06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73106-Layer 3 - IP Routing Configuration Guide
03-RIP configuration
03-RIP configuration 399.71 KB
Configuring RIP· 1
Overview·· 1
RIP route entries 1
Routing loop prevention· 1
RIP operation· 1
RIP versions 2
Protocols and standards 2
RIP configuration task list 2
Configuring basic RIP· 3
Enabling RIP· 3
Controlling RIP reception and advertisement on interfaces 4
Configuring a RIP version· 5
Configuring RIP route control 5
Configuring an additional routing metric· 5
Configuring RIPv2 route summarization· 6
Disabling host route reception· 7
Advertising a default route· 7
Configuring received/redistributed route filtering· 8
Setting a preference for RIP· 8
Configuring RIP route redistribution· 9
Tuning and optimizing RIP networks 9
Configuration prerequisites 9
Configuring RIP timers 9
Configuring split horizon and poison reverse· 10
Setting the maximum number of ECMP routes 11
Enabling zero field check on incoming RIPv1 messages 11
Enabling source IP address check on incoming RIP updates 11
Configuring RIPv2 message authentication· 12
Specifying a RIP neighbor 12
Configuring RIP network management 13
Configuring the RIP packet sending rate· 13
Setting the maximum length of RIP packets 13
Configuring RIP GR· 14
Configuring BFD for RIP· 14
Configuring single-hop echo detection (for a directly connected RIP neighbor) 15
Configuring single-hop echo detection (for a specific destination) 15
Configuring bidirectional control detection· 16
Configuring RIP FRR· 16
Configuration restrictions and guidelines 16
Configuration prerequisites 17
Configuration procedure· 17
Displaying and maintaining RIP· 18
RIP configuration examples 18
Configuring basic RIP· 18
Configuring RIP route redistribution· 20
Configuring an additional metric for a RIP interface· 23
Configuring RIP to advertise a summary route· 24
Configuring BFD for RIP (single-hop echo detection for a directly connected neighbor) 27
Configuring BFD for RIP (single-hop echo detection for a specific destination) 30
Configuring BFD for RIP (bidirectional detection) 32
Configuring RIP FRR· 36
Overview
Routing Information Protocol (RIP) is a distance-vector IGP suited to small-sized networks. It employs UDP to exchange route information through port 520.
RIP uses a hop count to measure the distance to a destination. The hop count from a router to a directly connected network is 0. The hop count from a router to a directly connected router is 1. To limit convergence time, RIP restricts the value range of the metric from 0 to 15. A destination with a metric value of 16 (or greater) is considered unreachable. For this reason, RIP is not suitable for large-sized networks.
RIP route entries
RIP stores route entries in a database. Each route entry contains the following elements:
·     Destination address—IP address of a destination host or a network.
·     Next hop—IP address of the next hop.
·     Egress interfaceEgress interface of the route.
·     Metric—Cost from the local router to the destination.
·     Route time—Time elapsed since the last update. The time is reset to 0 when the route entry is updated.
·     Route tagUsed for route control. For more information, see "Configuring routing policies."
RIP uses the following mechanisms to prevent routing loops:
·     Counting to infinityA destination with a metric value of 16 is considered unreachable. When a routing loop occurs, the metric value of a route will increment to 16 to avoid endless looping.
·     Triggered updatesRIP immediately advertises triggered updates for topology changes to reduce the possibility of routing loops and to speed up convergence.
·     Split horizonDisables RIP from sending routes through the interface where the routes were learned to prevent routing loops and save bandwidth.
·     Poison reverseEnables RIP to set the metric of routes received from a neighbor to 16 and sends these routes back to the neighbor. The neighbor can delete such information from its routing table to prevent routing loops.
RIP operation
RIP works as follows:
1.     RIP sends request messages to neighboring routers. Neighboring routers return response messages that contain their routing tables.
2.     RIP uses the received responses to update the local routing table and sends triggered update messages to its neighbors. All RIP routers on the network do this to learn latest routing information.
3.     RIP periodically sends the local routing table to its neighbors. After a RIP neighbor receives the message, it updates its routing table, selects optimal routes, and sends an update to other neighbors. RIP ages routes to keep only valid routes.
RIP versions
There are two RIP versions, RIPv1 and RIPv2.
RIPv1 is a classful routing protocol. It advertises messages only through broadcast. RIPv1 messages do not carry mask information, so RIPv1 can only recognize natural networks such as Class A, B, and C. For this reason, RIPv1 does not support discontiguous subnets.
RIPv2 is a classless routing protocol. It has the following advantages over RIPv1:
·     Supports route tags to implement flexible route control through routing policies.
·     Supports masks, route summarization, and CIDR.
·     Supports designated next hops to select the best ones on broadcast networks.
·     Supports multicasting route updates so only RIPv2 routers can receive these updates to reduce resource consumption.
·     Supports plain text authentication and MD5 authentication to enhance security.
RIPv2 supports two transmission modes: broadcast and multicast. Multicast is the default mode using 224.0.0.9 as the multicast address. An interface operating in RIPv2 broadcast mode can also receive RIPv1 messages.
·     RFC 1058, Routing Information Protocol
·     RFC 1723, RIP Version 2 - Carrying Additional Information
·     RFC 1721, RIP Version 2 Protocol Analysis
·     RFC 1722, RIP Version 2 Protocol Applicability Statement
·     RFC 1724, RIP Version 2 MIB Extension
·     RFC 2082, RIPv2 MD5 Authentication
·     RFC 2091, Triggered Extensions to RIP to Support Demand Circuits
·     RFC 2453, RIP Version 2
Tasks at a glance
Configuring basic RIP:
·     (Required.) Enabling RIP
·     (Optional.) Controlling RIP reception and advertisement on interfaces
·     (Optional.) Configuring a RIP version
(Optional.) Configuring RIP route control:
·     Configuring an additional routing metric
·     Configuring RIPv2 route summarization
·     Disabling host route reception
·     Advertising a default route
·     Configuring received/redistributed route filtering
·     Setting a preference for RIP
·     Configuring RIP route redistribution
(Optional.) Tuning and optimizing RIP networks:
·     Configuring RIP timers
·     Configuring split horizon and poison reverse
·     Setting the maximum number of ECMP routes
·     Enabling zero field check on incoming RIPv1 messages
·     Enabling source IP address check on incoming RIP updates
·     Configuring RIPv2 message authentication
·     Specifying a RIP neighbor
·     Configuring RIP network management
·     Configuring the RIP packet sending rate
·     Setting the maximum length of RIP packets
(Optional.) Configuring RIP GR
(Optional.) Configuring BFD for RIP
(Optional.) Configuring RIP FRR
Before you configure basic RIP settings, complete the following tasks:
·     Configure the link layer protocol.
·     Configure IP addresses for interfaces to ensure IP connectivity between neighboring routers.
Enabling RIP
To enable multiple RIP processes on a router, you must specify an ID for each process. A RIP process ID has only local significance. Two RIP routers having different process IDs can also exchange RIP packets.
If you configure RIP settings in interface view before enabling RIP, the settings do not take effect until RIP is enabled. If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes. You cannot enable multiple RIP processes on a physical interface.
Enabling RIP on a network
You can enable RIP on a network and specify a wildcard mask for the network. After that, only the interface attached to the network runs RIP.
To enable RIP on a network:
Step
Remarks
N/A
1.     Enable RIP and enter RIP view.
rip [ process-id ] [ vpn-instance vpn-instance-name ]
By default, RIP is disabled.
2.     Enable RIP on a network.
By default, RIP is disabled on a network.
The network 0.0.0.0 command can enable RIP on all interfaces in a single process, but does not apply to multiple RIP processes.
Enabling RIP on an interface
Step
Remarks
N/A
2.     Enable RIP and enter RIP view.
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Enable RIP on the interface.
rip process-id enable [ exclude-subip ]
By default, RIP is disabled on an interface.
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable an interface from sending RIP messages.
By default, all RIP-enabled interfaces can send RIP messages.
The disabled interface can still receive RIP messages and respond to unicast requests containing unknown ports.
4.     Return to system view.
N/A
5.     Enter interface view.
N/A
6.     Enable an interface to receive RIP messages.
rip input
By default, a RIP-enabled interface can receive RIP messages.
7.     Enable an interface to send RIP messages.
rip output
By default, a RIP-enabled interface can send RIP messages.
You can configure a global RIP version in RIP view or an interface-specific RIP version in interface view.
An interface preferentially uses the interface-specific RIP version. If no interface-specific version is specified, the interface uses the global RIP version. If neither a global nor interface-specific RIP version is configured, the interface sends RIPv1 broadcasts and can receive the following:
·     RIPv1 broadcasts and unicasts.
·     RIPv2 broadcasts, multicasts, and unicasts.
To configure a RIP version:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Specify a global RIP version.
version { 1 | 2 }
By default, no global version is specified. An interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
N/A
N/A
6.     Specify a RIP version for the interface.
rip version { 1 | 2 [ broadcast | multicast ] }
By default, no interface-specific RIP version is specified. The interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
Before you configure RIP route control, complete the following tasks:
·     Configure basic RIP.
An additional routing metric (hop count) can be added to the metric of an inbound or outbound RIP route.
An outbound additional metric is added to the metric of a sent route, and it does not change the route's metric in the routing table.
An inbound additional metric is added to the metric of a received route before the route is added into the routing table, and the route's metric is changed. If the sum of the additional metric and the original metric is greater than 16, the metric of the route is 16.
To configure additional routing metrics:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Specify an inbound additional routing metric.
rip metricin [ route-policy route-policy-name ] value
The default setting is 0.
4.     Specify an outbound additional routing metric.
rip metricout [ route-policy route-policy-name ] value
The default setting is 1.
Perform this task to summarize contiguous subnets into a summary network and sends the network to neighbors. The smallest metric among all summarized routes is used as the metric of the summary route.
Enabling RIPv2 automatic route summarization
Automatic summarization enables RIPv2 to generate a natural network for contiguous subnets. For example, suppose there are three subnet routes 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24. Automatic summarization automatically creates and advertises a summary route 10.0.0.0/8 instead of the more specific routes.
To enable RIPv2 automatic route summarization:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     (Optional.) Enable RIPv2 automatic route summarization.
summary
By default, RIPv2 automatic route summarization is enabled.
If subnets in the routing table are not contiguous, disable automatic route summarization to advertise more specific routes.
Advertising a summary route
Perform this task to manually configure a summary route.
For example, suppose contiguous subnets routes 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24 exist in the routing table. You can create a summary route 10.1.0.0/16 on GigabitEthernet 3/0/1 to advertise the summary route instead of the more specific routes.
To configure a summary route:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable RIPv2 automatic route summarization.
undo summary
Quit
N/A
N/A
6.     Configure a summary route.
rip summary-address ip-address { mask-length | mask }
By default, no summary route is configured.
Perform this task to disable RIPv2 from receiving host routes from the same network to save network resources. This feature does not apply to RIPv1.
To disable RIP from receiving host routes:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Disable RIP from receiving host routes.
undo host-route
By default, RIP receives host routes.
You can advertise a default route on all RIP interfaces in RIP view or on a specific RIP interface in interface view. The interface view setting takes precedence over the RIP view settings.
To disable an interface from advertising a default route, use the rip default-route no-originate command on the interface.
To configure RIP to advertise a default route:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable RIP to advertise a default route.
default-route { only | originate } [ cost cost ]
By default, RIP does not advertise a default route.
N/A
N/A
6.     Configure the RIP interface to advertise a default route.
rip default-route { { only | originate } [ cost cost ] | no-originate }
By default, a RIP interface can advertise a default route if the RIP process is enabled to advertise a default route.
The router enabled to advertise a default route does not accept default routes from RIP neighbors.
Perform this task to filter received and redistributed routes by using an IP prefix list. You can also configure RIP to receive routes only from a specified neighbor.
To configure route filtering:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure the filtering of received routes.
filter-policy { acl-number | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] } import [ interface-type interface-number ]
By default, the filtering of received routes is not configured.
This command filters received routes. Filtered routes are not installed into the routing table or advertised to neighbors.
4.     Configure the filtering of redistributed routes.
filter-policy { acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] | interface-type interface-number ]
By default, the filtering of redistributed routes is not configured.
This command filters redistributed routes, including routes redistributed with the import-route command.
If multiple IGPs find routes to the same destination, the route found by the IGP that has the highest priority is selected as the optimal route. Perform this task to assign a preference to RIP. The smaller the preference value, the higher the priority.
To set a preference for RIP:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Set a preference for RIP.
preference [ route-policy route-policy-name ] value
The default setting is 100.
Perform this task to configure RIP to redistribute routes from other routing protocols, including OSPF, IS-IS, BGP, static, and direct.
To configure RIP route redistribution:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Redistribute routes from another routing protocol.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | route-policy route-policy-name | tag tag ] *
By default, RIP route redistribution is disabled.
This command can redistribute only active routes. To view active routes, use the display ip routing-table protocol command.
4.     (Optional.) Set a default cost for redistributed routes.
default cost value
Before you tune and optimize RIP networks, complete the following tasks:
·     Configure IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
You can change the RIP network convergence speed by adjusting the following RIP timers:
·     Update timerSpecifies the interval between route updates.
·     Timeout timerSpecifies the route aging time. If no update for a route is received within the aging time, the metric of the route is set to 16.
·     Suppress timerSpecifies how long a RIP route stays in suppressed state. When the metric of a route is 16, the route enters the suppressed state. A suppressed route can be replaced by an updated route that is received from the same neighbor before the suppress timer expires and has a metric less than 16.
·     Garbage-collect timerSpecifies the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. RIP advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, the route is deleted from the routing table.
IMPORTANT:
To avoid unnecessary traffic or route flapping, configure identical RIP timer settings on RIP routers.
To set RIP timers:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Set RIP timers.
By default:
·     The garbage-collect timer is 120 seconds.
·     The suppress timer is 120 seconds.
·     The timeout timer is 180 seconds.
·     The update timer is 30 seconds.
The split horizon and poison reverse functions can prevent routing loops.
If both split horizon and poison reverse are configured, only the poison reverse function takes effect.
Enabling split horizon
Split horizon disables RIP from sending routes through the interface where the routes were learned to prevent routing loops between adjacent routers.
To enable split horizon:
Step
Remarks
N/A
N/A
3.     Enable split horizon.
rip split-horizon
By default, split horizon is enabled.
Enabling poison reverse
Poison reverse allows RIP to send routes through the interface where the routes were learned. The metric of these routes is always set to 16 (unreachable) to avoid routing loops between neighbors.
To enable poison reverse:
Step
Remarks
N/A
N/A
3.     Enable poison reverse.
rip poison-reverse
By default, poison reverse is disabled.
Perform this task to implement load sharing over ECMP routes.
To set the maximum number of ECMP routes:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Set the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of ECMP routes is 32.
Some fields in the RIPv1 message must be set to zero. These fields are called "zero fields." You can enable zero field check on incoming RIPv1 messages. If a zero field of a message contains a non-zero value, RIP does not process the message. If you are certain that all messages are trustworthy, disable zero field check to save CPU resources.
This feature does not apply to RIPv2 packets, because they have no zero fields.
To enable zero field check on incoming RIPv1 messages:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable zero field check on incoming RIPv1 messages.
checkzero
The default setting is enabled.
Perform this task to enable source IP address check on incoming RIP updates.
Upon receiving a message on an Ethernet interface, RIP compares the source IP address of the message with the IP address of the interface. If they are not in the same network segment, RIP discards the message.
To enable source IP address check on incoming RIP updates:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable source IP address check on incoming RIP messages.
validate-source-address
By default, this function is enabled.
Perform this task to enable authentication on RIPv2 messages. This feature does not apply to RIPv1 because RIPv1 does not support authentication. Although you can specify an authentication mode for RIPv1 in interface view, the configuration does not take effect.
RIPv2 supports two authentication modes: simple authentication and MD5 authentication.
To configure RIPv2 message authentication:
Step
Remarks
N/A
N/A
3.     Configure RIPv2 authentication.
rip authentication-mode { md5 { rfc2082 { cipher cipher-string | plain plain-string } key-id | rfc2453 { cipher cipher-string | plain plain-string } } | simple { cipher cipher-string | plain plain-string } }
By default, RIPv2 authentication is not configured.
Typically RIP messages are sent in broadcast or multicast. To enable RIP on a link that does not support broadcast or multicast, you must manually specify RIP neighbors.
Follow these guidelines when you specify a RIP neighbor:
·     Do not use the peer ip-address command when the neighbor is directly connected. Otherwise, the neighbor might receive both unicast and multicast (or broadcast) messages of the same routing information.
·     If the specified neighbor is not directly connected, disable source address check on incoming updates.
To specify a RIP neighbor:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Specify a RIP neighbor.
peer ip-address
By default, RIP does not unicast updates to any peer.
4.     Disable source IP address check on inbound RIP updates
undo validate-source-address
By default, source IP address check on inbound RIP updates is enabled.
You can use network management software to manage the RIP process to which MIB is bound.
To configure RIP network management:
Step
Remarks
N/A
2.     Bind MIB to a RIP process.
rip mib-binding process-id
By default, MIB is bound to the RIP process with the smallest process ID.
Perform this task to specify the interval for sending RIP packets and the maximum number of RIP packets that can be sent at each interval. This feature can avoid excessive RIP packets from affecting system performance and consuming too much bandwidth.
To configure the RIP packet sending rate:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Specify the interval for sending RIP packets and the maximum number of RIP packets that can be sent at each interval.
output-delay time count count
By default, an interface sends up to three RIP packets every 20 milliseconds.
The supported maximum length of RIP packets varies by vendor. Use this feature with caution to avoid compatibility issues.
The packet length of RIP packets determines how many routes can be carried in a RIP packet. Set the maximum length of RIP packets to make good use of link bandwidth.
When authentication is enabled, follow these guidelines to ensure packet forwarding:
·     For simple authentication, the maximum length of RIP packets must be no less than 52 bytes.
·     For MD5 authentication (with packet format defined in RFC 2453), the maximum length of RIP packets must be no less than 56 bytes.
·     For MD5 authentication (with packet format defined in RFC 2082), the maximum length of RIP packets must be no less than 72 bytes.
To set the maximum length of RIP packets:
Step
Remarks
N/A
N/A
3.     Set the maximum length of RIP packets.
rip max-packet-length value
By default, the maximum length of RIP packets is 512 bytes.
Configuring RIP GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
After RIP restarts on a router, the router must learn RIP routes again and update its FIB table, which causes network disconnections and route reconvergence.
With the GR feature, the restarting router (known as the GR restarter) can notify the event to its GR capable neighbors. GR capable neighbors (known as GR helpers) maintain their adjacencies with the router within a GR interval. During this process, the FIB table of the router does not change. After the restart, the router contacts its neighbors to retrieve its FIB.
By default, a RIP-enabled device acts as the GR helper. Perform this task on the GR restarter.
To configure GR on the GR restarter:
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Enable GR for RIP.
graceful-restart
By default, RIP GR is disabled.
RIP detects route failures by periodically sending requests. If it receives no response for a route within a certain time, RIP considers the route unreachable. To speed up convergence, perform this task to enable BFD for RIP. For more information about BFD, see High Availability Configuration Guide.
RIP supports the following BFD detection modes:
·     Single-hop echo detectionDetection mode for a direct neighbor. In this mode, a BFD session is established only when the directly connected neighbor has route information to send.
·     Single-hop echo detection for a specific destination—In this mode, a BFD session is established to the specified RIP neighbor when RIP is enabled on the local interface.
·     Bidirectional control detectionDetection mode for an indirect neighbor. In this mode, a BFD session is established only when both ends have routes to send and BFD is enabled on the receiving interface.
Step
Remarks
4.     Enter system view.
N/A
5.     Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
6.     Enter interface view.
N/A
7.     Enable BFD for RIP.
rip bfd enable
By default, BFD for RIP is disabled.
When a unidirectional link occurs between the local device and a specific neighbor, BFD can detect the failure. The local device will not receive or send any RIP packets through the interface connected to the neighbor to improve convergence speed. When the link recovers, the interface can send RIP packets again.
This feature applies to RIP neighbors that are directly connected.
To configure BFD for RIP (single hop echo detection for a specific destination):
Step
Remarks
N/A
2.     Configure the source IP address of BFD echo packets.
By default, no source IP address is configured for BFD echo packets.
3.     Enter interface view.
N/A
4.     Enable BFD for RIP.
rip bfd enable destination ip-address
Step
Remarks
N/A
2.     Enter RIP view.
N/A
peer ip-address
Because the undo peer command does not remove the neighbor relationship immediately, executing the command cannot bring down the BFD session immediately.
N/A
5.     Enable BFD on the RIP interface.
rip bfd enable
By default, BFD is disabled on a RIP interface.
Configuring RIP FRR
A link or router failure on a path can cause packet loss and even routing loop until RIP completes routing convergence based on the new network topology. FRR uses BFD to detect failures and enables fast rerouting to minimize the impact of link or node failures.
Figure 1 Network diagram for RIP FRR
As shown in Figure 1, configure FRR on Router B by using a routing policy to specify a backup next hop. When the primary link fails, RIP directs packets to the backup next hop. At the same time, RIP calculates the shortest path based on the new network topology, and forwards packets over that path after network convergence.
·     RIP FRR takes effect only for RIP routes learned from directly connected neighbors.
·     Do not use RIP FRR and BFD for RIP at the same time. Otherwise, FRR might fail to work.
·     RIP FRR is available only when the state of primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down.
You must specify a next hop by using the apply fast-reroute backup-interface command in a routing policy and reference the routing policy for FRR. For more information about routing policy configuration, see "Configuring routing policies."
To configure RIP FRR:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
3.     Enter RIP view.
N/A
4.     Configure RIP FRR.
By default, RIP FRR is disabled.
Configuring RIP FRR
Step
Remarks
N/A
2.     Enter RIP view.
N/A
3.     Configure RIP FRR.
Enabling BFD for RIP FRR
By default, RIP FRR does not use BFD to detect primary link failures. To speed up RIP convergence, enable BFD single-hop echo detection for RIP FRR to detect primary link failures.
To configure BFD for RIP FRR:
Step
Remarks
N/A
N/A
4.     Enable BFD for RIP FRR.
rip primary-path-detect bfd echo
By default, BFD for RIP FRR is disabled.
Execute display commands in any view and execute reset commands in user view.
Display RIP current status and configuration information.
display rip [ process-id ]
Display active routes in RIP database.
display rip process-id database [ ip-address { mask-length | mask } ]
Display RIP interface information.
display rip process-id interface [ interface-type interface-number ]
Display routing information about a specified RIP process.
display rip process-id route [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ]
Reset a RIP process.
reset rip process-id process
Clear the statistics for a RIP process.
reset rip process-id statistics
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. These examples assume that all these interfaces are already up.
Network requirements
As shown in Figure 2, enable RIPv2 on all interfaces on Switch A and Switch B. Configure Switch B to not advertise route 10.2.1.0/24 to Switch A, and to accept only route 2.1.1.0/24 from Switch A.
Figure 2 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure basic RIP by using either of the following methods:
(Method 1) # Enable RIP on the specified networks on Switch A.
[SwitchA] rip
[SwitchA-rip-1] network 192.168.1.0
[SwitchA-rip-1] network 172.16.0.0
[SwitchA-rip-1] network 172.17.0.0
[SwitchA-rip-1] quit
(Method 2) # Enable RIP on the specified interfaces on Switch B.
[SwitchB] rip
[SwitchB-rip-1] quit
[SwitchB-Vlan-interface100] rip 1 enable
[SwitchB-Vlan-interface101] rip 1 enable
[SwitchB-Vlan-interface102] rip 1 enable
# Display the RIP routing table of Switch A.
[SwitchA] display rip 1 route
 Route Flags: R - RIP
              A - Aging, S - Suppressed, G - Garbage-collect
              O - Optimal, F - Flush to RIB
 Peer 192.168.1.2  on Vlan-interface100
      Destination/Mask        Nexthop           Cost    Tag     Flags   Sec
      10.0.0.0/8              192.168.1.2       1       0       RAOF    11
The output shows that RIPv1 uses a natural mask.
3.     Configure a RIP version:
# Configure RIPv2 on Switch A.
[SwitchA] rip
[SwitchA-rip-1] version 2
[SwitchA-rip-1] undo summary
# Configure RIPv2 on Switch B.
[SwitchB] rip
[SwitchB-rip-1] version 2
[SwitchB-rip-1] undo summary
# Display the RIP routing table on Switch A.
      10.0.0.0/8              192.168.1.2       1       0       RAOF    50
      10.2.1.0/24             192.168.1.2       1       0       RAOF    16
      10.1.1.0/24             192.168.1.2       1       0       RAOF    16
The output shows that RIPv2 uses classless subnet masks.
After RIPv2 is configured, RIPv1 routes might still exist in the routing table until they are aged out.
# Display the RIP routing table on Switch B.
 Peer 192.168.1.3 on Vlan-interface100
      172.16.1.0/24           192.168.1.3       1       0       RAOF    19
      172.17.1.0/24           192.168.1.3       1       0       RAOF    19
4.     Configure route filtering:
# Reference IP prefix lists on Switch B to filter received and redistributed routes.
[SwitchB] ip prefix-list aaa index 10 permit 172.16.1.0 24
[SwitchB] ip prefix-list bbb index 10 permit 10.1.1.0 24
[SwitchB] rip 1
[SwitchB-rip-1] filter-policy prefix-list aaa import
[SwitchB-rip-1] filter-policy prefix-list bbb export
[SwitchA] display rip 100 route
      10.1.1.0/24             192.168.1.2       1       0       RAOF    19
[SwitchB] display rip 1 route
As shown in Figure 3, Switch B communicates with Switch A through RIP 100 and with Switch C through RIP 200.
Configure RIP 200 to redistribute direct routes and routes from RIP 100 on Switch B so Switch C can learn routes destined for 10.2.1.0/24 and 11.1.1.0/24. Switch A cannot learn routes destined for 12.3.1.0/24 and 16.4.1.0/24.
Figure 3 Network diagram
2.     Configure basic RIP:
# Enable RIP 100, and configure RIPv2 on Switch A.
[SwitchA] rip 100
[SwitchA-rip-100] network 10.0.0.0
[SwitchA-rip-100] network 11.0.0.0
[SwitchA-rip-100] version 2
[SwitchA-rip-100] undo summary
[SwitchA-rip-100] quit
# Enable RIP 100 and RIP 200, and configure RIPv2 on Switch B.
[SwitchB] rip 100
[SwitchB-rip-100] network 11.0.0.0
[SwitchB-rip-100] version 2
[SwitchB-rip-100] undo summary
[SwitchB-rip-100] quit
[SwitchB] rip 200
[SwitchB-rip-200] network 12.0.0.0
[SwitchB-rip-200] version 2
[SwitchB-rip-200] undo summary
[SwitchB-rip-200] quit
# Enable RIP 200, and configure RIPv2 on Switch C.
[SwitchC] rip 200
[SwitchC-rip-200] network 12.0.0.0
[SwitchC-rip-200] network 16.0.0.0
[SwitchC-rip-200] version 2
[SwitchC-rip-200] undo summary
[SwitchC-rip-200] quit
# Display the IP routing table on Switch C.
[SwitchC] display ip routing-table
Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
12.3.1.0/24         Direct 0    0            12.3.1.2        Vlan200
12.3.1.0/32         Direct 0    0            12.3.1.2        Vlan200
12.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
12.3.1.255/32       Direct 0    0            12.3.1.2        Vlan200
16.4.1.0/24         Direct 0    0            16.4.1.1        Vlan400
16.4.1.0/32         Direct 0    0            16.4.1.1        Vlan400
16.4.1.1/32         Direct 0    0            127.0.0.1       InLoop0
16.4.1.255/32       Direct 0    0            16.4.1.1        Vlan400
3.     Configure route redistribution:
# Configure RIP 200 to redistribute routes from RIP 100 and direct routes on Switch B.
[SwitchB] rip 200
[SwitchB-rip-200] import-route rip 100
[SwitchB-rip-200] import-route direct
Destinations : 15        Routes : 15
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
10.2.1.0/24         RIP    100  1            12.3.1.1        Vlan200
11.1.1.0/24         RIP    100  1            12.3.1.1        Vlan200
As shown in Figure 4, run RIPv2 on all the interfaces of Switch A, Switch B, Switch C, Switch D, and Switch E.
Switch A has two links to Switch D. The link from Switch B to Switch D is more stable than that from Switch C to Switch D. Configure an additional metric for RIP routes received from VLAN-interface 200 on Switch A so Switch A prefers route 1.1.5.0/24 learned from Switch B.
Figure 4 Network diagram
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI. For more information, see Layer 2—LAN Switching Configuration Guide.
# Configure Switch A.
[SwitchA] rip 1
[SwitchA-rip-1] network 1.0.0.0
# Configure Switch B.
[SwitchB] rip 1
[SwitchB-rip-1] network 1.0.0.0
# Configure Switch C.
[SwitchB] rip 1
[SwitchC-rip-1] network 1.0.0.0
[SwitchC-rip-1] version 2
[SwitchC-rip-1] undo summary
# Configure Switch D.
<SwitchD> system-view
[SwitchD] rip 1
[SwitchD-rip-1] network 1.0.0.0
[SwitchD-rip-1] version 2
[SwitchD-rip-1] undo summary
# Configure Switch E.
<SwitchE> system-view
[SwitchE] rip 1
[SwitchE-rip-1] network 1.0.0.0
[SwitchE-rip-1] version 2
[SwitchE-rip-1] undo summary
# Display all active routes in the RIP database on Switch A.
[SwitchA] display rip 1 database
   1.0.0.0/8, auto-summary
       1.1.1.0/24, cost 0, nexthop 1.1.1.1, RIP-interface
       1.1.2.0/24, cost 0, nexthop 1.1.2.1, RIP-interface
       1.1.3.0/24, cost 1, nexthop 1.1.1.2
       1.1.4.0/24, cost 1, nexthop 1.1.2.2
       1.1.5.0/24, cost 2, nexthop 1.1.1.2
       1.1.5.0/24, cost 2, nexthop 1.1.2.2
The output shows two RIP routes destined for network 1.1.5.0/24. The next hops of the routes are Switch B (1.1.1.2) and Switch C (1.1.2.2). The cost of the routes is 2.
3.     Configure an additional metric for a RIP interface:
# Configure an inbound additional metric of 3 for RIP-enabled interface VLAN-interface 200 on Switch A.
[SwitchA-Vlan-interface200] rip metricin 3
[SwitchA-Vlan-interface200] display rip 1 database
       1.1.4.0/24, cost 2, nexthop 1.1.1.2
The output shows that only one RIP route reaches network 1.1.5.0/24, with the next hop as Switch B (1.1.1.2) and a cost of 2.
As shown in Figure 5, Switch A and Switch B run OSPF, Switch D runs RIP, and Switch C runs OSPF and RIP.
·     Configure RIP to redistribute OSPF routes on Switch C so Switch D can learn routes destined for networks 10.1.1.0/24, 10.2.1.0/24, 10.5.1.0/24, and 10.6.1.0/24.
·     To reduce the routing table size of Switch D, configure route summarization on Switch C to advertise only the summary route 10.0.0.0/8 to Switch D.
Figure 5 Network diagram
2.     Configure basic OSPF:
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchC-ospf-1] quit
3.     Configure basic RIP:
[SwitchC] rip 1
[SwitchC-rip-1] network 11.3.1.0
[SwitchD] rip 1
[SwitchD-rip-1] network 11.0.0.0
[SwitchD-rip-1] quit
# Configure RIP to redistribute routes from OSPF process 1 and direct routes on Switch C.
[SwitchC-rip-1] import-route direct
[SwitchC-rip-1] import-route ospf 1
[SwitchC-rip-1] quit
# Display the IP routing table on Switch D.
[SwitchD] display ip routing-table
10.1.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.2.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.5.1.0/24         RIP    100  1            11.3.1.1        Vlan300
10.6.1.0/24         RIP    100  1            11.3.1.1        Vlan300
11.3.1.0/24         Direct 0    0            11.3.1.2        Vlan300
11.3.1.0/32         Direct 0    0            11.3.1.2        Vlan300
11.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
11.4.1.0/24         Direct 0    0            11.4.1.2        Vlan400
11.4.1.0/32         Direct 0    0            11.4.1.2        Vlan400
11.4.1.2/32         Direct 0    0            127.0.0.1       InLoop0
4.     Configure route summarization:
# Configure route summarization on Switch C and advertise only the summary route 10.0.0.0/8.
[SwitchC-Vlan-interface300] rip summary-address 10.0.0.0 8
Destinations : 12        Routes : 12
10.0.0.0/8          RIP    100  1            11.3.1.1        Vlan300
As shown in Figure 6, VLAN-interface 100 of Switch A and Switch C runs RIP process 1. VLAN-interface 200 of Switch A runs RIP process 2. VLAN-interface 300 of Switch C and VLAN-interface 200 and VLAN-interface 300 of Switch B run RIP process 1.
·     Configure a static route destined for 100.1.1.1/24 and enable static route redistribution into RIP on Switch C. This allows Switch A to learn two routes destined for 100.1.1.1/24 through VLAN-interface 100 and VLAN-interface 200 respectively, and uses the one through VLAN-interface 100.
·     Enable BFD for RIP on VLAN-interface 100 of Switch A. When the link over VLAN-interface 100 fails, BFD can quickly detect the failure and notify it to RIP. RIP deletes the neighbor relationship and route information learned on VLAN-interface 100. It uses the route destined for 100.1.1.1 24 through VLAN-interface 200.
Figure 6 Network diagram
[SwitchA] rip 1
[SwitchA-Vlan-interface100] rip bfd enable
[SwitchA] rip 2
[SwitchA-rip-2] version 2
[SwitchA-rip-2] undo summary
[SwitchA-rip-2] network 192.168.2.0
[SwitchA-rip-2] quit
[SwitchB] rip 1
[SwitchB-rip-1] network 192.168.2.0
[SwitchB-rip-1] network 192.168.3.0
[SwitchC] rip 1
[SwitchC-rip-1] network 192.168.1.0
[SwitchC-rip-1] network 192.168.3.0
[SwitchC-rip-1] import-route static
3.     Configure BFD parameters on VLAN-interface 100 of Switch A.
[SwitchA] bfd echo-source-ip 11.11.11.11
[SwitchA-Vlan-interface100] bfd min-transmit-interval 500
[SwitchA-Vlan-interface100] bfd min-receive-interval 500
[SwitchA-Vlan-interface100] bfd detect-multiplier 7
[SwitchA] quit
4.     Configure a static route on Switch C.
[SwitchC] ip route-static 120.1.1.1 24 null 0
# Display the BFD session information on Switch A.
<SwitchA> display bfd session
 IPv4 Session Working Under Echo Mode:
 LD          SourceAddr      DestAddr        State    Holdtime    Interface
 4            192.168.1.1     192.168.1.2     Up       2000ms      Vlan100
# Display RIP routes destined for 120.1.1.0/24 on Switch A.
<SwitchA> display ip routing-table 120.1.1.0 24 verbose
Summary Count : 1
Destination: 120.1.1.0/24
   Protocol: RIP             Process ID: 1
  SubProtID: 0x1                    Age: 04h20m37s
       Cost: 1               Preference: 100
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NBRID: 0x26000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 192.168.1.2
      Flags: 0x1008c        OrigNextHop: 192.168.1.2
      Label: NULL           RealNextHop: 192.168.1.2
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: Vlan-interface100
BkTunnel ID: Invalid        BkInterface: N/A
The output shows that Switch A communicates with Switch C through VLAN-interface 100. Then the link over VLAN-interface 100 fails.
Summary Count : 1
   Protocol: RIP             Process ID: 2
       Cost: 2               Preference: 100
     AttrID: 0xffffffff        Neighbor: 192.168.2.2
      Flags: 0x1008c        OrigNextHop: 192.168.2.2
      Label: NULL           RealNextHop: 192.168.2.2
  Tunnel ID: Invalid          Interface: Vlan-interface200
The output shows that Switch A communicates with Switch C through VLAN-interface 200.
As shown in Figure 7, VLAN-interface 100 of Switch A and Switch B runs RIP process 1. VLAN-interface 200 of Switch B and Switch C runs RIP process 1.
·     Configure a static route destined for 100.1.1.0/24 and enable static route redistribution into RIP on both Switch A and Switch C. This allows Switch B to learn two routes destined for 100.1.1.0/24 through VLAN-interface 100 and VLAN-interface 200. The route redistributed from Switch A has a smaller cost than that redistributed from Switch C, so Switch B uses the route through VLAN-interface 200.
·     Enable BFD for RIP on VLAN-interface 100 of Switch A, and specify VLAN-interface 100 of Switch B as the destination. When a unidirectional link occurs between Switch A and Switch B, BFD can quickly detect the link failure and notify RIP. Switch B then deletes the neighbor relationship and the route information learned on VLAN-interface 100. It does not receive or send any packets from VLAN-interface 100. When the route learned from Switch A ages out, Switch B uses the route destined for 100.1.1.1 24 through VLAN-interface 200.
Figure 7 Network diagram
2.     Configure basic RIP and enable BFD on the interfaces:
[SwitchA] rip 1
[SwitchA-rip-1] network 192.168.2.0
[SwitchA-rip-1] import-route static
[SwitchA-Vlan-interface100] rip bfd enable destination 192.168.2.2
[SwitchB] rip 1
[SwitchC] rip 1
[SwitchC-rip-1] import-route static cost 3
[SwitchA-Vlan-interface100] bfd min-echo-receive-interval 500
[SwitchA-Vlan-interface100] return
4.     Configure static routes:
# Configure a static route on Switch A.
[SwitchA] ip route-static 100.1.1.0 24 null 0
# Configure a static route on Switch C.
# Display BFD session information on Switch A.
 IPv4 session working under Echo mode:
 3              192.168.2.1     192.168.2.2     Up       2000ms      vlan100
# Display routes destined for 100.1.1.0/24 on Switch B.
<SwitchB> display ip routing-table 100.1.1.0 24 verbose
Summary Count : 1
Destination: 100.1.1.0/24
  SubProtID: 0x1                    Age: 00h02m47s
      NBRID: 0x12000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 192.168.2.1
      Flags: 0x1008c        OrigNextHop: 192.168.2.1
      Label: NULL           RealNextHop: 192.168.2.1
  Tunnel ID: Invalid          Interface: vlan-interface 100
# Display routes destined for 100.1.1.0/24 on Switch B when the link between Switch A and Switch B fails.
Summary Count : 1
  SubProtID: 0x1                    Age: 00h21m23s
       Cost: 4               Preference: 100
     AttrID: 0xffffffff        Neighbor: 192.168.3.2
      Flags: 0x1008c        OrigNextHop: 192.168.3.2
      Label: NULL           RealNextHop: 192.168.3.2
  Tunnel ID: Invalid          Interface: vlan-interface 200
As shown in Figure 8, VLAN-interface 100 of Switch A and VLAN-interface 200 of Switch C run RIP process 1.
VLAN-interface 300 of Switch A runs RIP process 2. VLAN-interface 400 of Switch C, and VLAN-interface 300 and VLAN-interface 400 of Switch D run RIP process 1.
·     Configure a static route destined for 100.1.1.0/24 on Switch A.
·     Configure a static route destined for 101.1.1.0/24 on Switch C.
·     Enable static route redistribution into RIP on Switch A and Switch C. This allows Switch A to learn two routes destined for 100.1.1.0/24 through VLAN-interface 100 and VLAN-interface 300. It uses the route through VLAN-interface 100.
·     Enable BFD on VLAN-interface 100 of Switch A and VLAN-interface 200 of Switch C.
When the link over VLAN-interface 100 fails, BFD can quickly detect the link failure and notify RIP. RIP deletes the neighbor relationship and the route information received learned on VLAN-interface 100. It uses the route destined for 100.1.1.0/24 through VLAN-interface 300.
Figure 8 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int300
192.168.3.1/24
Switch B
Vlan-int100
192.168.1.2/24
Switch A
Vlan-int100
192.168.1.1/24
Switch B
Vlan-int200
192.168.2.1/24
Switch C
Vlan-int200
192.168.2.2/24
Switch D
Vlan-int300
192.168.3.2/24
Switch C
Vlan-int400
192.168.4.2/24
Switch D
Vlan-int400
192.168.4.1/24
2.     Configure basic RIP and enable static route redistribution into RIP so Switch A and Switch C have routes to send to each other:
[SwitchA] rip 1
[SwitchA-rip-1] network 101.1.1.0
[SwitchA-rip-1] peer 192.168.2.2
[SwitchA-rip-1] undo validate-source-address
[SwitchA] rip 2
[SwitchA-rip-2] network 192.168.3.0
[SwitchC] rip 1
[SwitchC-rip-1] network 192.168.2.0
[SwitchC-rip-1] network 192.168.4.0
[SwitchC-rip-1] network 100.1.1.0
[SwitchC-rip-1] peer 192.168.1.1
[SwitchC-rip-1] undo validate-source-address
[SwitchC-Vlan-interface200] rip bfd enable
[SwitchD] rip 1
[SwitchD-rip-1] network 192.168.3.0
[SwitchD-rip-1] network 192.168.4.0
3.     Configure BFD parameters:
[SwitchC] bfd session init-mode active
[SwitchC-Vlan-interface200] bfd min-transmit-interval 500
[SwitchC-Vlan-interface200] bfd min-receive-interval 500
[SwitchC-Vlan-interface200] bfd detect-multiplier 7
# Configure a static route to Switch C on Switch A.
[SwitchA] ip route-static 192.168.2.0 24 vlan-interface 100 192.168.1.2
[SwitchA] quit
# Configure a static route to Switch A on Switch C.
[SwitchC] ip route-static 192.168.1.0 24 vlan-interface 200 192.168.2.1
 IPv4 session working under Ctrl mode:
 LD/RD             SourceAddr      DestAddr        State    Holdtime    Interface
 513/513           192.168.1.1     192.168.2.2     Up       1700ms      vlan100
# Display RIP routes destined for 100.1.1.0/24 on Switch A.
Summary Count : 1
# Display RIP routes destined for 100.1.1.0/24 on Switch A when the link between Switch B and Switch C fails.
<SwitchA> display ip routing-table 100.1.1.0 24 verbose
Summary Count : 1
  SubProtID: 0x1                    Age: 00h18m40s
      NBRID: 0x12000003          LastAs: 0
  Tunnel ID: Invalid          Interface: vlan-interface 300
Configuring RIP FRR
As shown in Figure 9, Switch S, Switch A, and Switch D run RIPv2. Configure RIP FRR so that when Link A becomes unidirectional, services can be switched to Link B immediately.
Figure 9 Network diagram
1.     Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure RIPv2 on the switches to make sure Switch A, Switch D, and Switch S can communicate with each other at Layer 3. (Details not shown.)
3.     Configure RIP FRR:
# Configure Switch S.
<SwitchS> system-view
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] ip prefix-list abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchS-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy-frr-10] quit
[SwitchS] rip 1
[SwitchS-rip-1] fast-reroute route-policy frr
[SwitchS-rip-1] quit
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchD-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy-frr-10] quit
[SwitchD] rip 1
[SwitchD-rip-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
     AttrID: 0xffffffff        Neighbor: 13.13.13.2
      Flags: 0x1008c        OrigNextHop: 13.13.13.2
      Label: NULL           RealNextHop: 13.13.13.2
    BkLabel: NULL             BkNextHop: 12.12.12.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
     AttrID: 0xffffffff        Neighbor: 13.13.13.1
      Flags: 0x1008c        OrigNextHop: 13.13.13.1
      Label: NULL           RealNextHop: 13.13.13.1
    BkLabel: NULL             BkNextHop: 24.24.24.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
