H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
Table of Contents
Related Documents
45-OAM Configuration Guide
45-OAM Configuration Guide 36.98 KB
Configuring OAM
Network Diagram
Figure 1-1 Network diagram for OAM configuration
Networking and Configuration Requirements
l          Enable Ethernet OAM on Device A and Device B to manage links at the data link layer.
l          Monitor link performance and collect statistics about the error frames received by Device A.
Applicable Product Matrix
Product series
Software version
Hardware version
S3610 Series Ethernet Switches
Release 5301, Release 5303
All versions
S5510 Series Ethernet Switches
All versions
S7500E Series Etherne Switches
Release 6300
All versions
Configuration Procedure
l          Configuration on Device A
# Configure GigabitEthernet 1/0/1 to operate in passive Ethernet OAM mode and enable Ethernet OAM for it.
[DeviceA] interface GigabitEthernet 1/0/1
[DeviceA-GigabitEthernet1/0/1] oam mode passive
[DeviceA-GigabitEthernet1/0/1] oam enable
# Set the errored frame detection interval to 20 seconds.
[DeviceA] oam errored-frame period 20
# Set the errored frame event triggering threshold to 10.
[DeviceA] oam errored-frame threshold 10
# Display global Ethernet OAM configuration.
[DeviceA] display oam configuration
Configuration of the errored symbol/frame event window/threshold :
Errored-symbol Event period           :     1
Errored-symbol Event threshold        :     1
Errored-frame Event period            :     20
Errored-frame Event threshold         :     10
Errored-frame-period Event period     :     1000
Errored-frame-period Event threshold  :     1
Errored-frame-seconds Event period    :     60
Errored-frame-seconds Event threshold :     1
l          Configuration on Device B
# Configure GigabitEthernet 1/0/1 to operate in active Ethernet OAM mode (the default) and enable Ethernet OAM for it.
[DeviceB] interface GigabitEthernet 1/0/1
[DeviceB-GigabitEthernet1/0/1] oam enable
# Display Ethernet OAM link error event statistics.
[DeviceB] display oam link-event remote
Port :GigabitEthernet1/0/1
Link Status :Up
OAMRemoteErrFrameEvent : (ms = milliseconds)
Event Time Stamp          : 5789        Errored FrameWindow   : 10(100ms)
Errored Frame Threshold   : 1           Errored Frame         : 3
Error Running Total       : 35          Event Running Total   : 17
The above information indicates that 35 errors have been detected since the setup of OAM connection to Device A, 17 of which were caused by error frames. This indicates that the link is instable.
Complete Configuration
l          Configuration on DeviceA
 oam mode passive
 oam enable
l          Configuration on DeviceB
 oam enable
Configuration Guidelines
l          OAM connections can be initiated only by OAM entities operating in active OAM mode, while those operating in passive mode wait and respond to the connection requests sent by their peers.
l          With OAM enabled, you cannot change the OAM operating mode. To do so, you must disable OAM first.
