H3C S7500E Series Ethernet Switches Operation Manual(Release 6100 series V1.01)
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E Series Ethernet Switches Operation Manual(Release 6100 series V1.01)
Title Size Downloads
22-Port Mirroring Configuration.pdf 140.24 KB
22-Port Mirroring Configuration 140.24 KB
Chapter 1  Port Mirroring Configuration
When configuring port mirroring, go to these sections for information you are interested in:
l           Introduction to Port Mirroring
l           Configuring Local Port Mirroring
l           Configuring Remote Port Mirroring
l           Displaying and Maintaining Port Mirroring
l           Port Mirroring Configuration Examples
1.1  Introduction to Port Mirroring
Port mirroring allows you to duplicate the packets passing specified ports to the destination mirroring port. As destination mirroring ports usually have data monitoring devices connected to them, you can analyze the packets duplicated to the destination mirroring port on these devices so as to monitor and troubleshoot the network.
Figure 1-1 A port mirroring implementation
1.1.1  Classification of Port Mirroring
There are two kinds of port mirroring: local port mirroring and remote port mirroring.
l           Local port mirroring copies packets passing through one or more ports (known as source ports) of a device to the monitor port (also destination port) for analysis and monitoring purpose. In this case, the source ports and the destination port are located on the same device.
l           Remote port mirroring implements port mirroring between multiple devices. That is, the source ports and the destination port can be located on different devices in a network. Currently, remote port mirroring can only be implemented on Layer 2.
1.1.2  Implementing Port Mirroring
Port mirroring is implemented through port mirroring groups, which fall into these three categories: local port mirroring group, remote source port mirroring group, and remote destination port mirroring group. Two port mirroring implementation modes are introduced in the following section.
I. Local port mirroring
Local port mirroring is implemented by local port mirroring group.
In this mode, the source ports and the destination port are in the same local port mirroring group. Packets passing through the source ports are duplicated and then are forwarded to the destination port.
II. Remote port mirroring
Remote port mirroring is achieved through the cooperation of remote source port mirroring group and remote destination port mirroring group.
Figure 1-2 illustrates a remote port mirroring implementation.
Figure 1-2 A remote mirroring implementation
The devices in Figure 1-2 function as follows:
l           Source device
Source device contains source mirroring ports, and remote source port mirroring groups are created on source devices. A source device duplicates the packets passing the source ports on it and sends them to the outbound port. The packets are then broadcast in the remote mirroring VLAN and are received by the intermediate device or destination device.
l           Intermediate device
Intermediate devices are used to connect source devices and destination devices. An intermediate device forwards the mirrored packets to the next intermediate device or the destination device. If the source device is directly connected to the destination device, no intermediate device is needed. In a remote mirroring VLAN, the source devices and the destination device need to be able to communicate with one another on Layer 2.
l           Destination device
Destination device contains destination mirroring port, and remote destination port mirroring groups are created on destination devices. Upon receiving a mirrored packet, the destination device checks to see if the VLAN ID of the received packet is the same as that of the remote mirroring VLAN of the remote destination port mirroring group. If yes, the destination device forwards the packet to the monitoring device through the destination mirroring port.
1.1.3  Other Functions Supported by Port Mirroring
Port mirroring group supports inter-board mirroring, which means that the destination port and source ports can be located on different boards of a device.
In addition, in a port mirroring group, a destination port can monitor multiple source ports simultaneously in the mirroring group.
1.2  Configuring Local Port Mirroring
Follow these steps to configure local port mirroring:
To do…
Use the command…
Remarks
Enter system view
Create a local mirroring group
mirroring-group group-id local
Required
Add ports to the port mirroring group as source ports
In system view
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
Use either approach.
You can add ports to a port mirroring group as source ports in either system view or interface view.
In system view, you can add multiple ports to a port mirroring group at one time. While in interface view, you can only add the current port to a port mirroring group.
In interface view
[ mirroring-group group-id ] mirroring-port { both | inbound | outbound }
Add a port to the mirroring group as the destination port
In system view
mirroring-group group-id monitor-port monitor-port-id
You can add a destination port to a port mirroring group in either system view or interface view. They achieve the same purpose.
In interface view
[ mirroring-group group-id ] monitor-port
&  Note:
l      A local mirroring group is effective only when it has both source ports and the destination port configured.
l      It is not recommended to enable STP, RSTP or MSTP on the destination port; otherwise, the mirroring function may be affected.
l      Do not use the destination mirroring port for any purpose other than port mirroring.
l      The source ports and the destination port cannot be the member ports of the current mirroring group.
l      Before adding the destination port for a port mirroring group, make sure the port mirroring group exists. A mirroring group can have only one destination port.
1.3  Configuring Remote Port Mirroring
1.3.1  Configuring a Remote Source Mirroring Group
Follow these steps to configure a remote port mirroring group
To do…
Use the command…
Remarks
Enter system view
Create a remote source mirroring group
mirroring-group group-id remote-source
Required
Add ports to the mirroring group as source ports
In system view
You can add ports to a source port mirroring group in either system view or interface view. They achieve the same purpose.
In interface view
Add a port to the mirroring group as the outbound mirroring port
In system view
mirroring-group group-id  monitor-egress monitor-egress-port-id
You can add ports to a source mirroring group in either system view or interface view. They achieve the same purpose.
In interface view
Configure the remote port mirroring VLAN for the mirroring group
mirroring-group group-id remote-probe vlan rprobe-vlan-id
Required
&  Note:
l      All ports in a remote mirroring group belong to the same device. A remote source mirroring group can have only one outbound mirroring port.
l      The outbound mirroring port cannot be a member port of the current mirroring group.
l      It is not recommended to add the source ports to a remote VLAN, which can be used for remote mirroring only.
l      It is not recommended to configure STP, RSTP, MSTP, 802.1x, IGMP Snooping, static ARP and MAC address learning on the outbound mirroring port; otherwise, the mirroring function may be affected.
l      Only existing static VLANs can be configured as remote port mirroring VLANs. To remove a VLAN operating as a remote port mirroring VLAN, you need to restore it to a normal VLAN first. A remote port mirroring group gets invalid if the corresponding remote port mirroring VLAN is removed.
l      A port can belong to only one port mirroring group. A VLAN can be the remote port mirroring VLAN of only one port mirroring group.
1.3.2  Configuring a Remote Destination Port Mirroring Group
Follow these steps to configure a remote destination port mirroring group:
To do…
Use the command…
Remarks
Enter system view
Create a remote destination port mirroring group
mirroring-group group-id remote-destination
Required
Configure the remote port mirroring VLAN for the port mirroring group
Required
Add a port to the port mirroring group as the destination port
In system view
You can add a port to a remote port mirroring group as the destination port in either system view or interface view. They achieve the same purpose.
In interface view
Enter destination interface view
Add the port to the remote port mirroring VLAN
The port is an access port
port access vlan rprobe-vlan-id
Perform one of these three operations according to the port type.
The port is a trunk port
port trunk permit vlan rprobe-vlan-id
The port is a hybrid port
port hybrid vlan rprobe-vlan-id { tagged | untagged }
&  Note:
l      The remote destination mirroring port cannot be a member port of the current mirroring group.
l      The remote destination mirroring port can be an access, trunk, or hybrid port. It must be assigned to the remote mirroring VLAN.
l      Do not enable STP, RSTP or MSTP on the remote destination mirroring port. Otherwise, the mirroring function may be affected.
l      Do not use the remote destination mirroring port for any purpose other than port mirroring.
l      Use a remote port mirroring VLAN for remote port mirroring only.
1.4  Displaying and Maintaining Port Mirroring
To do…
Use the command…
Remarks
Display the configuration of a port mirroring group
display mirroring-group { group-id | all | local | remote-destination | remote-source }
Available in any view
1.5  Port Mirroring Configuration Examples
1.5.1  Local Port Mirroring Configuration Example
I. Network requirements
The departments of a company connect to each other through Ethernet switches:
l           Research and Development (R&D) department is connected to Switch C through Ethernet 2/0/1.
l           Marketing department is connected to Switch C through Ethernet 2/0/2.
l           Data monitoring device is connected to Switch C through Ethernet 2/0/3
The administrator wants to monitor the packets received on and sent from the R&D department and the marketing department through the data monitoring device.
Use the local port mirroring function to meet the requirement. Perform the following configurations on Switch C.
l           Configure Ethernet 2/0/1 and Ethernet 2/0/2 as mirroring source ports.
l           Configure Ethernet 2/0/3 as the mirroring destination port.
II. Network diagram
Figure 1-3 Network diagram for local port mirroring configuration
III. Configuration procedure
Configure Switch C.
# Create a local port mirroring group.
[SwitchC] mirroring-group 1 local
# Add port Ethernet 2/0/1 and Ethernet 2/0/2 to the port mirroring group as source ports. Add port Ethernet 2/0/3 to the port mirroring group as the destination port.
[SwitchC] mirroring-group 1 mirroring-port Ethernet 2/0/1 Ethernet 2/0/2 both
[SwitchC] mirroring-group 1 monitor-port Ethernet 2/0/3
# Display the configuration of all the port mirroring groups.
[SwitchC] display mirroring-group all
mirroring-group 1:
    type: local
    status: active
    mirroring port:
        Ethernet2/0/1  both
        Ethernet2/0/2  both
    monitor port: Ethernet2/0/3
After finishing the configuration, you can monitor all the packets received and sent by R&D department and Marketing department on the Data monitoring device.
1.5.2  Remote Port Mirroring Configuration Example
l           Department 1 is connected to Ethernet 2/0/1 of Switch A.
l           Department 2 is connected to Ethernet 2/0/2 of Switch A.
l           Ethernet 2/0/3 of Switch A connects to Ethernet 2/0/1 of Switch B.
l           Ethernet 2/0/2 of Switch B connects to Ethernet 2/0/1 of Switch C.
l           The data monitoring device is connected to Ethernet 2/0/2 of Switch C.
The administrator wants to monitor the packets sent from Department 1 and 2 through the data monitoring device.
Use the remote port mirroring function to meet the requirement. Perform the following configurations:
l           Use Switch A as the source device, Switch B as the intermediate device, and Switch C as the destination device.
l           On Switch A, create a remote source mirroring group; create VLAN 2 and configure it as the remote port mirroring VLAN; add port Ethernet 2/0/1 and Ethernet 2/0/2 to the port mirroring group as two source ports. Configure port Ethernet 2/0/3 as the outbound mirroring port.
l           Configure port Ethernet 2/0/3 of Switch A, port Ethernet 2/0/1 and Ethernet 2/0/2 of Switch B, and port Ethernet 2/0/1 of Switch C as trunk ports and configure them to permit packets of VLAN 2.
l           Create a remote destination mirroring group on Switch C. Configure VLAN 2 as the remote port mirroring VLAN and port Ethernet 2/0/2, to which the data monitoring device is connected, as the destination port.
II. Network diagram
Figure 1-4 Network diagram for remote port mirroring configuration
1)         Configure Switch A.
# Create a remote source port mirroring group.
[SwitchA] mirroring-group 1 remote-source
# Create VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
# Configure VLAN 2 as the remote port mirroring VLAN of the remote port mirroring group. Add port Ethernet 2/0/1 and Ethernet 2/0/2 to the remote port mirroring group as source ports. Configure port Ethernet 2/0/3 as the outbound mirroring port.
[SwitchA] mirroring-group 1 remote-probe vlan 2
[SwitchA] mirroring-group 1 mirroring-port Ethernet 2/0/1 Ethernet 2/0/2 inbound
[SwitchA] mirroring-group 1 monitor-egress Ethernet 2/0/3
# Configure port Ethernet 2/0/3 as a trunk port and configure the port to permit the packets of VLAN 2.
[SwitchA] interface Ethernet 2/0/3
[SwitchA-Ethernet2/0/3] port link-type trunk
[SwitchA-Ethernet2/0/3] port trunk permit vlan 2
2)         Configure Switch B.
# Configure port Ethernet 2/0/1 as a trunk port and configure the port to permit the packets of VLAN 2.
[SwitchB] interface Ethernet 2/0/1
[SwitchB-Ethernet2/0/1] port link-type trunk
[SwitchB-Ethernet2/0/1] port trunk permit vlan 2
[SwitchB-Ethernet2/0/1] quit
# Configure port Ethernet 2/0/2 as a trunk port and configure the port to permit the packets of VLAN 2.
[SwitchB] interface Ethernet 2/0/2
[SwitchB-Ethernet2/0/2] port link-type trunk
[SwitchB-Ethernet2/0/2] port trunk permit vlan 2
3)         Configure Switch C.
[SwitchC] interface Ethernet 2/0/1
[SwitchC-Ethernet2/0/1] port link-type trunk
[SwitchC-Ethernet2/0/1] port trunk permit vlan 2
[SwitchC-Ethernet2/0/1] quit
# Create a remote destination port mirroring group.
[SwitchC] mirroring-group 1 remote-destination
# Create VLAN 2.
[SwitchC] vlan 2
[SwitchC-vlan2] quit
# Configure VLAN 2 as the remote port mirroring VLAN of the remote destination port mirroring group. Add port Ethernet 2/0/2 to the remote destination port mirroring group as the destination port.
[SwitchC] mirroring-group 1 remote-probe vlan 2
[SwitchC] mirroring-group 1 monitor-port Ethernet 2/0/2
[SwitchC] interface Ethernet 2/0/2
[SwitchC-Ethernet2/0/2] port access vlan 2
After finishing the configuration, you can monitor all the packets sent by Department 1 and Department 2 on the Data monitoring device.
