25-WLAN Configuration Guide(AC)
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6728-6W10125-WLAN Configuration Guide(AC)
01-Compatibility of hardware and AC functionality
This document describes MSR routers that can function as ACs and compatible APs.
Table 1 Compatibility with Wi-Fi 4 and Wi-Fi 5 APs
MSR routers
Compatible APs
MSR810
MSR810-W
MSR810-W-DB
MSR810-LM
MSR810-LM-HK
MSR810-LM-CNDE-SJK
MSR810-W-LM
MSR810-W-LM-HK
MSR810-LME
MSR2600-6-X1
MSR2600-10-X1
MSR26-30
MSR3600-28
MSR3600-28-X1
MSR3600-28-X1-DP
MSR3600-51
MSR3600-51-X1
MSR3600-51-X1-DP
MSR36-10
MSR3610-X1-DP
MSR3610-X1-DC
MSR3610-X1-DP-DC
MSR36-20
MSR36-40
MSR36-60
MSR3620-X1
MSR3640-X1
MSR3640-X1-HI
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-CAN
SIC-AP320 (supported only on the MSR2600-6-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, and MSR3640-X1)
MSR3610-I-DP
MSR3610-I-DP+DDR4-16GB
MSR3610-I-DP+DDR4-32GB
MSR3610-IE-DP
MSR3610-IE-DP+DDR4-8GB
MSR3610-IE-DP+DDR4-32GB
MSR3610-IE-EAD
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-ACN
SIC-AP220
SIC-AP320
MSR810
MSR810-10-PoE
MSR3610-X1
MSR3620-DP
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-ACN
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
SIC-AP320 (supported only on the MSR3610-X1)
MSR3610-I-DP+DDR4-8GB
MSR3610-IE-DP+DDR4-16GB
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
WA4320-ACN-SI
WA4320H
WA4320H-EI
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-ACN
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
SIC-AP220
SIC-AP320
MSR1004S-5G
MSR1004S-5G-GL
MSR2600-15-X1
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
WA5530
WA5530-SI
WA5620
WA5620i-CAN
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR830-10HI-GL
MSR2600-6-X1-GL
WA510H-WW
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
WA560-WW
MSR2630-XS
MSR3600-28-XS
MSR3610-XS
MSR3610-I-XS
MSR3610-IE-XS
MSR3620-XS
MSR860-6EI-XS
MSR860-6HI-XS
MSR3620-X1-XS
MSR3640-XS
MSR3660-XS
WA2610H
WA2610H-LI
WA4320H-SI
WA4320-ACN-E
WA4320-ACN-D
WA4320-ACN-C
WA4320i-X
WA4320H
WA5320H-LI
WA5320-D
WA5320-C
WA5320-C-IOT
WA5320
WA5320i-LI
WA5320H
WA5320-C-EI
WA5320X-E
WA5320X-SI
WA5320X
WA5320X-LI
WA5530S
WA5530-LI
WA5530
SIC-AP320 (supported only on the MSR2630-XS, MSR3610-XS, MSR3610-I-XS, MSR3610-IE-XS, MSR3620-X1-XS, and MSR3640-XS)
MSR810-W-WiNet
MSR810-LM-WiNet
MSR830-4LM-WiNet
MSR830-6EI-WiNet
MSR830-5BEI-WiNet
MSR830-10BEI-WiNet
MSR830-6BHI-WiNet
MSR830-10BHI-WiNet
MSR2600-6-WiNet
MSR2600-10-WiNet
EWP-WAP712C-HI-FIT
EWP-WAP712C-LI
EWP-WAP712C-LI-G-FIT
EWP-WAP712C-LI-S-FIT
EWP-WAP712E-FIT
EWP-WAP722E-W2-FIT
EWP-WAP722S-W2
EWP-WAP722S-W2-FIT
EWP-WAP722S-W2-IOT-FIT
EWP-WAP922
EWP-WAP922E-FIT
WAP722S-HI
EWP-WAP723-W2-FIT
EWP-WAP923-FIT
EWP-WAP711H
EWP-WAP711H-FIT-G
EWP-WAP711H-FIT-W
EWP-WAP712H-FIT
EWP-WAP712H-G
EWP-WAP722H-FIT
EWP-WAP922H
EWP-WAP712X-FIT
EWP-WAP722XS-W2-FIT
EWP-WAP722X-W2
EWP-WAP722X-W2-FIT
EWP-WAP922X
EWP-WA2620E-WiNet-FIT
EWP-WA2620-WiNet-FIT
EWP-WA5320E-WiNet-FIT
EWP-WA5320H-WiNet-FIT
EWP-WA5320-WiNet-FIT
Table 2 Compatibility with Wi-Fi 6 APs
MSR routers
Compatible APs
MSR810
MSR2600-6-X1
MSR2600-10-X1
MSR3600-28-X1
MSR3600-51-X1
MSR3610-X1
MSR3620-DP
MSR3610-I-DP
MSR3610-IE-DP
WA6320-FIT
WA6320H-FIT
WA6322-FIT
WA6322H-FIT
WA6330-FIT
WA6338-FIT
WA6528-FIT
WA6620-FIT
WA6622-FIT
WA6628-FIT
WA6638-FIT
MSR810
MSR810-10-PoE
MSR3610-X1
MSR3620-DP
WA6320-FIT
WA6320H-FIT
WA6330-FIT
WA6622-FIT
WA6628-FIT
WA6638-FIT
WA6620X-FIT
WA6630X-FIT
WA6320-FIT
WA6320H-FIT
WA6330-FIT
WA6622-FIT
WA6628-FIT
WA6638-FIT
WA6620X-FIT
WA6630X-FIT
MSR1004S-5G
MSR1004S-5G-GL
MSR2600-15-X1
WA6320-FIT
WA6320H-FIT
WA6330-FIT
WA6622-FIT
WA6628-FIT
WA6638-FIT
WA6620X-FIT
WA6630X-FIT
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR830-10HI-GL
MSR2600-6-X1-GL
WA6320-FIT
WA6320H-FIT
WA6330-FIT
WA6622-FIT
WA6628-FIT
WA6638-FIT
WA6620X-FIT
WA6630X-FIT
MSR2630-XS
MSR3600-28-XS
MSR3610-XS
MSR3620-XS
MSR3610-I-XS
MSR3610-IE-XS
WA6320-C-FIT
WA6320-D-FIT
WA6330-LI-FIT
WA6320H-LI-FIT
