- 17-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-NETCONF commands
- 09-CWMP commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetStream commands
- 15-IPv6 NetStream commands
- 16-sFlow commands
- 17-Information center commands
- 18-Flow log commands
- 19-SmartMC commands
| 19-SmartMC commands | 150.45 KB |
display smartmc backup configuration status
display smartmc batch-file status
display smartmc replace status
display smartmc upgrade status
smartmc backup configuration max-number
smartmc backup configuration interval
smartmc tc startup-configuration
smartmc topology-refresh interval
smartmc upgrade startup-configuration
SmartMC commands
boot-loader
Use boot-loader to specify the upgrade startup software files for a SmartMC group.
Use undo boot-loader to restore the default.
boot-loader file { ipe-filename | boot boot-filename system system-filename }
undo boot-loader
No upgrade startup software files are specified for a SmartMC group.
SmartMC group view
ipe-filename: Specifies an IPE file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .ipe extension.
boot boot-filename: Specifies a boot image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
system system-filename: Specifies a system image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
# Specify IPE file device.ipe for SmartMC group testgroup.
[Sysname] smartmc group testgroup
[Sysname-smartmc-group-testgroup] boot-loader file device.ipe
smartmc group
create batch-file
Use create batch-file to create a batch file.
create batch-file batch-file-name
No batch files exist.
batch-file-name: Specifies a name for the batch file, a case-insensitive string of 1 to 255 characters. If you do not specify a file extension when specifying a file name, the default extension .cmdset is used.
After executing this command, you will enter the batch edit mode. In this mode, each command occupies a line. When you finish editing all command lines, enter a percent sign (%) to return to user view.
Make sure the command lines that you enter are correct because the system does not verify whether the command lines are correct.
# Create batch file test.cmdset, and enter the command lines for specifying the device name as Sysname and enabling Telnet.
<Sysname> create batch-file test.cmdset
Begin to edit batch commands, and quit with the character '%'.
sysname Sysname
telnet server enable%
<Sysname>
smartmc batch-file deploy
Use display smartmc backup configuration status to display the backup status for TCs.
This command displays the status of the ongoing backup task or the most recent backup task if the TC is not performing backup.
# Display the backup status for TCs.
<Sysname> display smartmc backup configuration status
ID IpAddress MacAddress Status Time
1 192.168.56.30 08d2-38ff-0300 Finished 2017-04-05 11:30:35
2 192.168.56.40 62d2-c21c-0400 Finished 2017-04-05 11:30:40
ID |
ID of the TC. |
IpAddress |
IP address of the TC. |
MacAddress |
MAC address of the TC. |
Status |
Backup status: · Waiting—The TC is waiting for configuration backup. · Processing—The TC is backing up the configuration. · Finished—The TC has finished backing up the configuration. · Timeout—Configuration backup times out. · Failed—The TC failed to back up the configuration. |
Time |
Time when the TC finished backing up the configuration. If the TC has not finished backing up the configuration, this field displays a hyphen (-). |
Use display smartmc batch-file status to display the batch file execution result.
display smartmc batch-file status [ last number ]
last number: Specifies a configuration deployment by its number counting from the most recent configuration deployment, in the range of 1 to 5. If you do not specify this option, the command displays the execution result for the most recent configuration deployment.
# Display the batch file execution result.
<Sysname> display smartmc batch-file status last 1
TC ID 1
Device MAC : 201c-e7c3-0300
Start time : 2017-03-21 10:23:53
End time : 2017-03-21 10:23:57
Result :
<Sysname>system-view
[Sysname]display smartmc configuration
Device role : TC
TM IP address : 192.168.22.103
TM MAC address : 0ec3-6a94-0100
TM sysname : Sysname
TC ID 2
Device MAC : 2409-600f-0400
Start time : 2017-05-06 17:47:20
End time : 2017-05-06 17:47:25
Result :
Device role : TC
TM sysname : S1
TC ID |
ID of the TC. |
Device MAC |
Start time |
Batch command line execution start time. |
End time |
Batch command line execution end time. |
Result |
Batch command line execution result in details. |
create batch-file
Use display smartmc configuration to display the SmartMC configuration.
# Display the SmartMC configuration on the TM.
<Sysname> display smartmc configuration
Device role : TM
FTP server IP : 192.168.22.103
FTP server username : admin
Topology-refresh interval : 60(s)
Backup startup-configuration interval : N/A
Sync backup number : 5
# Display the TM information on a TC.
Device role : TC
TM IP : 192.168.22.103
TM MAC : 8288-468d-0100
Device role |
Role of the device. |
FTP server IP |
IP address of the FTP server. If no FTP server IP address is configured, this field displays N/A. |
FTP server username |
FTP server username. If no username is configured, this field displays N/A. |
Topology-refresh interval |
Topology refresh interval, in seconds. |
Backup startup-configuration interval |
Automatic configuration file backup interval, in hours. If no interval is set, this field displays N/A. |
Sync backup number |
Number of TCs that can perform configuration backup at the same time. |
TM IP |
IP address of the TM. If the TC failed to obtain the TM IP address, this field displays N/A. |
TM MAC |
MAC address of the TM, If the TC failed to obtain the TM MAC address, this field displays N/A. |
TM sysname |
Name of the TM. If the TC failed to obtain the TM name, this field displays N/A. |
display smartmc device-link
Use display smartmc device-link to display connections between devices in the SmartMC network.
This command allows you to display the connections between the TM and TCs.
# Display connections between the devices in the SmartMC network.
<Sysname> display smartmc device-link
(TM IP)[192.168.56.20]
ID Hop LocalPort LocalIP PeerPort PeerIP
0 0 GigabitEthernet1/0/2 192.168.56.20 GigabitEthernet1/0/1 192.168.56.30
1 1 GigabitEthernet1/0/1 192.168.56.30 GigabitEthernet1/0/2 192.168.56.20
1 2 GigabitEthernet1/0/2 192.168.56.30 GigabitEthernet1/0/1 192.168.56.40
2 3 GigabitEthernet1/0/1 192.168.56.40 GigabitEthernet1/0/2 192.168.56.30
TM IP |
IP address of the TM. |
ID |
ID of the TM or TC. |
Hop |
Number of hops between the TM and TC. |
LocalPort |
Local port. |
LocalIP |
IP address of the local device. |
PeerPort |
Peer port. |
PeerIP |
IP address of the peer port. |
display smartmc group
Use display smartmc group to display SmartMC group information.
display smartmc group [ group-name ] [ verbose ]
group-name: Specifies a SmartMC group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a SmartMC group, the command displays information about all SmartMC groups.
Verbose: Displays detailed SmartMC group information. If you do not specify this keyword, the command displays brief SmartMC group information.
# Display detailed information about all SmartMC groups.
<Sysname> display smartmc group verbose
Group name : test
TC count : 5
Boot-loader file :
Startup-configuration file :
Rule:
Match Device-type S5560-EI
Match IP-address 192.168.56.0 24
Match MAC-address 0e74-ea13-0000 32
TCID DeviceType IpAddress MacAddress Status Version Sysname
1 S5560-EI 192.168.56.103 0e74-e2fb-0400 Normal R1306 S1
2 S5560-EI 192.168.56.102 0e74-ea13-0500 Normal R1306 S2
3 S5560-EI 192.168.56.104 0e74-db54-0300 Normal R1306 S3
Table 5 Command output
GroupName |
Name of the SmartMC group. |
TC count |
Number of TCs in the SmartMC group. |
Boot-loader file |
Names of the upgrade startup software files for upgrading the SmartMC group. If no upgrade startup software files are specified, this field displays null. |
Startup-configuration file |
Name of the configuration file for upgrading the SmartMC group. If no configuration file is specified, this field displays null. |
Rule |
Match criteria of the SmartMC group. |
Match |
Match type and its value. The match types include the following: · Device-type—Matches TCs by device type. · IP-address—Matches TCs by IP address. · MAC-address—Matches TCs by MAC address. |
TCID |
ID of the TC. |
DeviceType |
Device type of the TC. |
IpAddress |
MacAddress |
Version |
Software version of the TC. |
Status |
Operating status of the TC: · Offline—The TC is offline. · Normal—The TC is online. |
Sysname |
Device name of the TC. |
match
smartmc group
Use display smartmc replace status to display faulty TC replacement status.
# Display faulty TC replacement status.
<Sysname> display smartmc replace status
Faulty ID : 2
Faulty MAC : 94e2-cdcb-0600
Replacement ID : 3
Replacement MAC: 2443-5f8c-0200
Mode : Manual
Status : Successful
Start time : 2017-03-21 15:01:31
End time : 2017-03-21 15:01:40
Table 6 Command output
Faulty ID |
ID of the faulty TC. |
Faulty MAC |
MAC address of the faulty TC. |
Replacement ID |
ID of the new TC. |
Replacement MAC |
MAC address of the new TC. |
Mode |
Replacement method, which can be Manual or Auto. |
Status |
Replacement status: · Successful. · Failed. · Replacing. · Timeout. |
Start time |
Replacement start time |
End time |
Replacement end time. |
smartmc auto-replace enable
smartmc replace
display smartmc tc
Use display smartmc tc to display TC information.
display smartmc tc [ tc-id ] [ verbose ]
tc-id: Specifies a TC by its ID in the range of 1 to 255. If you do not specify a TC, this command displays information about all TCs.
verbose: Displays detailed TC information. If you do not specify this keyword, the command displays brief TC information.
# Display brief information about all TCs.
<Sysname> display smartmc tc
1 S5560-EI 192.168.22.104 201c-e7c3-0300 Normal R1308 S1
Table 7 Command output
TCID |
ID of the TC. |
DeviceType |
IpAddress |
MacAddress |
Status |
Operating status of the TC: · Normal—The TC is operating correctly. · Offline—The TC is offline. |
Version |
Sysname |
# Display detailed information about all TCs.
<Sysname> display smartmc tc verbose
TC ID : 1
Adding method : Manual
Sysname : S1
Model : S5560-54C-PWR-EI
Device type : S5560-EI
SYSOID :1.3.6.1.4.1.25506
MAC address : 0e74-e2fb-0400
IP address : 192.168.56.103
Boot image :
Boot image version :
System image :
System image version :
Current-configuration file :
uptime is: 0 week, 0 day, 0 hour, 0 minute
System CPU usage : 0%
System memory usage : 0%
Status : Offline
Boot-loader file :
Table 8 Command output
TC ID |
ID of the TC. |
Adding method |
Method through which the TC is added to the SmartMC network: · Manual. · Auto. |
Sysname |
Model |
Device model of the TC. |
Device type |
SYSOID |
SYSOID of the TC. |
MAC address |
IP address |
Boot image |
Boot image file that the TC runs. |
Boot image version |
Version of the boot image file. |
System image |
System image file that the TC runs. |
System image version |
Version of the system image file. |
Current-configuration file |
Current startup configuration file used by the TC. |
Uptime |
Operation duration of the TC. |
System CPU usage |
CPU usage on the TC. |
System memory usage |
Memory usage on the TC. |
Status |
Boot-loader file |
Upgrade startup software files. |
Upgrade configuration file. |
Use display smartmc upgrade status to display TC upgrade status.
# Display TC upgrade status.
<Sysname> display smartmc upgrade status
ID IpAddress MacAddress Status UpdateTime UpdateFile
1 192.168.56.1 82dd-a434-0200 Finished Immediately bootloader.ipe
2 192.168.56.103 5caf-2e5f-0100 Finished Immediately bootloader.ipe
Table 9 Command output
ID |
ID of the TC. |
MacAddress |
IpAddress |
Status |
Upgrade status: · Waiting—The TC is waiting for downloading the upgrade file. · Download-failed—The TC failed to download the upgrade file. · Download-finished—The TC has downloaded the upgrade file. · Downloading—The TC is downloading the upgrade file. · Updating—The TC is upgrading. · Finished—The TC has finished upgrading. · Failed—The TC failed to upgrade. · Unknown. |
Updated File |
Name of the upgrade file. |
UpdateTime |
Upgrade time: · Immediately—Upgrade at once. · Delay(m)—Upgrade after the specified delay. · Time(HH:MM)—Upgrade at the specified time. |
smartmc upgrade group
smartmc upgrade tc
match
Use match to set a match criterion to add all matching TCs to a SmartMC group.
Use undo match to delete a match criterion.
match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
undo match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
No match criterion is set.
SmartMC group view
device-type device-type: Sets a device type match criterion.
ip-address ip-address { ip-mask-length | ip-mask }: Sets an IP address match criterion. The ip-address argument specifies an IP address in dotted decimal notation. The ip-mask argument specifies the subnet mask in dotted decimal notation. The ip-mask-length argument specifies the subnet mask length in the range of 1 to 32.
mac-address mac-address mac-mask-length: Sets a MAC address match criterion. The mac-address argument specifies a MAC address in the format of H-H-H. The mac-mask-length argument specifies the mask length in the range of 1 to 48.
# Create SmartMC group a and add TCs in subnet 192.168.1.0/24 to the group.
[Sysname] smartmc group a
[Sysname-smartmc-group-a] match ip-address 192.168.1.0 24
smartmc group
Use smartmc auto-replace enable to enable the automatic faulty TC replacement feature.
Use undo smartmc auto-replace enable to disable the automatic faulty TC replacement feature.
The automatic faulty TC replacement feature is disabled.
Before you execute this command, perform the following tasks:
1. Install the new TC at the location where the faulty TC was installed.
2. Connect all cables to the new TC.
Make sure the new TC and the faulty TC have the same neighbor relationship, device model, and IRF member ID.
# Enable the automatic faulty TC replacement feature.
[Sysname] smartmc auto-replace enable
smartmc replace
Use smartmc backup configuration to manually back up the configuration file on TCs.
smartmc backup configuration { group group-name-list | tc [ tc-id-list ] }
group group-name-list: Specifies a space-separated list of up to 10 SmartMC group items. Each item specifies a SmartMC group name, a case-sensitive string of 1 to 31 characters.
tc tc-id-list: Specifies a space-separated list of up to 10 TC items. Each item specifies a TC or a range of TCs in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255. If you do not specify any TCs, all TCs will perform configuration backup.
After you execute this command, the TCs immediately save the running configuration to the next-startup configuration files and upload the configuration files to the FTP server.
The backup configuration files are named in the format of bridge MAC address_backup.cfg.
# Back up the configuration file on TC 1, TC 2, TC 3, and TC 4.
[Sysname] smartmc backup configuration tc 1 to 4
# Back up the configuration file on all TCs in SmartMC groups test1, test2, and test3.
[Sysname] smartmc backup configuration group test1 test2 test3
Use smartmc backup configuration max-number to set the maximum number of TCs that can perform automatic configuration backup at the same time.
Use undo smartmc backup configuration max-number to restore the default.
smartmc backup configuration max-number max-number
A maximum of five TCs can perform automatic configuration backup at the same time.
max-number: Specifies the maximum number of TCs that can perform automatic configuration backup at the same time, in the range of 2 to 20.
# Specify that a maximum of 10 TCs can perform automatic configuration backup at the same time.
[Sysname] smartmc backup configuration max-number 10
Use smartmc backup configuration interval to enable the automatic configuration file backup feature and set the automatic backup interval.
Use undo smartmc backup configuration interval to restore the default.
smartmc backup configuration interval interval
The automatic configuration file backup feature is disabled.
Interval: Specifies the automatic configuration file backup interval in the range of 1 to 720 hours.
This command enables the TM and TCs to back up their configuration files by saving the running configuration to the files and then uploading them to the FTP server. When you configure this command, the TM and TCs immediately perform a backup. After that, they back up the configuration files at the specified interval. The backup configuration files are named in the format of bridge MAC address_backup.cfg.
# Enable the automatic configuration file backup feature and set the backup interval to 24 hours.
[Sysname] smartmc backup configuration interval 24
Use smartmc batch-file deploy to deploy a batch file to a list of TCs or SmartMC groups.
smartmc batch-file batch-file-name deploy { group group-name-list | tc tc-id-list }
batch-file-name: Specifies a batch file by its name, a case-insensitive string of 1 to 255 characters.
# Deploy batch file startup.cmdset to SmartMC group testgroup.
[Sysname] smartmc batch-file startup.cmdset deploy group testgroup
create batch-file
smartmc enable
Use smartmc enable to enable SmartMC and set the device role.
Use undo smartmc enable to disable SmartMC.
smartmc { tm [ username username password { cipher | simple } string ] | tc } enable
undo smartmc enable
SmartMC is disabled.
tm: Enables SmartMC and sets the device role to TM.
username username: Specifies a username for the local user, a case-sensitive string of 1 to 55 characters.
password: Specifies a password for the local user.
simple: Specifies a password in plaintext form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
tc: Enables SmartMC and sets the device role to TC.
A SmartMC network must have one and only one TM.
To enable SmartMC, execute this command on both the TM and TCs. To configure the other SmartMC features, execute associated commands only on the TM.
If you change the role of the TM to TC or disable SmartMC on the TM, all SmartMC settings in its running configuration will be cleared.
For manual SmartMC network establishment, the TM preferentially uses the user-specified username and password. If no username and password are specified, the TM uses the default username admin and password admin.
# Enable SmartMC and set the device role to TM.
[Sysname] smartmc tm enable
smartmc ftp-server
Use smartmc ftp-server to configure the FTP server information.
Use undo smartmc ftp-server to delete the FTP server information.
smartmc ftp-server server-address username username password { cipher | simple } string
No FTP server information is configured.
server-address: Specifies an FTP server by its IP address.
username username: Specifies the FTP server username, a case-sensitive string of 1 to 55 characters.
password: Specifies the FTP server password.
# Set the FTP server IP address, username, and password to 192.168.22.19, admin, and admin, respectively.
[Sysname] smartmc ftp-server 192.168.22.19 username admin password simple admin
smartmc group
Use smartmc group to create a SmartMC group and enter its view, or enter the view of an existing SmartMC group.
Use undo smartmc group to delete a SmartMC group.
smartmc group group-name
undo smartmc group group-name
No SmartMC groups exist.
group-name: Specifies the name of the SmartMC group, a case-sensitive string of 1 to 31 characters.
When you perform the following operations, you can specify a SmartMC group to apply the operations to all TCs in the group:
· Startup software upgrade.
· Configuration file upgrade.
· Configuration deployment.
# Create SmartMC group testgroup.
match
smartmc replace
Use smartmc replace to manually replace a faulty TC.
smartmc replace tc tc-id1 faulty-tc tc-id2
tc tc-id1: Specifies the ID of the new TC, in the range of 1 to 255.
faulty-tc tc-id2: Specifies the ID of the faulty TC, in the range of 1 to 255.
# Replace faulty TC 5 with new TC 10.
[Sysname] smartmc replace tc 10 faulty-tc 5
smartmc tc boot-loader
Use smartmc tc boot-loader to specify the upgrade startup software files for a TC.
Use undo smartmc tc boot-loader to remove the configuration.
smartmc tc tc-id boot-loader { ipe-filename | boot boot-filename system system-filename }
undo smartmc tc tc-id boot-loader
tc tc-id: Specifies a TC by its ID in the range of 1 to 255.
# Specify boot image file boot.bin and system image file system.bin for TC 1.
[Sysname] smartmc tc 1 boot-loader boot boot.bin system system.bin
display smartmc tc
smartmc tc device-type
Use smartmc tc device-type to define a TC type on the TM.
Use undo smartmc tc device-type to delete a TC type.
smartmc tc sysoid sysoid device-type device-type
undo smartmc tc sysoid sysoid device-type device-type
sysoid sysoid: Specifies the SYSOID of a device.
device-type device-type: Specifies a device type.
To obtain the SYSOID of a TC, use the display smartmc tc verbose command.
# Define a TC type by specifying the SYSOID as 1.3.6.1.4.1.25506.1.1588 and the device type as SW.
[Sysname] smartmc tc sysoid 1.3.6.1.4.1.25506.1.1588 device-type SW
smartmc tc password
Use smartmc tc password to modify the password for the default user on TCs.
smartmc tc password string
string: Specifies a password, a case-sensitive string of 1 to 63 characters.
During SmartMC network establishment, the TM establishes NETCONF sessions to TCs and adds them to the network. The default username and password on the TCs for NETCONF session establishment are admin and admin. To enhance security, you can perform this task to change the password for the default user admin of the TCs after the TM adds the TCs to the network.
Do not modify the password for TCs that are manually added to the SmartMC network. If you modify the password for a manually added TC, you will not be able to manage that TC from the TM.
# Modify the password to Admin123 for the default user on TCs.
[Sysname] smartmc tc password Admin123
Use smartmc tc startup-configuration to specify the upgrade configuration file for a TC.
Use undo smartmc tc startup-configuration to remove the configuration.
smartmc tc tc-id startup-configuration cfg-filename
undo smartmc tc tc-id startup-configuration
cfg-filename: Specifies a configuration file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify upgrade configuration file startup.cfg for TC 1.
[Sysname] smartmc tc 1 startup-configuration startup.cfg
display smartmc tc
Use smartmc topology-refresh to manually refresh the network topology.
To display topology changes, use this command to manually refresh the topology.
# Manually refresh the network topology.
<Sysname> smartmc topology-refresh
Use smartmc topology-refresh interval to set the automatic network topology refresh interval.
Use undo smartmc topology-refresh interval to restore the default.
smartmc topology-refresh interval interval
The automatic network topology refresh interval is 60 seconds.
interval: Specifies the automatic network topology refresh interval in the range of 60 to 300 seconds.
# Set the automatic network topology refresh interval to 100 seconds.
[Sysname] smartmc topology-refresh interval 100
smartmc topology-save
Use smartmc topology-save to save the current network topology.
This task allows you to save the current network topology to the topology.dba file in the flash memory. After the TM reboots, it uses the topology.dba file to restore the network topology.
# Save the current network topology
[Sysname] smartmc topology-save
smartmc upgrade boot-loader
Use smartmc upgrade boot-loader to upgrade the startup software on a list of TCs or SmartMC groups.
Use undo smartmc upgrade delete the startup software upgrade task.
smartmc upgrade boot-loader { group | tc } list [ delay minutes | time time ]
smartmc upgrade boot-loader { group | tc } { list { boot boot-filename system system-filename | file ipe-filename } }&<1-40> [ delay delay-time | time time ]
group: Specifies SmartMC group-based upgrade.
tc: Specifies TC-based upgrade.
list: Specifies a space-separated list of TC items or SmartMC group items.
· SmartMC group—Each item specifies a SmartMC group name, a case-sensitive string of 1 to 31 characters.
· TC—Each item specifies a TC ID or a range of TC IDs in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
boot boot-filename: Specifies a boot image file by its name.
system system-filename: Specifies a system image file by its name.
file ipe-filename: Specifies an IPE file by its name.
delay delay-time: Specifies the upgrade delay time in the range of 1 to 1440 minutes.
time in-time: Specifies the upgrade time in the format of hh:mm. The value range for the hh argument is 0 to 23 hours. The value range for the mm argument is 0 to 59 minutes.
To use this command to upgrade the startup software on TCs without specifying the upgrade files, you must first perform one of the following tasks:
· Execute the smartmc tc boot-loader command to specify the upgrade files for TCs.
· Execute the boot-loader command to specify the upgrade files for a SmartMC group.
A TC can perform only one upgrade task at a time.
If you execute this command without specifying the delay time or update time, the TCs or SmartMC group immediately upgrades the startup software.
# Upgrade startup software images boot.bin and sys.bin on all TCs in SmartMC groups test1 and test2.
[Sysname] smartmc upgrade boot-loader group test1 test2 boot boot.bin system sys.bin
boot-loader
Use smartmc upgrade startup-configuration to upgrade the configuration file on a list of TCs or on all TCs in SmartMC groups.
Use undo smartmc upgrade delete the configuration file upgrade task.
smartmc upgrade startup-configuration { group | tc } list [ delay minutes | time time ]
smartmc upgrade startup-configuration { group | tc } { list cfg-filename }&<1-40> [ delay delay-time | time time ]
cfg-filename: Specifies a configuration file by its name.
To use this command to upgrade the configuration file on TCs without specifying the upgrade file, you must first perform one of the following tasks:
· Execute the smartmc tc startup-configuration command to specify the upgrade file for TCs.
· Execute the startup-configuration command to specify the upgrade file for a SmartMC group.
If you execute this command without specifying the delay time or update time, the TCs or SmartMC group immediately upgrades the configuration file.
# Upgrade configuration file startup.cfg on all TCs in SmartMC groups test1 and test2.
boot-loader
Use startup-configuration to specify an upgrade configuration file for a SmartMC group .
Use undo startup-configuration to restore the default.
startup-configuration cfgfile
No upgrade configuration file is specified for the SmartMC group.
SmartMC group view
cfgfile: Specifies a configuration file by its name, a string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify configuration file startup.cfg for SmartMC group testgroup.
[Sysname-smartmc-group-testgroup] startup-configuration startup.cfg
smartmc group
