07-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[2600][3600] Routers Configuration Guides(V7)-R0809-6W40007-Layer 3—IP Services Configuration Guide
21-WAAS configuration
21-WAAS configuration 203.24 KB
Configuring WAAS
About WAAS
The Wide Area Application Services (WAAS) feature is a set of services that can optimize WAN traffic. WAAS solves WAN issues such as high delay and low bandwidth by using optimization services. WAAS provides the following optimization services:
·     Transport Flow Optimization (TFO).
·     Data Redundancy Elimination (DRE).
·     Lempel-Ziv compression (LZ compression).
TFO
TFO optimizes TCP traffic without modifying packet header information. TFO uses the following optimization methods:
·     Slow start optimization.
·     Increased buffering.
·     Congestion algorithm optimization.
·     Selective acknowledgement.
The initial congestion window size for TCP slow start is one TCP segment. During slow start, TCP doubles the congestion window size for each received ACK that acknowledges new data. In this manner, the congestion window will reach an appropriate value by examining the congestion status. In a WAN environment, the congestion window takes a long time to reach an appropriate size because of high delay.
Slow start optimization shortens the slow start process by increasing the initial congestion window size.
Increased buffering
TCP has a maximum buffer size of 64 KB. After the sender sends 64 KB data, it must wait for an ACK from the receiver before continuing to send data. This mechanism wastes bandwidth on a WAN link.
Increased buffering increases the TCP buffer size to a maximum of 16384 KB. This improves link efficiency.
TCP uses the congestion window to control congestion. The window size indicates the size of data that can be sent out before an ACK is received. The window size changes with the congestion status. The greater the window size, the faster the data rate. A higher data rate more likely causes congestion. The smaller the window size, the lower the data rate. A lower data rate causes low link efficiency.
Congestion algorithm optimization achieves a trade-off between the data rate and congestion by selecting the optimum window size.
TCP uses a cumulative acknowledgement scheme. This scheme forces the sender to either wait a roundtrip time to know each lost packet, or to unnecessarily retransmit segments that have been correctly received. When multiple nonconsecutive segments are lost, this scheme reduces overall TCP throughput.
Selective acknowledgement (SACK) allows the receiver to inform the sender of all segments that have arrived successfully. The sender retransmits only the segments that have been lost.
DRE
DRE reduces the size of transmitted data by replacing repeated data blocks with shorter indexes. A WAAS device synchronizes its data dictionary to its peer devices. A data dictionary stores mappings between repeated data blocks and indexes.
Replacing repeated data blocks with indexes is called DRE compression. Replacing indexes with repeated data blocks is called DRE decompression.
DRE compression process
DRE compresses data in the following process:
1.     The sending WAAS device caches TCP data and sends a large data block to the DRE module.
2.     The DRE module divides the large data block into non-overlapping data blocks.
¡     For a repeated data block, the DRE module performs the following operations:
-     Replaces the data block with its index and creates an MD5 digest for the data block.
-     Sends the index and MD5 digest to the peer.
¡     For a non-repeated data block, the DRE module performs the following operations:
-     Creates an index for the data block and adds it to the local data dictionary.
-     Creates an MD5 digest for the data block and sends the data block, index, and MD5 digest to the peer.
To improve calculation speed and efficiency, DRE uses a sliding window mechanism to segment data and detect data redundancy. This mechanism detects repeated data blocks by using a fixed-size window to compare the original data byte by byte with data blocks in the dictionary.
DRE decompression process
DRE decompresses data in the following process:
1.     The receiving WAAS device reconstructs the original data.
¡     For an index, the device replaces the index with its data block after querying the data dictionary.
If the query fails, the decompression fails, and the receiving WAAS device waits for the peer to retransmit the data.
¡     For an index and a data block, the device creates an entry for them and adds the entry to the local data dictionary.
2.     The receiving WAAS device calculates an MD5 digest for the original data and compares the calculated MD5 digest with the MD5 digest in the packet.
¡     If the two MD5 digests are the same, the decompression succeeds.
¡     If the two MD5 digests are different, the decompression fails, and the receiving WAAS device waits for the peer to retransmit the data.
LZ compression
LZ compression is a lossless compression algorithm that uses a compression dictionary to replace repeated data in the same message. The compression dictionary is carried in the compression result. The sending device uses the sliding window technology to detect repeated data.
Compared with DRE, LZ compression has a lower compression ratio. LZ compression does not require synchronization of compression dictionaries between the local and peer devices. This reduces memory consumption.
Protocols and standards
·     RFC 1323, TCP Extensions for High Performance
·     RFC 3390, Increasing TCP's Initial Window
·     RFC 2581, TCP Congestion Control
·     RFC 2018, TCP Selective Acknowledgment Options
·     RFC 3042, Enhancing TCP's Loss Recovery Using Limited Transmit
·     RFC 2582, The NewReno Modification to TCP's Fast Recovery Algorithm
Restrictions: Hardware compatibility with WAAS
Hardware
WAAS compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
Hardware
WAAS compatibility
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
WAAS compatibility
MSR2630-XS
Yes
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
WAAS compatibility
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
MSR810-LM-GL
Yes
Restrictions and guidelines: WAAS configuration
For the WAAS feature to work correctly, make sure fast forwarding load sharing is disabled. For information about fast forwarding load sharing, see Layer 3—IP Services Configuration Guide.
WAAS tasks at a glance
To configure WAAS, perform the following tasks:
1.     Configuring a WAAS class
2.     Configuring a WAAS policy
3.     Applying a WAAS policy to an interface
4.     (Optional.) Specifying traffic processing slots for an interface
5.     (Optional.) Configuring WAAS to operate in asymmetric mode
6.     (Optional.) Configuring TFO parameters
7.     (Optional.) Configuring the TFO blacklist autodiscovery feature
8.     (Optional.) Configuring DRE optimization parameters
9.     (Optional.) Configuring UDP log message compression or decompression
10.     (Optional.) Restoring predefined WAAS settings
11.     (Optional.) Deleting all WAAS settings
2.     Create a WAAS class and enter WAAS class view.
waas class class-name
By default, only predefined WAAS classes exist.
3.     Configure a match criterion.
match [ match-id ] tcp { any | destination | source } [ ip-address ipv4-address [ mask-length | mask ] | ipv6-address ipv6-address [ prefix-length ] ] [ port port-list ]
To configure a WAAS policy, perform the following tasks:
1.     Create a WAAS policy.
2.     Specify a WAAS class for the WAAS policy.
3.     Configure actions for the WAAS class.
You can configure the following actions for a WAAS class:
·     Optimization actions—Optimize matching TCP traffic by using TFO alone, or by using TFO with any combination of DRE and LZ compression.
·     Passthrough action—Allows matching TCP traffic to pass through unoptimized.
For an optimization action to take effect, you must enable the corresponding optimization feature.
As a best practice, configure a WAAS policy by modifying the predefined WAAS policy.
2.     Create a WAAS policy and enter WAAS policy view.
waas policy policy-name
By default, a predefined WAAS policy named waas_default exists.
3.     Specify a WAAS class and enter WAAS policy class view.
class class-name [ insert-before existing_class ]
By default, no WAAS class is specified.
4.     Configure optimization actions or the passthrough action.
¡     optimize tfo [ dre | lz ] *
¡     passthrough
By default, no action is configured.
5.     Return to system view.
6.     Enable DRE.
waas tfo optimize dre
By default, DRE is enabled.
7.     Enable LZ compression.
waas tfo optimize lz
By default, LZ compression is enabled.
Apply a WAAS policy to an interface that connects to the WAN. The device optimizes or passes through the traffic entering and leaving the WAN according to the configured policy. If the incoming and outgoing interfaces of the traffic are both connected to the WAN, the traffic is not optimized.
A WAAS policy can be applied to multiple interfaces. Only one WAAS policy can be applied to an interface.
2.     Enter interface view.
3.     Apply a WAAS policy to the interface.
waas apply policy [ policy-name ]
By default, no WAAS policy is applied to an interface.
If a logical interface that spans cards or IRF member devices acts as a WAN interface, specify the slot of any member port in logical interface view as its traffic processing slot.
For high availability, you can specify one primary and one backup traffic processing slot by using the service command and the service standby command, respectively. The primary and backup slots must be different slots.
If you specify both primary and backup slots, the backup slot takes over when the primary slot becomes unavailable. The backup slot continues to process traffic for the interface after the primary slot becomes available again. The switchover will not occur until the backup slot becomes unavailable.
When both primary and backup slots are unavailable, the traffic is processed by the slot at which it arrives. The specified processing slot that first becomes available again takes over.
To avoid processing slot switchover, specify the primary slot before specifying the backup slot. If you specify the backup slot before specifying the primary slot, traffic is switched over to the primary slot immediately after you specify the primary slot.
3.     Specify the primary traffic processing slot for the interface.
In IRF mode:
service slot slot-number
By default, no primary traffic processing slot is specified for an interface.
For more information about this command, see Layer 2—LAN Switching Command Reference.
4.     Specify the backup traffic processing slot for the interface.
In IRF mode:
service standby slot slot-number
By default, no backup traffic processing slot is specified for an interface.
If the device sends and receives packets on the same interface, the device should operate in symmetric mode. Perform this task if the device sends and receives packets on different interfaces.
2.     Configure WAAS to operate in asymmetric mode.
waas asymmetric
By default, WAAS operates in symmetric mode.
The congestion window size changes with the congestion status and transmission speed. An appropriate initial congestion window size can quickly restore the network to its full transmission capacity after congestion occurs.
After you enable TFO keepalives, the system starts the 2-hour TCP keepalive timer. If the local device does not send or receive any data when the timer expires, it sends a keepalive to the peer to maintain the connection.
The receiving buffer size specifies the size of data that can be received. It affects network throughput.
Different network performance requirements require different TCP congestion control algorithms. Selecting a proper TCP congestion control algorithm enables a network to quickly recover to the maximum transmission capacity.
After the maximum number of concurrent connections is reached, WAAS does not optimize traffic for newly established connections.
2.     Set the initial congestion window size.
waas tfo base-congestion-window segments
The default setting is two segments.
3.     Enable TFO keepalives.
waas tfo keepalive
By default, TFO keepalives are enabled.
4.     Set the receiving buffer size.
waas tfo receive-buffer buffer-size
The default setting is 64 KB.
5.     Specify a TCP congestion control algorithm for the WAN side.
waas tfo congestion-method { bic | reno }
By default, WAAS uses BIC as the TCP congestion control algorithm on the WAN side.
6.     Set the maximum number of concurrent connections.
waas tfo connect-limit limit
The default setting is 10000.
You can tune the following DRE optimization parameters:
·     DRE match offset step—The higher the step level, the lower the match precision. As a best practice, use a higher-level offset step on high-speed links to improve match efficiency. Use a lower-level offset step on low-speed links to ensure match precision.
·     Aging time for entries in the data dictionary—The device polls all data dictionary entries and deletes the entries that are not hit within the aging time. If the number of data dictionary entries reaches the limit, the device no longer creates new entries.
The amount of time used by the device to poll all data dictionary entries depends on the number of data dictionary entries on the device.
2.     Set the DRE match offset step.
waas dre offset-step { general | fast | fastest | normal }
The default setting is normal.
The following DRE match offset step levels are listed from high to low:
¡     fastest
¡     fast
¡     general
¡     normal
3.     Set the aging time for data dictionary entries.
waas dre cache aging minutes
By default, data dictionary entries are not aged out, and the newly created entry overwrites the oldest entry if the number of data dictionary entries reaches the limit.
This feature automatically discovers servers that cannot receive TCP packets with options and adds the server IP addresses and port numbers to a blacklist. The system automatically removes blacklist entries after a user-configured aging time.
During the 3-way handshake, the local device determines that the TCP connection attempt fails if either of the following situations occurs:
·     The peer device does not respond within the specified time period.
·     The peer device closes the TCP connection.
2.     Enable the TFO blacklist autodiscovery feature.
waas tfo auto-discovery blacklist enable
By default, the TFO blacklist autodiscovery feature is disabled.
3.     Set the aging time for blacklist entries.
waas tfo auto-discovery blacklist hold-time minutes
The default setting is 5 minutes.
You configure UDP log message compression on the upstream device and configure UDP log message decompression on the downstream device. The upstream device compresses packets and forwards them to the downstream device. The downstream device decompresses the received packets and then forwards them.
Fragmented packets and packets with the Options field are not compressed or decompressed.
You can enable UDP log message compression or decompression for the same destination IP address, but not both.
2.     Enable UDP log message compression or decompression.
waas udp { compress [ max max-number ] | decompress }
By default, UDP log message compression and decompression is disabled.
3.     Specify the destination IP address and destination port number of UDP log messages to be compressed or decompressed.
waas udp ip ip-address port port-number
By default, no destination IP address and destination port number are specified.
This feature allows you to restore the predefined WAAS policy and WAAS classes to their configurations when the WAAS process starts for the first time.
To successfully restore predefined WAAS settings, make sure none of the interfaces has a WAAS policy applied.
2.     Restore predefined WAAS settings.
waas config restore-default
This feature allows you to delete all configuration data and running data for WAAS and to exit the WAAS process.
2.     Delete all WAAS settings.
waas config remove-all
Display and maintenance commands for WAAS
Display WAAS class configuration.
display waas class [ class-name ]
Display WAAS policy configuration.
display waas policy [ policy-name ]
Display WAAS session information.
In standalone mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ]
In IRF mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ slot slot-number ]
Display DRE statistics.
In standalone mode:
display waas statistics dre [ peer peer-id ]
In IRF mode:
display waas statistics dre [ peer peer-id ] [ slot slot-number ]
Display UDP log message compression statistics.
display waas statistics udp compress
Display the global WAAS status.
display waas status
Display autodiscovered blacklist information.
In standalone mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 }
In IRF mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ slot slot-number ]
Clear the DRE data dictionary.
reset waas cache dre [ peer-id peer-id ]
Clear DRE statistics.
reset waas statistics dre [ peer-id peer-id ]
Clear UDP log message compression statistics.
reset waas statistics udp compress
Clear all blacklist entries.
reset waas tfo auto-discovery blacklist
WAAS configuration examples
Example: Applying the predefined WAAS policy
As shown in Figure 1, apply the predefined WAAS policy on Router A and Router B.
The host downloads data from the server. Examine the optimization effect by comparing DRE statistics for the first download and second download.
·     For the first download, both WAAS devices create data dictionary entries and Router A sends both indexes and metadata.
·     For the second download, Router A replaces repeated data with indexes.
Figure 1 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure routing protocols to ensure connectivity. (Details not shown.)
3.     Disable fast forwarding load sharing:
# Disable fast forwarding load sharing on Router A.
[RouterA] undo ip fast-forwarding load-sharing
# Disable fast forwarding load sharing on Router B.
<RouterB> system-view
[RouterB] undo ip fast-forwarding load-sharing
4.     Apply the predefined WAAS policy to GigabitEthernet 1/0/1 on Router A.
[RouterA-GigabitEthernet1/0/1] waas apply policy
[RouterA] quit
5.     Apply the predefined WAAS policy to GigabitEthernet 1/0/1 on Router B.
[RouterB-GigabitEthernet1/0/1] waas apply policy
6.     Download a test file of 14 MB from the server to the host.
7.     Clear DRE statistics on Router A.
<RouterA> reset waas statistic dre
8.     Download the same file from the server to the host.
# After the first download, display DRE statistics on Router A.
<RouterA> display waas statistic dre
Peer-ID: cc3e-5fd8-5158
Peer version: 1.0
Cache in storage: 12710912 bytes
Index number: 49652
Age: 00 weeks, 00 days, 00 hours, 00 minutes, 35 seconds
Total connections: 1
Active connections: 0
Encode Statistics
  Dre msgs: 2
  Bytes in: 286 bytes
  Bytes out: 318 bytes
  Bypass bytes: 0 bytes
  Bytes Matched: 0 bytes
  Space saved: -11%
  Average latency: 0 usec
Decode Statistics
  Dre msgs: 57050
  Bytes in: 14038391 bytes
  Bytes out: 14079375 bytes
  Space saved: 0%
# After the second download, display DRE statistics on Router A.
Peer version: 1.0
Cache in storage: 12851200 bytes
Index number: 50200
Age: 00 weeks, 00 days, 00 hours, 2 minutes, 56 seconds
Encode Statistics
  Dre msgs: 2
  Bytes in: 286 bytes
  Bytes out: 60 bytes
  Bytes Matched: 256 bytes
  Space saved: 79%
Decode Statistics
  Dre msgs: 62791
  Bytes in: 2618457 bytes
  Bytes out: 13972208 bytes
  Space saved: 81%
In the second download, the number of received bytes for decompression is much more smaller, and the download speed is much faster.
Example: Configuring a user-defined WAAS policy
As shown in Figure 2, configure and apply a user-defined WAAS policy on Router A and Router B.
·     For the first download, both WAAS devices need to create data dictionary entries and Router A sends both indexes and metadata.
Figure 2 Network diagram
4.     Configure WAAS classes:
# Create a WAAS class named c1 on Router A, and configure the WAAS class to match any TCP packets.
[RouterA] waas class c1
[RouterA-waasclass-c1] match 1 tcp any
[RouterA-waasclass-c1] quit
# Create a WAAS class named c1 on Router B, and configure the WAAS class to match any TCP packets.
[RouterB] waas class c1
[RouterB-waasclass-c1] match tcp any
[RouterB-waasclass-c1] quit
5.     Configure WAAS policies:
# Create a WAAS policy named p1 on Router A, and specify WAAS class c1. Configure TFO, DRE, and LZ optimization actions for the WAAS class.
[RouterA] waas policy p1
[RouterA-waaspolicy-p1] class c1
[RouterA-waaspolicy-p1-c1] optimize tfo dre lz
[RouterA-waaspolicy-p1-c1] quit
[RouterA-waaspolicy-p1] quit
# Create a WAAS policy named p1 on Router B, and specify WAAS class c1. Configure TFO, DRE, and LZ optimization actions for the WAAS class.
[RouterB] waas policy p1
[RouterB-waaspolicy-p1] class c1
[RouterB-waaspolicy-p1-c1] optimize tfo dre lz
[RouterB-waaspolicy-p1-c1] quit
[RouterB-waaspolicy-p1] quit
6.     Apply WAAS policies:
# Apply WAAS policy p1 to GigabitEthernet 1/0/1 on Router A.
[RouterA] quit
# Apply WAAS policy p1 to GigabitEthernet 1/0/1 on Router B.
[RouterB-GigabitEthernet1/0/1] waas apply policy p1
[RouterB] quit
7.     Download a test file of 14 MB from the server to the host.
8.     Clear DRE statistics on Router A.
9.     Download the same file from the server to the host.
Peer version: 1.0
Cache in storage: 12718592 bytes
Index number: 49682
Encode Statistics
  Dre msgs: 2
  Bytes in: 286 bytes
  Space saved: -11%
Decode Statistics
  Dre msgs: 56959
  Bytes in: 13999244 bytes
  Bytes out: 14055291 bytes
  Space saved: 0%
Peer version: 1.0
Cache in storage: 12857856 bytes
Index number: 50226
Age: 00 weeks, 00 days, 00 hours, 2 minutes, 02 seconds
Encode Statistics
  Dre msgs: 2
  Bytes in: 286 bytes
  Bytes out: 60 bytes
  Space saved: 79%
Decode Statistics
  Dre msgs: 62687
  Bytes in: 2592183 bytes
  Space saved: 81%
Example: Configuring UDP log message compression and decompression
As shown in Figure 3, the IP address of the server is 172.16.105.48.
Configure UDP log message compression and decompression to meet the following requirements:
·     Router A compresses log messages from the host and then forwards them to Router B.
·     Router B decompresses the log messages from Router A and then forwards them to the server.
Figure 3 Network diagram
4.     Configure UDP log message compression and decompression:
# Enable UDP log message compression on Router A.
[RouterA] waas udp compress
# Specify that UDP log messages with destination IP address 172.16.105.48 and destination port number 5000 are compressed.
[RouterA] waas udp ip 172.16.105.48 port 5000
# Enable UDP log message decompression on Router B.
[RouterB] waas udp decompress
# Specify that UDP log messages with destination IP address 172.16.105.48 and destination port number 5000 are decompressed.
[RouterB] waas udp ip 172.16.105.48 port 5000
# Display UDP log message compression statistics on Router A.
[RouterA] display waas statistic udp compress
Bytes in                : 30106991182
Bytes out               : 375556018
Saved bandwidth ratio   : 98.75%
Compressed packet ratio : 100.00%
The output shows that the bandwidth is saved by 98.75% through log message compression.
