| 06-WLAN IDS Commands | 166.45 KB |
WLAN IDS configuration commands
WLAN IDS rogue detection configuration commands
display wlan ids rogue-history
WLAN IDS attack detection configuration commands
WLAN frame filtering configuration commands
countermeasures enable
undo countermeasures enable
View
WLAN IDS view
Default level
2: System level
None
Use countermeasures enable to enable countermeasures against rogue devices present in the attack list.
Use undo countermeasures enable to restore the default.
By default, no countermeasures are enabled.
# Enable countermeasures.
[Sysname] wlan ids
[Sysname-wlan-ids] countermeasures enable
countermeasures mode
countermeasures mode { all | { rogue | adhoc | config }* }
undo countermeasures mode
View
WLAN IDS view
Default level
2: System level
all: Takes countermeasures against all rogue devices present in the attack list.
rogue: Takes countermeasures against all rogue APs and clients.
adhoc: Takes countermeasures against all rogue ad hoc devices.
config: Takes countermeasures against statically configured rogue devices.
Use countermeasures mode to set the countermeasures mode.
Use undo countermeasures mode to restore the default.
By default, the countermeasures mode is config.
NOTE: Wireless bridge devices are classified as rogues by default, but in any case, countermeasures are not taken against rogue wireless bridges. |
# Set the countermeasures mode to rogue.
[Sysname] wlan ids
[Sysname-wlan-ids] countermeasures mode rogue
device aging-duration
device aging-duration duration
undo device aging-duration
View
WLAN IDS view
Default level
2: System level
duration: Interval, in the range of 300 to 1800 seconds.
Use device aging-duration to set the age time for entries in the detected device table.
Use undo device aging-duration to restore the default.
The default age time is 600 seconds.
If an entry is not detected within the interval, it is deleted from the detected device table. If the deleted entry is that of a rogue, it is added to the rogue history table.
# Specify the age time for device entries as 1200 seconds.
[Sysname] wlan ids
[Sysname-wlan-ids] device aging-duration 1200
device attack mac-address
device attack mac-address mac-address
undo device attack mac-address [ mac-address ]
View
WLAN IDS view
Default level
2: System level
mac-address: MAC address of an AP or client.
Use device attack mac-address to add an entry to the static attack list.
Use undo device attack mac-address to remove the specified entry or all entries from the static attack list.
The maximum number of entries in the static attack list is 64.
# Add a MAC address to and then remove it from the static attack list.
[Sysname] wlan ids
[Sysname-wlan-ids] device attack mac-address aabb-cc00-0001
[Sysname-wlan-ids] undo device attack mac-address aabb-cc00-0001
# Remove all entries from the static attack list.
[Sysname] wlan ids
device permit
device permit { mac-address mac-address | ssid ssid | vendor oui }
undo device permit { mac-address [ mac-address ] | ssid [ ssid ] | vendor [ oui ] }
View
WLAN IDS view
Default level
2: System level
mac-address: MAC address of an AP or client, such as known devices which are to be ignored during RF scan. The maximum number of entries in the permitted MAC address list is 256.
ssid: Service set identifier, a case-sensitive string of characters including spaces, digits, and special characters, which is in the range of 1 to 32. The maximum number of entries in the permitted SSID list is 128.
oui: Organizational unique identifier of an AP, a string of six hexadecimal digits. The maximum number of entries in the permitted vendor list is 64.
Use device permit to add an entry to the permitted MAC address list, permitted SSID list, or permitted vendor list.
Use undo device permit to remove a specified entry, or, if no entry is specified, all entries from the permitted MAC address list, permitted SSID list, or permitted vendor list.
# Add a MAC address to the MAC address list and then remove it from the list.
[Sysname] wlan ids
[Sysname-wlan-ids] device permit mac-address aabb-cccc-dddd
[Sysname-wlan-ids] undo device permit mac-address aabb-cccc-dddd
device-detection enable
undo device-detection enable
View
AP template view
Default level
2: System level
None
Use device-detection enable to enable the AP to provide both device detection and WLAN services.
Use undo device-detection enable to restore the default.
By default, the AP provides only WLAN data services. For an AP in monitor mode, this command is invisible.
Device detection in normal AP mode can be enabled or disabled only when all radios of the AP are disabled.
NOTE: The AP starts device detection only when the radio has been provisioned and is ready to provide WLAN data service. To support this, at least one service template has to be configured and be operational on the detecting AP. If device detection is desired and no service template configuration is required, you can change the AP operating mode to monitor. |
# Enable device detection for an AP in normal mode.
[Sysname] wlan ap 2 model WA2100
[Sysname-wlan-ap2] device-detection enable
display wlan ids attack-list
display wlan ids attack-list { config | all | ap ap-name } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
config: Displays the static attack list.
all: Displays the dynamic attack list established based on the rules for detection of rogue devices, for all APs. If the number of entries for an AP exceeds 256, only the first 256 entries are sent and present in the attack list of that AP.
ap ap-name: Displays dynamic attack list information about the specified AP. Its name is a string of characters. If the number of entries for the AP exceeds 256, only the first 256 entries are sent and present in the attack list of the AP.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display wlan ids attack-list to display attack list information in the order of MAC address.
# Display dynamic attack list information for all APs.
<Sysname> display wlan ids attack-list all
Total Number of Entries: 2
Flags: a = adhoc, w = ap, c = client
#AP = number of active APs detecting, Ch = channel number
Attack List - All
MAC Address type #AP Ch Last Detected Time SSID
0009-5b94-2fb0 --c 1 1 2008-05-16/14:16:05 -
001b-1109-a32b --c 1 5 2008-05-16/14:16:17 -
MAC address |
MAC address of the device that is to be attacked by the monitor AP |
Flags |
Type of the device, which can be ad hoc, AP, or client. |
#AP |
Number of active APs that detect the device If WIDS is enabled on multiple APs, these APs may detect the same device. |
Ch |
Channel in which the device was last detected |
Last Detected Time |
Time at which the entry was last detected |
SSID |
Service set identifier for the ESS of the entry |
# Display attack list information for AP 6.
<Sysname> display wlan ids attack-list ap ap6
Total Number of Entries: 22
Attack List - AP
MAC Address type #AP Ch Last Detected SSID
000b-6b8f-fc6a --c 1 11 2008-01-22/15:33:21 -
000f-e000-0052 -w- 1 10 2008-01-22/15:33:58 "xxxx-xxxx-xxxx"
000f-e200-0000 -w- 1 9 2008-01-22/15:33:59 "6103_kaifang"
000f-e200-0001 -w- 1 9 2008-01-22/15:33:59 "6103_youxian"
000f-e200-0002 -w- 1 9 2008-01-22/15:33:59 "6103_zhengshu"
000f-e200-0003 -w- 1 9 2008-01-22/15:33:59 "6103_zhengshu+WPA2"
000f-e200-00a2 --c 1 9 2008-01-22/15:33:29 -
000f-e25d-f4b0 -w- 1 9 2008-01-22/15:33:58 "6103_kaifang"
000f-e25d-f4b1 -w- 1 9 2008-01-22/15:33:59 "6103_youxian"
000f-e25d-f4b2 -w- 1 9 2008-01-22/15:33:59 "6103_zhengshu"
000f-e25d-f4b3 -w- 1 9 2008-01-22/15:33:59 "6103_zhengshu+WPA2"
000f-e26c-2250 -w- 1 11 2008-01-22/15:33:59 "bjwifidata"
000f-e26c-2251 -w- 1 11 2008-01-22/15:33:58 "bjwifivoice"
000f-e26c-2252 -w- 1 11 2008-01-22/15:33:58 "voice"
000f-e26c-28d0 -w- 1 11 2008-01-22/15:33:58 "wyg3000"
000f-e278-8020 -w- 1 6 2008-01-22/15:33:58 "test11"
000f-e278-8181 -w- 1 7 2008-01-22/15:33:59 "nsw-wep"
000f-e27b-3f80 -w- 1 6 2008-01-22/15:33:38 "ytj-a"
000f-e27b-4230 -w- 1 4 2008-01-22/15:33:58 "test2"
0011-9548-4007 --c 1 7 2008-01-22/15:33:49 -
0019-5bcf-cce3 --c 1 5 2008-01-22/15:33:25 -
001a-9228-2d3e --c 1 11 2008-01-22/15:33:53 -
For related information, see Table 1.
display wlan ids detected
display wlan ids detected { all | rogue { ap | client } | adhoc | ssid | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all devices detected (rogues and friends) in the WLAN.
rogue: Displays rogue devices detected (AP or clients) in the WLAN.
ap: Displays all rogue APs detected in the WLAN.
client: Displays all rogue clients detected in the WLAN.
adhoc: Displays clients which belong to adhoc networks detected in the WLAN.
ssid: Displays all SSIDs detected in the WLAN.
mac-address mac-address: Displays information about an AP or client.
Use display wlan ids detected to display detected devices in the WLAN in the order of MAC address or SSID.
# Display information about all detected devices.
<Sysname> display wlan ids detected all
Total Number of Entries : 18
Flags: r = rogue, p = permit, a = adhoc, w = ap, b = wireless-bridge,
c = client
Detected Device(s) List
MAC Address Vendor Type #AP Ch Last Detected SSID
000f-e281-1322 XEROX CORP... -p-w- 1 4 2008-05-16/10:49:15 "cyh-psk2"
000f-e281-1323 XEROX CORP... -p-w- 1 4 2008-05-16/10:49:05 "cyh-ccmp"
000f-e281-1460 XEROX CORP... -p-w- 1 6 2008-05-16/10:49:26 "fl"
000f-e281-1461 XEROX CORP... -p-w- 1 6 2008-05-16/10:49:26 "fg2"
0012-f0cc-4789 XEROX CORP... -p--c 1 1 2008-05-16/10:49:11 -
0013-f702-dbd2 XEROX CORP... -p--c 1 7 2008-05-16/10:46:58 -
0016-6f99-fbf6 XEROX CORP... -p--c 1 11 2008-05-16/10:49:02 -
0016-6f99-fc21 XEROX CORP... -p--c 1 6 2008-05-16/10:49:25 -
0017-9a00-7986 XEROX CORP... -p--c 1 8 2008-05-16/10:48:04 -
0017-9a00-79bd XEROX CORP... -p--c 1 7 2008-05-16/10:47:18 -
0017-9a00-7b47 XEROX CORP... r---c 1 10 2008-05-16/10:48:49 -
0017-9a00-7cb8 XEROX CORP... -p--c 1 1 2008-05-16/10:49:20 -
0019-5bcf-ccfd XEROX CORP... -p--c 1 11 2008-05-16/10:49:24 -
001b-111d-b46f XEROX CORP... -p--c 1 6 2008-05-16/10:48:56 -
001c-f017-41dc XEROX CORP... -p--c 1 6 2008-05-16/10:48:00 -
001c-f017-41dd XEROX CORP... -p--c 1 6 2008-05-16/10:49:19 -
001d-0f32-4305 XEROX CORP... -p--c 1 1 2008-05-16/10:48:33 -
0810-741a-1b4c XEROX CORP... -p--c 1 11 2008-05-16/10:49:04 -
MAC Address |
MAC address of the device detected. |
Vendor |
Vendor of the detected device. |
Flags |
Whether the device detected is an AP, wireless bridge, ad hoc, or client, and whether it is permitted or a rogue. |
#AP |
Number of active APs that detect the device. If WIDS is enabled on multiple APs, these APs may detect the same device. |
Ch |
Channel in which the device was last detected. |
Last Detected |
Time at which the entry was last detected. |
SSID |
Service set identifier for the ESS of the entry. |
# Display information about detected rogue APs.
<Sysname> display wlan ids detected rogue ap
Total Number of Entries : 6
Detected Rogue AP(s) List
MAC Address Vendor #AP Ch Last Detected Time SSID
000B-8580-738F Aires... 1 10 2007-03-16/12:44:11 "Diamond"
000F-E212-1230 Hangz... 1 5 2007-03-16/12:44:11 "1"
000F-E234-0200 Hangz... 1 11 2007-03-16/12:44:11 "VClear"
000F-E2AA-CC04 Hangz... 1 12 2007-03-16/12:44:11 "baba"
000F-E2BB-CCD0 Hangz... 1 1 2007-03-16/12:44:11 "Rogue AP Team B..."
000F-E2F2-2230 Hangz... 1 7 2007-03-16/12:44:11 "int-RT"
For the command output description, see Table 2.
# Display information about the detected rogue clients.
<Sysname> display wlan ids detected rogue client
Detected Rogue Client(s) List
MAC Address Vendor #AP Ch Last Detected SSID
0017-9a00-7b47 XEROX CORP... 1 9 2008-05-16/10:49:30 -
# Display information about all the detected adhoc devices.
<Sysname> display wlan ids detected adhoc
Total Number of Entries : 4
#AP = number of active APs, Ch = channel number
Detected Adhoc(s) List
000F-E212-1230 Hangz... 1 5 2007-03-16/12:44:11 -
000F-E234-0200 Hangz... 1 11 2007-03-16/12:44:11 -
000F-E2AA-CC04 Hangz... 1 12 2007-03-16/12:44:11 -
000F-E2BB-CCD0 Hangz... 1 1 2007-03-16/12:44:11 -...
# Display information about all detected SSIDs.
<Sysname> display wlan ids detected ssid
Total Number of Entries : 7
#Device = number of devices using SSID
Detected SSID List
SSID #Device Last Detected Time
"Crywep" 1 2007-03-16/12:44:37
"H3COMTEST11" 1 2007-03-16/12:44:37
"autowep" 2 2007-03-16/12:44:37
"baba" 2 2007-03-16/12:44:37
"s1" 1 2007-03-16/12:44:37
"s2" 1 2007-03-16/12:44:37
"s4crypto" 1 2007-03-16/12:43:48
For the command output description, see Table 3.
# Display detailed information about a device detected.
<Sysname> display wlan ids detected mac-address 000F-E2BB-CCD0
Detected Device Profile
MAC Address : 000F-E2BB-CCD0
BSSID : 000F-E2BB-CCD0
Type : Rogue-AP
SSID : "H3C"
Vendor : Hangzhou H3C Tech. Co., Ltd
Number of APs detected it : 2
Channel : 11
Maximum RSSI Detected : 47
Beacon Interval : 100
First Detected(yyyy-mm-dd/hh:mm:ss) : 2007-03-16/11:32:54
Reported AP 1
MAC Address : 000F-E210-2000
AP Name : ap1
Radio Type : 11g
RSSI : 75
Last Detected(yyyy-mm-dd/hh:mm:ss): 2007-03-16/12:43:37
Reported AP 2:
MAC Address : 000F-E210-2001
AP Name : ap12
Radio Type : 11g
RSSI : 75
Last Detected(yyyy-mm-dd/hh:mm:ss): 2007-03-16/12:44:37
MAC Address |
BSSID |
Basic service set identifier of the detected device. |
Type |
Whether the device detected is an AP, wireless bridge, ad hoc device, or client, and whether it is permitted or a rogue. |
SSID |
Vendor |
Vendor for the detected device. |
Number of APs detected it |
Number of active APs that detected the device. If WIDS is enabled on multiple APs, these APs may detect the same device. In this output, the value indicates that there are two APs detecting the device with the MAC address 000F-E2BB-CCD0, and considering the device as a rogue device. |
Channel |
RSSI |
Maximum detected RSSI of the device. |
Beacon Interval |
Beacon interval for the detected AP. |
First Detected |
Time at which the entry was first detected. |
Reported AP |
Mac Address |
MAC address of the AP that detected the device. |
AP name |
Name of the AP. |
Radio type |
Radio type of the AP. |
RSSI |
Last Detected (yyyy-mm-dd/hh:mm:ss) |
Time at which the rogue AP was detected. |
display wlan ids permitted
display wlan ids permitted { mac-address | ssid | vendor } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mac-address: Displays the permitted MAC address list.
ssid: Displays the permitted SSID list.
vendor: Displays the permitted vendor OUI list.
Use display wlan ids permitted to display the list of permitted MAC addresses, permitted SSIDs, or permitted vendor OUIs.
# Display the permitted MAC-address list.
<Sysname> display wlan ids permitted mac-address
Total Number of Entries: 4
Flags: a = adhoc, w = ap, b = wireless-bridge, c = client
Permitted Mac Address(s)
MAC Address Detected Type
0000-0000-0001 Yes a--
0000-1111-1111 Yes -b-
0000-1111-1234 No -
0000-1111-5634 Yes --c
MAC address |
MAC address of the device permitted. |
Detected |
Whether the device is detected or not. |
Type |
Type of the device, which can be adhoc, wireless bridge, AP, or client. |
# Display information about the permitted SSID list.
<Sysname> display wlan ids permitted ssid
Total Number of Entries: 5
Permitted SSID(s)
SSID Detected
"s1" Yes
"s2" Yes
"s3" Yes
"s4" Yes
"s5" No
Table 5 Command output
SSID |
Service set identifier for the ESS. |
Detected |
Whether the device has been detected or not. |
# Display information about the permitted OUI list.
<Sysname> display wlan ids permitted vendor
Total Number of Entries: 3
Permitted Vendor(s)
OUI Vendor Name
Hangzhou H3C Tech. Co., Ltd.Netgear Inc.Cisco Systems, Inc.
Table 6 Command output
OUI |
OUI (organizational unique identifier) of the AP |
Vendor |
Vendor of the device |
display wlan ids rogue-history [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan ids rogue-history to display all expired rogue devices which have been deleted from the list of detected rogue devices because they could not be detected within the device aging duration.
# Display information about all expired rogue devices.
<Sysname> display wlan ids rogue-history
Total Number of Entries: 6
Ch = channel number
Rogue History List
MAC Address Vendor Type Ch Last Detected SSID
00E0-9855-1D9A AboCo... -w- 11 2007-03-16/11:38:22 "ATNet"
000F-E2CC-0005 Hangz... -b- 4 2007-03-16/11:37:06 -
000F-E2CC-0004 Hangz... --c 4 2007-03-16/11:36:20 -
000F-E2CC-DD00 Hangz... -w- 2 2007-03-16/11:36:17 "AKHIL"
000F-E2CC-0003 Hangz... --c 4 2007-03-16/11:35:34 -
0013-4651-23E7 D-Lin... -w- 6 2007-03-16/11:35:10 "home"
Table 7 Command output
MAC Address |
MAC address of the device. |
Vendor |
Vendor for the device. |
Flags |
Type of the device, which can be ad hoc, wireless bridge, AP, or client. |
Ch |
Last Time Heard |
SSID |
wlan ids
wlan ids
View
Default level
2: System level
None
Use wlan ids to enter WLAN IDS view.
# Enter WLAN IDS view.
[Sysname] wlan ids
[Sysname-wlan-ids]
work-mode monitor
work-mode monitor
undo work-mode
View
AP template view
Default level
2: System level
monitor: Configures the AP to operate in monitor mode.
Use work-mode monitor to configure the AP to operate in monitor mode to scan rogue devices.
Use undo work-mode to restore the default.
By default, the AP operates in normal mode to provide WLAN services.
If the AP operates in monitor mode, the AP can only operate as a monitor AP and cannot operate as an access AP, and cannot provide WLAN services.
# Set the monitor operation mode for the AP.
[Sysname] wlan ap ap2 model WA2100
[Sysname-wlan-ap-ap2] work-mode monitor
reset wlan ids detected
reset wlan ids detected { all | rogue { ap | client } | adhoc | ssid | mac-address mac-address }
View
Default level
1: Monitor level
all: Clears information about all devices detected in the WLAN.
rogue: Clears information about detected rogue devices (AP or clients) in the WLAN.
ap: Clears information about rogue APs detected in the WLAN.
client: Clears information about rogue clients detected in the WLAN.
adhoc: Clears information about ad hoc devices detected in the WLAN.
ssid: Clears information about SSIDs detected in the WLAN.
mac-address mac-address: Clears information about the device (AP or client) detected in the WLAN.
Use reset wlan ids detected to clear information about specified or all devices detected in the WLAN.
# Clear information about all devices (permitted and non-permitted) detected in the WLAN.
<Sysname> reset wlan ids detected all
reset wlan ids rogue-history
View
Default level
1: Monitor level
None
Use reset wlan ids rogue-history to clear all entries from the rogue history table.
# Delete all entries from the rogue history table.
<Sysname> reset wlan ids rogue-history
attack-detection enable
attack-detection enable { all | flood | weak-iv | spoof | all }
undo attack-detection enable
View
WLAN IDS view
Default level
2: System level
all: Enables detection of all kinds of attacks.
flood: Enables detection of flood attacks.
spoof: Enables detection of spoof attacks.
weak-iv: Enables weak-IV detection.
Use attack-detection enable to enable the WIDS detection of various DoS attacks.
Use undo attack-detection enable to restore the default.
By default, no WIDS detection is enabled.
# Enable spoof attack detection.
[Sysname] wlan ids
[Sysname-wlan-ids] attack-detection enable spoof
display wlan ids history
display wlan ids history [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan ids history to display the history of attacks detected in the WLAN system. It supports a maximum of 512 entries.
# Display the history of attacks.
<Sysname> display wlan ids history
Flags:
act = Action Frame asr = Association Request
aur = Authentication Request daf = Deauthentication Frame
dar = Disassociation Request ndf = Null Data Frame
pbr = Probe Request rar = Reassociation Request
saf = Spoofed Disassociation Frame
sdf = Spoofed Deauthentication Frame
wiv = Weak IV Detected
AT - Attack Type, Ch - Channel Number, AR - Average RSSI
WIDS History Table
MAC Address AT Ch AR Detected Time AP
0027-E699-CA71 asr 8 44 2007-06-12/19:47:54 ap12
0015-E9A4-D7F4 wiv 8 45 2007-06-12/19:45:28 ap48
0027-E699-CA71 asr 8 20 2007-06-12/19:18:17 ap12
003d-B5A6-539F pbr 8 43 2007-06-12/19:10:48 ap56
0015-E9A4-D7F4 wiv 8 50 2007-06-12/19:01:28 ap48
Table 8 Command output
MAC Address |
In case of spoof attacks, this field provides the BSSID which was spoofed. In case of other attacks, this field provides the MAC address of the device which initiated the attack. |
AT |
Type of attack. |
Ch |
Channel in which the attack was detected. |
AR |
Average RSSI of the attack frames. |
Detected time |
Time at which this attack was detected. |
AP |
Name of the AP that detected this attack. |
display wlan ids statistics
display wlan ids statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan ids statistics to display the count of attacks detected.
# Display WLAN IDS statistics.
<Sysname> display wlan ids statistics
Current attack tracking since: 2007-06-21/12:46:33
Type Current Total
Probe Request Frame Flood Attack 2 7
Authentication Request Frame Flood Attack 0 0
Deauthentication Frame Flood Attack 0 0
Association Request Frame Flood Attack 1 1
Disassociation Request Frame Flood Attack 4 8
Reassociation Request Frame Flood Attack 0 0
Action Frame Flood Attack 0 0
Null Data Frame Flood Attack 0 0
Weak IVs Detected 12 21
Spoofed Deauthentication Frame Attack 0 0
Spoofed Disassociation Frame Attack 0 2
Table 9 Command output
current |
This field provides the count of attacks detected since the time specified by the current attack tracking time (specified in the field "Current attack tracking since:"). The current attack tracking time is started at the system startup and is refreshed each hour subsequently. |
total |
This field provides the total count of the attacks detected since the system startup. |
Probe Request Frame Flood Attack |
Number of probe request frame flood attacks detected. |
Authentication Request Frame Flood Attack |
Number of authentication request frame flood attack detected. |
Deauthentication Frame Flood Attack |
Number of deauthentication frame flood attacks detected. |
Association Request Frame Flood Attack |
Number of association request frame flood attacks detected. |
Disassociation Request Frame Flood Attack |
Number of disassociation request frame flood attacks detected. |
Reassociation Request Frame Flood Attack |
Number of reassociation request frame flood attacks detected. |
Action Frame Flood Attack |
Number of action frame flood attacks detected. |
Null Data Frame Flood Attack |
Number of null data frame flood attacks detected. |
Weak IVs Detected |
Number of weak IVs detected. |
Spoofed Deauthentication Frame Attack |
Number of spoofed deauthentication frame attacks detected. |
Spoofed Disassociation Frame Attack |
Number of spoofed disassociation frame attacks detected. |
reset wlan ids history
View
Default level
1: Monitor level
None
Use reset wlan ids history to clear the history information of attacks detected in the WLAN.
After this command is executed, all the history information regarding attacks is cleared, and the history table becomes empty.
# Clear all history information of attacks.
<Sysname> reset wlan ids history
reset wlan ids statistics
View
Default level
1: Monitor level
None
Use reset wlan ids statistics to clear the statistics of attacks detected in the WLAN system.
This command clears both the "current" and "total" of all attack types in the WLAN IDS statistics table.
# Clear WLAN IDS statistics.
<Sysname>reset wlan ids statistics
display wlan blacklist
display wlan blacklist { static | dynamic } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
static: Displays static blacklist entries.
dynamic: Displays dynamic blacklist entries.
Use display wlan blacklist to display the static or dynamic blacklist entries.
# Display information about the static blacklist.
<Sysname> display wlan blacklist static
Static Blacklist
MAC-Address
0014-6c8a-43ff
0016-6F9D-61F3
0019-5B79-F04A
Table 10 Command output
MAC-Address |
MAC addresses of clients |
# Display information about the dynamic blacklist.
<Sysname> display wlan blacklist dynamic
Total Number of Entries : 3
Dynamic Blacklist
MAC-Address Lifetime(s) Last Updated Since(hh:mm:ss) Reason
000f-e2cc-0001 60 00:02:11 Assoc-Flood
000f-e2cc-0002 60 00:01:17 Deauth-Flood
000f-e2cc-0003 60 00:02:08 Auth-Flood
Table 11 Command output
MAC-Address |
MAC address of the device inserted into the dynamic blacklist |
Lifetime(s) |
Lifetime of the corresponding entry in seconds |
Last Updated Since(hh:mm:ss) |
Time elapsed since the entry was last updated |
Reason |
Reason why the entry was added into the dynamic blacklist |
display wlan whitelist
display wlan whitelist [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan whitelist to display the configured white list.
# Display the white list.
<Sysname> display wlan whitelist
Whitelist
MAC-Address
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
Table 12 Command output
MAC-Address |
MAC addresses of clients in the white list |
dynamic-blacklist enable
undo dynamic-blacklist enable
View
WLAN IDS view
Default level
2: System level
enable: Enables the dynamic blacklist feature.
Use dynamic-blacklist enable to enable the dynamic blacklist feature.
Use undo dynamic-blacklist enable to disable the dynamic blacklist feature.
By default, the dynamic blacklist feature is disabled.
With this feature, a WLAN device, upon detecting flood attacks from a device, adds the device to the dynamic blacklist, and denies any packets from this device until the dynamic blacklist entry ages out.
# Enable the dynamic blacklist feature.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist enable
dynamic-blacklist lifetime
dynamic-blacklist lifetime lifetime
undo dynamic-blacklist lifetime
View
WLAN IDS view
Default level
2: System level
lifetime: Interval, in the range of 60 to 3600 seconds.
Use dynamic-blacklist lifetime to set the lifetime for dynamic blacklist entries.
Use undo dynamic-blacklist lifetime to restore the default.
By default, the lifetime is 300 seconds.
If a dynamic blacklist entry is not detected within the lifetime, the entry is removed from the dynamic blacklist.
# Specify a lifetime of 1200 seconds for dynamic blacklist entries.
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist lifetime 1200
reset wlan dynamic-blacklist
reset wlan dynamic-blacklist { mac-address mac-address | all }
View
Default level
1: Monitor level
mac-address mac-address: Removes an entry with the specified MAC address from the dynamic blacklist.
all: Removes all entries from the dynamic blacklist.
Use reset wlan dynamic-blacklist to remove a specified entry or all entries from the dynamic blacklist.
The maximum number of entries depends on the device model. For more information, see "About the WX Series Access Controllers Command References."
# Remove a client with MAC address 001d-0f31-87d from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address 001d-0f31-87d
static-blacklist mac-address
static-blacklist mac-address mac-address
undo static-blacklist { mac-address mac-address | all }
View
WLAN IDS view
Default level
2: System level
mac-address: Adds/deletes a client to/from the static blacklist.
all: Deletes all entries from the static blacklist.
Use static-blacklist mac-address to add a client with a specified MAC address to the static blacklist.
Use undo static-blacklist to remove the client with the specified MAC address or all clients from the static blacklist.
Clients in the static blacklist cannot get associated with the AP.
# Add the client with MAC address 0014-6c8a-43ff to the static blacklist.
[Sysname] wlan ids
[Sysname-wlan-ids] static-blacklist mac-address 0014-6c8a-43ff
whitelist mac-address
whitelist mac-address mac-address
undo whitelist { mac-address mac-address | all }
View
WLAN IDS view
Default level
2: System level
mac-address: Adds/deletes the client with the MAC address to/from the white list.
all: Deletes all entries from the white list.
Use whitelist mac-address to add a client with a specified MAC address to the white list.
Use undo whitelist to remove the client with the specified MAC address or all clients from the white list.
Clients in the white list can be associated with the AP.
The maximum number of entries in the white list is 255.
# Add the client with MAC address 001c-f0bf-9c92 to the white list.
[Sysname] wlan ids
[Sysname-wlan-ids] whitelist mac-address 001c-f0bf-9c92
