- 02-Layer 2-LAN Switching Configuration Guide
- 01-Ethernet interface configuration
- 02-Loopback and null interface configuration
- 03-Bulk interface configuration
- 04-MAC address table configuration
- 05-Ethernet link aggregation configuration
- 06-Port isolation configuration
- 07-Spanning tree configuration
- 08-BPDU tunneling configuration
- 09-VLAN configuration
- 10-GVRP configuration
- 11-LLDP configuration
- 12-Service loopback group configuration
- 13-MVRP configuration
02-Loopback and null interface configuration | 61.27 KB |
Configuring loopback and null interfaces
Configuring a loopback interface
Configuring the null interface
Displaying and maintaining loopback and null interfaces
This section describes how to configure loopback and null interfaces.
A loopback interface is a virtual interface. The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down. A loopback interface is widely used in the following scenarios:
· You can configure a loopback interface address as the source address of the IP packets that the device generates. Because loopback interface addresses are stable unicast addresses, they are usually used as device identifications. When you configure a rule on an authentication or security server to permit or deny packets that a device generates, you can simplify the rule by configuring it to permit or deny packets carrying the loopback interface address that identifies the device. When you use a loopback interface address as the source address of IP packets, make sure that the peer is reachable through routes by performing routing configuration. All data packets sent to the loopback interface are considered as packets sent to the device itself, so the device does not forward these packets.
· You can use a loopback interface in dynamic routing protocols. For example, if no router ID is configured for a dynamic routing protocol, the highest loopback interface IP address is selected as the router ID.
To configure a loopback interface:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
1. Create a loopback interface and enter loopback interface view. |
interface loopback interface-number |
N/A |
2. Set the interface description. |
description text |
Optional. By default, the description of a loopback interface is interface name Interface. |
3. Shut down the loopback interface. |
shutdown |
Optional. By default, a loopback interface is up. |
4. Restore the default settings for the loopback interface. |
default |
Optional. |
You can configure settings such as IP addresses and IP routes on loopback interfaces. For more information, see Layer 3—IP Services Configuration Guide and Layer 3—IP Routing Configuration Guide.
A null interface is a completely software-based logical interface, and is always up. However, you cannot use it to forward data packets or configure an IP address or link layer protocol on it. With a null interface specified as the next hop of a static route to a specific network segment, any packets routed to the network segment are dropped. The null interface provides a simpler way to filter packets than ACL. You can filter uninteresting traffic by transmitting it to a null interface instead of applying an ACL.
For example, by executing the ip route-static 92.101.0.0 255.255.0.0 null 0 command (which configures a static route leading to null interface 0), you can have all packets destined to the network segment 92.101.0.0/16 discarded.
Only one null interface, Null 0, is supported on your device. You cannot remove or create a null interface.
To enter null interface view:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter null interface view. |
interface null 0 |
The Null 0 interface is the default null interface on your device. It cannot be manually created or removed. |
3. Set the interface description. |
description text |
Optional. By default, the description of a null interface is interface name Interface. |
4. Restore the default settings for the null interface. |
default |
Optional. |
Task |
Command |
Remarks |
Display information about loopback interfaces. |
display interface [ loopback ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface loopback interface-number [ brief ] [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Display information about the null interface. |
display interface [ null ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ] display interface null 0 [ brief ] [ | { begin | exclude | include } regular-expression ] |
Clear the statistics on a loopback interface. |
reset counters interface [ loopback [ interface-number ] ] |
Available in user view. |
Clear the statistics on the null interface. |
reset counters interface [ null [ 0 ] ] |
