13-OAA Configuration Guide
HomeSupportRoutersH3C SR8800 Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10313-OAA Configuration Guide
02-ACSEI Configuration
02-ACSEI Configuration 79.22 KB
Configuring ACSEI
ACSEI overview
As a private protocol, ACSEI provides a method for exchanging information between ACFP clients and ACFP server. It well supports Application Control Forwarding Protocol (ACFP) collaboration, ensuring valid information interaction between the ACFP clients and the ACFP server, so that the ACFP server and clients can cooperate to run a service.
As a supporting protocol of ACFP, ACSEI also has two entities: server and client.
·           ACSEI server is integrated into the software system (Comware) of the device and is supported by the device.
·           ACSEI client is implemented in two ways. One way is to integrate it into the system software (Comware) of the device. In this way it is a function supported by the device. The other way is to integrate it into the software system of the OAP module. In this way it is a function supported by the OAP module. Hardware and configurations needed in the two implementations are different. This chapter will introduce them respectively.
·       ACFP is designed based on the Open Application Architecture (OAA).
·       OAP is designed for new services. On OAP module runs the operating system. You can load various service software, such as security, voice, and so on as needed. For more information about the OAP module, see the chapter “Configuring OAP modules.”
·       This manual covers the configuration of the ACSEI server integrated into the software system of the router.
ACSEI functions
ACSEI mainly provides the following functions:
·           Registration and deregistration of an ACSEI client to the ACSEI server.
·           ID assignment. The ACSEI server assigns IDs to ACSEI clients to distinguish between them.
·           Mutual monitoring and awareness between an ACSEI client and the ACSEI server.
·           Information interaction between the ACSEI server and ACSEI clients, including clock synchronization.
·           Control of the ACSEI clients on the ACSEI server. For example, you can restart ACSEI client on the ACSEI server.
ACSEI timers
An ACSEI server uses two timers, the clock synchronization timer and the monitoring timer.
·           The clock synchronization timer is used to periodically trigger the ACSEI server to send clock synchronization advertisements to ACSEI clients. You can set this timer through command lines.
·           The monitoring timer is used to periodically trigger the ACSEI server to send monitoring requests to ACSEI clients. You can set this timer through command lines.
An ACSEI client starts two timers, the registration timer and the monitoring timer.
·           The registration timer is used to periodically trigger the ACSEI client to multicast registration requests (with the multicast MAC address being 010F-E200-0021). You cannot set this timer.
·           The monitoring timer is used to periodically trigger the ACSEI client to send monitoring requests to the ACSEI server. You cannot set this timer.
ACSEI startup and running
ACSEI starts up and runs in the following procedures:
1.      Run the ACSEI client application to enable ACSEI client.
2.      Start up the router and enable the ACSEI server function on it.
3.      The ACSEI client multicasts registration requests.
4.      After the ACSEI server receives a valid registration request, it negotiates parameters with the ACSEI client and establishes connection with the client if the negotiation succeeds.
5.      The ACSEI server and the ACSEI client mutually monitor the connection.
6.      If detecting the disconnection of the ACSEI client, the ACFP server will remove the configuration and policies associated with the client.
Configuring the ACSEI server
Enabling ACSEI server
To enable ACSEI server:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable ACSEI server.
acsei server enable
Disabled by default.
Configuring the clock synchronization timer
To configure the clock synchronization timer:
Step
Remarks
N/A
2.     Enable the ACSEI server function.
acsei server enable
N/A
3.     Enter ACSEI server view.
acsei server
N/A
4.     Configure the clock synchronization timer from ACSEI server to ACSEI client.
acsei timer clock-sync minutes
Optional.
Five minutes by default.
Configuring the monitoring timer
To configure the monitoring timer:
Step
Remarks
N/A
acsei server enable
N/A
acsei server
N/A
4.     Configure the monitoring timer for ACSEI server to monitor ACSEI client.
acsei timer monitor seconds
Optional.
Five seconds by default.
Restarting an ACSEI client
To restart an ACSEI client:
Step
acsei server enable
acsei server
4.     Restart the specified ACSEI client.
acsei client reboot client-id
Displaying and maintaining ACSEI server
Remarks
Display ACSEI client summary.
display acsei client summary [ client-id ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display ACSEI client information.
display acsei client info [ client-id ] [ | { begin | exclude | include } regular-expression ]
