11-ACL and QoS Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command References-Release7951PXX-6W10011-ACL and QoS Command Reference
03-MPLS QoS commands
03-MPLS QoS commands 45.40 KB
MPLS QoS commands
SPC and MPE-1104 cards do not support MPLS QoS.
diffserv-mode
Use diffserv-mode to configure the MPLS DiffServ mode.
Use undo diffserv-mode to restore the default.
diffserv-mode { ingress { pipe service-class | short-pipe service-class | uniform } egress { pipe | short-pipe | uniform } | { pipe service-class | short-pipe service-class | uniform } }
undo diffserv-mode
The MPLS DiffServ mode is pipe, and the EXP value is 0.
VPN instance view
ingress: Configures the MPLS DiffServ mode for the inbound direction.
egress: Configures the MPLS DiffServ mode for the outbound direction.
pipe: Specifies the pipe mode.
short-pipe: Specifies the short-pipe mode.
uniform: Specifies the uniform mode.
service-class: Specifies the MPLS EXP value for packets that enter from a private network to a public network, in the range of 0 to 7.
If you do not specify a direction when executing this command, the configured MPLS DiffServ mode applies to both directions.
If you execute this command for the same direction multiple times, the most recent configuration takes effect.
In a DiffServ architecture, an intermediate node can modify the DSCP and EXP fields, which are collectively referred to as class of service (CoS). Therefore, the CoS value of a packet might change during transmission in an IP network or MPLS network. The device supports the following MPLS DiffServ modes to process CoS:
·          pipe—When an IP packet enters an MPLS network, the ingress node ignores the DSCP value of the IP packet and uses the configured value as the EXP value of the MPLS packet. When the MPLS packet leaves the MPLS network, the egress node does not modify the original DSCP value. In the MPLS network, the packet is scheduled based on the configured EXP value.
·          short-pipe—When an IP packet enters and leaves an MPLS network, the packet is processed in the same way as in pipe mode. On nodes from the ingress node to the penultimate node, the packet is scheduled based on the configured EXP value. On the egress node, the top label is popped, and then the packet is scheduled based on its DSCP value.
·          uniform—When an IP packet enters an MPLS network, the ingress node maps the DSCP value of the IP packet to the EXP value of the MPLS packet. When the MPLS packet leaves the MPLS network, the ingress node maps the EXP value to the DSCP value.
Mappings between DSCP and EXP are performed according to the dscp-exp map and exp-dscp map. For more information about these priorities and maps, see ACL and QoS Configuration Guide.
When a VPN instance uses an MPLS DiffServ mode other than the default, the following rules apply:
·          If the public network interface or the interface bound to the VPN instance is applied with a QoS policy containing a priority marking action, the priority in the action takes precedence.
·          If the public network interface or the interface bound to the VPN instance is configured a port priority, the priority configured for the VPN instance takes precedence.
# Configure the MPLS DiffServ mode as uniform for VPN instance abc.
[Sysname] ip vpn-instance abc
[Sysname-vpn-instance-abc] diffserv-mode uniform
# In VPN instance xyz, configure the MPLS DiffServ mode as pipe with EXP AF1 for the inbound direction and as short-pipe for the outbound direction.
[Sysname] ip vpn-instance xyz
[Sysname-vpn-instance-xyz] diffserv-mode ingress pipe af1 egress short-pipe
if-match mpls-exp
Use if-match mpls-exp to define a criterion to match the EXP field in the first MPLS label.
Use undo if-match mpls-exp to delete the match criterion.
if-match mpls-exp exp-value&<1-8>
undo if-match mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the first MPLS label.
Traffic class view
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the first MPLS label.
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
remark imposition-mpls-exp
Use remark imposition-mpls-exp to configure an EXP value marking action in a traffic behavior.
Use undo remark imposition-mpls-exp to delete the action.
remark imposition-mpls-exp exp-value
No EXP value marking action is configured in a traffic behavior.
Traffic behavior view
exp-value: Specifies an EXP value in the range of 0 to 7.
This command takes effect only when the QoS policy is applied to the inbound direction. On a P device, this command modifies only the EXP value in the first label. On a PE device, this command modifies the EXP values in both the first label and second label.
If both the remark mpls-exp and remark imposition-mpls-exp commands are configured in a QoS policy applied to the inbound direction on a PE device, the following rules apply:
·          The remark mpls-exp command modifies only the EXP value in the first label.
·          The remark imposition-mpls-exp command modifies only the EXP value in the second label.
CSPEX (except CSPEX-1104-E) and CEPC cards support configuring both remark mpls-exp and remark imposition-mpls-exp commands in one QoS policy.
# Set the EXP value to 0 for MPLS packets.
[Sysname-behavior-database] remark imposition-mpls-exp 0
remark mpls-exp
remark mpls-exp
Use remark mpls-exp to configure an action of marking the EXP value in the first label in a traffic behavior.
Use undo remark mpls-exp to delete the action.
remark mpls-exp exp-value
No action of marking the EXP value in the first label is configured in a traffic behavior.
If the QoS policy is applied to the inbound direction, the remark mpls-exp command modifies the EXP value in the second label.
If the QoS policy is applied to the outbound direction, the remark mpls-exp command modifies only the EXP value in the first (outer) label.
CSPEX (except CSPEX-1104-E) and CEPC cards support configuring both remark mpls-exp and emark imposition-mpls-exp commands in one QoS policy.
# Set the EXP value in the first label to 0 for MPLS packets.
[Sysname-behavior-database] remark mpls-exp 0
