- 07-IP Multicast Configuration Guide
- 01-Multicast Overview
- 02-IGMP Snooping Configuration
- 03-PIM Snooping Configuration
- 04-Multicast VLAN Configuration
- 05-Multicast Routing and Forwarding Configuration
- 06-IGMP Configuration
- 07-PIM Configuration
- 08-MSDP Configuration
- 09-MBGP Configuration
- 10-Multicast VPN Configuration
- 11-MLD Snooping Configuration
- 12-IPv6 PIM Snooping Configuration
- 13-IPv6 Multicast VLAN Configuration
- 14-IPv6 Multicast Routing and Forwarding Configuration
- 15-MLD Configuration
- 16-IPv6 PIM Configuration
- 17-IPv6 MBGP Configuration
| 09-MBGP Configuration | 207.2 KB |
Configuring MBGP basic functions
Controlling route advertisement and reception
Configuring MBGP route redistribution
Configure default route redistribution into MBGP
Configuring MBGP route summarization
Advertising a default route to an IPv4 MBGP peer or peer group
Configuring outbound MBGP route filtering
Configuring inbound MBGP route filtering
Configuring MBGP route dampening
Configuring MBGP route attributes
Configuring MBGP route preferences
Configuring the default local preference
Configuring the next hop attribute
Configuring the AS-PATH attribute
Tuning and optimizing MBGP networks
Enabling the MBGP ORF capability
Configuring the maximum number of MBGP routes for load balancing
Configuring a large scale MBGP network
Configuring ipv4 MBGP peer groups
Configuring an MBGP route reflector
Displaying and maintaining MBGP
MBGP overview
BGP-4 can carry routing information for IPv4 only. IETF defined multiprotocol BGP extensions to carry routing information for multiple network layer protocols.
For a network, the multicast topology might be different from the unicast topology. To meet the requirement, the multiprotocol BGP extensions enable BGP to carry the unicast Network Layer Reachability Information (NLRI) and multicast NLRI separately, and the multicast NLRI performs reverse path forwarding (RPF) exclusively. In this way, route selection for a destination through the unicast routing table and through the multicast routing table will have different results, ensuring normal unicast and multicast routing.
Multi-protocol BGP is defined in RFC 2858 (Multiprotocol Extensions for BGP-4).
Multi-protocol BGP for IP multicast is referred to as Multicast BGP (MBGP) for short.
NOTE: · This document covers configuration tasks related to multiprotocol BGP for IP multicast only. For more information about BGP, see Layer 3—IP Routing Configuration Guide. · For more information about RPF, see the chapter “Configuring multicast routing and forwarding.” |
Protocols and standards
· RFC2858, Multiprotocol Extensions for BGP-4
· RFC3392, Capabilities Advertisement with BGP-4
· draft-ietf-idmr-bgp-mcast-attr-00, BGP Attributes for Multicast Tree Construction
· RFC4271, A Border Gateway Protocol 4 (BGP-4)
· RFC5291, Outbound Route Filtering Capability for BGP-4
· RFC5292, Address-Prefix-Based Outbound Route Filter for BGP-4
MBGP configuration task list
Complete the following tasks to configure MBGP:
Task |
Remarks |
Required |
Optional |
Optional |
Optional |
Advertising a default route to an IPv4 MBGP peer or peer group |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Configuring the maximum number of MBGP routes for load balancing |
Optional |
Optional |
Optional |
Optional |
Before you configure MBGP, make sure neighboring nodes can access each other at the network layer.
Configuration procedure
To configure MBGP basic functions:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter BGP view. |
bgp as-number |
N/A |
3. Specify a peer or peer group and its AS number. |
peer { group-name | ip-address } as-number as-number |
Not specified by default. |
4. Enter IPv4 MBGP address family view. |
ipv4-family multicast |
N/A |
5. Enable a peer or peer group created in IPv4 unicast view. |
Not enabled by default. |
6. Specify a preferred value for routes from an IPv4 MBGP peer or peer group. |
peer { group-name | ip-address } preferred-value value |
Optional. The default preferred value is 0. |
Configuration prerequisites
You need to configure MBGP basic functions before configuring this task.
MBGP can advertise routing information in the local AS to neighboring ASs. It redistributes such routing information from IGP into its routing table rather than learns the information by itself.
To configure MBGP route redistribution:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
3. Enter IPv4 MBGP address family view. |
N/A |
4. Configure MBGP route redistribution. |
Enable route redistribution from another
routing protocol: ·
Inject a network into the MBGP routing table: |
Use at least one approach. By default, no route redistribution is configured. The allow-direct keyword is available only when the specified routing protocol is OSPF. |
NOTE: · The Origin attribute of routes redistributed into the MBGP routing table with the import-route command is Incomplete. · The Origin attribute of routes injected into the MBGP routing table with the network command is IGP. · The networks to be injected must exist in the local IP routing table, and using a routing policy makes route control more flexible. |
Using the import-route command cannot redistribute any default route into MBGP. This task allows you to do so.
To configure MBGP to redistribute a default route from another protocol:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
3. Enter MBGP address family view. |
N/A |
4. Enable route redistribution from another routing protocol. |
import-route protocol [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ] |
5. Enable default route redistribution into the MBGP routing table. |
default-route imported |
To reduce the routing table size on medium and large MBGP networks, you need to configure route summarization on peers. MBGP supports automatic and manual summarization modes.
· Automatic summarization—Summarizes subnets redistributed from IGP. With the feature configured, MBGP advertises only summary natural networks rather than subnets. The default routes and routes injected with the network command are not summarized.
· Manual summarization—Summarizes MBGP local routes. A manual summary route has a higher priority than an automatic one.
To configure MBGP route summarization:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure MBGP route summarization. |
Enable automatic route summarization: ·
Configure manual route summarization: |
Use either approach. By default, no route summarization is configured. If both are configured, the manual route summarization takes effect. |
To advertise a default route to an MBGP peer or peer group:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Advertise a default route to an MBGP peer or peer group. |
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ] |
Not advertised by default |
NOTE: With the peer default-route-advertise command executed, the router sends a default route with the next hop being itself to the specified MBGP peer or peer group, whether the default route is available or not in the routing table. |
If several filtering policies are configured, they are applied in the following sequence:
1. filter-policy export
2. peer filter-policy export
3. peer as-path-acl export
4. peer ip-prefix export
5. peer route-policy export
Only the routes that have passed all the configured policies can be advertised.
To configure BGP route distribution filtering policies:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure BGP route distribution filtering policies. |
Configure the filtering of redistributed
routes: ·
Apply a routing policy to advertisements to an
IPv4 MBGP peer/peer group: ·
Reference an ACL to filter advertisements to an
Reference an AS path ACL to filter route
advertisements to an IPv4 MBGP peer/peer group: ·
Reference an IP prefix list to filter route
advertisements to an IPv4 MBGP peer/peer group: |
Use at least one approach. By default, no outbound route filtering is configured. |
By configuring MBGP route reception filtering policies, you can filter out unqualified routes from an MBGP peer or peer group.
1. filter-policy import
2. peer filter-policy import
3. peer as-path-acl import
4. peer ip-prefix import
5. peer route-policy import
To configure MBGP route reception filtering policies:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure MBGP route reception filtering policies. |
Filter incoming routes using an ACL or IP
prefix list: ·
Reference a routing policy to routes from an
Reference an ACL to filter routing information
from an IPv4 MBGP peer/peer group: ·
Reference an AS path ACL to filter routing
information from an IPv4 MBGP peer/peer group: ·
Reference an IP prefix list to filter routing
information from an IPv4 MBGP peer/peer group: |
Use at least one approach. By default, no inbound route filtering is configured. |
5. Specify the maximum number of routes that can be received from an IPv4 MBGP peer/peer group. |
peer { group-name | ip-address } route-limit limit [ percentage ] |
Optional. The number is unlimited by default. |
NOTE: Members of a peer group can have different route reception filtering policies from the peer group. |
By configuring MBGP route dampening, you can suppress unstable routes from being added to the MBGP routing table or being advertised to MBGP peers.
To configure BGP route dampening:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure BGP route dampening parameters. |
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] * |
Not configured by default |
You can modify MBGP route attributes to affect route selection.
Before you configure this task, you need to configure MBGP basic functions.
You can reference a routing policy to set preferences for routes matching it. Routes not matching it use the default preferences.
To configure MBGP route preferences:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure preferences for external, internal, local MBGP routes. |
preference { external-preference internal-preference local-preference | route-policy route-policy-name } |
Optional. The default preferences of multicast MBGP EBGP, MBGP IBGP, and local MBGP routes are 255, 255, and 130 respectively. |
To configure the default local preference:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure the default local preference. |
default local-preference value |
Optional 100 by default |
Configuring the MED attribute
When other conditions of routes to a destination are identical, the route with the smallest MED is selected.
To configure the MED attribute:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure the MED attribute. |
Configure the default MED value: ·
Enable the comparison of the MED of routes
from different ASs: · Enable the comparison of the MED of routes from each AS: ·
from confederation peers: |
Optional. The default MED value is 0. By default, the comparison of the MED of routes is not enabled. |
You can use the peer next-hop-local command to specify the local router as the next hop of routes sent to a MBGP IBGP peer or peer group. If load balancing is configured, the router specifies itself as the next hop of route advertisements to the multicast IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
In a “third party next hop” network, that is, when the local router has two multicast EBGP peers in a broadcast network, the router does not specify itself as the next hop of routing information sent to the EBGP peers unless the peer next-hop-local command is configured.
To specify the router as the next hop of routes sent to a peer/peer group:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Specify the router as the next hop of routes sent to a peer/peer group. |
peer { group-name | ip-address } next-hop-local |
Optional. By default, the next hop of routes sent to a MBGP EBGP peer/peer group is the advertising router, but that of routes sent to a MBGP IBGP peer/peer group is not. |
In general, MBGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
To configure the AS-PATH attribute:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure the AS_PATH attribute. |
Specify the maximum number of times the local
AS number can appear in routes from the peer/peer group: ·
Disable BGP from considering the AS_PATH during
best route selection: ·
Configure updates to a peer/peer group to not keep
private AS numbers: |
Optional. By default: · The local AS number cannot appear in routes from a peer/peer group. · BGP considers AS_PATH during best route selection. · BGP updates carry private AS numbers. |
This task involves resetting MBGP connections and configuring load balancing.
You must configure BGP basic functions before configuring this task.
Configuring MBGP soft reset
After modifying a route selection policy, you have to reset MBGP connections to make it take effect.
The current MBGP implementation supports the route-refresh feature that enables dynamic route refresh without terminating MBGP connections.
However, if a peer not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command to save all routes from the peer. When the routing policy is changed, the system will update the MBGP routing table and apply the new policy.
Soft reset through route-refresh
If the peer is enabled with route-refresh, when the MBGP route selection policy is modified on a router, the router advertises a route-refresh message to its MBGP peers, which resend their routing information to the router after receiving the message. Therefore, the local router can perform dynamic route update and apply the new policy without terminating MBGP connections.
To configure MBGP soft reset through route-refresh:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
3. Enable BGP route refresh for a peer/peer group. |
peer { group-name | ip-address } capability-advertise route-refresh |
Optional Enabled by default |
Perform a manual soft reset
If the peer does not support route-refresh, you can use the peer keep-all-routes command to save all the route updates from the peer, and then use the refresh bgp ipv4 multicast command to soft-reset MBGP connections to refresh the MBGP routing table and apply the new policy without terminating MBGP connections.
To configure MBGP manual soft reset
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
3. Disable BGP route-refresh and multi-protocol extensions for a peer/peer group. |
peer { group-name | ip-address } capability-advertise conventional |
N/A |
5. Keep all original routes from a peer/peer group regardless of whether they pass the inbound filtering policies. |
peer { group-name | ip-address } keep-all-routes |
Not kept by default |
6. Return to user view. |
return |
N/A |
7. Soft-reset MBGP connections manually. |
refresh bgp ipv4 multicast { all | ip-address | group group-name | external | internal } { export | import } |
Optional |
The MBGP Outbound Router Filter (ORF) feature enables an MBGP speaker to send a set of ORFs to its MBGP peer through route-refresh messages. The peer then applies the ORFs, in addition to its local routing policies (if any), to filter updates to the MBGP speaker, thus reducing the number of exchanged update messages and saving network resources.
After you enable the ORF capability, the local MBGP router negotiates the ORF capability with the MBGP peer through Open messages. That is, the MBGP router determines whether to carry ORF information in messages, and if yes, whether to carry non-standard ORF information in the packets. After completing the negotiation process and establishing the neighboring relationship, the MBGP router and its MBGP peer can exchange ORF information through specific route-refresh messages.
For the parameters configured on both sides for ORF capability negotiation, see Table 1.
To enable the MBGP ORF capability:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
Optional. Enabled by default. If this feature is not enabled, you need to configure this command. For more information about the command, see Layer 3—IP Routing Command Reference. |
4. Enable the non-standard BGP ORF capability for a BGP peer/peer group. |
peer { group-name | ipv6-address } capability-advertise orf non-standard |
Optional. By default, standard BGP ORF capability defined in RFC 5291 and RFC 5292 is supported. If this feature is not enabled, you need to configure this command. For more information about the command, see Layer 3—IP Routing Command Reference. |
5. Enter MBGP address family view. |
N/A |
6. Enable the ORF IP prefix negotiation capability for an MBGP peer/peer group. |
peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send } |
Optional. Not enabled by default. |
Table 1 Description of the both, send, and receive parameters and the negotiation result
Local parameter |
Peer parameter |
Negotiation result |
send |
· receive · both |
The ORF sending capability is enabled locally and the ORF receiving capability is enabled on the peer. |
receive |
· send · both |
The ORF receiving capability is enabled locally and the ORF sending capability is enabled on the peer. |
both |
both |
Both the ORF sending and receiving capabilities are enabled locally and on the peer, respectively. |
To configure the number of MBGP routes for load balancing:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure the maximum number of MBGP routes for load balancing. |
balance number |
Before you configure this task, you need to make peering nodes accessible to each other at the network layer.
To configure an IPv4 MBGP peer group:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
3. Create a BGP peer group. |
group group-name [ external | internal ] |
Not created by default. |
4. Add a peer into the peer group. |
peer ip-address group group-name [ as-number as-number ] |
By default, no peer is added. |
5. Enter IPv4 MBGP address family view. |
N/A |
6. Enable the IPv4 unicast peer group. |
peer group-name enable |
N/A |
7. Add an IPv4 MBGP peer to the peer group. |
peer ip-address group group-name |
Not configured by default. |
CAUTION: · To configure an MBGP peer group, you must enable the corresponding IPv4 BGP unicast peer group in IPv4 MBGP address family view. · Before adding an MBGP peer to an MBGP peer group, you must add the corresponding IPv4 unicast peer to the IPv4 BGP peer group. |
Configuring MBGP community
The community attribute can be advertised between MBGP peers in different ASs. Routers in the same community share the same policy.
You can reference a routing policy to modify the community attribute for routes sent to a peer. In addition, you can define extended community attributes as needed.
To configure MBGP community:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Advertise the community attribute to an MBGP peer/peer group. |
peer/peer group: ·
Advertise the extended community attribute to
an MBGP peer/peer group: |
5. Apply a routing policy to routes advertised to an MBGP peer/peer group. |
peer { group-name | ip-address } route-policy route-policy-name export |
CAUTION: · When you configure MBGP community, you must reference a routing policy to define the specific community attributes, and apply the routing policy for route advertisement. · For routing policy configuration, see Layer 3—IP Routing Configuration Guide. |
To guarantee the connectivity between multicast IBGP peers in an AS, you need to make them fully meshed. But this becomes unpractical when large numbers of multicast IBGP peers exist. Configuring route reflectors can solve this problem.
To configure an MBGP route reflector:
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number |
N/A |
N/A |
4. Configure the router as a route reflector and specify an MBGP peer/peer group as its client. |
peer { group-name | peer-address } reflect-client |
5. Enable route reflection between clients. |
reflect between-clients |
Optional. Enabled by default. |
6. Configure the cluster ID of the route reflector. |
reflector cluster-id cluster-id |
Optional. By default, a route reflector uses its router ID as the cluster ID. |
CAUTION: · In general, it is not required that clients of a route reflector be fully meshed. The route reflector forwards routing information between clients. If clients are fully meshed, you can disable route reflection between clients to reduce routing costs. · In general, a cluster has only one route reflector, and the router ID of the route reflector identifies the cluster. You can configure multiple route reflectors to improve network stability. In this case, you need to specify the same cluster ID for these route reflectors to avoid routing loops. |
Displaying MBGP
Task |
Command |
Remarks |
Display the IPv4 MBGP routing table. |
display ip multicast routing-table [ verbose] [ | { begin | exclude | include } regular-expression ] |
Available in any view |
Display the IPv4 MBGP routing information matching the specified destination IP address. |
display ip multicast routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ] |
Display MBGP peer group information. |
display bgp multicast group [ group-name ] [ | { begin | exclude | include } regular-expression ] |
Display the advertised networks. |
display bgp multicast network [ | { begin | exclude | include } regular-expression ] |
Display AS path information. |
display bgp multicast paths [ as-regular-expression | | { begin | exclude | include } regular-expression ] |
Display MBGP peer/peer group information. |
display bgp multicast peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ] |
Display the prefix entries in the ORF information from the specified BGP peer. |
display bgp multicast peer ip-address received ip-prefix [ | { begin | exclude | include } regular-expression ] |
Display MBGP routing information. |
display bgp multicast routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ] [ | { begin | exclude | include } regular-expression ] |
Display MBGP routing information matching the AS path ACL. |
display bgp multicast routing-table as-path-acl as-path-acl-number [ | { begin | exclude | include } regular-expression ] |
Display MBGP CIDR routing information. |
display bgp multicast routing-table cidr [ | { begin | exclude | include } regular-expression ] |
Display MBGP routing information matching the specified BGP community. |
display bgp multicast routing-table community[ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] [ | { begin | exclude | include } regular-expression ] |
Display MBGP routing information matching an MBGP community list. |
display bgp multicast routing-table community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> [ | { begin | exclude | include } regular-expression ] |
Display MBGP dampened routing information. |
display bgp multicast routing-table dampened [ | { begin | exclude | include } regular-expression ] |
Display MBGP dampening parameter information. |
display bgp multicast routing-table dampening parameter [ | { begin | exclude | include } regular-expression ] |
Display MBGP routing information originating from different ASs. |
display bgp multicast routing-table different-origin-as [ | { begin | exclude | include } regular-expression ] |
Display IPv4 MBGP routing flap statistics. |
display bgp multicast routing-table flap-info [ regular-expression as-regular-expression | [ as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ] [ | { begin | exclude | include } regular-expression ] ] |
Display IPv4 MBGP routing information sent to or received from an MBGP peer. |
display bgp multicast routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ] [ | { begin | exclude | include } regular-expression ] |
Display IPv4 MBGP routing information matching an AS regular expression. |
display bgp multicast routing-table regular-expression as-regular-expression |
Display IPv4 MBGP routing statistics. |
display bgp multicast routing-table statistic [ | { begin | exclude | include } regular-expression ] |
Resetting MBGP connections
Task |
Command |
Remarks |
Reset specified MBGP connections. |
reset bgp ipv4 multicast { all | as-number | ip-address | group group-name | external | internal } |
Available in user view |
Clearing MBGP information
Task |
Command |
Remarks |
Clear dampened routing information and release suppressed routes. |
reset bgp ipv4 multicast dampening [ ip-address [ mask | mask-length ] ] |
Clear MBGP route flap statistics. |
reset bgp ipv4 multicast flap-info [ regexp as-path-regexp | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ] |
MBGP configuration example
Network requirements
As shown in Figure 1:
PIM-SM 1 is in AS 100 and PIM-SM 2 is in AS 200. OSPF is the IGP in the two ASs, and MBGP runs between the two ASs to exchange multicast route information. The multicast source belongs to PIM-SM 1, and the receiver belongs to PIM-SM 2. Configure the respective Loopback 0 of Router A and Router B as the C-BSR and C-RP of the respective PIM-SM domains.
Set up an MSDP peer relationship between Router A and Router B through MBGP.
Device |
IP address |
Device |
IP address |
Source |
N/A |
10.110.1.100/24 |
Router C |
GE3/1/1 |
10.110.2.1/24 |
Router A |
GE3/1/1 |
10.110.1.1/24 |
S4/1/9/1:1 |
192.168.4.1/24 |
POS5/1/1 |
192.168.1.1/24 |
S4/1/9/1:2 |
192.168.2.2/24 |
Loop0 |
1.1.1.1/32 |
Loop0 |
3.3.3.3/32 |
Router B |
POS5/1/1 |
192.168.1.2/24 |
Router D |
S4/1/9/1:1 |
192.168.3.2/24 |
S4/1/9/1:1 |
192.168.2.1/24 |
S4/1/9/1:2 |
192.168.4.2/24 |
S4/1/9/1:2 |
192.168.3.1/24 |
Loop0 |
4.4.4.4/32 |
Loop0 |
2.2.2.2/32 |
1. Configure IP addresses for router interfaces as shown in Figure 1. (Details not shown)
2. Configure OSPF. (Details not shown)
3. Enable IP multicast routing, PIM-SM and IGMP, and configure a PIM-SM domain border:
# Enable IP multicast routing on Router A, and enable PIM-SM on each interface.
[RouterA] multicast routing-enable
[RouterA] interface GigabitEthernet 3/1/1
[RouterA-GigabitEthernet3/1/1] pim sm
[RouterA-GigabitEthernet3/1/1] quit
[RouterA] interface pos 5/1/1
[RouterA-Pos5/1/1] pim sm
[RouterA-Pos5/1/1] quit
The configuration on Router B and Router D is similar to the configuration on Router A.
# Enable IP multicast routing on Router C, enable PIM-SM on each interface, and enable IGMP on the host-side interface GigabitEthernet 3/1/1.
<RouterC> system-view
[RouterC] multicast routing-enable
[RouterC] interface serial 4/1/9/1:1
[RouterC-Serial4/1/9/1:1] pim sm
[RouterC-Serial4/1/9/1:1] quit
[RouterC] interface serial 4/1/9/1:2
[RouterC-Serial4/1/9/1:2] pim sm
[RouterC-Serial4/1/9/1:2] quit
[RouterC] interface GigabitEthernet 3/1/1
[RouterC-GigabitEthernet3/1/1] pim sm
[RouterC-GigabitEthernet3/1/1] igmp enable
[RouterC-GigabitEthernet3/1/1] quit
# Configure a PIM domain border on Router A.
[RouterA-Pos5/1/1] pim bsr-boundary
# Configure a PIM domain border on Router B.
[RouterB] interface pos 5/1/1
[RouterB-Pos5/1/1] pim bsr-boundary
[RouterB-Pos5/1/1] quit
4. Configure C-BSRs and C-RPs:
# Configure the C-BSR and C-RP on Router A.
[RouterA-LoopBack0] ip address 1.1.1.1 32
[RouterA-LoopBack0] pim sm
[RouterA-LoopBack0] quit
[RouterA] pim
[RouterA-pim] c-bsr loopback 0
[RouterA-pim] c-rp loopback 0
[RouterA-pim] quit
# Configure the C-BSR and C-RP on Router B.
[RouterB-LoopBack0] ip address 2.2.2.2 32
[RouterB-LoopBack0] pim sm
[RouterB-LoopBack0] quit
[RouterB] pim
[RouterB-pim] c-bsr loopback 0
[RouterB-pim] c-rp loopback 0
[RouterB-pim] quit
5. Configure BGP, specify the MBGP peer and enable direct route redistribution:
# On Router A, configure the MBGP peer and enable direct route redistribution.
[RouterA] bgp 100
[RouterA-bgp] router-id 1.1.1.1
[RouterA-bgp] peer 192.168.1.2 as-number 200
[RouterA-bgp] import-route direct
[RouterA-bgp] ipv4-family multicast
[RouterA-bgp-af-mul] peer 192.168.1.2 enable
[RouterA-bgp-af-mul] import-route direct
[RouterA-bgp-af-mul] quit
[RouterA-bgp] quit
# On Router B, configure the MBGP peer and enable route redistribution from OSPF.
[RouterB] bgp 200
[RouterB-bgp] router-id 2.2.2.2
[RouterB-bgp] peer 192.168.1.1 as-number 100
[RouterB-bgp] import-route ospf 1
[RouterB-bgp] ipv4-family multicast
[RouterB-bgp-af-mul] peer 192.168.1.1 enable
[RouterB-bgp-af-mul] import-route ospf 1
[RouterB-bgp-af-mul] quit
[RouterB-bgp] quit
6. Configure MSDP peer:
# Specify the MSDP peer on Router A.
[RouterA] msdp
[RouterA-msdp] peer 192.168.1.2 connect-interface pos 5/1/1
[RouterA-msdp] quit
# Specify the MSDP peer on Router B.
[RouterB] msdp
[RouterB-msdp] peer 192.168.1.1 connect-interface pos 5/1/1
[RouterB-msdp] quit
7. Verify the configuration:
You can use the display bgp multicast peer command to display MBGP peers on each router. For example,
# Display MBGP peers on Router B.
[RouterB] display bgp multicast peer
BGP local router ID : 2.2.2.2
Local AS number : 200
Total number of peers : 1 Peers in established state : 1
192.168.1.1 100 56 56 0 0 00:40:54 Established
You can use the display msdp brief command to display MSDP peers on a router. For example,
Display brief information about MSDP peers on Router B.
[RouterB] display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
Configured Up Listen Connect Shutdown Down
1 1 0 0 0 0
Peer's Address State Up/Down time AS SA Count Reset Count
192.168.1.1 Up 00:07:17 100 1 0
