06-Layer 3 - IP Routing Configuration Guide
HomeSupportRoutersH3C SR8800 Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10306-Layer 3 - IP Routing Configuration Guide
11-IPv6 IS-IS Configuration
11-IPv6 IS-IS Configuration 162.25 KB
·       IPv6 IS-IS supports all IPv4 IS-IS features, but advertises IPv6 routing information. This document describes only IPv6 IS-IS exclusive configuration tasks. For other configuration tasks, see the chapter “Configuring IS-IS.”
·       The term router in this document refers to both routers and Layer 3 switches.
Introduction to IPv6 IS-IS
The IS-IS routing protocol (Intermediate System-to-Intermediate System intra-domain routing information exchange protocol) supports multiple network protocols, including IPv6. The international engineer task force (IETF) defines two type-length-values (TLVs) and a new network layer protocol identifier (NLPID) to enable IS-IS to support IPv6.
TLV is a variable-length field in the link state PDU or link state packet (LSP). The two TLVs are:
·           IPv6 Reachability—Defines the prefix, metric of routing information to indicate network reachability, and has a type value of 236 (0xEC).
·           IPv6 Interface Address—Same as the “IP Interface Address” TLV in IPv4 ISIS, except that the 32-bit IPv4 address is translated to the 128-bit IPv6 address.
The NLPID is an 8-bit field that identifies which network layer protocol is supported. For IPv6, the NLPID is 142 (0x8E), which must be carried in hello packets sent by a router that supports IPv6 IS-IS.
For information about IS-IS, see the chapter “Configuring IS-IS.”
Configuring IPv6 IS-IS basic functions
You can implement IPv6 inter-networking through configuring IPv6 IS-IS in IPv6 network environment.
Configuration prerequisites
Before the configuration, complete the following tasks:
·           Enable IPv6 globally.
·           Configure IP addresses for interfaces, and make sure that all neighboring nodes are reachable to each other.
·           Enable IS-IS.
Configuration procedure
To configure the basic functions of IPv6 IS-IS:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable an IS-IS process and enter IS-IS view.
Not enabled by default
3.     Configure the network entity title for the IS-IS process.
network-entity net
Not configured by default
4.     Enable IPv6 for the IS-IS process.
ipv6 enable
Disabled by default
5.     Return to system view.
N/A
6.     Enter interface view.
N/A
7.     Enable IPv6 for an IS-IS process on the interface.
isis ipv6 enable [ process-id ]
Disabled by default
Configuring IPv6 IS-IS routing information control
Complete the IPv6 IS-IS basic function configuration before configuring this task.
To configure IPv6 IS-IS routing information control:
Step
Remarks
N/A
2.     Enter IS-IS view.
N/A
3.     Define the priority for IPv6 IS-IS routes.
ipv6 preference { route-policy route-policy-name | preference } *
Optional.
15 by default.
4.     Configure an IPv6 IS-IS summary route.
ipv6 summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
Optional.
Not configured by default.
5.     Generate an IPv6 IS-IS default route.
ipv6 default-route-advertise [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ] *
Optional.
By default, no IPv6 default route is defined.
6.     Configure IPv6 IS-IS to filter incoming routes.
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
Optional.
No filtering policy is defined by default.
7.     Configure IPv6 IS-IS to redistribute routes from another routing protocol.
ipv6 import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
Optional.
8.     Configure the maximum number of redistributed Level 1/Level 2 IPv6 routes.
ipv6 import-route limit number
Optional.
9.     Configure the filtering of outgoing redistributed routes.
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Optional.
10.   Enable route leaking.
ipv6 import-route isisv6 level-2 into level-1 [ filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } | tag tag ] *
Optional.
Not enabled by default.
11.   Specify the maximum number of equal-cost load balanced routes.
ipv6 maximum load-balancing number
Optional.
By default, load balancing is disabled.
·       The ipv6 filter-policy export command is usually used in combination with the ipv6 import-route command. If no protocol is specified for the ipv6 filter-policy export command, routes redistributed from all routing protocols are filtered before advertisement. If a protocol is specified, only routes redistributed from the routing protocol are filtered for advertisement.
·       For information about ACL, see ACL and QoS Configuration Guide.
·       For information about routing policy and IPv6 prefix list, see the chapter “Configuring routing policies.”
Configuring BFD for IPv6 IS-IS
Bidirectional forwarding detection (BFD) provides a mechanism to quickly detect the connectivity of links between IPv6 IS-IS neighbors, thus to improve the convergence speed of IPv6 IS-IS.
To configure BFD for IPv6 IS-IS:
Step
Remarks
N/A
isis [ process-id ]
N/A
network-entity net
ipv6 enable
Disabled by default
N/A
N/A
Disabled by default
8.     Enable BFD on the interface.
isis ipv6 bfd enable
For more information about BFD, see High Availability Configuration Guide.
Displaying and maintaining IPv6 IS-IS
Remarks
Display brief IPv6 IS-IS information.
display isis brief [ | { begin | exclude | include } regular-expression ]
Available in any view
Display the status of the debug switches.
display isis debug-switches { process-id | vpn-instance vpn-instance-name } [ | { begin | exclude | include } regular-expression ]
Display IS-IS enabled interface information.
display isis interface [ statistics | [ interface-type interface-number ] [ verbose ] ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display LSDB information.
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ [ lsp-id lsp-id | lsp-name lspname | local ] | verbose ] * ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS mesh group information.
display isis mesh-group [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display the mapping table between the host name and system ID.
display isis name-table [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IPv6 IS-IS routing information.
display isis route ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display SPF log information.
display isis spf-log [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of the IS-IS process.
display isis statistics [ level-1 | level-1-2 | level-2 ] [ process-id |  vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Clear all IS-IS data structure information.
reset isis all [ process-id | vpn-instance vpn-instance-name ]
Available in user view
Clear the IS-IS data information of a neighbor.
reset isis peer system-id [ process-id | vpn vpn-instance-name ]
IPv6 IS-IS configuration examples
IPv6 IS-IS basic configuration example
Network requirements
As shown in Figure 1, Router A, Router B, Router C and Router D, all enabled with IPv6, reside in the same autonomous system. Configure IPv6 IS-IS on the routers to make them reachable to each other.
Router A and Router B are Level-1 routers, Router D is a Level-2 router, and Router C is a Level-1-2 router. Router A, Router B, and Router C belong to area 10, and Router D is in area 20.
Figure 1 Network diagram
1.      Configure IPv6 addresses for interfaces. (Details not shown)
2.      Configure IPv6 IS-IS:
# Configure Router A.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.0000.0000.0001.00
[RouterA-isis-1] ipv6 enable
[RouterA-isis-1] quit
[RouterA] interface POS 2/1/1
[RouterA-POS2/1/1] isis ipv6 enable 1
[RouterA-POS2/1/1] quit
# Configure Router B.
<RouterB> system-view
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.0000.0000.0002.00
[RouterB-isis-1] ipv6 enable
[RouterB-isis-1] quit
[RouterB] interface POS 2/1/1
[RouterB-POS2/1/1] isis ipv6 enable 1
[RouterB-POS2/1/1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.0000.0000.0003.00
[RouterC-isis-1] ipv6 enable
[RouterC-isis-1] quit
[RouterC] interface POS 2/1/1
[RouterC-POS2/1/1] isis ipv6 enable 1
[RouterC-POS2/1/1] quit
[RouterC] interface POS 2/1/2
[RouterC-POS2/1/2] isis ipv6 enable 1
[RouterC-POS2/1/2] quit
[RouterC] interface POS 2/1/3
[RouterC-POS2/1/3] isis ipv6 enable 1
[RouterC-POS2/1/3] quit
# Configure Router D.
<RouterD> system-view
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.0000.0000.0004.00
[RouterD-isis-1] ipv6 enable
[RouterD-isis-1] quit
[RouterD] interface POS 2/1/1
[RouterD-POS2/1/1] isis ipv6 enable 1
[RouterD-POS2/1/1] quit
[RouterD] interface GigabitEthernet 1/1/1
[RouterD-GigabitEthernet1/1/1] isis ipv6 enable 1
[RouterD-GigabitEthernet1/1/1] quit
3.      Verify the configuration:
# Display the IPv6 IS-IS routing table of Router A.
[RouterA] display isis route ipv6
                         Route information for ISIS(1)
                     ISIS(1) IPv6 Level-1 Forwarding Table
 Destination: ::                                      PrefixLen: 0
 Flag       : R/-/-                                   Cost     : 10
 Next Hop   : FE80::200:FF:FE0F:4                     Interface: S2/1/1
 Destination: 2001:1::                                PrefixLen: 64
 Flag       : D/L/-                                   Cost     : 10
 Next Hop   : Direct                                  Interface: S2/1/1
 Destination: 2001:2::                                PrefixLen: 64
 Flag       : R/-/-                                   Cost     : 20
 Destination: 2001:3::                                PrefixLen: 64
      Flags: D-Direct, R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
# Display the IPv6 IS-IS routing table of Router B.
[RouterB] display isis route ipv6
# Display the IPv6 IS-IS routing table of Router C.
[RouterC] display isis route ipv6
 Next Hop   : Direct                                  Interface: S2/1/2
 Next Hop   : Direct                                  Interface: S2/1/3
                     ISIS(1) IPv6 Level-2 Forwarding Table
 Destination: 2001:4::1                               PrefixLen: 128
 Next Hop   : FE80::20F:E2FF:FE3E:FA3D                Interface: S2/1/3
# Display the IPv6 IS-IS routing table of Router D.
[RouterD] display isis route ipv6
 Flag       : D/L/-                                   Cost     : 0
 Next Hop   : Direct                                  Interface: GE1/1/1
Configuring BFD for IS-IS
·           As shown in Figure 2, configure IPv6 IS-IS on Router A, Router B and Router C and configure BFD over the link Router A<—>L2 Switch<—>Router B.
·           After the link between Router B and the Layer-2 switch fails, BFD can quickly detect the failure and notify IPv6 IS-IS of the failure. Then Router A and Router B communicate through Router C.
Figure 2 Network diagram
Device
IPv6 address
Device
IPv6 address
Router A
GE3/1/1
2001::1/64
Router B
GE3/1/1
2001::2/64
GE3/1/2
2001:2::1/64
GE3/1/2
2001:3::2/64
Router C
GE3/1/1
2001:2::2/64
GE3/1/2
2001:3::1/64
1.      Configure IP addresses for interfaces. (Details not shown)
[RouterA] ipv6
[RouterA] isis 1
[RouterA] interface GigabitEthernet 3/1/1
[RouterA-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterA-GigabitEthernet3/1/1] quit
[RouterA] interface GigabitEthernet 3/1/2
[RouterA-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterA-GigabitEthernet3/1/2] quit
[RouterA] ipv6
[RouterB] isis 1
[RouterB] interface GigabitEthernet 3/1/1
[RouterB-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterB-GigabitEthernet3/1/1] quit
[RouterB] interface GigabitEthernet 3/1/2
[RouterB-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterB-GigabitEthernet3/1/2] quit
[RouterA] ipv6
[RouterC] isis 1
[RouterC] interface GigabitEthernet 3/1/1
[RouterC-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterC-GigabitEthernet3/1/1] quit
[RouterC] interface GigabitEthernet 3/1/2
[RouterC-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterC-GigabitEthernet3/1/2] quit
3.      Configure BFD functions:
# Enable BFD on Router A and configure BFD parameters.
[RouterA] bfd session init-mode active
[RouterA-GigabitEthernet3/1/1] isis ipv6 bfd enable
[RouterA-GigabitEthernet3/1/1] bfd min-transmit-interval 500
[RouterA-GigabitEthernet3/1/1] bfd min-receive-interval 500
[RouterA-GigabitEthernet3/1/1] bfd detect-multiplier 7
[RouterA-GigabitEthernet3/1/1] return
# Enable BFD on Router B and configure BFD parameters.
[RouterB] bfd session init-mode active
[RouterB-GigabitEthernet3/1/1] isis ipv6 bfd enable
[RouterB-GigabitEthernet3/1/1] bfd min-transmit-interval 500
[RouterB-GigabitEthernet3/1/1] bfd min-receive-interval 500
[RouterB-GigabitEthernet3/1/1] bfd detect-multiplier 6
4.      Verify configuration:
The following operations are performed on Router A. Operations for Router B are similar. (Details not shown)
# Display the BFD information of Router A.
<RouterA> display bfd session
Total Session Num: 1            Init Mode: Active
 IPv6 Session Working Under Ctrl Mode:
     Local Discr: 1441                Remote Discr: 1450
       Source IP: FE80::20F:FF:FE00:1202 (link-local address of GigabitEthernet3/1/1 on Router A)
  Destination IP: FE80::20F:FF:FE00:1200 (link-local address of GigabitEthernet3/1/1 on Router B)
   Session State: Up                     Interface: GE3/1/1
       Hold Time:    /
# Display route 2001:4::0/64 on Router A, and you can see that Router A and Router B communicate through the Layer 2 switch.
<RouterA> display ipv6 routing-table 2001:4::0 64 verbose
Routing Table :
Summary Count : 2
 Destination  : 2001:4::0                               PrefixLength : 64
 NextHop      : 2001::2                                 Preference   : 15
 RelayNextHop : ::                                      Tag          : 0H
 Neighbor     : ::                                      ProcessID    : 0
 Interface    : GigabitEthernet3/1/1                    Protocol     : ISISv6
 State        : Active Adv                              Cost         : 20
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 4538sec
 NextHop      : 2001:2::2                               Preference   : 15
 Interface    : GigabitEthernet3/1/2                    Protocol     : ISISv6
 State        : Invalid Adv                             Cost         : 30
 Age          : 4515sec
# Enable BFD debugging on Router A.
<RouterA> debugging bfd scm
<RouterA> debugging bfd event
<RouterA> debugging isis event bfd
<RouterA> terminal debugging
# When the link between Router B and the Layer-2 switch fails, BFD can quickly detect the failure.
#Aug  8 14:54:05:362 2009 RouterA IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983041 is Down, ifAdminStatus is 1, ifOperStatus is 2
#Aug  8 14:54:05:363 2009 RouterA ISIS/4/ADJ_CHANGE:TrapID(1.3.6.1.2.1.138.0.17<isisAdjacencyChange>), ISIS Level-2 Adjencency IN Circuit-983041 State Change.
#Aug  8 14:54:05:364 2008 RouterA ISIS/4/ADJ_CHANGE:TrapID(1.3.6.1.2.1.138.0.17<isisAdjacencyChange>), ISIS Level-1 Adjencency IN Circuit-983041 State Change.
%Aug  8 14:54:05:365 2009 RouterA IFNET/4/LINK UPDOWN: GigabitEthernet3/1/1: link status is DOWN
%Aug  8 14:54:05:366 2008 RouterA IFNET/4/UPDOWN: Line protocol on the interface GigabitEthernet3/1/1 is DOWN
%Aug  8 14:54:05:367 2009 RouterA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (GE3/1/1) DOWN, Level-2 Circuit Down.
%Aug  8 14:54:05:367 2009 RouterA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (GE3/1/1) DOWN, Level-2 Adjacency clear.
%Aug  8 14:54:05:368 2009 RouterA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (GE3/1/1) DOWN, Level-1 Circuit Down.
%Aug  8 14:54:05:369 2009 RouterA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (GE3/1/1) DOWN, Level-1 Adjacency clear.
*Aug  8 14:54:05:369 2009 RouterA ISIS/6/ISIS: ISIS-1-BFD: Recieve BFD session down . Type 0. DstIPAddr: FE80::20F:FF:FE00:1200 , SrcIPAddr: FE80::20F:FF:FE00:1202
*Aug  8 14:54:05:370 2009 RouterA ISIS/6/ISIS: ISIS-1-BFD: Success to send msg. Msg type 1 delete session. IfPhyIndex: 5 ,DstIPAddr: FE80::20F:FF:FE00:1200 , SrcIPAddr: FE80::20F:FF:FE00:1202 . NeighborType: Level-1.
# Display the BFD information of Router A. You can see that Router A has removed its neighbor relationship with Router B and therefore no information is output.
# Display route 2001:4::0/64 on Router A, and you can see that Router A and Router B communicate through Router C.
Routing Table :
Summary Count : 1
 Age          : 4610sec
