- 16-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-NTP commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-Sampler commands
- 09-Mirroring commands
- 10-NetStream commands
- 11-IPv6 NetStream commands
- 12-sFlow commands
- 13-CWMP commands
- 14-PTP commands
| 08-Sampler commands | 42.60 KB |
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
display sampler [ sampler-name ] [ slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays sampler configuration information for the active MPU.
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
Sampler name: 256
Mode: Random; Packet-interval: 8; IsNpower: Y
Sampler name |
Name of the sampler. |
Mode |
Sampling mode. In the current software version, only the random mode is supported. . |
Packet-interval |
Sampling rate. |
IsNpower |
Whether the sampling rate is 2 to the nth power Y indicates Yes. |
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode random packet-interval n-power rate
undo sampler sampler-name
No samplers exist.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. One packet is selected from 2 to the rateth power packets in each sampling. For example, if n-power 8 is specified, one packet is selected from 256 (2 to the 8th power) packets in each sampling.
This command takes effect on all cards.
# Create sampler abc in random sampling mode. Set the sampling rate to 8 to select one packet from 256 packets in each sampling.
[Sysname] sampler abc mode random packet-interval n-power 8
