13-User Access and Authentication Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5426P02)-6W10413-User Access and Authentication Configuration Guide
00-Preface
00-Preface 101.25 KB
Preface
The access controllers documentation set describes the software features for the access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The User Access and Authentication Configuration Guide describes user access and authentication features, including:
·     AAA.
·     802.1X.
·     MAC authentication.
·     Portal.
·     Port security.
·     WLAN authentication.
·     WLAN IP snooping.
·     802.1X client.
·     User identification.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
