCIe err error has occurred.
Temperature
 Normal
All component temperatures are within the normal range.
 Minor
The temperature has crosses a minor threshold, but is has not reached a major threshold.
 Major
The temperature has crossed a major threshold, but it has not reached a critical threshold.
 Critical
The temperature has crossed a critical threshold.
Others
 Normal
All components are operating correctly.
A major component error has occurred.
home-fatal-small  Critical
A critical component error has occurred.
Information
Event log
Perform this task to view event logs reported by sensors. If you identify an event log for an abnormal state, access HDM Web interface for action suggestions and resolve the issue.
When the number of event logs reaches the upper limit (3639), the system will store event logs based on configured event log policies.
3.     Click the Information > Event Log menu.
Figure 22 Event log
4.     Click Filter in the upper right corner.
Figure 23 Filtering logs
¡     Select one or more severities. The Event Log page will display event logs with the selected severities.
¡     Select sensor types. The Event Log page will display event logs generated by the sensors.
5.     Click OK.
6.     To cancel filtering, click Reset.
·     ID: Event number. Events are numbered in chronological order. By default, the events in the event list are sorted by event number in ascending order.
·     Event log severities include the following levels:
¡     Normal—The event does not adversely affect the system. No action is required. Examples of normal events include expected state change events and alarm removed events.
¡     Minor—The event has minor impacts on the system. Prompt action is required to avoid an escalation in severity.
¡     Major—The event might cause part of the system to fail and result in service interruption. Immediate action is required.
¡     Critical—The event might result in system outage or power failure. Immediate action is required.
Hardware
Perform this task to view information for hardware such as processors, memories, and PCIe modules. Configurations vary by server model.
CAUTION
CAUTION:
·     When the server is down, the Processors tab and the Memory tab display information of the last POST phase.
·     During POST, information for processors, memory, and PCIe modules might be incorrect or incomplete. To obtain the correct information, refresh the page after the server POST.
3.     Click the Information > Hardware menu.
4.     Click Processors.
Figure 24 Processor information
·     Model: Model of the processor.
·     Status: Status for the processor. Options include Present and Absent.
·     Frequency: Base frequency of the server.
·     Status: Operation status for the server. Options include Normal and Abnormal.
·     Cores: Number of cores for the server.
·     Threads: Maximum number of threads supported by the server.
·     64 bits: Support of the processor for 64-bit computing.
·     L1 cache: L1 cache of the processor.
·     L2 cache: L2 cache of the processor.
·     L3 cache: L3 cache of the processor.
·     If a DIMM is absent, the Status field displays Absent, and the rest fields display a tilde (~).
·     If a DIMM is abnormal, the Status field displays Abnormal, and the rest fields display a tilde (~).
·     When a channel is disabled because of a DIMM training error, the Status fields for other present DIMMs in the channel display Abnormal, and the rest fields for these DIMMs display a tilde (~).
4.     Click Memory.
Figure 25 Memory information
·     Location: Processor ID of a DIMM.
·     Channel: Channel ID of a DIMM processor.
·     Slot: Slot number of a DIMM.
·     Status: Status of a DIMM. Options include Absent, Non-Initialized, Normal, and Abnormal.
·     Max frequency: Main frequency of the memory module.
·     Technology: Technology of the DIMM.
·     Authenticity: Authentication status for a DIMM. Normal indicates that the DIMM is unauthorized. Authorized indicates that the DIMM has been authorized.
·     ECC: Support for error-correcting code (ECC).
4.     Click Fans.
Figure 26 Fan information
·     Model: Fan module.
·     Rotation speed (RPM): Current actual rotational speed of the fan.
·     Rotation speed (%): Ideal RPM based on current temperature as a percentage of the rated RPM.
·     Status: Health status of the fan.
4.     Click Power.
Figure 27 Power supply information
·     Status: Current status of the power supply. Options include Present and Absent.
·     Model: Model of the power supply.
·     Vendor: Manufacturer of the power supply.
·     Serial number: Unique code assigned by the manufacturer.
·     Firmware version: Firmware version of the power supply.
·     Power status: Power output status.
·     Max power (W): Maximum output power of the power supply.
·     Power supply redundancy state:
¡     Abnormal—Indicates that the required fans are absent or damaged.
¡     Normal—Indicates that the required fans are correctly present with the optional fans present or absent.
4.     Click Network Adapters.
Figure 28 Network adapter information
·     TypeNIC: Type of the network adapter.
·     Name: Name of the network adapter.
·     Network port: Port number of the network adapter.
·     Location: Location of the network adapter.
·     MAC addresses: MAC address of the network port.
·     Speed: Rate of the network port.
·     Firmware version: Firmware version of the network port.
4.     Click PCIe.
Figure 29 PCIe module information
·     Slot: Slot of the PCIe module. For more information about slot locations, see the user guide for the server.
·     Status: PCIe module status, including Normal and Abnormal.
·     Product name: Model of the PCIe module.
·     Vendor name: Manufacturer of the PCIe module.
·     Product ID: ID assigned by the manufacturer.
·     Negotiated speed: Auto-negotiated PCIe link rate.
·     Negotiated protocol: Auto-negotiated generation of the PCIe standard.
·     Negotiated link width: Auto-negotiated PCIe link bandwidth.
·     Max speed: Maximum PCIe link rate.
·     Supported latest protocol: Supported latest generation of the PCIe standard.
Sensors
Perform this task to view readings of temperature sensors. For more information about sensors, see the HDM online help. Support for sensors varies by server model.
3.     Click the Information > Sensors menu.
4.     Click the Temperature tab.
Figure 30 Temperature sensor information
·     Status: Temperature status of a component:
¡     Normal—The temperature is normal, between the lower and upper minor thresholds (exclusive). No action is required.
¡     Minor—The temperature is between the lower major threshold (exclusive) and lower minor threshold (inclusive) or between the upper minor threshold (inclusive) and upper major threshold exclusive). Administrative attention is required.
¡     Major—The temperature is between the lower critical threshold (exclusive) and lower major threshold (inclusive) or between the upper major threshold (inclusive) and upper critical threshold (exclusive). Immediate action is required.
¡     Critical—The temperature is equal to or below the lower critical threshold, or it is equal to or above the upper critical threshold. Immediate action is required.
¡     N/A—The monitored component is not installed or the temperature sensor cannot be read.
·     Reading: Current temperature. If BMC fails to read the sensor, this field displays N/A.
·     Thresholds: Temperature thresholds:
¡     CriticalLower and upper critical thresholds. When the temperature reaches either threshold, the server might automatically shut down to avoid damage to its components.
¡     MajorLower and upper major thresholds. If the temperature reaches either threshold, server performance will significantly degrade.
¡     MinorLower and upper minor thresholds. If the temperature reaches either threshold, server performance will slightly degrade.
Perform this task to view fan information and configure the fan speed mode.
4.     Click the Fans tab.
Figure 31 Fan sensor information
·     Status: Operation status of the fan. Options include:
¡     Normal—The fan is present and working correctly.
¡     Minor—The fan rotation speed has degraded
¡     Major—The fan is absent or has installation errors.
¡     N/A—The fan is absent or the rotator speed is abnormal.
·     Reading: Indicates the rotation speed or operation status for the fan.
Perform this task to view operation status for the processor.
4.     Click the Processors tab.
Figure 32 Processor sensor information
Status: Status of the processor. Options include:
·     Normal—The processor is working correctly.
·     Minor—A recoverable processor error has occurred.
·     Major—An overtemperature condition has occurred or a processor configuration error is present.
·     Critical—One of the following conditions exists:
¡     The temperature of the processor has exceeded the critical threshold.
¡     An unrecoverable processor error has occurred.
¡     The primary processor is absent.
¡     The BIOS gets stuck at the POST phase because of a processor error.
·     N/A—The processor is absent.
Perform this task to view the input power and operation status for the power supply.
4.     Click the Power tab.
Figure 33 Power supply sensor information
·     Status:
¡     CPU_PowerTotal power of all present processors.
-     NormalProcessors are present and the system is powered on.
-     N/AAll processors are absent or the system is powered off.
¡     DISK_Power: Total power of all present drives.
-     NormalThe drive backplane is working correctly and the system is powered on.
-     N/AThe drive backplane is not initialized or the system is powered off.
¡     Fan _Power: Total power of all present fans.
-     NormalFans are present and the system is powered on.
-     N/AAll fans are absent or the system is powered off.
¡     MEM_Power: Total power of present DIMMs.
-     NormalDIMMs are present and the system is powered on.
-     N/AAll DIMMs are absent or the system is powered off.
¡     PSUnumber_PIN: Input power of the power supply module.
-     NormalPower is input.
-     N/ANo power is input.
¡     PSUnumber_Status: Operation status of the power supply module.
-     NormalThe power supply module is present and in cold backup status.
-     MinorA predictive alarm occurs to the power supply module.
-     MajorErrors are detected, including power supply failure, predictive alarms, loss of AC/DC power source, power input out of range, and configuration errors.
-     N/AThe power supply module is absent.
¡     PSU_Redundancy: Redundancy status of the power supply module.
-     Normal.
-     Minor—The power supply is not in redundancy.
¡     Total_Power: Input power for the server.
-     NormalThe input power for the server is obtained correctly.
-     N/AUnable to obtain the input power for the server.
·     Reading:
¡     DISK_PowerTotal power of all present drives.
¡     Fan_PowerTotal power of all present fans.
¡     MEM_PowerTotal power of all present DIMMs.
¡     PSUnumber_PINCurrent input power for the power supply module.
¡     Total_PowerInput power for the server.
Perform this task to view the operation status for the memory.
4.     Click the Memory tab.
Figure 34 Memory sensor information
Status: DIMM operation status. Options include:
·     NormalThe DIMM is present and operating correctly.
·     N/AThe DIMM is absent.
·     Minor/Major/CriticalThe DIMM cannot work correctly.
4.     Click the Drives tab.
Figure 35 Drive sensor information
Status: Drive status. Options include:
·     NormalThe drives is present and operating correctly.
·     N/A—The Drive is absent.
·     Minor/Major/Critical—A Failure has occurred to the drive.
Perform this task to view whether overcurrent occurs to system board components.
4.     Click the Current tab.
Figure 36 Current sensor information
·     Status: Current status. Options include:
¡     NormalA current failure is removed or the current value is between the lower minor threshold (exclusive) and upper minor threshold (exclusive).
¡     MajorA current failure is triggered or the current value is between the lower major threshold and the upper major threshold.
¡     CriticalThe current value is between the lower critical threshold and the upper critical threshold.
¡     N/AThe sensor is faulty or the server is not powered on.
·     Reading: Displays the current value for a system board component.
Perform this task to view the voltage states for system board components.
4.     Click the Voltage tab.
Figure 37 Voltage sensor information
·     Status: Voltage status. Options include:
¡     NormalA voltage failure is removed or the voltage value is between the lower minor threshold (exclusive) and upper minor threshold (exclusive).
¡     MajorA voltage failure is triggered or the voltage value is over the upper major threshold or below the lower major threshold.
¡     N/AThe component is not installed or unable to obtain the voltage reading.
·     Reading: Displays the voltage value for a system board component.
·     Threshold: Voltage thresholds for a system board component in different severities, including upper thresholds and lower thresholds for minor, major, and critical levels.
SEL
Perform this task to view the operation status for the SEL (System Event Log) sensor.
4.     Click the Others tab.
Figure 38 SEL sensor information
Status: Options include:
·     Normal:
¡     The SEL sensor is working correctly.
¡     Log area reset/cleared: Event logs are cleared.
·     Minor:
¡     The SEL section is full: The number of event logs has exceeded the upper limit.
¡     The SEL section being full: The number of event logs has exceeded 75% of the total logs.
Watchdog2
Use Watchdog2 sensor to monitor the operation system status for the server. When Watchdog2 sensor detects that the operating system crashes, it restarts the operating system automatically.
Figure 39 Watchdog2 sensor information
·     Normal—Indicates that the operating system for the serve is working correctly.
·     Minor—Indicates that the timer is overdue or is interrupted.
·     Major—Indicates timeouts for immediate reset, power-on, and power cycle.
Physical Security
Use Physical Security sensor to monitor the chassis-open state and the operation states for shared ports. The system generates an event log upon chassis opening, and does not generate an event log when the chassis is closed.
Figure 40 Physical Security sensor information
·     Name: Options include:
¡     AreaIntrusion: Monitors whether the server chassis is opened.
¡     Lan_number_Link: Monitors the operation state for a shared port.
¡     Lan_Leash_Lost: Monitors the operation states for all shared ports.
·     Status: Options include:
¡     AreaIntrusion:
-     NormalIndicates that the security chassis is closed.
-     MinorIndicates that the security chassis is opened.
-     N/AIndicates chassis-open alarm module is absent.
¡     Lan_number_Link:
-     NormalIndicates that the shared port is enabled.
-     N/AIndicates that the shared port is disabled.
¡     Lan_Leash_Lost:
-     NormalIndicates a minimum of one shares port is enabled.
-     N/AIndicates all shared ports are unavailable.
Sys_fw_progress
Use BIOS_POST_Status sensor to monitor the BIOS initialization progress.
Figure 41 BIOS_POST_Status sensor information
·     Name
¡     BIOS_POST_Status: Monitors the BIOS initiation progress.
¡     Normal.
¡     N/AThe server is shut down.
¡     MajorAn error has occurred to the BIOS initiation progress.
Module_board
Use Boards sensor to monitor states for system modules.
Restriction and guidelines
·     The system modules include the system board, processors, SMC modules, sLOM network adapters, mLOM network adapters, FLOM network adapters, riser cards, Mezzanine modules, PCIe modules, CPU & memory Mezzanine boards, GPU adapters, dual SD card extended modules, and drive backplanes. Types of system modules vary by server model.
·     When the system modules are faulty, access the Event Log page for failure details.
Figure 42 Boards sensor information
·     Name:
¡     BoardsMonitors the state of a system module.
·     Status:
¡     NormalThe system module is working correctly.
¡     CriticalAn error has occurred to the system module.
Mgmt
Use the BMC_Self_Test sensor to monitor the FRU component states for the server. Support for this feature varies by server model.
Figure 43 BMC_Self_Test sensor information
·     NormalThe FRU component is working correctly.
·     Major—Unable to obtain the FRU component information or an FRU verification error has occurred.
Configuration
Power control
Perform this task to manage the power status of a server.
3.     Click the Configuration > Power Control menu.
The Power status field represents the power supply state for the server.
4.     Select a power action and click Save.
Figure 44 Power supply control
CAUTION
CAUTION:
The force power-off, force system reset, and force power-cycle actions might cause corruption or loss of data. When you perform these actions, make sure you fully understand their impact on the services.
·     Force system reset: Warm reboots the server without power cycling the server.
·     Force power-off: Shuts down the server immediately by force. This action is equivalent to pressing the power button on the server for five seconds to put the server in standby mode.
·     Graceful power-off: Shuts down the operating system first, and then removes power from the server to put it in standby mode.
·     Power on: Starts up the server.
·     Force power-cycle: Powers off and then powers on the server.
Perform this task to view power information and configure power capping.
3.     Click the Configuration > Power Supply Configuration menu.
4.     View the total power of installed power supplies.
5.     Enable or disable power capping as needed.
6.     Configure the power cap value and the action upon a power capping failure as needed.
7.     Click Save.
Figure 45 Power supply configuration
·     Power cap value (W): With power capping enabled, if the power cap value of the power supplies is exceeded, the server attempts to decrease power consumption by automatically decreasing the operating frequency of system components such as processors.
·     Shutdown upon power capping failure: Power capping fails if the power consumption cannot drop below the power cap value in 30 seconds. You can configure the server to shut down or continue to run on a power capping failure.
UID LED control
Perform this task to quickly identify the target server in a server-intensive environment.
When the UID LED is in flashing green, you cannot turn on or off the UID LED.
3.     Click the Configuration > UID Light Control menu.
4.     Select Turn on or Turn off for the UID LED as needed.
Figure 46 UID LED control
Current status: Current status of the UID LED for the server. Options include:
·     On—The UID LED is steady blue. The server is selected.
·     Flashing—The UID LED is flashing blue. A firmware update is being performed on the server or the remote console is open.
·     Off—The UID LED is off. The server is not selected.
Users
4.     View the current account information.
Figure 47 Viewing account information
4.     Click About HDM Mobile to view the HDM Mobile version and user agreement.
Figure 48 Viewing HDM Mobile version and user agreement
Log out a server
4.     Click Log out.
Figure 49 Logging out the server
