| 00-Preface | 100.21 KB |
Preface
The H3C SR8800 documentation set includes 13 configuration guides, which describe the software features for the H3C SR8800 10G Core Routers and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The MPLS Configuration Guide describes fundamentals and configuration of MPLS basics, MPLS TE, VPLS, MPLS L2VPN, and MPLS L3VPN.
This preface includes:
· Audience
· About the H3C SR8800 documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the SR8800 series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your router.
The H3C SR8800 documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Describe product specifications and benefits. |
Provide an in-depth description of software features and technologies. |
Describe card specifications, features, and standards. |
Hardware specifications and installation |
Provides regulatory information and the safety instructions that must be followed during installation. |
Provides a complete guide to hardware installation and hardware specifications. |
Guides you through installing and remodeling H3C N68 cabinets. |
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes the hot-swappable modules available for the H3C high-end network products, their external views, and specifications. |
Software configuration |
Describe software features and configuration procedures. |
Provide a quick reference to all available commands. |
Operations and maintenance |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
