- H3C S7500 Series Ethernet Switches Installation Manual-(V1.02)
- 00-1Cover
- 01-Chapter 1 Product Overview
- 02-Chapter 2 Line Processing Units
- 03-Chapter 3 Installation Preparations
- 04-Chapter 4 Hardware Installation
- 05-Chapter 5 System Commissioning
- 06-Chapter 6 Hardware Maintenance
- 07-Chapter 7 Software Maintenance
- 08-Chapter 8 Troubleshooting
- 09-Appendix A B68-22 Cabinet Installation
- 10-Appendix B N68 Cabinet Installation
- 11-Appendix C Lightning Protection
- 12-Appendix D AC Power Cables Used in Different Countries or Regions
02-Chapter 2 Line Processing Units | 2.28 MB |
Table of Contents
2.2.1 Technical Specifications
2.3.1 Technical Specifications
2.4.1 Technical Specifications
2.5.1 Technical Specifications
2.6.1 Technical Specifications
2.7.1 Technical Specifications
2.8.1 Technical Specifications
2.9.1 Technical Specifications
2.10.1 Technical Specifications
2.11.1 Technical Specifications
2.12.1 Technical Specifications
2.13.1 Technical Specifications
2.14.1 Technical Specifications
2.15.1 Technical Specifications
2.16.1 Technical Specifications
2.17.1 Technical Specifications
2.18.1 Technical Specifications
2.19.1 Technical Specifications
2.20.1 Technical Specifications
2.21.1 Technical Specifications
2.22.1 Technical Specifications
2.23.1 Technical Specifications
2.24.1 Technical Specifications
2.1 Introduction to LPUs
The modular design of the S700 series provides a reasonable system architecture as well as standard, mutually independent function modules. Currently, the S7500 series provide autosensing 10/100/1000 Mbps Ethernet electrical ports, 100 Mbps Ethernet (single mode/multi-mode) optical ports, GBIC/SFP (single mode/multi-mode) optical ports, and 10GE optical ports.
The following sections introduce the specifications and performance of LPUs in detail.
2.2 LS81FT48E
Figure 2-1 LS81FT48E appearance
The LS81FT48E provides forty-eight autosensing 10/100Base-TX Ethernet ports.
Table 2-1 LS81FT48E specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
Dimensions (H x W x D) |
40.1 × 376.7 × 354.5 mm (1.6 × 14.8 × 14 in.) |
Maximum power consumption |
35 W |
Connector |
RJ-45 |
Number of ports |
48 |
Port speed |
l 10/100 Mbps half-duplex/full-duplex l MDI/MDI-X autosensing |
Matching cable and maximum transmission distance |
Category-5 twisted pair with a maximum transmission distance of 100 m (328.1 ft) |
Compliant standards |
IEEE 802.3 IEEE 802.3u IEEE 802.3ad IEEE 802.3x IEEE 802.1p IEEE 802.1D IEEE 802.1Q IEEE 802.1X IEEE 802.1s IEEE 802.1w |
2.2.2 Panel and LEDs
Figure 2-2 LS81FT48E panel
(1) Silkscreen of the LPU name |
(2) Captive screw |
(3) LPU edge (purple) |
(4) Ejector lever |
(5) 10/100Base-TX Ethernet port status LED |
(6) 10/100Base-TX Ethernet port |
Figure 2-3 Partially amplified view of the LS81FT48E panel
Each 10/100Base-TX Ethernet port has a green LED.
Table 2-2 LED description of the LS81FT48E
LED |
Status |
Meaning |
LINK/ACT |
OFF |
No link is present. |
ON |
A link is present. |
Blinking |
Data is being transmitted/received. |
2.2.3 Matching Cable
The 10/100Base-TX Ethernet ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.3 LS81FT48F
Figure 2-4 LS81FT48F appearance
The LS81FT48F provides forty-eight autosensing 10/100Base-TX Ethernet ports. All the ports support PoE, that is, they can supply power to remote PDs through Ethernet twisted pairs.
Table 2-3 LS81FT48F specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
35 W |
Connector |
RJ-45 |
Number of ports |
48 |
Port speed |
Category-5 twisted pair, with a maximum transmission distance of 100 m (328.1 ft) |
Maximum PoE distance |
100 m (328.1 ft) |
Maximum power each port can provide |
15.4 W |
Compliant standard |
IEEE 802.3 IEEE 802.3u IEEE 802.3x IEEE 802.3ad IEEE 802.1p IEEE 802.1D IEEE 802.1Q IEEE 802.1X IEEE 802.1s IEEE 802.1w IEEE 802.3af |
2.3.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
(6) 10/100Base-TX Ethernet port (supporting PoE) |
Figure 2-6 Partially amplified view of the LS81FT48F panel
Table 2-4 LED description of the LS81FT48F
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.3.3 Matching Cable
2.4 LS81FP48
Figure 2-7 LS81FP48 appearance
The LS81FP48 provides forty-eight 100Base-FX-SFP ports operating in the full-duplex mode.
Table 2-5 LS81FP48 specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
60 W |
Connector |
LC |
Number of ports |
48 |
Port speed |
100 Mbps full-duplex |
SFP module |
l SFP-FE-SX-MM1310-A l SFP-FE-LX-SM1310-A l SFP-FE-LH40-SM1310 l SFP-FE-LH80-SM1550 l SFP-FE-LX-SM1310-BIDI l SFP-FE-LX-SM1550-BIDI |
l IEEE 802.3 l IEEE 802.1p l IEEE 802.1Q l IEEE 802.1D l IEEE 802.3x l IEEE 802.3ad l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w |
2.4.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
(5) 100Base-FX-SFP port status LED |
(6) 100Base-FX-SFP port |
Figure 2-9 Partially amplified view of the LS81FP48 panel
Each 100Base-FX-SFP port has a green LED.
Table 2-6 LED description of the LS81FP48
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.4.3 Matching Cable
Table 2-7 Cables for 100Base-FX-SFP ports of the LS81FP48
SFP module |
Central wavelength |
Connector |
Matching cable |
Maximum transmission distance |
SFP-FE-SX-MM1310-A |
1,310 nm |
LC |
50 µm/125 µm multimode optical fiber cable |
2 km (1.2 mi) |
62.5 µm/125 µm multimode optical fiber cable |
SFP-FE-LX-SM1310-A |
1,310 nm |
LC |
9 µm/125 µm single mode optical fiber cable |
15 km (9.3 mi) |
SFP-FE-LH40-SM1310 |
1,310 nm |
LC |
40 km (24.9 mi) |
SFP-FE-LH80-SM1550 |
1,550 nm |
LC |
80 km (49.7 mi) |
SFP-FE-LX-SM1310-BIDI |
1,550 nm (receive)/1310 nm (transmit) |
LC |
9µm/125µm single mode optical fiber cable |
15 km (9.3 mi) |
1310 (transmit)/1550 (receive) |
LC |
15 km (9.3 mi) |
2.5 LS81GT8UE
Figure 2-10 LS81GT8UE appearance
The LS81GT8UE provides eight autosensing 10/100/1000Base-T Ethernet ports.
Table 2-8 LS81GT8UE specifications
Item |
Specification |
CPU |
MPC850, 50 MHz |
Boot ROM |
512 KB |
SDRAM |
64 MB |
11 W |
Connector |
RJ-45 |
Number of ports |
8 |
Port speed |
l 10/100/1000 Mbps half-duplex/full-duplex l MDI/MDI-X autosensing |
l IEEE 802.3 l IEEE 802.3u l IEEE 802.3ab l IEEE 802.3x l IEEE 802.1D l IEEE 802.1Q l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w |
& Note:
l The LS81GT8UE can only be used together with Salience III or Salience III Edge SRPUs.
l If a Salience III or Salience III Edge SRPU is used, the LS81GT8UE cannot be inserted in the last LPU slot of the S7506 or the S7506R (slot 6 for the S7506 and slot 7 for the S7506R), but can be inserted in any LPU slot of the S7503.
2.5.2 Panel and LEDs
(1) Ethernet port number |
(2) 10/100/1000Base-T Ethernet port status LED (LINK) |
(3) 10/100/1000Base-T Ethernet port status LED (ACT) |
(4) Silkscreen of the LPU name |
(5) Captive screw |
(6) LPU edge (purple) |
(7) Ejector lever |
(8) 10/100/1000Base-T Ethernet port (Gigabit) |
Figure 2-12 Partially amplified view of the LS81GT8UE panel
Each 10/100/1000Base-T Ethernet port has two LEDs.
Table 2-9 LED description of the LS81GT8UE
LED |
Status |
Meaning |
LINK |
OFF |
ON |
ACT |
OFF |
No data is being transmitted/received. |
Blinking |
2.5.3 Matching Cable
The ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.6 LS82GT20
Figure 2-13 LS82GT20 appearance
The LS82GT20 provides twenty autosensing 10/100/1000Base-T Ethernet ports.
Table 2-10 LS82GT20 specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
64 MB |
45 W |
Connector |
RJ-45 |
Number of ports |
20 |
Port speed |
l 10/100 Mbps half-duplex/full-duplex l 1000 Mbps full-duplex l MDI/MDI-X autosensing |
l IEEE 802.3 l IEEE 802.3u l IEEE 802.3ab l IEEE 802.3x l IEEE 802.1p l IEEE 802.1D l IEEE 802.1Q l IEEE 802.1X l IEEE 802.1w l IEEE 802.1ad l IEEE 802.1s |
2.6.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
(5) 10/100/1000Base-T Ethernet port |
(6) 10/100/1000Base-T Ethernet port status LED |
Figure 2-15 Partially amplified view of the LS82GT20 panel
Each 10/100/1000Base-T Ethernet port has a LED.
Table 2-11 LED description of the LS82GT20
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.6.3 Matching Cable
2.7 LS82GT20A
Figure 2-16 LS82GT20A appearance
The LS82GT20A provides twenty autosensing 10/100/1000Base-T Ethernet ports.
Table 2-12 LS82GT20A specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
Dimensions (W x D) |
45 W |
Connector |
RJ-45 |
Number of ports |
20 |
Port speed |
2.7.2 Panel and LEDs
(1) 10/100/1000Base-T Ethernet port |
(2) Silkscreen of the LPU name |
(3) Captive screw |
(4) LPU edge (purple) |
(5) Ejector lever |
(6) Ethernet port status LED |
Figure 2-18 Partially amplified view of the LS82GT20A panel
Table 2-13 LED description of the LS82GT20A
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.7.3 Matching Cable
2.8 LS81GT48
Figure 2-19 LS81GT48 appearance
The LS81GT48 provides forty-eight autosensing 10/100/1000Base-T Ethernet ports.
Table 2-14 LS81GT48 specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
70 W |
Connector |
RJ-45 |
Number of ports |
48 |
Port speed |
l IEEE 802.3 l IEEE 802.3u l IEEE 802.3ab l IEEE 802.3x l IEEE 802.1p l IEEE 802.1D l IEEE 802.1Q l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w |
2.8.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
(5) 10/100/1000Base-T Ethernet port status LED |
(6) 10/100/1000Base-T Ethernet port |
Figure 2-21 Partially amplified view of the LS81GT48 panel
Each 10/100/1000Base-T Ethernet port has a green LED.
Table 2-15 LED description of the LS81GT48
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.8.3 Matching Cable
2.9 LS81GT48A
Figure 2-22 LS81GT48A appearance
The LS81GT48A provides forty-eight autosensing 10/100/1000Base-T Ethernet ports. All the ports support PoE, that is, they supply power to remote PDs through Ethernet twisted pair cables.
Table 2-16 LS81GT48A specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
70 W |
Connector |
RJ-45 |
Number of ports |
48 |
Port speed |
100 m (328.1 ft) |
15.4 W |
l IEEE 802.3 l IEEE 802.3u l IEEE 802.3ab l IEEE 802.3x l IEEE 802.1p l IEEE 802.1D l IEEE 802.1Q l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w l IEEE 802.3af |
2.9.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
Figure 2-24 Partially amplified view of the LS81GT48A panel
Table 2-17 LED description of the LS81GT48A
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.9.3 Matching Cable
The 10/100/1000Base-T Ethernet ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.10 LS81GT48B
Figure 2-25 LS81GT48B appearance
The LS81GT48B adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-18 LS81GT48B specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
40.1 x 376.7 x 364.5 mm (1.6 × 14.8 × 14 in.) |
107 W |
Connector |
RJ-45 |
Number of ports |
48 |
Port speed |
l 10 Mbps half-duplex/full-duplex l 100 Mbps half-duplex/full-duplex l 1000 Mbps half-duplex/full-duplex l MDI/MDI-X autosensing |
& Note:
When using the LS81GT48B as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU:
l If you use the LS81GT48B together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81GT48B together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R switch (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
2.10.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
Figure 2-27 Partially amplified view of the LS81GT48B panel
Table 2-19 LED description of the LS81GT48B
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.10.3 Matching Cable
The 10/100/1000Base-T Ethernet ports use category-5 twisted pairs and RJ-45 connecters, with a maximum transmission distance of 100 m (328.1 ft).
2.11 LS81T12P
Figure 2-28 LS81T12P appearance
The LS81T12P provides twelve autosensing 10/100/1000Base-T Ethernet ports and four 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-20 LS81T12P specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
33 W |
Connector |
RJ-45, LC |
Number of ports |
16 |
Port speed |
l 1000 Mbps full-duplex (optical/electrical) l 10/100 Mbps half-duplex/full-duplex (electrical) |
SFP modules |
Refer to Table 2-22 |
l IEEE 802.3 l IEEE 802.3u l IEEE 802.3z l IEEE 802.3ab l IEEE 802.1p l IEEE 802.1Q l IEEE 802.1D l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w l IEEE 802.3x l IEEE 802.3ad |
2.11.2 Panel and LEDs
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
(6) 1000Base-X-SPF port |
(7) 10/100/1000Base-T Ethernet port status LED |
(8) 10/100/1000Base-T Ethernet port |
Figure 2-30 Partially amplified view of the LS81T12P panel
The following table describes the LED.
Table 2-21 LED description of the LS81T12P
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.11.3 Matching Cable
I. Cables for the four 1000Base-X-SFP ports
Table 2-22 Cables for 1000Base-X-SFP ports
SFP module |
Connector |
Matching cable |
SFP-GE-SX-MM850-A |
850 nm |
LC |
550 m (1804 ft) |
275 m (902 ft) |
SFP-GE-LX-SM1310-A |
1,310 nm |
LC |
10 km (6 mi) |
SFP-GE-LH40-SM1310 |
40 km (25 mi) |
SFP-GE-LH40-SM1550 |
1,550 nm |
LC |
40 km (about 25 mi) |
SFP-GE-LH70-SM1550 |
70 km (43 mi) |
SFP-GE-LH100-SM1550 |
100 km (62 mi) |
SFP-GE-LH70-SM1470-CW |
1,470 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1490-CW |
1,490 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1510-CW |
1,510 nm |
LC |
70 km (43 mi)
SFP-GE-LH70-SM1530-CW |
1,530 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1550-CW |
1,550 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1570-CW |
1,570 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1590-CW |
1,590 nm |
LC |
70 km (43 mi) |
SFP-GE-LH70-SM1610-CW |
1,610 nm |
LC |
70 km (43 mi) |
II. Cables for the twelve 10/100/1000Base-T Ethernet ports
2.12 LS81T12PE
Figure 2-31 LS81T12PE appearance
The LS81T12PE can serve as the SRPU of the S7502.
Table 2-23 LS81T12PE specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
Boot ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
Number of ports |
Twelve 10/100/1000Base-T Ethernet ports Four 1000BASE-X-SFP ports |
29 W |
Connector |
RJ-45, LC |
Number of ports |
16 |
Port speed |
l 1000 Mbps full-duplex (optical port) l 10 Mbps half-duplex/full-duplex (electrical port) l 100 Mbps half-duplex/full-duplex (electrical port) l 1000M full-duplex (electrical port) |
SFP modules |
Port cable and max transmission distance |
2.12.2 Panel and LEDs
LS81T12PE provides twelve 10/100/1000BASE-T ports and four 1000BASE-X-SFP ports, and each port has a status LED.
(1) Port number |
(3) Captive screw |
(4) LPU edge (green) |
(5) Ejector lever |
Figure 2-33 Partially amplified view of the LS81T12PE panel
The status LEDs on an LS81T12PE are described in the following table.
Table 2-24 LED description of the LS81T12PE
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.12.3 Matching Cable
Refer to section 2.11 “LS81T12P“ on page 2-21.
2.13 LS81P12T
Figure 2-34 LS81P12T appearance
The LS81P12T provides twelve 1000Base-X-SFP ports operating in the full duplex mode and four autosensing 10/100/1000 Base-T Ethernet ports.
Table 2-25 LS81P12T specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
31 W |
Connector |
RJ-45, LC |
Number of ports |
16 |
Port speed |
l 1000 Mbps full-duplex (optical) l 10/100/1000 Mbps half-duplex/full-duplex (electrical) |
SFP modules |
2.13.2 Panel and LEDs
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
(6) 1000Base-X-SFP port status LED |
(7) 1000Base-X-SPF port |
Figure 2-36 Partially amplified view of the LS81P12T panel
Table 2-26 LED description of the LS81P12T
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.13.3 Matching Cable
Refer to section 2.11.3 “Matching Cable” on page 2-23.
2.14 LS81P12TE
Figure 2-37 LS81P12TE appearance
The LS81P12TE can serve as the SRPU of the S7502.
Table 2-27 LS81P12TE specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
Boot ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
Number of ports |
l Four 10/100/1000BASE-T Ethernet ports l Twelve 1000BASE-X-SFP ports |
40 W |
Port speed |
l 1000 Mbps full-duplex (optical port) l 10 Mbps half-duplex/full-duplex (electrical port) l 100 Mbps half-duplex/full-duplex (electrical port) l 1000 Mbps full-duplex (electrical port) |
SFP modules |
Category-5 twisted pair cable, with a maximum transmission distance of 100 m (328.1 ft) |
2.14.2 Panel and LEDs
The LS81P12TE provides four 10/100/1000BASE-T Ethernet ports and twelve 1000BASE-X-SFP ports and each port has a status LED.
Figure 2-38 LS81P12TE panel
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
(6) Port status LED |
(7) SPF port (Gigabit) |
(8) Ethernet port (Gigabit) |
Figure 2-39 Partially amplified view of the LS81P12TE panel
For the description of the LED of the LS81P12TE, see Table 2-26.
2.14.3 Matching Cable
Refer to section 2.11 “LS81T12P” on page 2-21.
2.15 LS81T16P
Figure 2-40 LS81T16P appearance
The LS81T16P adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-28 LS81T16P specifications
Item |
Specification |
CPU |
MPC8245, 300M |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
366.7 x 340 mm (14.4 x 13.4 in.) |
Number of ports |
l Sixteen autosensing 10/100/1000Base-T Ethernet ports l Eight 1000Base-X-SFP ports |
55 W |
Connector |
RJ-45, LC |
Number of ports |
24 |
Port speed |
l 10 Mbps half-duplex/full-duplex l 100 Mbps half-duplex/full-duplex l 1000 Mbps full-duplex MDI/MDI-X autosensing
SFP module |
Refer to Table 2-22. |
& Note:
When using the LS81T16P as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l If you use the LS81T16P together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81T16P together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for S7506R).
2.15.2 Panel and LEDs
(2) Captive screw |
(3) LPU edge (green) |
(4) Ejector lever |
(5) 1000Base-X-SPF port |
(7) 10/100/1000Base-T Ethernet port |
Figure 2-42 Partially amplified view of the LS81T16P panel
The following table describes the LED of the LS81T16P:
Table 2-29 LED description of the LS81T16P
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.15.3 Matching Cable
Refer to section 2.11 “LS81T12P” on page 2-21..
2.16 LS81T32P
Figure 2-43 LS81T32P appearance
The LS81T32P adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-30 LS81T32P specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
Number of ports |
l Thirty-two autosensing 10/100/1000Base-T Ethernet ports l Sixteen 1000Base-X-SFP ports |
93 W |
Connector |
RJ-45, LC |
Port speed |
SFP modules |
& Note:
When using the LS81T32P as an LPU of the S7503/S7506/S7506R switch, you can only use it together with a Salience III or Salience III Plus SRPU.
l If you use the LS81T32P together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81T32P together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
2.16.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
(5) 1000Base-X-SFP port status LED |
Figure 2-45 Partially amplified view of the LS81T32P panel
The following table describes the LED of the LS81T32P:
Table 2-31 LED state description of LS81T32P
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.16.3 Matching Cable
2.17 LS81GP8UB
Figure 2-46 LS81GP8UB appearance
The LS81GP8UB provides eight 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-32 LS81GP8UB specifications
Item |
Specification |
CPU |
MPC850, 50 MHz |
Boot ROM |
512 KB |
SDRAM |
64M |
9.5 W |
Connector |
LC, RJ-45 |
Number of ports |
8 |
Port speed |
1000 Mbps full-duplex |
SFP modules |
l IEEE 802.3 l IEEE 802.3z l IEEE 802.1p l IEEE 802.1Q l IEEE 802.1D l IEEE 802.3x l IEEE 802.3ad l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w |
& Note:
l The LS81GP8UB can only be used together with a Salience III and Salience III Edge SRPU.
l If a Salience III or Salience III Edge SRPU is used, the LS81GP8UB cannot be inserted in the last LPU slot of the S7506 or the S7506R (slot 6 for the S7506 and slot 7 for the S7506R), but can be inserted in any LPU slot of the S7503.
2.17.2 Panel and LEDs
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
(7) 1000Base-X-SFP port |
Figure 2-48 Partially amplified view of the LS81GP8UB panel
The following table describes the LED of the LS81GP8UB.
Table 2-33 LED description of the LS81GP8UB
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.17.3 Matching Cable
Refer to Table 2-22 in section 2.11.3 "Matching Cable" on page 2-23.
2.18 LS82GP20
Figure 2-49 LS82GP20 appearance
The LS82GP20 provides twenty 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-34 LS82GP20 specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
64 MB |
35 W |
Connector |
LC |
Number of ports |
20 |
Port speed |
SFP modules |
l IEEE 802.3 l IEEE 802.3z l IEEE 802.1p l IEEE 802.1Q l IEEE 802.1D l IEEE 802.3x l IEEE 802.1X l IEEE 802.1w l IEEE 802.3ad l IEEE 802.1s |
2.18.2 Panel and LEDs
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
(6) 1000Base-X-SFP port |
(7) 1000Base-X-SFP port status LED |
Figure 2-51 Partially amplified view of the LS82GP20 panel
The following table describes the LED of the LS82GP20.
Table 2-35 LED description of the LS82GP20
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.18.3 Matching Cable
2.19 LS82GP20A
Figure 2-52 LS82GP20A appearance
The LS82GP20A provides twenty 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-36 LS82GP20A specifications
Item |
Specification |
CPU |
MPC8241, 200 MHz |
Boot ROM |
512 KB |
SDRAM |
128 MB |
35 W |
Connector |
LC |
Number of ports |
20 |
Port speed |
SFP modules |
2.19.2 Panel and LEDs
(1) Port number |
(3) Captive screw |
(5) Ejector lever |
Figure 2-54 Partially amplified view of the LS82GP20A panel
The following table describes the LED of the LS82GP20A.
Table 2-37 LED description of the LS82GP20A
LED |
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.19.3 Matching Cable
Refer to Table 2-22 in section “Matching Cable” on page 2-23.
2.20 LS81GP48
Figure 2-55 LS81GP48 appearance
The LS81GP48 adopts an XG high-speed bus and provides forty-eight 1000Base-X-SFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-38 LS81GP48 specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
75 W |
Connector |
LC |
Number of ports |
48 |
Port speed |
l 1000 Mbps full-duplex |
SFP modules |
& Note:
When using the LS81GP48 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l If you use the LS81GP48 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81GP48 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
2.20.2 Panel and LEDs
(2) Captive screw |
(4) Ejector lever |
Figure 2-57 Partially amplified view of the LS81GP48 panel
The following table describes the LED of the LS81GP48:
Table 2-39 LED description of the LS81GP48
Status |
Meaning |
LINK/ACT |
OFF |
ON |
Blinking |
2.20.3 Matching Cable
2.21 LS81TGX1C
Figure 2-58 LS81TGX1C appearance
The LS81TGX1C provides one 10GBase-R-XENPAK port operating the full-duplex mode.
Table 2-40 LS81TGX1C specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
Boot ROM |
512 KB |
SDRAM |
64 MB |
35 W |
Connector |
SC |
Number of ports |
1 |
Port speed |
10 Gbps full-duplex |
XENPAK modules |
l XENPAK-SX-MM850 (multimode optical fiber, 850 nm, 300 m [984 ft]) l XENPAK-LX-SM1310 (single mode optical fiber, 1310 nm, 10 km [6.2 mi]) l XENPAK-LH40-SM1550 (single mode optical fiber, 1550 nm, 40 km [24.9 mi]) |
l IEEE 802.3 l IEEE 802.3ae l IEEE 802.1p l IEEE 802.1Q l IEEE 802.1D l IEEE 802.3x l IEEE 802.3ad l IEEE 802.1X l IEEE 802.1s l IEEE 802.1w |
2.21.2 Panel and LEDs
(1) 10GBase-R-XENPAK port status LED (LINK) |
(2) 10GBase-R-XENPAK port status LED (ACT) |
(3) Silkscreen of the LPU |
(4) Captive screw |
(5) LPU edge (green) |
(6) Ejector lever |
(7) 10GBase-R-XENPAK port |
(8) Captive screw |
Figure 2-60 Partially amplified view of the LS81TGX1C panel
The following table describes the LEDs of the LS81TGX1C.
Table 2-41 LED state description of LS81TGX1C
LED |
Status |
Meaning |
LINK |
OFF |
ON |
ACT |
OFF |
Blinking |
2.21.3 Matching Cable
Table 2-42 Cables for the LS81TGX1C
XENPAK module |
Connector |
Matching cable |
XENPAK-SX-MM850 |
850 nm |
SC |
Multimode fiber |
300 m (984 ft) |
XENPAK-LX-SM1310 |
1310 nm |
9µm/125µm single mode fiber |
10 km (6 mi) |
XENPAK-LH40-SM1550 |
1550 nm |
40 km (25 mi) |
2.22 LS81TGX2
Figure 2-61 LS81TGX2 appearance
The LS81TGX2 adopts an XG high-speed bus and provides two 10GBase-XFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-43 LS81TGX2 specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
38 W |
Connector |
LC |
Number of ports |
2 |
Port speed |
XFP modules |
l XFP-SX-MM850 (850 nm multi-mode fiber with a maximum transmission distance of 300 m [984.3 ft]). l XFP-LX-SM1310 (1,310 nm single-mode fiber with a maximum transmission distance of 10 km [6.2 mi]) l XFP-LH40-SM1550 (1,550 nm single-mode fiber with a maximum transmission distance of 40 km [24.9 mi]) l XFP-LH80-SM1550(1,550 nm single-mode fiber with a maximum transmission distance of 80 km [49.7 mi]) |
& Note:
When using the LS81TGX2 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l If you use the LS81TGX2 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81TGX2 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
2.22.2 Panel and LEDs
(1) 10GBase-XFP port number |
(2) 10GBase-XFP port status LED (LINK) |
(3) 10GBase-XFP port status LED (ACT) |
(5) Captive screw |
(6) LPU edge (green) |
(7) Ejector lever |
(8) 10GBase-XFP port |
Figure 2-63 Partially amplified view of the LS81TGX2 panel
The following table describes the LEDs of the LS81TGX2:
Table 2-44 LED description of the LS81TGX2
State |
LINK |
OFF |
ON |
ACT |
OFF |
Blinking |
2.22.3 Matching Cable
Table 2-45 Cables for the LS81TGX2
XFP module |
Connector |
Matching cable |
XFP-SX-MM850 |
850 nm |
LC |
50 µm/125 µm multi-mode optical fiber |
300 m (984.3 ft) |
XFP-LX-SM1310 |
1,310 nm |
9 µm/125 µm single-mode optical fiber |
10 km (6.2 mi) |
XFP-LH40-SM1550 |
1510 nm |
40 km (24.9 mi) |
XFP-LH80-SM1550 |
1510 nm |
80 km (49.7 mi) |
2.23 LS81TGX4
Figure 2-64 LS81TGX4 appearance
The LS81TGX4 adopts an XG high-speed bus and provides four 10GBase-XFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-46 LS81TGX4 specifications
Item |
Specification |
CPU |
MPC8245, 300 MHz |
BOOT ROM |
512 KB |
Flash memory |
32 MB |
SDRAM |
256 MB |
54 W |
Connector |
LC |
Number of ports |
4 |
Port speed |
l 10 Gbps full-duplex |
XFP modules |
l XFP-SX-MM850 (850 nm multi-mode fiber with a maximum transmission distance of 300 m [984.3 ft]) l XFP-LX-SM1310 (1310 nm single-mode fiber with a maximum transmission distance of 10 km [6.2 mi]) l XFP-LH40-SM1550 (1550 nm single-mode fiber with a maximum transmission distance of 40 km [24.9 mi]) l XFP-LH80-SM1550 (1550 nm single-mode fiber with a maximum transmission distance of 80 km [49.7 mi]) |
& Note:
When using the LS81TGX4 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l If you use the LS81TGX4 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81TGX4 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
2.23.2 Panel and LEDs
(5) Captive screw |
(7) Ejector lever |
Figure 2-66 Partially amplified view of the LS81TGX4 panel
Refer to Table 2-44 in section 2.22.2 "Panel and LEDs" on page 2-48 for the LED description of the LS81TGX4.
2.23.3 Matching Cable
Refer to Table 2-45 in section 2.22.3 "Matching Cable" on page 2-49.
2.24 LS81VSNP (without Port)
Figure 2-67 LS81VSNP appearance
The LS81VSNP supports XG high speed bus and possesses a high-performance network processor (NP) and CPU and can cooperate with other LPUs to provide the following features:
l Policy routing
l Network address translation (NAT)
l NetStream
The LS81VSNP provides no port.
Table 2-47 LS81VSNP specifications
Item |
Specification |
CPU |
MPC750, 350 MHz |
BOOT ROM |
512 KB |
SDRAM |
256 MB |
100 W |
Connector |
Number of ports |
0 |
& Note:
When using the LS81VSNP as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU:
l If you use the LS81VSNP together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l If you use the LS81VSNP together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
l When serving as an LPU of the S7502, the LS81VSNP can be inserted only into slot 1.
2.24.2 Panel and LEDs
Figure 2-68 LS81VSNP panel
