- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-Login management configuration
- 03-RBAC configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Device management configuration
- 10-Python configuration
- 11-License management(HP不支持)
- 12-Preprovisioning feature configuration
- 13-Automatic configuration
00-Preface | 103.73 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures that help you get started with the switch. It covers the following items:
· CLI.
· RBAC, switch login, and switch access control.
· FTP and TFTP.
· Management of the switch, file system, configuration files, and licenses.
· ISSU and common software upgrade.
· Python.
· Preprovisioning feature and automatic configuration.
· Audience
Audience
· Network planners.
· Network administrators working with the S12500-X & S12500X-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
