11-High Availability Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10011-High Availability Command Reference
04-RPR commands
04-RPR commands 174.34 KB
RPR configuration commands
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
RPR logical interface view
RPRPOS/RPRXGE interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 10000 kbps for the RPR logical interface RPR 4/0/1.
[Sysname] interface rpr 4/0/1
[Sysname-RPR4/0/1] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for the RPR physical port RPRXGE 4/1/1.
[Sysname] interface rprxge 4/1/1
[Sysname-RPRXGE4/1/1] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for the RPR physical port RPRPOS 4/1/1.
[Sysname] interface rprpos 4/1/1
[Sysname-RPRPOS4/1/1] bandwidth 10000
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings for the RPR logical interface RPR 4/0/1.
[Sysname-RPR4/0/1] default
# Restore the default settings for the RPR physical port RPRXGE 4/1/1.
[Sysname-RPRXGE4/1/1] default
# Restore the default settings for the RPR physical port RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] default
description
Use description to configure a description for an interface.
The interface description uses the interface-name Interface format, for example, RPR Interface.
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Configure the description of RPR logical interface RPR 4/0/1 as RPR4/0/1.
[Sysname-RPR4/0/1] description RPR4/0/1
# Configure the description of the RPR physical port RPRXGE 4/1/1 as RPRXGE-1.
[Sysname-RPRXGE4/1/1] description RPRXGE-1
# Configure the description of the RPR physical port RPRPOS 4/1/1 as RPRPOS-1.
[Sysname-RPRPOS4/1/1] description RPRPOS-1
display interface
display interface
Use display interface to display information about an interface.
display interface [ { rpr| rprpos | rprxge } [ interface-number ] ] [ brief [ description | down ] ]
rpr: Displays RPR logical interface information.
rprpos: Displays RPRPOS interface information.
rprxge: Displays RPRXGE interface information.
interface-number: Specifies an interface by its number.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in any state.
If you do not specify the interface type, this command displays information about all types of interfaces.
If you specify the interface type but not the interface number, this command displays information about all interfaces of the specified type.
# Display detailed information about the RPR logical interface RPR 4/0/1.
<Sysname> display interface rpr 4/0/1
RPR4/0/1
Current state: UP
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 5cdd-70c1-651b
Description: RPR4/0/1 Interface
Bandwidth: 10000000kbps
Media type is twisted pair
Port hardware type is 10G_BASE_T
10Gbps-speed mode, full-duplex mode
Link speed type is autonegotiation, link duplex type is force link
PVID: 1
Port link-type: trunk
 VLAN Passing:   1(default vlan), 100
 VLAN permitted: 1(default vlan), 100
 Trunk port encapsulation: IEEE 802.1q
Last clearing of counters: 13:56:56 Tue 02/19/2013
 Peak value of input: 874920532 bytes/sec, at 2013-02-19 14:10:28
 Peak value of output: 222 bytes/sec, at 2013-02-19 18:24:10
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
 Input (total):  10378003037 packets, 1104314523057 bytes
          5241554027 unicasts, 5136447473 broadcasts, 1503 multicasts, 0 pauses
 Input (normal):  10378003003 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 23952 packets, 1790138 bytes
          22630 unicasts, 39 broadcasts, 1283 multicasts, 0 pauses
 Output (normal): 23952 packets, - bytes
          0 lost carrier, - no carrier
# Display brief information about the RPR logical interface RPR 4/0/1.
<Sysname> display interface rpr 4/0/1 brief
Brief information on interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
RPR4/0/1             DOWN auto    F      T    1
# Display detailed information about RPR physical port RPRPOS 4/1/1.
<Sysname> display interface rprpos 4/1/1
RPRPOS4/1/1
Current state: DOWN
Line protocol state: DOWN
Description: RPRPOS4/1/1 Interface
Internet protocol processing: disabled
Optical module state: RPR_PHYPOS_CONNECTOR
Physical layer is packet over SDH
Port speed type: STM-64
Clock source: Master
Loopback is not set
Clock grade: DNU(Do not use for synchronization)
BER thresholds:
    SD: 10e-5    SF: 10e-3
Regenerator section layer:
    J0(TX): ""
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    J0(RX): ""
    Alarm: LOS
    Error: 64898 BIP(B1)
Multiplex section layer:
    Alarm: NONE
    Error: 0 BIP(B2), 1150002850 REI(M1)
Higher order path layer:
    C2(TX): 0x16    C2(RX): 0x16
    J1(TX): ""
    J1(RX): ""
    Alarm: NONE
    Error: 0 BIP(B3), 0 REI(G1)
           -- PJE, -- NJE
Host receive              Packets                Bytes
 unicast               5241554019         528109814290
 multicast             5136433135         763006552586
Line receive              Packets                Bytes
 unicast               5241554019         549076030366
 multicast             5136432145         783552090938
Host send                 Packets                Bytes
 unicast                      251                17600
 multicast                   1000                95068
Line send                 Packets                Bytes
 unicast                    22379              1790208
 multicast                    326                31384
Input Errors
 parity 0  short 0 crc 0 ringiderr --
Output Errors
 parity 0  short 0 giant 0 fifo 0
Control Frame                  In                  Out
       Oam                      0                    0
       Atd                  60084                22887
        Tc                 230559               245662
        Tp                  12488               246960
      Mode                Packets                Bytes
   SaStrip                      0                    0
   TtlDrop              465537325          76815173267
   TxFlood            10377963522        1332626294516
   RxFlood            10377963522        1332626294516
Last 300 second Host input :  0 packet/sec   0 byte/sec  0%
Last 300 second Line input :  0 packet/sec   0 byte/sec  0%
Last 300 second Host output:  0 packet/sec   0 byte/sec  0%
Last 300 second Line output:  0 packet/sec   0 byte/sec  0%
Host peak value of input: 974946303 bytes/sec, at 0000-00-00 00:00:00
Line peak value of input: 1003225087 bytes/sec, at 0000-00-00 00:00:00
Host peak value of output: 23 bytes/sec, at 0000-00-00 00:00:00
Line peak value of output: 240 bytes/sec, at 0000-00-00 00:00:00
# Display detailed information about RPR physical port RPRXGE 2/1/1.
<Sysname> display interface rprxge 2/1/1
RPRXGE2/1/1
Current state: UP
Line protocol state: UP
Description: RPRXGE2/1/1 Interface
Bandwidth: 10000000 kbps
Optical module state: RPR_PHY10GE_CONNECTOR
 unicast 2169501443 298962827678
 multicast 2775550994 372340528272
 unicast 2801599056 399927084948
 multicast 7602033836 1041740109834
 unicast 2132286065 291451729050
 multicast 4826529225 658304147264
 unicast 1718097192 241089230760
 multicast 6496370993 909150513270
Input Errors
 parity 0 short 0 crc 0 ringiderr –
Output Errors
       Oam 0 0
       Atd 70089 23397
        Tc 233646 233948
        Tp 24 233656
      Mode Packets Bytes
   SaStrip 0 0
   TtlDrop 233965 42451862761
   TxFlood 9674077497 1344258484004
   RxFlood 9674077497 1344258484004
Last 300 second Host input : 1 packet/sec 108 byte/sec 0%
Last 300 second Line input : 100004 packet/sec 13400497 byte/sec 1%
Last 300 second Host output: 100003 packet/sec 13400378 byte/sec 1%
Last 300 second Line output: 100010 packet/sec 14601227 byte/sec 1%
Host peak value of input: 148590894 bytes/sec, at 2015-01-04 09:01:47
Line peak value of input: 306347188 bytes/sec, at 2015-01-04 09:01:47
Host peak value of output: 179905297 bytes/sec, at 2015-01-04 09:01:47
Line peak value of output: 279746068 bytes/sec, at 2015-01-04 09:01:47
Current state
Current physical and administrative state of the interface:
·     DOWN (Administratively)The interface has been shut down by using the shutdown command.
·     DOWNThe interface is physically down because no physical link is present or the link has failed.
·     UP—The interface is both administratively and physically up.
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
Hardware Address
MAC address of the interface.
Line protocol state
Data link layer state of the interface:
Partial or complete interface description set by using the description command:
·     If you do not specify the description keyword for the display interface brief command, this field displays only the first 27 characters of the interface description.
·     If you specify the description keyword for the display interface brief command, this field displays the complete interface description.
Bandwidth
Expected bandwidth of the interface.
10Gbps-speed mode, full-duplex mode, full-duplex mode
The port rate is 10 Gbps. The duplex mode is full duplex mode.
The interface is manually configured with a duplex mode by using the duplex command.
PVID
Default VLAN ID of the interface.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLAN ID
VLANs whose packets are to be sent out of the port tagged.
UnTagged VLAN
VLANs whose packets are to be sent out of the port untagged.
VLAN Passing
VLANs whose packets can be forwarded by the trunk port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the trunk port. The VLANs might not be created.
Encapsulation protocol type for the trunk port.
The most recent time when the interface statistics were cleared.
Average inbound traffic rate (in Bps, bps, and pps) for the last 300 seconds.
A hyphen (-) indicates that the statistical item is not supported.
Average outbound traffic rate (in Bps, bps, and pps) for the last 300 seconds.
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained at least one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receive buffer of the port ran low.
parity errors
Total number of frames with parity errors.
IP packet processing capability.
Disabled indicates that IP packet processing is disabled.
Transceiver module state.
Port speed type
Interface transmission rate.
loopback
Loopback status. (This field is not configurable.)
Clock source
Clock mode. (This field is not configurable.)
BER thresholds
Signal degree (SD) and signal failed (SF) thresholds.
Alarm and error statistics for the regenerator section.
Alarm
Alarm statistics.
Error
Error statistics.
Host receive
Traffic copied by the station.
Line receive
Inbound traffic on the ringlet.
Host send
Traffic inserted by the station.
Line send
Outbound traffic on the ringlet.
parity
Number of packets with parity errors.
short
Number of short packets.
crc
Number of packets with CRC errors.
ringiderr
Number of packets on the wrong ringlet.
fifo
Number of overflow packets with errors.
Mode
Packet transmission mode:
·     SaStrip—Packets stripped from the source node.
·     TtlDrop—Packets stripped after the TTL expires.
·     TxFlood—Broadcast packets sent.
·     RxFloodBroadcast packets received.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak value of input
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
reset counters interface
display rpr bind-info
Use display rpr bind-info to display binding information for an interface.
display rpr bind-info [ { rpr| rprpos | rprxge } interface-number ]
{ rpr| rprpos | rprxge } interface-number: Specifies an RPR physical port or RPR logical interface by its type and number. If you do not specify this option, this command displays binding information for all RPR logical interfaces.
# Display binding information for all RPR logical interfaces.
<Sysname> display rpr bind-info
Bind information on interface RPR4/0/1:
 Smart connection: Disabled
 PHY interface    Ringlet ID    Role       Mate port
 RPRPOS4/1/1      0             Primary    Up
 RPRPOS4/2/1      1             Secondary  Up
Smart connection
State of the RPR mate port smart connection feature and connection state of the mate ports:
·     Enabled/ConnectedThe RPR mate port smart connection feature is enabled, and the mate ports have been connected internally.
·     Enabled/DisconnectedThe RPR mate port smart connection feature is enabled, but the mate ports are not connected internally.
·     DisabledThe RPR mate port smart connection feature is disabled.
PHY interface
Physical ports bound to the RPR logical interface.
Ringlet ID
Binding relationship between the physical port and the RPR logical interface:
·     0—The physical port is the west port.
·     1—The physical port is the east port.
·     N/A—No binding exists.
Role
Role of the physical port:
·     Primary—The physical port is the master port.
·     Secondary—The physical port is the subordinate port.
Mate port
State of the mate port connected to the physical port:
·     UP—The mate port is up.
·     Down—The mate port is down.
display rpr defect
Use display rpr defect to display RPR defect information.
display rpr defect [ rpr interface-number ]
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays RPR defect information for all RPR logical interfaces.
# Display defect information for the RPR logical interface RPR 4/0/1.
<Sysname> display rpr defect rpr 4/0/1
RPR defects on interface RPR4/0/1:
  Reserved rate exceeded                         : Ringlet0: 0; Ringlet1: 0
  Jumbo configuration defect                     : 0
  Maximum number of stations exceeded            : 0
  Miscabling                                     : Ringlet0: 0; Ringlet1: 0
  Protection mode configuration defect           : 0
  Inconsistent topology                          : 0
  Unstable topology                              : 0
  Invalid topology entry                         : 0
  Duplicate IP address                           : 0
  Duplicate second MAC address                   : 0
  Maximum number of second MAC addresses exceeded: 0
RPR defects on interface RPR4/0/1.
Defect information for the station where the specified interface resides.
Defect information about the reserved bandwidth for the ringlets:
·     0—The used bandwidth has not exceeded the reserved bandwidth.
·     1—The used bandwidth has exceeded the reserved bandwidth.
Defect information about Jumbo frame configuration for the station:
·     0The Jumbo frame for this station is different than the Jumbo frames for other stations.
·     1No Jumbo frame for this station is the same as the Jumbo frames for other stations.
Defect information about station number limit:
·     0The number of stations has not reached the upper limit.
·     1The number of stations has reached the upper limit.
Miscabling
Defect information about the optical fiber connection for the ringlets:
·     0Optical fibers are connected correctly.
·     1Optical fibers are connected incorrectly.
Defect information about protection mode configuration for the station:
·     0This station uses the same protection mode as other stations.
·     1This station uses a different protection mode than other stations.
Defect information about topology consistency for the station:
·     0This station provides the same topology information as other stations.
·     1This station provides different topology information than other stations.
Unstable topology
Defect information about topology stability for the station:
·     0The topology is stable.
·     1The topology is not stable.
Defect information about topology validity for the station:
·     0The station is valid.
·     1The station is not valid.
Defect information about IP address duplication for the station:
·     0IP address duplication has not occurred.
·     1IP address duplication has occurred.
Defect information about secondary MAC address duplication for the station:
·     0Secondary MAC address duplication has not occurred.
·     1Secondary MAC address duplication has occurred.
Defect information about secondary MAC address number limit:
·     0The number of secondary MAC addresses has not reached the upper limit.
·     1The number of secondary MAC addresses has reached the upper limit.
display rpr fairness
Use display rpr fairness to display information about RPR fairness settings.
display rpr fairness [ rpr interface-number ]
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays the RPR fairness settings for all RPR logical interfaces.
# Display RPR fairness settings for the RPR logical interface RPR 4/0/1 that is bound with two POS ports.
<Sysname> display rpr fairness rpr 4/0/1
RPR fairness parameters on interface RPR4/0/1:
  Fairness weight on Ringlet0: 1
  Fairness weight on Ringlet1: 1
  Local reserved bandwidth for class A0 service on Ringlet0: 0 Mbps
  Local reserved bandwidth for class A0 service on Ringlet1: 0 Mbps
  Local rate limit for subclass A1 service on Ringlet0: 5 Mbps
  Local rate limit for subclass A1 service on Ringlet1: 5 Mbps
  Local rate limit for class B CIR service on Ringlet0: 0 Mbps
  Local rate limit for class B CIR service on Ringlet1: 0 Mbps
  Local rate limit for class B EIR and class C service on Ringlet0: 2500 Mbps
  Local rate limit for class B EIR and class C service on Ringlet1: 2500 Mbps
  Total reserved bandwidth for class A0 service on Ringlet0: 0 Mbps
  Total reserved bandwidth for class A0 service on Ringlet1: 0 Mbps
display rpr protection
Use display rpr protection to display RPR protection information.
display rpr protection [ rpr interface-number ]
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays RPR protection information for all RPR logical interfaces.
RPR automatically verifies the protection mode consistency of all the stations on the ring. The protection mode configured for a station does not take effect if it is different than the protection mode used by other stations.
# Display protection information for the RPR logical interface RPR 4/0/1 that is bound with two physical ports.
<Sysname> display rpr protection rpr 4/0/1
Protection information on interface RPR4/0/1:
  Configured protection mode: Steer
  Active protection mode: Steer
  Protection reversion mode: Revertible
  Context containment: Disabled
                                    West span              East span
  Protection state                  IDLE                   FS
  Edge state                        Unedged                Edged
  Last known neighbour              00e0-0100-0002         00e0-0300-0002
  The number of protection states   1                      4
  The number of local edges         0                      2
  Last local edge time              -                      2014.04.08 05:47:31
  Local edge start time             -                      2014.04.08 05:48:07
Protection state
Protection state on the west and east spans:
·     FSForced switch.
·     SFSignal fail.
·     SDSignal degrade.
·     MSManual switch.
·     WTRWait to restore.
·     IDLE.
Edge state
Edge state on the west and east spans:
·     Edged—An edge exists.
·     Unedged—No edge exists.
Last known neighbor
MAC address of the adjacent stations on the west and east.
Number of protection mode changes on the west and east spans.
Number of edges that have occurred on the west and east spans.
Time when the last edge occurred on the west and east spans.
Time that the current edge started on the west and east spans.
display rpr rs-table
Use display rpr rs-table to display RPR ringlet selection table information.
display rpr rs-table { default | dynamic | overall | static } [ rpr interface-number ]
default: Displays information about the default ringlet selection table.
dynamic: Displays information about the dynamic ringlet selection table.
overall: Displays information about the overall ringlet selection table.
static: Displays information about the static ringlet selection table.
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays ringlet selection table information for all RPR logical interfaces.
# Display dynamic ringlet selection table information for all RPR stations.
<Sysname> display rpr rs-table dynamic
Dynamic ringlet selection table on interface RPR4/0/1:
 MAC address     Ringlet ID  TTL  IP address       Station name
 4431-9257-1d86  1           1    -                10500-30016
 0000-fc00-1791  1           2    -                10500-4000
 5cdd-70c1-651c  0           1    -                10050-10003
 ---   Entries in total: 3    ---
# Display static ringlet selection table information for all RPR stations.
<Sysname> display rpr rs-table static
Static ringlet selection table on interface RPR4/0/1:
 MAC address     Ringlet ID  Status
 0001-0002-0003  0           Invalid
 0001-0002-0004  1           Invalid
 ---   Entries in total: 2    ---
# Display default ringlet selection table information for all RPR stations.
<Sysname>display rpr rs-table default
Default ringlet selection table on interface RPR4/0/1:
  Configured default ringlet: Ringlet1
  Active default ringlet: Ringlet1
# Display overall ringlet selection table information for all RPR stations.
<Sysname> display rpr rs-table overall
Overall ringlet selection table on interface RPR4/0/1:
 MAC address     Ringlet ID  TTL  Type      IP address       Station name
 4431-9257-1d86  1           1    Dynamic   -                10500-30016
 0000-fc00-1791  1           2    Dynamic   -                10500-4000
 5cdd-70c1-651c  0           1    Dynamic   -                10050-10003
Table 5 Command output
MAC address
MAC address of the destination station.
TTL
Number of hops to the destination station.
IP address
IP address of the destination station. means the IP address is not configured.
Station name
Name of the destination station.
display rpr statistics
Use display rpr statistics to display traffic statistics for RPR stations.
display rpr statistics { dmac | smac } [ mac-address ] [ rpr interface-number ]
dmac: Displays statistics for traffic sent to the destination station specified by its MAC address.
smac: Displays statistics for traffic received from the source station specified by its MAC addresses.
mac-address: Specifies the MAC address of a source or destination station. If you do not specify this argument, this command displays statistics for all traffic sent or received.
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays traffic statistics for all RPR logical interfaces.
# Display statistics for traffic destined to 00E0-FC00-1A01 on the ring.
<Sysname> display rpr statistics dmac 00e0-fc00-1a01
Statistics for traffic to the destination station on interface RPR3/0/1:
 MAC address     Packets               Bytes
 4431-9257-1d86  0                     0
 0000-fc00-1791  24102                 1929424
 5cdd-70c1-651c  68756                 5500696
display rpr timers
Use display rpr timers to display RPR timers.
display rpr timers [ rpr interface-number ]
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays the RPR timers for all RPR logical interfaces.
# Display RPR timers for all stations.
<Sysname> display rpr timers
RPR timers on interface RPR4/0/1:
  Fast TP timer: 10 ms
  Slow TP timer: 100 ms
  Fast TC timer: 10 ms
  Slow TC timer: 100 ms
  ATD timer: 1 s
  WTR timer: 10 s
  Holdoff timer: 0 ms
  Keepalive timer: 3 ms
  Topology stability timer: 40 ms
display rpr topology
Use display rpr topology to display RPR topology information.
display rpr topology { all | local | ring | stations } [ brief ] [ rpr interface-number ]
all: Displays all topology information.
local: Displays topology information for the local station.
ring: Displays ring topology information.
stations: Displays topology information for all stations on the ring.
brief: Displays brief RPR topology information. If you do not specify this argument, this command displays detailed RPR topology information.
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command displays topology information for all RPR logical interfaces.
# Display all topology information for the RPR logical interface RPR 4/0/1 that is bound with two physical ports.
<Sysname> display rpr topology all rpr 4/0/1
Ring-level topology information on interface RPR4/0/1:
  Number of stations on Ringlet0: 1
  Number of stations on Ringlet1: 1
  Total number of stations on the ring: 2
  Jumbo preference: Jumbo
  Ring topology type: Closed ring
Local station topology information on interface RPR4/0/1:
  Station name:
  MAC address: 00e0-fc00-1001
  IP address: -
  Protection state on the west span: IDLE
  Protection state on the east span: IDLE
  Edge state on the west span: Unedged
  Edge state on the east span: Unedged
  Sequence number: 10
  Last known neighbor on the west span: 00e0-fc00-1a01
  Last known neighbor on the east span: 00e0-fc00-1a01
  Local topology state: Valid
Station topology information on interface RPR4/0/1:
 Station entry on Ringlet0:
  MAC address: 00e0-fc00-1a01
  Station name:
  IP address: -
  Hops: 1
  Protection mode: Steer
  Sequence number: 9
  Reachability: Reachable
  Valid: 1
 Station entry on Ringlet1:
  Station name:
  IP address:  -
  Hops: 1
  Sequence number: 9
  Valid: 1
Table 6 Command output
IP address
Station IP address. means the IP address is not configured.
Protection mode used by the station: wrapping or steering.
·     FSForced switch.
·     SFSignal fail.
·     SDSignal degrade.
·     MSManual switch.
·     IDLE.
·     FSForced switch.
·     SFSignal fail.
·     SDSignal degrade.
·     MSManual switch.
·     IDLE.
Hops
Number of hops between the local station and a destination station.
Jumbo preference
Indicates whether Jumbo frames are supported:
·     RegularNot supported. This value is not available.
·     JumboSupported.
Sequence number
Sequence number of the TP frame.
MAC address of the most recently learned neighbor on the west span.
MAC address of the most recently learned neighbor on the east span.
Protection mode
Protection mode:
·     WrapWrapping mode. This mode is not supported.
·     SteerSteering mode.
Valid
Entry status:
·     1—Valid.
·     0—Invalid.
# Display brief topology information for all stations.
<Sysname> display rpr topology all brief
Topology information items:
PSW: Protection State, West       PSE: Protection State, East
ESW: Edge State, West             ESE: Edge State, East
WC: Wrap protection Configured    JP: Jumbo frame Preferred
 Ringlet0  Ringlet1  Ring  Jumbo preference  Topology type
 1         1         2     Jumbo             Closed ring
 MAC address    PSW  PSE  ESW  ESE  WC  JP  IP address        Station name
 00e0-fc00-1001 IDLE IDLE 0    0    0   1   -                 StationA
 Station entry on ringlet0:
 00e0-fc00-1a01 IDLE IDLE 0    0    0   1   -                 StationB
 Station entry on ringlet1:
Table 7 Command output
PSE
·     FSForced switch.
·     SFSignal fail.
·     SDSignal degrade.
·     MSManual switch.
·     IDLE.
PSW
·     FSForced switch.
·     SFSignal fail.
·     SDSignal degrade.
·     MSManual switch.
·     IDLE.
ESE
·     1An edge exists.
·     0—No edge exists.
ESW
·     1An edge exists.
·     0—No edge exists.
WC
Protection mode:
·     1—Wrapping mode. This mode is not supported.
·     0—Steering mode.
JP
·     1Jumbo frames are supported.
·     0Jumbo frames are not supported.
Ringlet0
Number of stations on the west span.
Ringlet1
Number of stations on the east span.
Ring
Total number of stations on the ring.
Jumbo preference
·     JumboSupported.
Brief topology information of the neighbor station on the west span.
Brief topology information of the neighbor station on the east span.
# Display topology information for the local station.
<Sysname>display rpr topology local
  Station name: StationA
  IP address: -
  Sequence number: 10
  Last known neighbour on the west span: 00e0-fc00-1a01
  Last known neighbour on the east span: 00e0-fc00-1a01
Table 8 Command output
Jumbo preference
·     JumboSupported.
# Display ring-level topology information.
<Sysname>display rpr topology ring
  Number of stations on Ringlet0: 3
  Number of stations on Ringlet1: 3
  Total number of stations on the ring: 4
Table 9 Command output
Jumbo preference
·     JumboSupported.
# Display topology information for all stations on the ring.
<Sysname>display rpr topology stations
  IP address:  0.0.0.0
  Hops: 1
  Sequence number: 9
  Valid: 1
  Station name: StationB
  IP address:  0.0.0.0
  Hops: 1
  Sequence number: 9
  Valid: 1
Table 10 Command output
Jumbo preference
·     regularNot supported. This value is not available.
·     jumboSupported.
Sequence number
Valid
Entry status:
·     1—Valid.
·     0—Invalid.
flag c2
Use flag c2 to set the C2 path signal label byte.
Use undo flag c2 to restore the default.
flag c2 flag-value
undo flag c2
The C2 value is 0x16.
RPRPOS interface view
flag-value: Specifies a C2 byte value, a hexadecimal number in the range of 0x00 to 0xFF.
The C2 byte is a higher-order path overhead byte. It indicates the multiplex structure of virtual container (VC) frames and the property of payload.
The C2 byte must be the same at both ends of a link.
# Set the C2 byte to 0x01 on RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] flag c2 01
display interface
flag j0
Use flag j0 to set the J0 regenerator section trace byte for SONET or SDH frames.
Use undo flag j0 to restore the default.
flag j0 { sdh | sonet } flag-value
undo flag j0 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J0 byte is an empty string.
flag-value: Specifies the J0 byte. It must be a string of 1 to 15 characters for SDH, and a hexadecimal number in the range of 0x00 to 0xFF for SONET.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
J0 byte is a section overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the span level.
The J0 byte can be different on devices of the same service provider. On the interfaces between two service providers, the J0 byte must be the same.
# Set the J0 byte to 0xFF for SDH on RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] flag j0 sdh ff
·     display interface
·     frame-format
flag j1
Use flag j1 to set the J1 path trace byte for SONET or SDH frames.
Use undo flag j1 to restore the default.
flag j1 { sdh | sonet } flag-value
undo flag j1 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J1 byte is an empty string.
flag-value: Specifies a J1 byte value. It must be a string of 1 to 15 characters for SDH and a string of 1 to 62 characters for SONET.
J1 byte is a higher-order path overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the path level.
The J1 byte must be the same at both ends of a link.
# Set the J1 byte to aabbcc for SDH on RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] flag j1 sdh aabbcc
·     display interface
·     frame-format
flow-interval
Use flow-interval to set the packet statistics collection interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The packet statistics collection interval is 300 seconds.
RPRXGE/RPRPOS interface view
interval: Sets the packet statistics collection interval in the range of 5 to 300 seconds, in increments of 5.
You can configure the packet statistics collection interval in system view and interface view. The configuration in system view applies to all interfaces and takes precedence over interface view.
# Set the packet statistics collection interval to 100 seconds for the RPR physical port RPRXGE 4/1/1.
[Sysname-RPRXGE4/1/1] flow-interval 100
# Set the packet statistics collection interval to 100 seconds for the RPR physical port RPRPOS 4/1/1.
# Set the packet statistics collection interval to 100 seconds for the RPR logical interface RPR 4/0/1.
[Sysname] interface rprpos 4/0/1
[Sysname-RPR4/0/1] flow-interval 100
frame-format
Use frame-format to set the framing format for the interface.
Use undo frame-format to restore the default.
frame-format { sdh | sonet }
undo frame-format
The framing format is SDH.
sdh: Sets the framing format to SDH.
sonet: Sets the framing format to SONET.
The overhead bytes configured with the flag j0 and flag j1 commands must match the framing format.
# Set the framing format to SONET for the interface RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] frame-format sonet
·     flag j0
·     flag j1
interface
Use { rprpos | rprxge } to enter RPR physical port view.
Use interface rpr to create an RPR logical interface and enter RPR logical interface view.
interface { rprpos | rprxge } interface-number
interface rpr interface-number
rprpos: Specifies an RPRPOS port.
rprxge: Specifies an RPRXGE port.
rpr: Specifies an RPR logical interface.
If the LSUM1SPMAEC0 base card is operating correctly, RPR automatically creates an RPR logical interface. If the LSUM1SPMAEC0 base card is removed, the logical interface is deleted.
RPR logical interfaces allow only the packets containing VLAN tags to pass through. The VLAN cannot be the same as the VLAN to which the Layer 2 Ethernet interfaces belong. Only Layer 3 forwarding is implemented between an RPR logical interface and a Layer 2 Ethernet interface.
# Create an RPR logical interface RPR 4/0/1 and enter its view.
[Sysname-RPR4/0/1]
# Enter RPR physical port RPRXGE 4/1/1 view.
# Enter RPR physical port RPRPOS 4/1/1 view.
Use reset counters interface to clear interface statistics.
reset counters interface [ { rpr| rprpos | rprxge } [ interface-number ] ]
rpr: Clears RPR logical interface statistics.
rprpos: Clears RPRPOS port statistics.
rprxge: Clears RPRXGE port statistics.
To collect statistics for an RPR logical interface within a specific period, you must clear statistics for the interface before starting statistics collection.
If you do not specify the interface type, this command clears statistics for all interfaces.
If you specify the interface type, but not the interface number, this command clears statistics for all interfaces of the specified type.
# Clear statistics for the RPR logical interface RPR 4/0/1.
<Sysname> reset counters interface rpr 4/0/1
# Clear statistics for the RPR physical port RPRXGE 4/1/1.
<Sysname> reset counters interface rprxge 4/1/1
# Clear statistics for the RPR physical port RPRPOS 4/1/1.
<Sysname> reset counters interface rprpos 4/1/1
display interface
reset rpr protection statistics
Use reset rpr protection statistics to clear RPR protection event statistics.
reset rpr protection statistics [ rpr interface-number ]
rpr interface-number: Specifies an RPR logical interface by its type and number. If you do not specify this option, this command clears the RPR protection events statistics for all RPR logical interfaces.
# Clear RPR protection event statistics for all stations.
<Sysname> reset rpr protection statistics
rpr admin-request
Use rpr admin-request to configure a manual protection request for a station on a ringlet.
rpr admin-request { fs | idle | ms } { ringlet0 | ringlet1 }
Idle protection applies.
fs: Specifies a forced switch (FS) protection request.
idle: Specifies an idle protection request. If you specify this keyword, the command clears the FS or MS protection request.
ms: Specifies a manual switch (MS) protection request.
ringlet0: Specifies Ringlet 0.
ringlet1: Specifies Ringlet 1.
Six types of protection requests, FS, signal fail (SF), signal degrade (SD), MS, wait to restore (WTR), and idle, are available with decreased priorities. FS and MS requests are sent manually. SF, SD, and WTR requests are sent automatically.
If you execute this command repeatedly for an RPR physical port, the most recent configuration takes effect.
# Configure an FS protection request on Ringlet 0 for the RPR logical interface RPR 4/0/1.
[Sysname-RPR4/0/1] rpr admin-request fs ringlet0
rpr default-rs ringlet1
Use rpr default-rs ringlet1 to configure Ringlet 1 as the default sending ringlet.
Use undo rpr default-rs to restore the default.
undo rpr default-rs
The default sending ringlet is Ringlet 0.
If the configured default sending ringlet is faulty, the other ringlet takes over. If both ringlets are faulty, the system uses the configured default sending ringlet.
# Specify Ringlet 1 as the default sending ringlet for the RPR logical interface RPR 4/0/1.
[Sysname-RPR4/0/1] rpr default-rs ringlet1
rpr echo mac
Use rpr echo mac to test the connectivity between the current station and a peer station.
rpr echo mac mac-address [ -c c-value | -r { ringlet0 | ringlet1 | reverse } | -s { ringlet0 | ringlet1 } | -t t-value ] *
mac-address: Specifies the MAC address of the peer station.
-c c-value: Specifies the number of Echo Requests to be sent for testing connectivity, in the range of 1 to 1000. The default value is 5.
-r: Specifies the sending ringlet for Echo Responses.
reverse: Specifies the ringlet on the reverse direction of the Echo Request receiving ringlet.
-s: Specifies the sending ringlet for Echo Requests.
-t t-value: Specifies the echo response timeout timer in the range of 10 to 65535 milliseconds. The default value is 10 milliseconds.
If neither the sending ringlet nor the receiving ringlet is specified, the default ringlet is used for transmitting Echo Request packets and Echo Response packets.
The connectivity between the current station and a peer station is considered normal if the following conditions exist:
·     The peer station can receive Echo Request packets from the current station on a specific ringlet.
·     The current station can receive Echo Response packets from the peer station on a specific ringlet.
# Test connectivity between the current station and the station with MAC address 0012-3F83-A1E3 on RPR 4/0/1. Specify ringlet 0 as the sending ringlet and ringlet 1 as the receiving ringlet.
[Sysname-RPR4/0/1] rpr echo mac 0012-3F83-A1E3 -s ringlet0 -r ringlet1
Ping 0012-3F83-A1E3: press CTRL+C to break
   Reply from 0012-3F83-A1E3: ringlet=1 hops=1 seq=2 time=1 ms
   Reply from 0012-3F83-A1E3: ringlet=1 hops=1 seq=3 time=1 ms
   Reply from 0012-3F83-A1E3: ringlet=1 hops=1 seq=4 time=1 ms
   Reply from 0012-3F83-A1E3: ringlet=1 hops=1 seq=5 time=1 ms
   Reply from 0012-3F83-A1E3: ringlet=1 hops=1 seq=6 time=1 ms
--- Ping statistics for 0012-3F83-A1E3 ---
    5 packet(s) transmitted
    5 packet(s) received
    0.0% packet loss
    Round-trip min/avg/max = 1/1/16 ms
rpr encapsulation extend
Use rpr encapsulation extend to set the extended packet encapsulation mode.
Use undo rpr encapsulation extend to restore the default.
An RPR station uses the standard packet encapsulation mode.
If a ring contains S9500E devices, you must set the extended packet encapsulation mode. As a best practice, set the standard packet encapsulation mode if the ring does not contain S9500E devices.
All devices on a ring must be configured with the same packet encapsulation mode.
# Set the extended packet encapsulation mode for the logical interface RPR 4/0/1.
[Sysname- RPR4/0/1] rpr encapsulation extend
rpr port-type
Use rpr port-type to change the RPR physical port type.
rpr port-type { 10ge | 10gpos }
The RPR physical port type is 10GPOS.
10ge: Changes the type of RPR physical ports to 10GE.
10gpos: Changes the type of RPR physical ports to 10GPOS.
After you change the RPR physical port type, the following results will occur:
·     The subcard where the RPR physical ports reside will reboot, and the configuration on the ports will be lost.
·     The ports previously assigned to the non-default Multitenant Device Context (MDC) will be assigned to the default MDC. You must manually change the MDC assignment.
·     The port will be automatically bound to the RPR logical interface.
This command takes effect only on 10GPOS and 10GE RPR physical ports.
# Change the type of RPRXGE 4/1/1 to 10GPOS.
[Sysname-RPRXGE4/1/1] rpr port-type 10gpos
# Change the type of RPRPOS 4/1/1 to 10GE.
[Sysname-RPRPOS4/1/1] rpr port-type 10ge
rpr rate-limit
Use rpr rate-limit to configure reserved bandwidth or rate limit for a service class on a ringlet.
Use undo rpr rate-limit to restore the default.
rpr rate-limit { high | low | medium | reserved } { ringlet0 | ringlet1 } value
undo rpr rate-limit { high | low | medium | reserved } { ringlet0 | ringlet1 }
The default setting varies by service class.
·     0‰ bandwidth reservation for subclass A0.
·     2‰ data rate limit for subclass A1.
·     0‰ data rate limit for class B-CIR.
·     1000‰ data rate limit for classes C and B-EIR.
high: Specifies rate limit for subclass A1 traffic.
low: Specifies rate limit for class B-EIR and class C traffic.
medium: Specifies rate limit for class B-CIR traffic.
reserved: Specifies the reserved bandwidth for subclass A0 traffic.
ringlet0: Specifies Ringlet 0 as the sending ringlet.
ringlet1: Specifies Ringlet 1 as the sending ringlet.
value: Set the reserved bandwidth or rate limit value in the range of 0 to 1000, in permillage.
The total bandwidth reserved for subclass A0 by the stations on a ringlet must be less than the ringlet bandwidth.
# Set the reserved bandwidth to 5‰ for subclass A0 traffic on Ringlet 0 for RPR 4/0/1.
[Sysname-RPR4/0/1] rpr rate-limit reserved ringlet0 5
rpr reversion-mode non-revertive
Use rpr reversion-mode non-revertive to set the RPR protection reversion mode.
Use undo rpr reversion-mode to restore the default.
A station uses the revertive protection mode.
# Set the non-revertive protection mode for RPR 4/0/1.
[Sysname-RPR4/0/1] rpr reversion-mode non-revertive
rpr static-rs
Use rpr static-rs to create a static ringlet selection entry.
Use undo rpr static-rs to remove a static ringlet selection entry.
rpr static-rs mac-address { ringlet0 | ringlet1 }
undo rpr static-rs mac-address
No static ringlet selection entry exists.
ringlet0: Specifies Ringlet 0 as the sending ringlet for data frames destined to the specified MAC address.
ringlet1: Specifies Ringlet 1 as the sending ringlet for data frames destined to the specified MAC address.
mac-address: Specifies a destination station by its MAC address.
# Create two static ringlet selection entries on RPR 4/0/1. Specify Ringlet 0 for sending data frames destined to 0001-0002-0003, and Ringlet 1 for sending data frames destined to 0001-0002-0004.
[Sysname-RPR4/0/1] rpr static-rs 0001-0002-0003 ringlet0
[Sysname-RPR4/0/1] rpr static-rs 0001-0002-0004 ringlet1
rpr station-name
Use rpr station-name to configure an RPR station name.
Use undo rpr station-name to remove an RPR station name.
rpr station-name station-name
An RPR station is not configured with a name.
station-name: Configures an RPR station name, a string of 1 to 127 characters.
# Configure ABC as the station name on RPR 4/0/1.
[Sysname-RPR4/0/1] rpr station-name ABC
rpr timer
Use rpr timer to set RPR timers.
Use undo rpr timer to restore the default.
rpr timer { atd atd-value | holdoff holdoff-value | keepalive keepalive-value | stability stability-value | tc-fast tc-fast-value | tc-slow tc-slow-value | tp-fast tp-fast-value | tp-slow tp-slow-value | wtr wtr-value }
undo rpr timer { atd | holdoff | keepalive | stability | tc-fast | tc-slow | tp-fast | tp-slow | wtr }
·     The ATD timer is 1 second.
·     The hold-off timer is 0 milliseconds.
·     The keepalive timer is 3 milliseconds.
·     The topology stability timer is 40 milliseconds.
·     The TC fast timer is 10 milliseconds.
·     The TC slow timer is 100 milliseconds.
·     The TP fast timer is 10 milliseconds.
·     The TP slow timer is 100 milliseconds.
·     The WTR timer is 10 seconds.
atd atd-value: Sets the ATD timer in the range of 1 to 10 seconds.
holdoff holdoff-value: Sets the hold-off timer, in steps of 10 milliseconds in the range of 0 to 200 milliseconds.
keepalive keepalive-value: Sets the keepalive timer in the range of 2 to 200 milliseconds.
stability stability-value: Sets the topology stability timer in the range of 10 to 100 milliseconds.
tc-fast tc-fast-value: Sets the TC fast timer in the range of 1 to 20 milliseconds.
tc-slow tc-slow-value: Sets the TC slow timer, in steps of 50 milliseconds and in the range of 50 to 10000 milliseconds.
tp-fast tp-fast-value: Sets the TP fast timer in the range of 1 to 20 milliseconds.
tp-slow tp-slow-value: Sets the TP slow timer, in steps of 50 milliseconds in the range of 50 to 10000 milliseconds.
wtr wtr-value: Sets the WTR timer in the range of 0 to 1440 seconds.
# Set the ATD timer to 3 seconds on RPR 4/0/1.
[Sysname-RPR4/0/1] rpr timer atd 3
display rpr timers
rpr weight
Use rpr weight to set the weight of a station.
Use undo rpr weight to restore the default.
rpr weight { ringlet0 | ringlet1 } value
undo rpr weight { ringlet0 | ringlet1 }
The weight of a station on both ringlets is 1.
ringlet0: Sets the weight of the station on Ringlet 0.
ringlet1: Sets the weight of the station on Ringlet 1.
value: Specifies the weight in the range of 0 to 255. The value must be a power of 2.
# Set the station weight to 2 for Ringlet 0 on RPR 4/0/1.
[Sysname-RPR4/0/1] rpr weight ringlet0 2
rpr weight standard
Use rpr weight standard to specify the standard algorithm for calculating the weight in ATD frames.
Use undo rpr weight standard to restore the default.
rpr weight standard
An RPR station uses the proprietary algorithm for calculating the weight in ATD frames.
If a ring contains S9500E and S9500 devices, use the default algorithm for calculating the weight in ATD frames.
All devices on a ring must be configured with the same algorithm for calculating the weight in ATD frames.
# Specify the standard algorithm for calculating the weight in ATD frames for the logical interface RPR 4/0/1.
[Sysname- RPR4/0/1] rpr weight standard
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An interface is up.
# Shut down RPRXGE 4/1/1.
[Sysname-RPRXGE4/1/1] shutdown
# Shut down RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] shutdown
threshold
Use threshold to set the SD or SF alarm threshold for an interface.
Use undo threshold to restore the default.
threshold { sd sdvalue| sf sfvalue }*
undo threshold { sd | sf }
The SD alarm threshold and SF alarm threshold are 10e–5 and 10e–3, respectively.
sd: Specifies the SD alarm threshold.
sdvalue: Specifies the power for setting the SD alarm threshold. The threshold is 10e to the power of negative sdvalue (10esdvalue). The value is in the range of 3 to 9. Only a value of 5 to 7 can be configured. The greater the value, the lower the SD alarm threshold.
sf: Specifies the SF alarm threshold. The SF alarm threshold must be higher than the SD alarm threshold.
sfvalue: Specifies the power for setting the SF alarm threshold. The threshold is 10e to the power of negative sdvalue (10esfvalue). The value is in the range of 3 to 9. Only a value of 3 to 5 can be configured. The greater the value, the lower the SF alarm threshold.
An interface generates SD or SF alarms when the bit error rate exceeds the SD or SF alarm threshold. The SF alarm threshold must be higher than the SD alarm threshold. SF alarms indicate a more serious line performance degradation than SD alarms. The sdvalue argument must be greater than the sfvalue argument
# Configure the SD threshold as 10e to the power of negative 4 (10e–6) on RPRPOS 2/4/0.
[Sysname] interface rprpos 2/4/0
[Sysname-RPRPOS2/4/0] threshold sd 6
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval for sending keepalive packets, in the range of 0 to 32767 seconds.
On an interface encapsulated with PPP, FR, or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end has been down if it does not receive keepalive messages when the keepalive retry limit is reached. The data link layer then reports the link down event to the upper-layer protocols.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for RPRPOS 4/1/1.
[Sysname-RPRPOS4/1/1] timer-hold 15
